[QGIS Commit] r10677 - in docs/trunk/english_us/user_guide: .
working_with_projections_screenies
svn_qgis at osgeo.org
Tue Apr 28 20:27:09 EDT 2009
Author: cfarmer
Date: 2009-04-28 20:27:09 -0400 (Tue, 28 Apr 2009)
New Revision: 10677
docs/trunk/english_us/user_guide/working_with_projections.tex
docs/trunk/english_us/user_guide/working_with_projections_screenies/crsdialog.png
docs/trunk/english_us/user_guide/working_with_projections_screenies/customProjectionDialog.png
update working with projections chapter
Modified: docs/trunk/english_us/user_guide/working_with_projections.tex
--- docs/trunk/english_us/user_guide/working_with_projections.tex 2009-04-29 00:25:30 UTC (rev 10676)
+++ docs/trunk/english_us/user_guide/working_with_projections.tex 2009-04-29 00:27:09 UTC (rev 10677)
@@ -46,8 +46,9 @@
first layer loaded. When you start a QGIS session with layers that do not
have a CRS, you need to control and define the CRS definition for these
layers. This can be done globally or project-wide in the \tab{CRS} tab under
-\mainmenuopt{Edit} > \dropmenuopttwo{mActionOptions}{Options} (See
-Figure~\ref{fig:crsdialog}).
+\mainmenuopt{Edit} > \dropmenuopttwo{mActionOptions}{Options} (Gnome, OSX)
+or \mainmenuopt{Settings} > \dropmenuopttwo{mActionOptions}{Options} (KDE, Windows).
+See Figure~\ref{fig:crsdialog}.
\begin{itemize}
\item \checkbox{Prompt for CRS}
@@ -82,7 +83,7 @@
\begin{enumerate}
\item Select \dropmenuopttwo{mActionOptions}{Project Properties} from the
-\mainmenuopt{Edit} menu.
+\mainmenuopt{Edit} (Gnome, OSX) or \mainmenuopt{Settings} (KDE, Windows) menu.
\item Click on the \toolbtntwo{mIconProjectionDisabled}{projector} icon in the
lower right-hand corner of the statusbar.
\end{enumerate}
@@ -129,10 +130,11 @@
\end{enumerate}
\begin{Tip}
- \caption{\textsc{Project Properties Dialog}}
+\caption{\textsc{Project Properties Dialog}}
\qgistip{
If you open the \dialog{Project Properties} dialog from the
-\mainmenuopt{Edit} menu, you must click on the \tab{Coordinate Reference
+(KDE, Windows) menu, you must click on the \tab{Coordinate Reference
System} tab to view the CRS settings. Opening the dialog from the
\toolbtntwo{mIconProjectionEnabled}{projector} icon will automatically bring
the \tab{Coordinate Reference System} tab to the front.
@@ -144,7 +146,8 @@
If QGIS does not provide the coordinate reference system you need, you
can define a custom CRS. To define a CRS, select
-\dropmenuopttwo{mIconNew}{Custom CRS} from the \mainmenuopt{Edit} menu.
+\dropmenuopttwo{mIconNew}{Custom CRS} from the \mainmenuopt{Edit}
+(Gnome, OSX) or \mainmenuopt{Settings} (KDE, Windows) menu.
Custom CRS are stored in your QGIS user database. In addition to your custom
CRS, this database also contains your spatial bookmarks and other custom data.
Modified: docs/trunk/english_us/user_guide/working_with_projections_screenies/crsdialog.png
(Binary files differ)
Modified: docs/trunk/english_us/user_guide/working_with_projections_screenies/customProjectionDialog.png
