[QGIS Commit] r10522 - branches/Version-1_0/src/app
svn_qgis at osgeo.org
Thu Apr 9 20:44:54 EDT 2009
Author: jef
Date: 2009-04-09 20:44:54 -0400 (Thu, 09 Apr 2009)
New Revision: 10522
branches/Version-1_0/src/app/qgisapp.cpp
merge r10521 to version 1.0
Modified: branches/Version-1_0/src/app/qgisapp.cpp
--- branches/Version-1_0/src/app/qgisapp.cpp 2009-04-10 00:22:06 UTC (rev 10521)
+++ branches/Version-1_0/src/app/qgisapp.cpp 2009-04-10 00:44:54 UTC (rev 10522)
@@ -945,7 +945,7 @@
#ifdef Q_WS_MAC
mActionHelpContents->setShortcut( tr( "Ctrl+?" ) );
#else
- mActionHelpContents->setShortcut( tr( "F1" ) );
+ mActionHelpContents->setShortcut( tr( "F1" ) );
#endif
mActionHelpContents->setShortcutContext( Qt::WindowShortcut );
mActionHelpContents->setStatusTip( tr( "Help Documentation" ) );
@@ -1634,7 +1634,7 @@
QBitmap overviewPanBmp = QBitmap::fromData( QSize( 16, 16 ), pan_bits );
QBitmap overviewPanBmpMask = QBitmap::fromData( QSize( 16, 16 ), pan_mask_bits );
- mOverviewMapCursor = new QCursor( overviewPanBmp, overviewPanBmpMask, 0, 0 ); //set upper left corner as hot spot - this is better when extent marker is small; hand won't cover the marker
+ mOverviewMapCursor = new QCursor( overviewPanBmp, overviewPanBmpMask, 0, 0 ); //set upper left corner as hot spot - this is better when extent marker is small; hand won't cover the marker
overviewCanvas->setCursor( *mOverviewMapCursor );
// QVBoxLayout *myOverviewLayout = new QVBoxLayout;
// myOverviewLayout->addWidget(overviewCanvas);
@@ -1804,7 +1804,7 @@
// store window and toolbar positions
QSettings settings;
// store the toolbar/dock widget settings using Qt4 settings API
- settings.setValue( "/UI/state", this->saveState() );
+ settings.setValue( "/UI/state", saveState() );
// store window geometry
settings.setValue( "/UI/geometry", saveGeometry() );
@@ -1812,15 +1812,32 @@
QgsPluginRegistry::instance()->unloadAll();
+static const unsigned char defaultUIgeometry[] =
+ 0x01, 0xd9, 0xd0, 0xcb, 0x00, 0x01, 0x00, 0x00, 0xff, 0xff, 0xff, 0xfc, 0xff, 0xff, 0xff, 0xfc, 0x00, 0x00, 0x04, 0xb8, 0x00, 0x00, 0x03, 0x22, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x43, 0x00, 0x00, 0x02, 0xaf, 0x00, 0x00, 0x02, 0x22, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00
+static const unsigned char defaultUIstate[] =
+ 0x00, 0x00, 0x00, 0xff, 0x00, 0x00, 0x00, 0x00, 0xfd, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x02, 0x87, 0xfc, 0x02, 0x00, 0x00, 0x00, 0x03, 0xfb, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x4c, 0x00, 0x65, 0x00, 0x67, 0x00, 0x65, 0x00, 0x6e, 0x00, 0x64, 0x01, 0x00, 0x00, 0x00, 0x68, 0x00, 0x00, 0x02, 0x87, 0x00, 0x00, 0x00, 0x72, 0x00, 0xff, 0xff, 0xff, 0xfb, 0x00, 0x00, 0x00, 0x10, 0x00, 0x4f, 0x00, 0x76, 0x00, 0x65, 0x00, 0x72, 0x00, 0x76, 0x00, 0x69, 0x00, 0x65, 0x00, 0x77, 0x00, 0x00, 0x00, 0x01, 0xf4, 0x00, 0x00, 0x00, 0x2a, 0x00, 0x00, 0x00, 0x14, 0x00, 0xff, 0xff, 0xff, 0xfb, 0x00, 0x00, 0x00, 0x22, 0x00, 0x43, 0x00, 0x6f, 0x00, 0x6f, 0x00, 0x72, 0x00, 0x64, 0x00, 0x69, 0x00, 0x6e, 0x00, 0x61, 0x00, 0x74, 0x00, 0x65, 0x00, 0x43, 0x00, 0x61, 0x00, 0x70, 0x00, 0x74, 0x00, 0x75, 0x00, 0x72, 0x00, 0x65, 0x00, 0x00, 0x00, 0x01, 0x7e, 0x00, 0x00, 0x00, 0xa0, 0x00, 0x00, 0x00, 0x7e, 0x00, 0xff, 0xff, 0xff, 0x00, 0x00, 0x03, 0xaf, 0x00, 0x00, 0x02, 0x87, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x02, 0xfc, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x16, 0x00, 0x46, 0x00, 0x69, 0x00, 0x6c, 0x00, 0x65, 0x00, 0x54, 0x00, 0x6f, 0x00, 0x6f, 0x00, 0x6c, 0x00, 0x42, 0x00, 0x61, 0x00, 0x72, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x90, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x00, 0x4c, 0x00, 0x61, 0x00, 0x79, 0x00, 0x65, 0x00, 0x72, 0x00, 0x54, 0x00, 0x6f, 0x00, 0x6f, 0x00, 0x6c, 0x00, 0x42, 0x00, 0x61, 0x00, 0x72, 0x01, 0x00, 0x00, 0x01, 0x90, 0x00, 0x00, 0x00, 0xbe, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x14, 0x00, 0x41, 0x00, 0x74, 0x00, 0x74, 0x00, 0x72, 0x00, 0x69, 0x00, 0x62, 0x00, 0x75, 0x00, 0x74, 0x00, 0x65, 0x00, 0x73, 0x01, 0x00, 0x00, 0x02, 0x4e, 0x00, 0x00, 0x01, 0x27, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x48, 0x00, 0x65, 0x00, 0x6c, 0x00, 0x70, 0x00, 0x00, 0x00, 0x03, 0xd9, 0x00, 0x00, 0x00, 0xdd, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0e, 0x00, 0x50, 0x00, 0x6c, 0x00, 0x75, 0x00, 0x67, 0x00, 0x69, 0x00, 0x6e, 0x00, 0x73, 0x01, 0x00, 0x00, 0x03, 0x75, 0x00, 0x00, 0x01, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x14, 0x00, 0x44, 0x00, 0x69, 0x00, 0x67, 0x00, 0x69, 0x00, 0x74, 0x00, 0x69, 0x00, 0x7a, 0x00, 0x69, 0x00, 0x6e, 0x00, 0x67, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x1c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1c, 0x00, 0x4d, 0x00, 0x61, 0x00, 0x70, 0x00, 0x20, 0x00, 0x4e, 0x00, 0x61, 0x00, 0x76, 0x00, 0x69, 0x00, 0x67, 0x00, 0x61, 0x00, 0x74, 0x00, 0x69, 0x00, 0x6f, 0x00, 0x6e, 0x01, 0x00, 0x00, 0x02, 0x1c, 0x00, 0x00, 0x02, 0x99, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00
void QgisApp::restoreWindowState()
// restore the toolbar and dock widgets postions using Qt4 settings API
QSettings settings;
- QVariant vstate = settings.value( "/UI/state" );
- this->restoreState( vstate.toByteArray() );
+ if ( !restoreState( settings.value( "/UI/state", QByteArray::fromRawData(( char * )defaultUIstate, sizeof defaultUIstate ) ).toByteArray() ) )
+ QgsDebugMsg( "restore of UI state failed" );
// restore window geometry
- restoreGeometry( settings.value( "/UI/geometry" ).toByteArray() );
+ if ( !restoreGeometry( settings.value( "/UI/geometry", QByteArray::fromRawData(( char * )defaultUIgeometry, sizeof defaultUIgeometry ) ).toByteArray() ) )
+ QgsDebugMsg( "restore of UI geometry failed" );
///////////// END OF GUI SETUP ROUTINES ///////////////
@@ -1858,12 +1875,12 @@
tr( "QGIS 1.0.2 is a bug fix release for the stable version of QGIS."
"A summary of the improvements can be found at "
"https://trac.osgeo.org/qgis/query?status=closed&milestone=Version+1.0.2"
whatsNew += "<h3>" + tr( "Changes" ) + "</h3>" +
tr( "QGIS 1.0.1 is a bug fix release for the stable version of QGIS."
"https://trac.osgeo.org/qgis/query?status=closed&milestone=Version+1.0.1"
whatsNew += "<h3>" + tr( "New features" ) + "</h3>" +
tr( "The QGIS 1.0 release includes over 265 bug fixes and enhancements "
"over the QGIS 0.11.0 release. In addition we have added "
