[QGIS Commit] r10678 - in docs/trunk/english_us/user_guide: . plugins_coordinate_capture_images plugins_decorations_images
svn_qgis at osgeo.org svn_qgis at osgeo.org
Tue Apr 28 20:30:42 EDT 2009
Author: cfarmer
Date: 2009-04-28 20:30:42 -0400 (Tue, 28 Apr 2009)
New Revision: 10678
   docs/trunk/english_us/user_guide/core_plugins.tex
   docs/trunk/english_us/user_guide/plugins_coordinate_capture.tex
   docs/trunk/english_us/user_guide/plugins_coordinate_capture_images/Makefile
   docs/trunk/english_us/user_guide/plugins_decorations.tex
   docs/trunk/english_us/user_guide/plugins_decorations_images/copyright.png
   docs/trunk/english_us/user_guide/plugins_decorations_images/north_arrow_dialog.png
   docs/trunk/english_us/user_guide/plugins_decorations_images/scale_bar_dialog.png
update to core plugins chapter, along with coordinate capture and decoration plugins sections
Modified: docs/trunk/english_us/user_guide/core_plugins.tex
--- docs/trunk/english_us/user_guide/core_plugins.tex	2009-04-29 00:27:09 UTC (rev 10677)
+++ docs/trunk/english_us/user_guide/core_plugins.tex	2009-04-29 00:30:42 UTC (rev 10678)
@@ -6,12 +6,9 @@
 % comment out the following line:
 %\updatedisclaimer
-QGIS currently contains 17 core plugins that can be loaded using the Plugin Manager.
+QGIS currently contains 19 core plugins that can be loaded using the Plugin Manager.
 Table \ref{tab:core_plugins} lists each of the core plugins along with a
-description of their purpose and the toolbar-icon.\footnote{The MapServer
-Export Plugin and the Plugin Installer Plugin are external Python Plugins,
-but they are part of the QGIS sources and automatically loaded and selectable
-inside the QGIS Plugin Manager.}
+description of their purpose and the toolbar-icon.
 % minipage is needed to appear the footnote under the table
 % SH
@@ -31,10 +28,16 @@
 \hline
 \includegraphics[width=0.6cm]{copyright_label}
  & Copyright Label \index{plugins!copyright}& Draws a copyright label with information\\
-\hline
+\hline
+\includegraphics[width=0.6cm]{diagram_overlay}
+ & Diagram Overlay \index{plugins!diagram}& Place charts (pie or bar) or proportional symbols over vector layers\\
+\hline
 \includegraphics[width=0.6cm]{dxf2shp_converter}
  & DXF2Shape Converter \index{plugins!DXF2Shape}& Converts from DXF to SHP file format\\
 \hline
+\includegraphics[width=0.6cm, height=0.6cm]{ftoolslogo}
+ & fTools \index{plugins!ftools}& A suite of analysis, geometry, geoprocessing, and research tools\\
+\hline
 \includegraphics[width=0.6cm]{gps_importer}
  & GPS Tools \index{plugins!gps}& Tools for loading and importing GPS data\\
 \hline
@@ -44,9 +47,6 @@
 \includegraphics[width=0.6cm]{georeferencer}
  & Georeferencer \index{plugin!georeferencer} & Adding projection info to Rasterfiles\\
 \hline
-\includegraphics[width=0.6cm]{grid_maker}
- & Graticule Creator \index{plugins!graticule}& Create a latitude/longitude grid and save as a shapefile\\
-\hline
 \includegraphics[width=0.6cm]{interpolation}
 & Interpolation plugin \index{plugins!Interpolation}& Interpolation on base of vertices of a vector layer\\
 \hline
@@ -60,6 +60,9 @@
  & OGR Layer Converter \index{plugins!OGR converter} & Translate vector
 layers between OGR suported formats\\
 \hline
+\includegraphics[width=0.6cm]{oracle_raster}
+ & Oracle Georaster \index{plugins!georaster}& Access Oracle Spatial GeoRasters\\
+\hline
 \includegraphics[width=0.6cm]{plugin_installer}
  & Plugin Installer \index{plugins!Plugin Installer} & Downloads and installs QGIS python plugins\\
 \hline
Modified: docs/trunk/english_us/user_guide/plugins_coordinate_capture.tex
--- docs/trunk/english_us/user_guide/plugins_coordinate_capture.tex	2009-04-29 00:27:09 UTC (rev 10677)
+++ docs/trunk/english_us/user_guide/plugins_coordinate_capture.tex	2009-04-29 00:30:42 UTC (rev 10678)
@@ -7,10 +7,8 @@
 % \updatedisclaimer
 The coordinate capture plugin is easy to use and provides the
-capability to display coordinates on the map canvas for two
-selected Coordinate Reference Systems (CRS). You can click a
-certain point and copy the coordinates to the clipboard or you
-use the mouse tracking functionality
+ability to display coordinates on the map canvas for two
+selected Coordinate Reference Systems (CRS).
 \begin{figure}[ht]
    \begin{center}
@@ -21,21 +19,20 @@
 \begin{enumerate}
   \item Start QGIS, select \dropmenuopttwo{mActionOptions}{Project Properties} from
-  the \mainmenuopt{Settings} menu and click on the \tab{Projection} tab. As an alternative you
+  the \mainmenuopt{Settings} (KDE, Windows) or \mainmenuopt{File} (Gnome, OSX) menu
+  and click on the \tab{Projection} tab. As an alternative you
   you can also click on the \toolbtntwo{mIconProjectionEnabled}{projector} icon in the lower
   right-hand corner of the statusbar.
-  \item Click on the \checkbox{Enable on the fly projection} checkbox and select the projected
-  coordinate system \filename{"NAD27/Alaska Albers"} with EPSG 2964 (see also
-  Section \ref{label_projections}).
-  \item Load the \filename{alaska.shp} vector layer from the qgis sample dataset.
+  \item Click on the \checkbox{Enable on the fly projection} checkbox and select a projected
+  coordinate system of your choice (see also Section \ref{label_projections}).
   \item Load the coordinate capture plugin in the Plugin Manager (see Section
-  \ref{sec:load_core_plugin}) and click on the \toolbtntwo{coordinate_capture}{Coordinate Capture}
-  icon. The cordinate capture dialog appears as shown in Figure \ref{fig:coordinate_capture_dialog}.
+  \ref{sec:load_core_plugin}) and ensure that the dialog is visible by going to \mainmenuopt{View}
+   > \dropmenuopt{Panels} and ensuring that \checkbox{Coordinate Capture} is enabled.
+   The cordinate capture dialog appears as shown in Figure \ref{fig:coordinate_capture_dialog}.
   \item Click on the \toolbtntwo{geographic}{Click to the select the CRS to use for coordinate display}
-  icon and select Geographic Coordinate System \filename{WGS84} (EPSG 4326).
-  \item You can now click anywhere on the map canvas and the plugin will show the
-  \filename{"NAD27/Alaska Albers"} and \filename{WGS84} coordinates for your selected points as shown in
-  Figure \ref{fig:coordinate_capture_dialog}.
+  icon and select a different CRS from the one you selected above.
+  \item To start capturing coordinates, click on \button{Start capture}. You can now click anywhere
+  on the map canvas and the plugin will show the coordinates for both of your selected CRS.
   \item To enable mouse coordinate tracking click the \toolbtntwo{tracking}{mouse tracking} icon.
   \item You can also copy selected coordinates to the clipboard.
 \end{enumerate}
Modified: docs/trunk/english_us/user_guide/plugins_coordinate_capture_images/Makefile
--- docs/trunk/english_us/user_guide/plugins_coordinate_capture_images/Makefile	2009-04-29 00:27:09 UTC (rev 10677)
+++ docs/trunk/english_us/user_guide/plugins_coordinate_capture_images/Makefile	2009-04-29 00:30:42 UTC (rev 10678)
@@ -15,6 +15,7 @@
 	geographic.eps\
 	tracking.eps\
 	transformed.eps\
+	coordinate_capture_dialog.eps\
 ##### TARGETS #####
Modified: docs/trunk/english_us/user_guide/plugins_decorations.tex
--- docs/trunk/english_us/user_guide/plugins_decorations.tex	2009-04-29 00:27:09 UTC (rev 10677)
+++ docs/trunk/english_us/user_guide/plugins_decorations.tex	2009-04-29 00:30:42 UTC (rev 10678)
@@ -31,9 +31,8 @@
 \item Click \button{OK}
 \end{enumerate}
-In the example above, the first line is in bold, the second (created using
-\textless br\textgreater) contains a copyright symbol, followed by our company name in
-italics.
+In the example above (default) places a copyright symbol followed by the date in the
+lower right hand corner of the map canvas.
 \subsubsection{North Arrow Plugin}
Modified: docs/trunk/english_us/user_guide/plugins_decorations_images/copyright.png
(Binary files differ)
Modified: docs/trunk/english_us/user_guide/plugins_decorations_images/north_arrow_dialog.png
Modified: docs/trunk/english_us/user_guide/plugins_decorations_images/scale_bar_dialog.png
More information about the QGIS-commit mailing list
