[QGIS Commit] r10521 - trunk/qgis/src/app
    svn_qgis at osgeo.org
    Thu Apr  9 20:22:06 EDT 2009
Author: jef
Date: 2009-04-09 20:22:06 -0400 (Thu, 09 Apr 2009)
New Revision: 10521
   trunk/qgis/src/app/qgisapp.cpp
add ui defaults
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp	2009-04-10 00:18:52 UTC (rev 10520)
+++ trunk/qgis/src/app/qgisapp.cpp	2009-04-10 00:22:06 UTC (rev 10521)
@@ -1780,7 +1780,7 @@
   // store window and toolbar positions
   QSettings settings;
   // store the toolbar/dock widget settings using Qt4 settings API
-  settings.setValue( "/UI/state", this->saveState() );
+  settings.setValue( "/UI/state", saveState() );
   // store window geometry
   settings.setValue( "/UI/geometry", saveGeometry() );
@@ -1788,15 +1788,32 @@
   QgsPluginRegistry::instance()->unloadAll();
+static const unsigned char defaultUIgeometry[] =
+  0x01, 0xd9, 0xd0, 0xcb, 0x00, 0x01, 0x00, 0x00, 0xff, 0xff, 0xff, 0xfc, 0xff, 0xff, 0xff, 0xfc, 0x00, 0x00, 0x04, 0xb8, 0x00, 0x00, 0x03, 0x22, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x43, 0x00, 0x00, 0x02, 0xaf, 0x00, 0x00, 0x02, 0x22, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00
+static const unsigned char defaultUIstate[] =
+  0x00, 0x00, 0x00, 0xff, 0x00, 0x00, 0x00, 0x00, 0xfd, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x02, 0x87, 0xfc, 0x02, 0x00, 0x00, 0x00, 0x03, 0xfb, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x4c, 0x00, 0x65, 0x00, 0x67, 0x00, 0x65, 0x00, 0x6e, 0x00, 0x64, 0x01, 0x00, 0x00, 0x00, 0x68, 0x00, 0x00, 0x02, 0x87, 0x00, 0x00, 0x00, 0x72, 0x00, 0xff, 0xff, 0xff, 0xfb, 0x00, 0x00, 0x00, 0x10, 0x00, 0x4f, 0x00, 0x76, 0x00, 0x65, 0x00, 0x72, 0x00, 0x76, 0x00, 0x69, 0x00, 0x65, 0x00, 0x77, 0x00, 0x00, 0x00, 0x01, 0xf4, 0x00, 0x00, 0x00, 0x2a, 0x00, 0x00, 0x00, 0x14, 0x00, 0xff, 0xff, 0xff, 0xfb, 0x00, 0x00, 0x00, 0x22, 0x00, 0x43, 0x00, 0x6f, 0x00, 0x6f, 0x00, 0x72, 0x00, 0x64, 0x00, 0x69, 0x00, 0x6e, 0x00, 0x61, 0x00, 0x74, 0x00, 0x65, 0x00, 0x43, 0x00, 0x61, 0x00, 0x70, 0x00, 0x74, 0x00, 0x75, 0x00, 0x72, 0x00, 0x65, 0x00, 0x00, 0x00, 0x01, 0x7e, 0x00, 0x00, 0x00, 0xa0, 0x00, 0x00, 0x00, 0x7e, 0x00, 0xff, 0xff, 0xff, 0x00, 0x00, 0x03, 0xaf, 0x00, 0x00, 0x02, 0x87, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x02, 0xfc, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x16, 0x00, 0x46, 0x00, 0x69, 0x00, 0x6c, 0x00, 0x65, 0x00, 0x54, 0x00, 0x6f, 0x00, 0x6f, 0x00, 0x6c, 0x00, 0x42, 0x00, 0x61, 0x00, 0x72, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x90, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x00, 0x4c, 0x00, 0x61, 0x00, 0x79, 0x00, 0x65, 0x00, 0x72, 0x00, 0x54, 0x00, 0x6f, 0x00, 0x6f, 0x00, 0x6c, 0x00, 0x42, 0x00, 0x61, 0x00, 0x72, 0x01, 0x00, 0x00, 0x01, 0x90, 0x00, 0x00, 0x00, 0xbe, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x14, 0x00, 0x41, 0x00, 0x74, 0x00, 0x74, 0x00, 0x72, 0x00, 0x69, 0x00, 0x62, 0x00, 0x75, 0x00, 0x74, 0x00, 0x65, 0x00, 0x73, 0x01, 0x00, 0x00, 0x02, 0x4e, 0x00, 0x00, 0x01, 0x27, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x48, 0x00, 0x65, 0x00, 0x6c, 0x00, 0x70, 0x00, 0x00, 0x00, 0x03, 0xd9, 0x00, 0x00, 0x00, 0xdd, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0e, 0x00, 0x50, 0x00, 0x6c, 0x00, 0x75, 0x00, 0x67, 0x00, 0x69, 0x00, 0x6e, 0x00, 0x73, 0x01, 0x00, 0x00, 0x03, 0x75, 0x00, 0x00, 0x01, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x14, 0x00, 0x44, 0x00, 0x69, 0x00, 0x67, 0x00, 0x69, 0x00, 0x74, 0x00, 0x69, 0x00, 0x7a, 0x00, 0x69, 0x00, 0x6e, 0x00, 0x67, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x1c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1c, 0x00, 0x4d, 0x00, 0x61, 0x00, 0x70, 0x00, 0x20, 0x00, 0x4e, 0x00, 0x61, 0x00, 0x76, 0x00, 0x69, 0x00, 0x67, 0x00, 0x61, 0x00, 0x74, 0x00, 0x69, 0x00, 0x6f, 0x00, 0x6e, 0x01, 0x00, 0x00, 0x02, 0x1c, 0x00, 0x00, 0x02, 0x99, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00
 void QgisApp::restoreWindowState()
   // restore the toolbar and dock widgets postions using Qt4 settings API
   QSettings settings;
-  QVariant vstate = settings.value( "/UI/state" );
-  this->restoreState( vstate.toByteArray() );
+  if ( !restoreState( settings.value( "/UI/state", QByteArray::fromRawData(( char * )defaultUIstate, sizeof defaultUIstate ) ).toByteArray() ) )
+    QgsDebugMsg( "restore of UI state failed" );
   // restore window geometry
-  restoreGeometry( settings.value( "/UI/geometry" ).toByteArray() );
+  if ( !restoreGeometry( settings.value( "/UI/geometry", QByteArray::fromRawData(( char * )defaultUIgeometry, sizeof defaultUIgeometry ) ).toByteArray() ) )
+    QgsDebugMsg( "restore of UI geometry failed" );
 ///////////// END OF GUI SETUP ROUTINES ///////////////
