[QGIS Commit] r9656 - trunk/qgis/src/providers/grass
svn_qgis at osgeo.org
Mon Nov 17 12:03:56 EST 2008
Author: jef
Date: 2008-11-17 12:03:56 -0500 (Mon, 17 Nov 2008)
New Revision: 9656
trunk/qgis/src/providers/grass/qgsgrassprovider.cpp
fix r9655
Modified: trunk/qgis/src/providers/grass/qgsgrassprovider.cpp
--- trunk/qgis/src/providers/grass/qgsgrassprovider.cpp 2008-11-17 16:29:34 UTC (rev 9655)
+++ trunk/qgis/src/providers/grass/qgsgrassprovider.cpp 2008-11-17 17:03:56 UTC (rev 9656)
@@ -1040,7 +1040,8 @@
if ( level == 1 )
QgsGrass::resetError();
-#if GRASS_VERSION_MAJOR >= 6 && GRASS_VERSION_MINOR >= 4
+#if defined(GRASS_VERSION_MAJOR) && defined(GRASS_VERSION_MINOR) && \
+ ( ( GRASS_VERSION_MAJOR == 6 && GRASS_VERSION_MINOR >= 4 ) || GRASS_VERSION_MAJOR > 6 )
Vect_build( map.map );
#else
Vect_build( map.map, stderr );
@@ -1524,7 +1525,8 @@
G__setenv(( char * ) "MAPSET", map->mapset.toAscii().data() );
Vect_build_partial( map->map, GV_BUILD_NONE, NULL );
#else
Vect_build( map->map, stderr );
