[QGIS Commit] r11345 - in trunk/qgis/src: app plugins/grass ui
svn_qgis at osgeo.org
Tue Aug 11 11:21:26 EDT 2009
Author: jef
Date: 2009-08-11 11:21:25 -0400 (Tue, 11 Aug 2009)
New Revision: 11345
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp
trunk/qgis/src/ui/qgsoptionsbase.ui
fix warnings
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2009-08-11 14:26:43 UTC (rev 11344)
+++ trunk/qgis/src/app/qgisapp.cpp 2009-08-11 15:21:25 UTC (rev 11345)
@@ -4656,7 +4656,6 @@
void QgisApp::removeLayer()
- QgsLegendLayerFile* currentLayerFile = mMapLegend->currentLayerFile();
mMapLegend->legendLayerRemove();
// notify the project we've made a change
QgsProject::instance()->dirty( true );
@@ -5437,7 +5436,7 @@
//pass any refresg signals off to canvases
// Line below was commented out by wonder three years ago (r4949).
// It is needed to refresh scale bar after changing display units.
- connect (pp,SIGNAL(refresh()), mMapCanvas, SLOT(refresh()));
+ connect( pp, SIGNAL( refresh() ), mMapCanvas, SLOT( refresh() ) );
QgsMapRenderer* myRender = mMapCanvas->mapRenderer();
bool wasProjected = myRender->hasCrsTransformEnabled();
Modified: trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp 2009-08-11 14:26:43 UTC (rev 11344)
+++ trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp 2009-08-11 15:21:25 UTC (rev 11345)
@@ -2004,11 +2004,7 @@
adjustTitle();
// Check if this parameter is required
- if (gnode.toElement().attribute("required") == "yes") {
- mRequired = true;
- } else {
- mRequired = false;
+ mRequired = gnode.toElement().attribute( "required" ) == "yes";
QDomNode promptNode = gnode.namedItem( "gisprompt" );
QDomElement promptElem = promptNode.toElement();
@@ -2221,11 +2217,12 @@
// If not required, add an empty item to combobox and a padding item into
// layer containers.
- if (!mRequired){
- mMaps.push_back(QString(""));
- mVectorLayerNames.push_back(QString(""));
- mMapLayers.push_back(NULL);
- mLayerComboBox->addItem(tr("Select a layer"), QVariant());
+ if ( !mRequired )
+ mMaps.push_back( QString( "" ) );
+ mVectorLayerNames.push_back( QString( "" ) );
+ mMapLayers.push_back( NULL );
+ mLayerComboBox->addItem( tr( "Select a layer" ), QVariant() );
QgsMapCanvas *canvas = mModule->qgisIface()->mapCanvas();
@@ -2439,18 +2436,16 @@
QgsDebugMsg( "called." );
- int limit = 0;
- if (!mRequired)
+ unsigned int limit = 0;
+ if ( !mRequired )
limit = 1;
std::vector<QgsField> fields;
- int c = mLayerComboBox->currentIndex();
- if ( c < limit )
+ unsigned int current = mLayerComboBox->currentIndex();
+ if ( current < limit )
return fields;
- unsigned current = c;
if ( current >= limit && current < mVectorFields.size() )
fields = mVectorFields[current];
@@ -2463,16 +2458,14 @@
- int limit = 0;
- if (!mRequired)
+ if ( !mRequired )
limit = 1;
- if ( c < limit )
return 0;
- unsigned int current = c;
if ( current >= limit && current < mMapLayers.size() )
return mMapLayers[current];
@@ -2485,16 +2478,14 @@
- int limit = 0;
- if (!mRequired)
+ if ( !mRequired )
limit = 1;
- if ( c < limit )
return QString();
if ( current >= limit && current < mMaps.size() )
return mMaps[current];
@@ -2646,11 +2637,7 @@
adjustTitle();
- mRequired = true;
- } else {
@@ -2721,10 +2708,11 @@
- if (!mRequired){
- mUri.push_back(QString());
- mOgrLayers.push_back(QString());
+ if ( !mRequired )
+ mUri.push_back( QString() );
+ mOgrLayers.push_back( QString() );
Modified: trunk/qgis/src/ui/qgsoptionsbase.ui
--- trunk/qgis/src/ui/qgsoptionsbase.ui 2009-08-11 14:26:43 UTC (rev 11344)
+++ trunk/qgis/src/ui/qgsoptionsbase.ui 2009-08-11 15:21:25 UTC (rev 11345)
@@ -477,7 +477,7 @@
</widget>
</item>
<item row="2" column="0">
- <widget class="QLabel" name="textLabel1_8">
+ <widget class="QLabel" name="textLabel1_11">
<property name="text">
<string>Preferred measurements units</string>
</property>
