[QGIS Commit] r10676 - in docs/trunk/english_us/user_guide: . plugins_diagram_overlay
svn_qgis at osgeo.org svn_qgis at osgeo.org
Tue Apr 28 20:25:31 EDT 2009
Author: cfarmer
Date: 2009-04-28 20:25:30 -0400 (Tue, 28 Apr 2009)
New Revision: 10676
Added:
   docs/trunk/english_us/user_guide/plugins_diagram_overlay/
   docs/trunk/english_us/user_guide/plugins_diagram_overlay/Makefile
   docs/trunk/english_us/user_guide/plugins_diagram_overlay/diagram_overlay.eps
   docs/trunk/english_us/user_guide/plugins_diagram_overlay/diagram_overlay.png
add diagram_overlay folder and create quick icon for use in core plugins table
Property changes on: docs/trunk/english_us/user_guide/plugins_diagram_overlay
___________________________________________________________________
   + *.aux
*.log
*.eps
*.bbl
*.blg
*.out
*.lof
*.toc
*.dvi
*.idx
*.xml
*.lot
*.lox
*.ind
*.tmp
*.pdf
*.ilg
Added: docs/trunk/english_us/user_guide/plugins_diagram_overlay/Makefile
--- docs/trunk/english_us/user_guide/plugins_diagram_overlay/Makefile	                        (rev 0)
+++ docs/trunk/english_us/user_guide/plugins_diagram_overlay/Makefile	2009-04-29 00:25:30 UTC (rev 10676)
@@ -0,0 +1,41 @@
+# makefile to convert figures into eps format for the book
+# Comments from Michel Wurtz:
+# You will notice that the list given is the list of targets.  "all" just
+# refer to this list.  The most important rule is the next rule, that give
+# the generic rule for transforming a .fig into a .eps file.  Note the use
+# of % (define the couple target:source) and the use of
+# $< (source postfix, here .fig) and $@ (target postfix, here .eps)
+# with .eps extension:
+# JPG=qgis_icon_new_verylarge.eps\
+#	nextfile.eps
+PNG=diagram_overlay.eps\
+##### TARGETS #####
+all: $(PNG) $(JPG)
+	if [ ! -d ../finalpix/ ]; then mkdir ../finalpix; fi
+	#do not use move (mv):
+	cp *.eps ../finalpix/
+#$(EPS):	%.eps: %.fig
+#	fig2dev -L eps $< > $@
+#$(FIGPNG): %.png: %.fig
+#	fig2dev -L png -m 2 $< > $@
+$(PNG): %.eps: %.png
+	# Workaround for PDF
+	#convert -geometry 300x -depth 1 $< $@
+	convert $< $@
+$(JPG): %.eps: %.jpg
+	convert $< $@
+clean:
+	rm -f *.bak *~ *.pdf $(PNG) $(JPG)
Added: docs/trunk/english_us/user_guide/plugins_diagram_overlay/diagram_overlay.eps
--- docs/trunk/english_us/user_guide/plugins_diagram_overlay/diagram_overlay.eps	                        (rev 0)
+++ docs/trunk/english_us/user_guide/plugins_diagram_overlay/diagram_overlay.eps	2009-04-29 00:25:30 UTC (rev 10676)
@@ -0,0 +1,364 @@
+%!PS-Adobe-3.0 EPSF-3.0
+%%Creator: (ImageMagick)
+%%Title: (diagram_overlay.eps)
+%%CreationDate: (Tue Apr 28 23:39:47 2009)
+%%BoundingBox: 0 0 25 25
+%%HiResBoundingBox: 0 0 25.3164 25
+%%DocumentData: Clean7Bit
+%%LanguageLevel: 1
+%%Pages: 1
+%%EndComments
+%%BeginDefaults
+%%EndDefaults
+%%BeginProlog
+% Display a color image.  The image is displayed in color on
+% Postscript viewers or printers that support color, otherwise
+% it is displayed as grayscale.
+/DirectClassPacket
+  % Get a DirectClass packet.
+  % Parameters:
+  %   red.
+  %   green.
+  %   blue.
+  %   length: number of pixels minus one of this color (optional).
+  currentfile color_packet readhexstring pop pop
+  compression 0 eq
+    /number_pixels 3 def
+    currentfile byte readhexstring pop 0 get
+    /number_pixels exch 1 add 3 mul def
+  } ifelse
+  0 3 number_pixels 1 sub
+    pixels exch color_packet putinterval
+  } for
+  pixels 0 number_pixels getinterval
+} bind def
+/DirectClassImage
+  % Display a DirectClass image.
+  systemdict /colorimage known
+    columns rows 8
+      columns 0 0
+      rows neg 0 rows
+    { DirectClassPacket } false 3 colorimage
+    % No colorimage operator;  convert to grayscale.
+    columns rows 8
+      columns 0 0
+      rows neg 0 rows
+    { GrayDirectClassPacket } image
+  } ifelse
+} bind def
+/GrayDirectClassPacket
+  % Get a DirectClass packet;  convert to grayscale.
+  % Parameters:
+  %   red
+  %   green
+  %   blue
+  color_packet 0 get 0.299 mul
+  color_packet 1 get 0.587 mul add
+  color_packet 2 get 0.114 mul add
+  cvi
+  /gray_packet exch def
+  compression 0 eq
+    /number_pixels 1 def
+    /number_pixels exch 1 add def
+  } ifelse
+  0 1 number_pixels 1 sub
+    pixels exch gray_packet put
+  } for
+} bind def
+/GrayPseudoClassPacket
+  % Get a PseudoClass packet;  convert to grayscale.
+  % Parameters:
+  %   index: index into the colormap.
+  /offset exch 3 mul def
+  /color_packet colormap offset 3 getinterval def
+  cvi
+  compression 0 eq
+  } ifelse
+  } for
+} bind def
+/PseudoClassPacket
+  % Get a PseudoClass packet.
+  % Parameters:
+  compression 0 eq
+  } ifelse
+  } for
+} bind def
+/PseudoClassImage
+  % Display a PseudoClass image.
+  % Parameters:
+  %   class: 0-PseudoClass or 1-Grayscale.
+  currentfile buffer readline pop
+  token pop /class exch def pop
+  class 0 gt
+    token pop /depth exch def pop
+    /grays columns 8 add depth sub depth mul 8 idiv string def
+    columns rows depth
+      columns 0 0
+      rows neg 0 rows
+    { currentfile grays readhexstring pop } image
+    % Parameters:
+    %   colors: number of colors in the colormap.
+    %   colormap: red, green, blue color packets.
+    token pop /colors exch def pop
+    /colors colors 3 mul def
+    /colormap colors string def
+    currentfile colormap readhexstring pop pop
+      columns rows 8
+        columns 0 0
+        rows neg 0 rows
+      { PseudoClassPacket } false 3 colorimage
+      columns rows 8
+        columns 0 0
+        rows neg 0 rows
+      { GrayPseudoClassPacket } image
+    } ifelse
+  } ifelse
+} bind def
+/DisplayImage
+  % Display a DirectClass or PseudoClass image.
+  % Parameters:
+  %   x & y translation.
+  %   x & y scale.
+  %   label pointsize.
+  %   image label.
+  %   image columns & rows.
+  %   class: 0-DirectClass or 1-PseudoClass.
+  %   compression: 0-none or 1-RunlengthEncoded.
+  %   hex color packets.
+  gsave
+  /buffer 512 string def
+  /byte 1 string def
+  /color_packet 3 string def
+  /pixels 768 string def
+  token pop /x exch def
+  token pop /y exch def pop
+  x y translate
+  token pop /pointsize exch def pop
+  /Times-Roman findfont pointsize scalefont setfont
+  x y scale
+  token pop /columns exch def
+  token pop /rows exch def pop
+  token pop /compression exch def pop
+  class 0 gt { PseudoClassImage } { DirectClassImage } ifelse
+  grestore
+} bind def
+%%EndProlog
+%%Page:  1 1
+%%PageBoundingBox: 0 0 25 25
+userdict begin
+DisplayImage
+0 0
+25.3164 25.3164
+12.000000
+32 32
+0
+0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+%%PageTrailer
+%%Trailer
+%%EOF
Added: docs/trunk/english_us/user_guide/plugins_diagram_overlay/diagram_overlay.png
(Binary files differ)
Property changes on: docs/trunk/english_us/user_guide/plugins_diagram_overlay/diagram_overlay.png
   + application/octet-stream
More information about the QGIS-commit mailing list
