[QGIS Commit] r9657 - in trunk/qgis: python/core python/gui src/core src/gui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Nov 17 12:20:21 EST 2008
Author: wonder
Date: 2008-11-17 12:20:21 -0500 (Mon, 17 Nov 2008)
New Revision: 9657
Added:
   trunk/qgis/python/gui/qgsmapcanvassnapper.sip
   trunk/qgis/python/core/qgssnapper.sip
   trunk/qgis/python/gui/gui.sip
   trunk/qgis/src/core/qgssnapper.cpp
   trunk/qgis/src/core/qgssnapper.h
   trunk/qgis/src/gui/qgsmapcanvassnapper.cpp
- QgsSnapper: use one list of QgsSnapper::SnapLayer structs rather than three separate lists
- PyQGIS: finished QgsSnapper binding, added QgsMapCanvasSnapper
Modified: trunk/qgis/python/core/qgssnapper.sip
--- trunk/qgis/python/core/qgssnapper.sip	2008-11-17 17:03:56 UTC (rev 9656)
+++ trunk/qgis/python/core/qgssnapper.sip	2008-11-17 17:20:21 UTC (rev 9657)
@@ -57,6 +57,16 @@
       SnapWithResultsWithinTolerances
+    struct SnapLayer
+      /**The layer to which snapping is applied*/
+      QgsVectorLayer* mLayer;
+      /**The snapping tolerances for the layers, always in source coordinate systems of the layer*/
+      double mTolerance;
+      /**What snapping type to use (snap to segment or to vertex)*/
+      QgsSnapper::SnappingType mSnapTo;
   QgsSnapper(QgsMapRenderer* mapRender);
   ~QgsSnapper();
   /**Does the snapping operation
@@ -66,9 +76,7 @@
   int snapPoint(const QPoint& startPoint, QList<QgsSnappingResult>& snappingResult, const QList<QgsPoint>& excludeList);
   //setters
-  void setLayersToSnap(const QList<QgsVectorLayer*>& layerList);
-  void setTolerances(const QList<double>& toleranceList);
-  // TODO wrap void setSnapToList(const QList<QgsSnapper::SnappingType>& snapToList);
+  void setSnapLayers( const QList<QgsSnapper::SnapLayer>& snapLayers );
   void setSnapMode(QgsSnapper::SnappingMode snapMode);
Modified: trunk/qgis/python/gui/gui.sip
--- trunk/qgis/python/gui/gui.sip	2008-11-17 17:03:56 UTC (rev 9656)
+++ trunk/qgis/python/gui/gui.sip	2008-11-17 17:20:21 UTC (rev 9657)
@@ -14,6 +14,7 @@
 %Include qgsmapcanvas.sip
 %Include qgsmapcanvasitem.sip
 %Include qgsmapcanvasmap.sip
+%Include qgsmapcanvassnapper.sip
 %Include qgsmaptool.sip
 %Include qgsmaptoolemitpoint.sip
 %Include qgsmaptoolpan.sip
Added: trunk/qgis/python/gui/qgsmapcanvassnapper.sip
--- trunk/qgis/python/gui/qgsmapcanvassnapper.sip	                        (rev 0)
+++ trunk/qgis/python/gui/qgsmapcanvassnapper.sip	2008-11-17 17:20:21 UTC (rev 9657)
@@ -0,0 +1,45 @@
+/** \ingroup gui
+ * This class reads the snapping properties from the current project and
+ * configures a QgsSnapper to perform the snapping.
+ * Snapping can be done to the active layer  (usefull for selecting a vertex to
+ * manipulate) or to background layers
+class QgsMapCanvasSnapper
+%TypeHeaderCode
+#include <qgsmapcanvassnapper.h>
+%End
+  public:
+    /**Constructor
+     @param canvas the map canvas to snap to*/
+    QgsMapCanvasSnapper( QgsMapCanvas* canvas );
+    QgsMapCanvasSnapper();
+    ~QgsMapCanvasSnapper();
+    /**Does a snap to the current layer. Uses snap mode
+       QgsSnapper::SnapWithResultsForSamePosition if topological editing is enabled
+       and QgsSnapper::SnapWithOneResult_BY_SEGMENT if not. As this method is usually used to
+       find vertices/segments for editing operations, it uses the search radius for vertex
+       editing from the qgis options.
+       @param p start point of the snap (in pixel coordinates)
+       @param results list to which the results are appended
+       @param snap_to snap to vertex or to segment
+       @param snappingTol snapping tolerance. -1 means that the search radius for vertex edits is taken
+       @param excludePoints a list with (map coordinate) points that should be excluded in the snapping result. Useful e.g. for vertex moves where a vertex should not be snapped to its original position*/
+    int snapToCurrentLayer( const QPoint& p, QList<QgsSnappingResult>& results, QgsSnapper::SnappingType snap_to, double snappingTol = -1, const QList<QgsPoint>& excludePoints = QList<QgsPoint>() );
+    /**Snaps to the background layers. This method is usefull to align the features of the
+       edited layers to those of other layers (as described in the project properties).
+       Uses snap mode QgsSnapper::SnapWithOneResult. Therefore, only the
+       closest result is returned.
+       @param result snapped point
+       @return 0 in case of success*/
+    int snapToBackgroundLayers( const QPoint& p, QList<QgsSnappingResult>& results, const QList<QgsPoint>& excludePoints = QList<QgsPoint>() );
+    void setMapCanvas( QgsMapCanvas* canvas );
Modified: trunk/qgis/src/core/qgssnapper.cpp
--- trunk/qgis/src/core/qgssnapper.cpp	2008-11-17 17:03:56 UTC (rev 9656)
+++ trunk/qgis/src/core/qgssnapper.cpp	2008-11-17 17:20:21 UTC (rev 9657)
@@ -43,16 +43,6 @@
   snappingResult.clear();
-  //list must have the same length
-  if ( !( mLayersToSnap.size() == mSnappingTolerances.size() && mLayersToSnap.size() == mSnapToList.size() ) )
-    return 1;
-  QList<QgsVectorLayer*>::iterator layerIt = mLayersToSnap.begin();
-  QList<double>::const_iterator  toleranceIt = mSnappingTolerances.constBegin();
-  QList<QgsSnapper::SnappingType>::const_iterator snapToIt = mSnapToList.constBegin();
   QMultiMap<double, QgsSnappingResult> snappingResultList;//all snapping results
   QMultiMap<double, QgsSnappingResult> currentResultList; //snapping results of examined layer
@@ -61,12 +51,13 @@
   QgsPoint layerCoordPoint; //start point in layer coordinates
   QgsSnappingResult newResult;
-  for ( ; layerIt != mLayersToSnap.end(); ++layerIt, ++toleranceIt, ++snapToIt )
+  QList<QgsSnapper::SnapLayer>::iterator snapLayerIt;
+  for (snapLayerIt = mSnapLayers.begin(); snapLayerIt != mSnapLayers.end(); ++snapLayerIt )
     //transform point from map coordinates to layer coordinates
-    layerCoordPoint = mMapRenderer->mapToLayerCoordinates( *layerIt, mapCoordPoint );
-    if (( *layerIt )->snapWithContext( layerCoordPoint, *toleranceIt, currentResultList, *snapToIt ) != 0 )
+    layerCoordPoint = mMapRenderer->mapToLayerCoordinates( snapLayerIt->mLayer, mapCoordPoint );
+    if ( snapLayerIt->mLayer->snapWithContext( layerCoordPoint, snapLayerIt->mTolerance,
+                                               currentResultList, snapLayerIt->mSnapTo ) != 0 )
       //error
@@ -78,9 +69,9 @@
       //for each snapping result: transform start point, snap point and other points into map coordinates to find out distance
       //store results in snapping result list
       newResult = currentResultIt.value();
-      newResult.snappedVertex = mMapRenderer->layerToMapCoordinates( *layerIt, currentResultIt.value().snappedVertex );
-      newResult.beforeVertex = mMapRenderer->layerToMapCoordinates( *layerIt, currentResultIt.value().beforeVertex );
-      newResult.afterVertex = mMapRenderer->layerToMapCoordinates( *layerIt, currentResultIt.value().afterVertex );
+      newResult.snappedVertex = mMapRenderer->layerToMapCoordinates( snapLayerIt->mLayer, currentResultIt.value().snappedVertex );
+      newResult.beforeVertex = mMapRenderer->layerToMapCoordinates( snapLayerIt->mLayer, currentResultIt.value().beforeVertex );
+      newResult.afterVertex = mMapRenderer->layerToMapCoordinates( snapLayerIt->mLayer, currentResultIt.value().afterVertex );
       snappingResultList.insert( sqrt( newResult.snappedVertex.sqrDist( mapCoordPoint ) ), newResult );
@@ -128,21 +119,12 @@
   return 0;
-void QgsSnapper::setLayersToSnap( const QList<QgsVectorLayer*>& layerList )
+void QgsSnapper::setSnapLayers( const QList<QgsSnapper::SnapLayer>& snapLayers )
-  mLayersToSnap = layerList;
+  mSnapLayers = snapLayers;
-void QgsSnapper::setTolerances( const QList<double>& toleranceList )
-  mSnappingTolerances = toleranceList;
-void QgsSnapper::setSnapToList( const QList<QgsSnapper::SnappingType>& snapToList )
-  mSnapToList = snapToList;
 void QgsSnapper::setSnapMode( QgsSnapper::SnappingMode snapMode )
   mSnapMode = snapMode;
Modified: trunk/qgis/src/core/qgssnapper.h
--- trunk/qgis/src/core/qgssnapper.h	2008-11-17 17:03:56 UTC (rev 9656)
+++ trunk/qgis/src/core/qgssnapper.h	2008-11-17 17:20:21 UTC (rev 9657)
@@ -78,6 +78,16 @@
+    struct SnapLayer
     QgsSnapper( QgsMapRenderer* mapRender );
     ~QgsSnapper();
@@ -88,9 +98,7 @@
     int snapPoint( const QPoint& startPoint, QList<QgsSnappingResult>& snappingResult, const QList<QgsPoint>& excludePoints = QList<QgsPoint>() );
     //setters
-    void setLayersToSnap( const QList<QgsVectorLayer*>& layerList );
-    void setTolerances( const QList<double>& toleranceList );
-    void setSnapToList( const QList<QgsSnapper::SnappingType>& snapToList );
     void setSnapMode( QgsSnapper::SnappingMode snapMode );
   private:
@@ -105,13 +113,8 @@
     QgsMapRenderer* mMapRenderer;
     /**Snap mode to apply*/
     QgsSnapper::SnappingMode mSnapMode;
-    /**The layers to which snapping is applied*/
-    QList<QgsVectorLayer*> mLayersToSnap;
-    /**The snapping tolerances for the layers. The order must correspond to the layer list.
-     Note that the tolerances are always in source coordinate systems of the layers*/
-    QList<double> mSnappingTolerances;
-    /**List if snap to segment of to vertex. The order must correspond to the layer list*/
-    QList<QgsSnapper::SnappingType> mSnapToList;
+    /**List of layers to which snapping is applied*/
+    QList<QgsSnapper::SnapLayer> mSnapLayers;
 #endif
Modified: trunk/qgis/src/gui/qgsmapcanvassnapper.cpp
--- trunk/qgis/src/gui/qgsmapcanvassnapper.cpp	2008-11-17 17:03:56 UTC (rev 9656)
+++ trunk/qgis/src/gui/qgsmapcanvassnapper.cpp	2008-11-17 17:20:21 UTC (rev 9657)
@@ -89,30 +89,26 @@
       return 3;
-    QList<QgsVectorLayer*> layerList;
-    QList<double> toleranceList;
-    QList<QgsSnapper::SnappingType> snapToList;
+    QgsSnapper::SnapLayer snapLayer;
+    snapLayer.mLayer = vlayer;
+    snapLayer.mSnapTo = snap_to;
-    layerList.push_back( vlayer );
-    snapToList.push_back( snap_to );
     QSettings settings;
     if ( snappingTol < 0 )
       //use search tolerance for vertex editing
-      toleranceList.push_back( settings.value( "/qgis/digitizing/search_radius_vertex_edit", 50 ).toDouble() );
+      snapLayer.mTolerance = settings.value( "/qgis/digitizing/search_radius_vertex_edit", 50 ).toDouble();
     else
-      toleranceList.push_back( snappingTol );
+      snapLayer.mTolerance = snappingTol;
+    QList<QgsSnapper::SnapLayer> snapLayers;
+    snapLayers.append( snapLayer );
+    mSnapper->setSnapLayers( snapLayers );
-    mSnapper->setLayersToSnap( layerList );
-    mSnapper->setTolerances( toleranceList );
-    mSnapper->setSnapToList( snapToList );
     if ( mSnapper->snapPoint( p, results, excludePoints ) != 0 )
       return 4;
@@ -160,9 +156,8 @@
       return 1; //lists must have the same size, otherwise something is wrong
-    QList<QgsVectorLayer*> vectorLayerList;
-    QList<double> toleranceDoubleList;
-    QList<QgsSnapper::SnappingType> snapTo;
     //Use snapping information from the project
     if ( snappingDefinedInProject )
@@ -190,27 +185,28 @@
           vlayer = dynamic_cast<QgsVectorLayer*>( layer );
           if ( vlayer )
-            vectorLayerList.push_back( vlayer );
         //tolerance
-        toleranceDoubleList.push_back( tolIt->toDouble() );
+        snapLayer.mTolerance = tolIt->toDouble();
         //segment or vertex
         if (( *snapIt ) == "to_vertex" )
-          snapTo.push_back( QgsSnapper::SnapToVertex );
+          snapLayer.mSnapTo = QgsSnapper::SnapToVertex;
         else if (( *snapIt ) == "to_segment" )
-          snapTo.push_back( QgsSnapper::SnapToSegment );
+          snapLayer.mSnapTo = QgsSnapper::SnapToSegment;
         else //to vertex and segment
-          snapTo.push_back( QgsSnapper::SnapToVertexAndSegment );
+          snapLayer.mSnapTo = QgsSnapper::SnapToVertexAndSegment;
+        snapLayers.append(snapLayer);
     else //nothing in project. Use default snapping tolerance to vertex of current layer
@@ -227,31 +223,31 @@
         return 3;
-      vectorLayerList.push_back( currentVectorLayer );
+      snapLayer.mLayer = currentVectorLayer;
       QSettings settings;
       //default snap mode
       QString defaultSnapString = settings.value( "/qgis/digitizing/default_snap_mode", "to vertex" ).toString();
       if ( defaultSnapString == "to segment" )
       else if ( defaultSnapString == "to vertex and segment" )
       else
       //default snapping tolerance
-      toleranceDoubleList.push_back( settings.value( "/qgis/digitizing/default_snapping_tolerance", 0 ).toDouble() );
+      snapLayer.mTolerance = settings.value( "/qgis/digitizing/default_snapping_tolerance", 0 ).toDouble();
-    mSnapper->setLayersToSnap( vectorLayerList );
-    mSnapper->setTolerances( toleranceDoubleList );
-    mSnapper->setSnapToList( snapTo );
More information about the QGIS-commit mailing list
