[QGIS Commit] r11350 - in trunk/qgis: python/core src/core/composer
svn_qgis at osgeo.org
Wed Aug 12 03:35:40 EDT 2009
Author: mhugent
Date: 2009-08-12 03:35:38 -0400 (Wed, 12 Aug 2009)
New Revision: 11350
trunk/qgis/python/core/qgscomposerlabel.sip
trunk/qgis/src/core/composer/qgscomposerlabel.cpp
trunk/qgis/src/core/composer/qgscomposerlabel.h
Fix current_date field in composer label
Modified: trunk/qgis/python/core/qgscomposerlabel.sip
--- trunk/qgis/python/core/qgscomposerlabel.sip 2009-08-12 06:47:32 UTC (rev 11349)
+++ trunk/qgis/python/core/qgscomposerlabel.sip 2009-08-12 07:35:38 UTC (rev 11350)
@@ -18,6 +18,11 @@
QString text();
void setText( const QString& text );
+ /**Returns the text as it appears on screen (with replaced data field)
+ @note this function was added in version 1.2*/
+ QString displayText() const;
QFont font() const;
void setFont( const QFont& f );
double margin();
Modified: trunk/qgis/src/core/composer/qgscomposerlabel.cpp
--- trunk/qgis/src/core/composer/qgscomposerlabel.cpp 2009-08-12 06:47:32 UTC (rev 11349)
+++ trunk/qgis/src/core/composer/qgscomposerlabel.cpp 2009-08-12 07:35:38 UTC (rev 11350)
@@ -47,9 +47,10 @@
double penWidth = pen().widthF();
QRectF painterRect( penWidth + mMargin, penWidth + mMargin, rect().width() - 2 * penWidth - 2 * mMargin,
rect().height() - 2 * penWidth - 2 * mMargin );
- //painter->drawText( painterRect, Qt::AlignLeft | Qt::AlignTop | Qt::TextWordWrap, mText );
- drawText( painter, painterRect, mText, mFont );
+ drawText( painter, painterRect, displayText(), mFont );
drawFrame( painter );
if ( isSelected() )
@@ -59,6 +60,9 @@
void QgsComposerLabel::setText( const QString& text )
+ mText = text;
+#if 0
//replace '$CURRENT_DATE<(FORMAT)>' with the current date
//e.g. $CURRENT_DATE(d 'June' yyyy)
mText = text;
@@ -79,8 +83,37 @@
mText.replace( "$CURRENT_DATE", QDate::currentDate().toString() );
+#endif //0
+QString QgsComposerLabel::displayText() const
+ QString displayText = mText;
+ replaceDateText(displayText);
+ return displayText;
+void QgsComposerLabel::replaceDateText(QString& text) const
+ int currentDatePos = text.indexOf( "$CURRENT_DATE" );
+ if ( currentDatePos != -1 )
+ //check if there is a bracket just after $CURRENT_DATE
+ QString formatText;
+ int openingBracketPos = text.indexOf( "(", currentDatePos );
+ int closingBracketPos = text.indexOf( ")", openingBracketPos + 1 );
+ if ( openingBracketPos != -1 && closingBracketPos != -1 && ( closingBracketPos - openingBracketPos ) > 1 )
+ formatText = text.mid( openingBracketPos + 1, closingBracketPos - openingBracketPos - 1 );
+ text.replace( currentDatePos, closingBracketPos - currentDatePos + 1, QDate::currentDate().toString( formatText ) );
+ else //no bracket
+ text.replace( "$CURRENT_DATE", QDate::currentDate().toString() );
void QgsComposerLabel::setFont( const QFont& f )
mFont = f;
@@ -88,7 +121,7 @@
void QgsComposerLabel::adjustSizeToText()
- double textWidth = textWidthMillimeters( mFont, mText );
+ double textWidth = textWidthMillimeters( mFont, displayText() );
double fontAscent = fontAscentMillimeters( mFont );
setSceneRect( QRectF( transform().dx(), transform().dy(), textWidth + 2 * mMargin + 2 * pen().widthF() + 1, \
Modified: trunk/qgis/src/core/composer/qgscomposerlabel.h
--- trunk/qgis/src/core/composer/qgscomposerlabel.h 2009-08-12 06:47:32 UTC (rev 11349)
+++ trunk/qgis/src/core/composer/qgscomposerlabel.h 2009-08-12 07:35:38 UTC (rev 11350)
@@ -36,6 +36,11 @@
QString text() {return mText;}
QFont font() const;
double margin() {return mMargin;}
@@ -61,6 +66,9 @@
// Border between text and fram (in mm)
double mMargin;
+ /**Replaces replace '$CURRENT_DATE<(FORMAT)>' with the current date (e.g. $CURRENT_DATE(d 'June' yyyy)*/
+ void replaceDateText(QString& text) const;
#endif
