[QGIS Commit] r10533 - trunk/qgis/src/core
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Apr 11 15:39:15 EDT 2009
Author: jef
Date: 2009-04-11 15:39:15 -0400 (Sat, 11 Apr 2009)
New Revision: 10533
   trunk/qgis/src/core/qgsrunprocess.cpp
fix #1203
Modified: trunk/qgis/src/core/qgsrunprocess.cpp
--- trunk/qgis/src/core/qgsrunprocess.cpp	2009-04-11 19:37:14 UTC (rev 10532)
+++ trunk/qgis/src/core/qgsrunprocess.cpp	2009-04-11 19:39:15 UTC (rev 10533)
@@ -47,9 +47,6 @@
     // inside the capture if() statement.
     connect( mProcess, SIGNAL( finished( int, QProcess::ExitStatus ) ), this, SLOT( processExit( int, QProcess::ExitStatus ) ) );
-    // start the process!
-    mProcess->start( action );
     // Use QgsMessageOutput for displaying output to user
     // It will delete itself when the dialog box is closed.
     mOutput = QgsMessageOutput::createMessageOutput();
@@ -63,6 +60,9 @@
       connect( mOutputObj, SIGNAL( destroyed() ), this, SLOT( dialogGone() ) );
+    // start the process!
+    mProcess->start( action );
   else
@@ -133,6 +133,8 @@
   // class being called after it has been deleted (Qt seems not to be
   // disconnecting them itself)
+  mOutput = 0;
   disconnect( mProcess, SIGNAL( error( QProcess::ProcessError ) ), this, SLOT( processError( QProcess::ProcessError ) ) );
   disconnect( mProcess, SIGNAL( readyReadStandardOutput() ), this, SLOT( stdoutAvailable() ) );
   disconnect( mProcess, SIGNAL( readyReadStandardError() ), this, SLOT( stderrAvailable() ) );
@@ -145,7 +147,7 @@
   if ( err == QProcess::FailedToStart )
-    QgsMessageOutput* output = QgsMessageOutput::createMessageOutput();
+    QgsMessageOutput* output = mOutput ? mOutput : QgsMessageOutput::createMessageOutput();
     output->setMessage( tr( "Unable to run command %1" ).arg( mCommand ), QgsMessageOutput::MessageText );
     // Didn't work, so no need to hang around
     die();
More information about the QGIS-commit mailing list
