[QGIS Commit] r11317 - branches/symbology-ng-branch/src/core/pal
svn_qgis at osgeo.org
Sun Aug 9 10:21:38 EDT 2009
Author: wonder
Date: 2009-08-09 10:21:38 -0400 (Sun, 09 Aug 2009)
New Revision: 11317
branches/symbology-ng-branch/src/core/pal/costcalculator.cpp
branches/symbology-ng-branch/src/core/pal/feature.cpp
branches/symbology-ng-branch/src/core/pal/feature.h
Penalize small lines/polygons with additional cost for all candidates of the feature part.
This has the effect that larger objects get higher chance of being labeled.
Modified: branches/symbology-ng-branch/src/core/pal/costcalculator.cpp
--- branches/symbology-ng-branch/src/core/pal/costcalculator.cpp 2009-08-09 14:09:05 UTC (rev 11316)
+++ branches/symbology-ng-branch/src/core/pal/costcalculator.cpp 2009-08-09 14:21:38 UTC (rev 11317)
@@ -188,6 +188,9 @@
setPolygonCandidatesCost( stop, (LabelPosition**) feat->lPos, max_p, obstacles, bbx, bby );
+ // add size penalty (small lines/polygons get higher cost)
+ feat->feature->addSizePenalty(max_p, feat->lPos, bbx, bby);
return max_p;
Modified: branches/symbology-ng-branch/src/core/pal/feature.cpp
--- branches/symbology-ng-branch/src/core/pal/feature.cpp 2009-08-09 14:09:05 UTC (rev 11316)
+++ branches/symbology-ng-branch/src/core/pal/feature.cpp 2009-08-09 14:21:38 UTC (rev 11317)
@@ -1279,7 +1279,45 @@
return rnbp;
+ void FeaturePart::addSizePenalty( int nbp, LabelPosition** lPos, double bbx[4], double bby[4])
+ int geomType = GEOSGeomTypeId(the_geom);
+ double sizeCost = 0;
+ if (geomType == GEOS_LINESTRING)
+ double length;
+ if (GEOSLength(the_geom, &length) != 1)
+ return; // failed to calculate length
+ double bbox_length = max(bbx[2]-bbx[0], bby[2]-bby[0]);
+ if (length >= bbox_length/4)
+ return; // the line is longer than quarter of height or width - don't penalize it
+ sizeCost = 1 - (length / (bbox_length/4)); // < 0,1 >
+ else if (geomType == GEOS_POLYGON)
+ double area;
+ if (GEOSArea(the_geom, &area) != 1)
+ return;
+ double bbox_area = (bbx[2]-bbx[0])*(bby[2]-bby[0]);
+ if (area >= bbox_area/16)
+ return; // covers more than 1/16 of our view - don't penalize it
+ sizeCost = 1 - (area / (bbox_area/16)); // < 0, 1 >
+ else
+ return; // no size penalty for points
+ std::cout << "size cost " << sizeCost << std::endl;
+ // apply the penalty
+ for (int i = 0; i < nbp; i++)
+ lPos[i]->setCost( lPos[i]->getCost() + sizeCost / 100 );
bool FeaturePart::isConnected(FeaturePart* p2)
return (GEOSTouches(the_geom, p2->the_geom) == 1);
Modified: branches/symbology-ng-branch/src/core/pal/feature.h
--- branches/symbology-ng-branch/src/core/pal/feature.h 2009-08-09 14:09:05 UTC (rev 11316)
+++ branches/symbology-ng-branch/src/core/pal/feature.h 2009-08-09 14:21:38 UTC (rev 11317)
@@ -266,6 +266,9 @@
/** merge other (connected) part with this one and save the result in this part (other is unchanged).
* Return true on success, false if the feature wasn't modified */
bool mergeWithFeaturePart(FeaturePart* other);
+ void addSizePenalty( int nbp, LabelPosition** lPos, double bbx[4], double bby[4]);
} // end namespace pal
