[QGIS Commit] r10534 - in trunk/qgis/src/core: . spatialite
svn_qgis at osgeo.org
Sat Apr 11 15:41:20 EDT 2009
Author: esseffe
Date: 2009-04-11 15:41:20 -0400 (Sat, 11 Apr 2009)
New Revision: 10534
trunk/qgis/src/core/CMakeLists.txt
trunk/qgis/src/core/spatialite/spatialite.c
fixed spatialite RTree issue
Modified: trunk/qgis/src/core/CMakeLists.txt
--- trunk/qgis/src/core/CMakeLists.txt 2009-04-11 19:39:15 UTC (rev 10533)
+++ trunk/qgis/src/core/CMakeLists.txt 2009-04-11 19:41:20 UTC (rev 10534)
@@ -132,7 +132,7 @@
- INCLUDE_DIRECTORIES(spatialite/headers)
+ INCLUDE_DIRECTORIES(spatialite/headers/spatialite)
ENDIF (WITH_INTERNAL_SPATIALITE)
ADD_FLEX_FILES(QGIS_CORE_SRCS qgssearchstringlexer.ll)
Modified: trunk/qgis/src/core/spatialite/spatialite.c
--- trunk/qgis/src/core/spatialite/spatialite.c 2009-04-11 19:39:15 UTC (rev 10533)
+++ trunk/qgis/src/core/spatialite/spatialite.c 2009-04-11 19:41:20 UTC (rev 10534)
@@ -7,7 +7,7 @@
** of 5% are more are commonly seen when SQLite is compiled as a single
** translation unit.
-** This amalgamation was generated on 2009-04-06 09:20:53 +0200.
+** This amalgamation was generated on 2009-04-11 15:32:35 +0200.
Author: Alessandro (Sandro) Furieri <a.furieri at lqt.it>
@@ -60,15 +60,13 @@
#include <locale.h>
#include <errno.h>
-#include "headers/spatialite/sqlite3ext.h"
+#include "sqlite3ext.h"
#if defined(__MINGW32__) || defined(_WIN32)
#define LIBICONV_STATIC
#include <iconv.h>
#define LIBCHARSET_STATIC
-#ifndef _MSC_VER
#include <localcharset.h>
-#endif
#else /* not WINDOWS */
#ifdef __APPLE__
#include <iconv.h>
@@ -1482,7 +1480,6 @@
/* #include <spatialite/gaiaaux.h> */
-#ifndef _MSC_VER
GAIAAUX_DECLARE const char *
gaiaGetLocaleCharset ()
@@ -1497,7 +1494,6 @@
#endif
#endif
-#endif
GAIAAUX_DECLARE int
gaiaConvertCharset (char **buf, const char *fromCs, const char *toCs)
@@ -14953,7 +14949,7 @@
/* building MbrCache SpatialIndex */
sprintf (trigger,
- "CREATE VIRTUAL TABLE \"cache_%s_%s\" USING MbrCache(\"%s\", \"%s\")\n",
+ "CREATE VIRTUAL TABLE \"cache_%s_%s\" USING MbrCache(%s, %s)\n",
curr_idx->TableName, curr_idx->ColumnName,
curr_idx->TableName, curr_idx->ColumnName);
ret = sqlite3_exec (sqlite, trigger, NULL, NULL, &errMsg);
@@ -26642,7 +26638,7 @@
int geom_done;
int err_geom = 0;
int geom_constraint_err = 0;
- char prefix;
+ char prefix[16];
const char *text;
const unsigned char *blob;
char *text_wkt;
@@ -26655,20 +26651,20 @@
for (ic = 0; ic < p_vt->nColumns; ic++)
if (ic == 0)
- prefix = '(';
+ strcpy(prefix, "(");
else
- prefix = ',';
- sprintf (buf, "%c%s", prefix, *(p_vt->Column + ic));
+ strcpy(prefix, ", ");
+ sprintf (buf, "%s\"%s\"", prefix, *(p_vt->Column + ic));
strcat (sql, buf);
strcat (sql, ") VALUES ");
if (ic == 0)
- prefix = '(';
else
- prefix = ',';
- sprintf (buf, "%c?", prefix);
+ sprintf (buf, "%s?", prefix);
strcat (sql, buf);
strcat (sql, ")");
@@ -26828,7 +26824,7 @@
int geom_done;
int err_geom = 0;
- char prefix;
+ char prefix[16];
const char *text;
char *text_wkt;
@@ -26841,10 +26837,10 @@
if (ic == 0)
- prefix = ' ';
+ strcpy(prefix, " ");
else
- prefix = ',';
- sprintf (buf, "\"%c%s\" = ?", prefix, *(p_vt->Column + ic));
+ sprintf (buf, "%s\"%s\" = ?", prefix, *(p_vt->Column + ic));
strcat (sql, buf);
#if defined(_WIN32) || defined(__MINGW32__)
@@ -27258,7 +27254,7 @@
char **results;
char sql[4096];
char buf[256];
- char prefix;
+ char prefix[16];
VirtualFDOPtr p_vt = NULL;
/* checking for table_name */
if (argc == 4)
@@ -27388,10 +27384,10 @@
for (i = 0; i < p_vt->nColumns; i++)
if (i == 0)
- prefix = '(';
else
- prefix = ',';
- sprintf (buf, "\"%c%s\" %s", prefix, *(p_vt->Column + i),
+ sprintf (buf, "%s\"%s\" %s", prefix, *(p_vt->Column + i),
*(p_vt->Type + i));
if (*(p_vt->NotNull + i))
strcat (buf, " NOT NULL");
