[QGIS Commit] r11392 - in trunk/qgis/src/app: . attributetable
svn_qgis at osgeo.org
Sat Aug 15 18:28:07 EDT 2009
Author: jef
Date: 2009-08-15 18:28:06 -0400 (Sat, 15 Aug 2009)
New Revision: 11392
trunk/qgis/src/app/attributetable/qgsattributetabledelegate.cpp
trunk/qgis/src/app/attributetable/qgsattributetabledelegate.h
trunk/qgis/src/app/attributetable/qgsattributetablefiltermodel.cpp
trunk/qgis/src/app/attributetable/qgsattributetablefiltermodel.h
trunk/qgis/src/app/attributetable/qgsattributetablememorymodel.h
trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp
trunk/qgis/src/app/attributetable/qgsattributetablemodel.h
trunk/qgis/src/app/qgsattributeeditor.cpp
trunk/qgis/src/app/qgsattributeeditor.h
attribute editor fixes:
- fix column misindexing in attribute table, if the geometry column is not last
- fix NULL handling (fixes #1876)
Modified: trunk/qgis/src/app/attributetable/qgsattributetabledelegate.cpp
--- trunk/qgis/src/app/attributetable/qgsattributetabledelegate.cpp 2009-08-15 21:01:59 UTC (rev 11391)
+++ trunk/qgis/src/app/attributetable/qgsattributetabledelegate.cpp 2009-08-15 22:28:06 UTC (rev 11392)
@@ -39,6 +39,20 @@
return NULL;
+int QgsAttributeTableDelegate::fieldIdx( const QModelIndex &index ) const
+ const QgsAttributeTableModel *tm = dynamic_cast<const QgsAttributeTableModel*>( index.model() );
+ if ( tm )
+ return tm->fieldIdx( index.column() );
+ const QgsAttributeTableFilterModel *fm = dynamic_cast<const QgsAttributeTableFilterModel*>( index.model() );
+ if ( fm )
+ return fm->tableModel()->fieldIdx( index.column() );
+ return -1;
QWidget *QgsAttributeTableDelegate::createEditor(
QWidget *parent,
const QStyleOptionViewItem &option,
@@ -48,7 +62,7 @@
if ( vl == NULL )
return NULL;
- QWidget *widget = QgsAttributeEditor::createAttributeEditor( parent, vl, index.column(), index.model()->data( index ) );
+ QWidget *widget = QgsAttributeEditor::createAttributeEditor( parent, vl, fieldIdx( index ), index.model()->data( index, Qt::EditRole ) );
widget->adjustSize();
QgsAttributeTableView *tv = dynamic_cast<QgsAttributeTableView *>( parent->parentWidget() );
@@ -65,12 +79,21 @@
return;
QVariant value;
- if ( !QgsAttributeEditor::retrieveValue( editor, vl, index.column(), value ) )
+ if ( !QgsAttributeEditor::retrieveValue( editor, vl, fieldIdx( index ), value ) )
return;
model->setData( index, value );
+void QgsAttributeTableDelegate::setEditorData( QWidget *editor, const QModelIndex &index ) const
+ QgsVectorLayer *vl = layer( index.model() );
+ if ( vl == NULL )
+ return;
+ QgsAttributeEditor::setValue( editor, vl, fieldIdx( index ), index.model()->data( index, Qt::EditRole ) );
void QgsAttributeTableDelegate::paint( QPainter * painter,
const QStyleOptionViewItem & option,
const QModelIndex & index ) const
Modified: trunk/qgis/src/app/attributetable/qgsattributetabledelegate.h
--- trunk/qgis/src/app/attributetable/qgsattributetabledelegate.h 2009-08-15 21:01:59 UTC (rev 11391)
+++ trunk/qgis/src/app/attributetable/qgsattributetabledelegate.h 2009-08-15 22:28:06 UTC (rev 11392)
@@ -31,6 +31,7 @@
Q_OBJECT;
QgsVectorLayer *layer( const QAbstractItemModel *model ) const;
+ int fieldIdx( const QModelIndex &index ) const;
public:
/** Constructor
@@ -52,13 +53,20 @@
const QModelIndex & index ) const;
- * Sets data from editor backk to model. Overloads default metod
+ * Sets data from editor back to model. Overloads default method
* @param editor editor which was created by create editor function in this class
* @param model model where data should be updated
* @param index index of field which is to be modified
void setModelData( QWidget *editor, QAbstractItemModel *model, const QModelIndex &index ) const;
+ * Sets data from model into the editor. Overloads default method
+ * @param editor editor which was created by create editor function in this class
+ * @param index index of field which is to be retrieved
+ void setEditorData( QWidget *editor, const QModelIndex &index ) const;
#endif //QGSATTRIBUTETABLEDELEGATE_H
Modified: trunk/qgis/src/app/attributetable/qgsattributetablefiltermodel.cpp
--- trunk/qgis/src/app/attributetable/qgsattributetablefiltermodel.cpp 2009-08-15 21:01:59 UTC (rev 11391)
+++ trunk/qgis/src/app/attributetable/qgsattributetablefiltermodel.cpp 2009-08-15 22:28:06 UTC (rev 11392)
@@ -23,10 +23,10 @@
void QgsAttributeTableFilterModel::sort( int column, Qt::SortOrder order )
- (( QgsAttributeTableModel * )sourceModel() )->sort( column, order );
+ tableModel()->sort( column, order );
-QgsAttributeTableFilterModel::QgsAttributeTableFilterModel( QgsVectorLayer* theLayer )
+QgsAttributeTableFilterModel::QgsAttributeTableFilterModel( QgsVectorLayer *theLayer )
mLayer = theLayer;
mHideUnselected = false;
@@ -36,21 +36,7 @@
bool QgsAttributeTableFilterModel::filterAcceptsRow( int sourceRow, const QModelIndex &sourceParent ) const
if ( mHideUnselected )
- // unreadable? yes, i agree :-)
- return mLayer->selectedFeaturesIds().contains((( QgsAttributeTableModel * )sourceModel() )->rowToId( sourceRow ) );
+ return mLayer->selectedFeaturesIds().contains( tableModel()->rowToId( sourceRow ) );
return true;
-QModelIndex QgsAttributeTableFilterModel::mapFromSource ( const QModelIndex& sourceIndex ) const
- return sourceIndex;
-QModelIndex QgsAttributeTableFilterModel::mapToSource ( const QModelIndex& filterIndex ) const
- return filterIndex;
Modified: trunk/qgis/src/app/attributetable/qgsattributetablefiltermodel.h
--- trunk/qgis/src/app/attributetable/qgsattributetablefiltermodel.h 2009-08-15 21:01:59 UTC (rev 11391)
+++ trunk/qgis/src/app/attributetable/qgsattributetablefiltermodel.h 2009-08-15 22:28:06 UTC (rev 11392)
@@ -23,6 +23,8 @@
//QGIS Includes
#include "qgsvectorlayer.h" //QgsAttributeList
+class QgsAttributeTableModel;
class QgsAttributeTableFilterModel: public QSortFilterProxyModel
public:
@@ -42,6 +44,7 @@
//QModelIndex mapFromSource ( const QModelIndex & sourceIndex ) const;
QgsVectorLayer *layer() const { return mLayer; }
+ QgsAttributeTableModel *tableModel() const { return reinterpret_cast<QgsAttributeTableModel*>( sourceModel() ); }
protected:
Modified: trunk/qgis/src/app/attributetable/qgsattributetablememorymodel.h
--- trunk/qgis/src/app/attributetable/qgsattributetablememorymodel.h 2009-08-15 21:01:59 UTC (rev 11391)
+++ trunk/qgis/src/app/attributetable/qgsattributetablememorymodel.h 2009-08-15 22:28:06 UTC (rev 11392)
@@ -28,7 +28,7 @@
#include "qgsattributetablemodel.h"
#include "qgsattributetableidcolumnpair.h"
-class QgsAttributeTableMemoryModel: public QgsAttributeTableModel
+class QgsAttributeTableMemoryModel : public QgsAttributeTableModel
Q_OBJECT;
Modified: trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp
--- trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp 2009-08-15 21:01:59 UTC (rev 11391)
+++ trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp 2009-08-15 22:28:06 UTC (rev 11392)
@@ -259,6 +259,11 @@
return mRowIdMap[id];
+int QgsAttributeTableModel::fieldIdx( int col ) const
+ return mAttributes[ col ];
int QgsAttributeTableModel::rowCount( const QModelIndex &parent ) const
return mFeatureCount;
@@ -364,15 +369,19 @@
if ( !mLastRow )
return QVariant( "ERROR" );
- QVariant& val = ( *mLastRow )[ mAttributes[index.column()] ];
+ QVariant &val = ( *mLastRow )[ mAttributes[index.column()] ];
if ( val.isNull() )
// if the value is NULL, show that in table, but don't show "NULL" text in editor
if ( role == Qt::EditRole )
- return QVariant();
+ return QVariant( fldType );
else
return QVariant( "NULL" );
// force also numeric data for EditRole to be strings
Modified: trunk/qgis/src/app/attributetable/qgsattributetablemodel.h
--- trunk/qgis/src/app/attributetable/qgsattributetablemodel.h 2009-08-15 21:01:59 UTC (rev 11391)
+++ trunk/qgis/src/app/attributetable/qgsattributetablemodel.h 2009-08-15 22:28:06 UTC (rev 11392)
@@ -100,6 +100,10 @@
int idToRow( const int id ) const;
+ * get field index from column
+ int fieldIdx( int col ) const;
* Maps row to feature id
* @param id row id
Modified: trunk/qgis/src/app/qgsattributeeditor.cpp
--- trunk/qgis/src/app/qgsattributeeditor.cpp 2009-08-15 21:01:59 UTC (rev 11391)
+++ trunk/qgis/src/app/qgsattributeeditor.cpp 2009-08-15 22:28:06 UTC (rev 11392)
@@ -74,10 +74,6 @@
for ( QList<QVariant>::iterator it = values.begin(); it != values.end(); it++ )
cb->addItem( it->toString() );
- int idx = cb->findText( value.toString() );
- if ( idx >= 0 )
- cb->setCurrentIndex( idx );
myWidget = cb;
break;
@@ -93,11 +89,7 @@
cb->addItem( *s_it );
- if ( idx >= 0 )
myWidget = cb;
break;
@@ -113,10 +105,6 @@
cb->addItem( it.key(), it.value() );
- int idx = cb->findData( value );
- if ( idx >= 0 )
myWidget = cb;
break;
@@ -151,10 +139,6 @@
cb->addItem( it.value(), it.key() );
- if ( idx >= 0 )
myWidget = cb;
break;
@@ -174,7 +158,6 @@
sb->setRange( min, max );
sb->setSingleStep( step );
- sb->setValue( value.toInt() );
myWidget = sb;
@@ -184,7 +167,6 @@
sl->setRange( min, max );
sl->setSingleStep( step );
- sl->setValue( value.toInt() );
myWidget = sl;
@@ -199,7 +181,6 @@
dsb->setRange( min, max );
dsb->setSingleStep( step );
- dsb->setValue( value.toDouble() );
myWidget = dsb;
break;
@@ -213,7 +194,7 @@
case QgsVectorLayer::Immutable:
default:
- QLineEdit *le = new QLineEdit( value.toString(), parent );
+ QLineEdit *le = new QLineEdit( parent );
if ( editType == QgsVectorLayer::Immutable )
@@ -249,7 +230,7 @@
case QgsVectorLayer::FileName:
- QLineEdit *le = new QLineEdit( value.toString() );
+ QLineEdit *le = new QLineEdit();
QPushButton *pb = new QPushButton( tr( "..." ) );
connect( pb, SIGNAL( clicked() ), new QgsAttributeEditor( pb ), SLOT( selectFileName() ) );
@@ -264,6 +245,8 @@
break;
+ setValue( myWidget, vl, idx, value );
return myWidget;
@@ -279,6 +262,10 @@
text = le->text();
modified = le->isModified();
+ if ( text == "NULL" )
+ text = QString::null;
QComboBox *cb = dynamic_cast<QComboBox *>( widget );
@@ -332,7 +319,7 @@
else if ( modified )
- value = QVariant( QString::null );
+ value = QVariant( theField.type() );
break;
@@ -347,7 +334,7 @@
break;
@@ -359,3 +346,93 @@
return modified;
+bool QgsAttributeEditor::setValue( QWidget *editor, QgsVectorLayer *vl, int idx, const QVariant &value )
+ QgsVectorLayer::EditType editType = vl->editType( idx );
+ const QgsField &field = vl->pendingFields()[idx];
+ QVariant::Type myFieldType = field.type();
+ switch ( editType )
+ case QgsVectorLayer::UniqueValues:
+ case QgsVectorLayer::Enumeration:
+ case QgsVectorLayer::ValueMap:
+ QComboBox *cb = dynamic_cast<QComboBox *>( editor );
+ if ( cb == NULL )
+ return false;
+ int idx = cb->findText( value.toString() );
+ if ( idx < 0 )
+ return false;
+ cb->setCurrentIndex( idx );
+ break;
+ case QgsVectorLayer::SliderRange:
+ case QgsVectorLayer::EditRange:
+ if ( myFieldType == QVariant::Int )
+ if ( editType == QgsVectorLayer::EditRange )
+ QSpinBox *sb = dynamic_cast<QSpinBox*>( editor );
+ if ( sb == NULL )
+ return false;
+ sb->setValue( value.toInt() );
+ else
+ QSlider *sl = dynamic_cast<QSlider *>( editor );
+ if ( sl == NULL )
+ return false;
+ sl->setValue( value.toInt() );
+ break;
+ else if ( myFieldType == QVariant::Double )
+ QDoubleSpinBox *dsb = dynamic_cast<QDoubleSpinBox*>( editor );
+ if ( dsb == NULL )
+ return false;
+ dsb->setValue( value.toDouble() );
+ // fall-through
+ case QgsVectorLayer::LineEdit:
+ case QgsVectorLayer::UniqueValuesEditable:
+ case QgsVectorLayer::Immutable:
+ default:
+ QLineEdit *le = dynamic_cast<QLineEdit*>( editor );
+ if ( le == NULL )
+ return false;
+ QString text;
+ if ( value.isNull() )
+ if ( myFieldType == QVariant::Int || myFieldType == QVariant::Double )
+ text = "";
+ else
+ text = "NULL";
+ else
+ text = value.toString();
+ le->setText( text );
+ break;
+ case QgsVectorLayer::FileName:
+ QLineEdit *le = editor->findChild<QLineEdit *>();
+ if ( le == NULL )
+ return false;
+ le->setText( value.toString() );
+ break;
+ return true;
Modified: trunk/qgis/src/app/qgsattributeeditor.h
--- trunk/qgis/src/app/qgsattributeeditor.h 2009-08-15 21:01:59 UTC (rev 11391)
+++ trunk/qgis/src/app/qgsattributeeditor.h 2009-08-15 22:28:06 UTC (rev 11392)
@@ -30,12 +30,12 @@
public:
QgsAttributeEditor( QObject *parent ) : QObject( parent ) {}
+ static QWidget *createAttributeEditor( QWidget *parent, QgsVectorLayer *vl, int idx, const QVariant &value );
+ static bool retrieveValue( QWidget *widget, QgsVectorLayer *vl, int idx, QVariant &value );
+ static bool setValue( QWidget *widget, QgsVectorLayer *vl, int idx, const QVariant &value );
public slots:
void selectFileName( void );
- static QWidget *createAttributeEditor( QWidget *parent, QgsVectorLayer *vl, int idx, const QVariant &value );
- static bool retrieveValue( QWidget *widget, QgsVectorLayer *vl, int idx, QVariant &value );
