[QGIS Commit] r11351 - trunk/qgis/src/core/composer
svn_qgis at osgeo.org
Wed Aug 12 03:43:38 EDT 2009
Author: mhugent
Date: 2009-08-12 03:43:37 -0400 (Wed, 12 Aug 2009)
New Revision: 11351
trunk/qgis/src/core/composer/qgscomposerlabel.cpp
Remove legacy code in composer label
Modified: trunk/qgis/src/core/composer/qgscomposerlabel.cpp
--- trunk/qgis/src/core/composer/qgscomposerlabel.cpp 2009-08-12 07:35:38 UTC (rev 11350)
+++ trunk/qgis/src/core/composer/qgscomposerlabel.cpp 2009-08-12 07:43:37 UTC (rev 11351)
@@ -61,29 +61,6 @@
void QgsComposerLabel::setText( const QString& text )
mText = text;
-#if 0
- //replace '$CURRENT_DATE<(FORMAT)>' with the current date
- //e.g. $CURRENT_DATE(d 'June' yyyy)
- mText = text;
- int currentDatePos = mText.indexOf( "$CURRENT_DATE" );
- if ( currentDatePos != -1 )
- //check if there is a bracket just after $CURRENT_DATE
- QString formatText;
- int openingBracketPos = mText.indexOf( "(", currentDatePos );
- int closingBracketPos = mText.indexOf( ")", openingBracketPos + 1 );
- if ( openingBracketPos != -1 && closingBracketPos != -1 && ( closingBracketPos - openingBracketPos ) > 1 )
- formatText = mText.mid( openingBracketPos + 1, closingBracketPos - openingBracketPos - 1 );
- mText.replace( currentDatePos, closingBracketPos - currentDatePos + 1, QDate::currentDate().toString( formatText ) );
- else //no bracket
- mText.replace( "$CURRENT_DATE", QDate::currentDate().toString() );
-#endif //0
QString QgsComposerLabel::displayText() const
