[QGIS Commit] r9672 - trunk/qgis/cmake
svn_qgis at osgeo.org
Wed Nov 19 15:10:34 EST 2008
Author: timlinux
Date: 2008-11-19 15:10:33 -0500 (Wed, 19 Nov 2008)
New Revision: 9672
trunk/qgis/cmake/FindGDAL.cmake
Patch from strk to specify minimum gdal of 1.4
Modified: trunk/qgis/cmake/FindGDAL.cmake
--- trunk/qgis/cmake/FindGDAL.cmake 2008-11-19 20:03:30 UTC (rev 9671)
+++ trunk/qgis/cmake/FindGDAL.cmake 2008-11-19 20:10:33 UTC (rev 9672)
@@ -49,6 +49,25 @@
# MESSAGE("DBG GDAL_CONFIG ${GDAL_CONFIG}")
IF (GDAL_CONFIG)
+ ## extract gdal version
+ EXEC_PROGRAM(${GDAL_CONFIG}
+ ARGS --version
+ OUTPUT_VARIABLE GDAL_VERSION )
+ STRING(REGEX REPLACE "([0-9]+)\\.([0-9]+)\\.([0-9]+)" "\\1" GDAL_VERSION_MAJOR "${GDAL_VERSION}")
+ STRING(REGEX REPLACE "([0-9]+)\\.([0-9]+)\\.([0-9]+)" "\\2" GDAL_VERSION_MINOR "${GDAL_VERSION}")
+ # MESSAGE("DBG GDAL_VERSION ${GDAL_VERSION}")
+ # MESSAGE("DBG GDAL_VERSION_MAJOR ${GDAL_VERSION_MAJOR}")
+ # MESSAGE("DBG GDAL_VERSION_MINOR ${GDAL_VERSION_MINOR}")
+ # check for gdal version
+ # version 1.2.5 is known NOT to be supported (missing CPL_STDCALL macro)
+ # According to INSTALL, 1.4.0+ is required
+ IF (GDAL_VERSION_MAJOR LESS 1 OR GDAL_VERSION_MINOR LESS 4)
+ MESSAGE (FATAL_ERROR "GDAL version is too old (${GDAL_VERSION}). Use 1.4.0 or higher.")
+ ENDIF (GDAL_VERSION_MAJOR LESS 1 OR GDAL_VERSION_MINOR LESS 4)
# set INCLUDE_DIR to prefix+include
ARGS --prefix
