[QGIS Commit] r11393 - trunk/qgis/doc
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Aug 15 22:38:23 EDT 2009
Author: kyngchaos
Date: 2009-08-15 22:38:22 -0400 (Sat, 15 Aug 2009)
New Revision: 11393
   trunk/qgis/doc/INSTALL.t2t
update install instructions for OSX
Modified: trunk/qgis/doc/INSTALL.t2t
--- trunk/qgis/doc/INSTALL.t2t	2009-08-15 22:28:06 UTC (rev 11392)
+++ trunk/qgis/doc/INSTALL.t2t	2009-08-16 02:38:22 UTC (rev 11393)
@@ -368,7 +368,7 @@
 == Install XCODE ==
 I recommend to get the latest xcode dmg from the Apple XDC Web site. Install
-XCODE after the ~941mb download is complete.
+XCODE after the ~1gb download is complete.
 /!\ Note: It may be that you need to create some symlinks after installing
 the XCODE SDK (in particular if you are using XCODE 2.5 on tiger):
@@ -384,26 +384,29 @@
 You need a minimum of Qt4.3.0. I suggest getting the latest (at time of writing).
-ftp://ftp.trolltech.com/qt/source/qt-mac-opensource-4.3.2.dmg
+ftp://ftp.trolltech.com/qt/source/
-If you want debug libs, Qt also provide a dmg with these:
+Mac versions are named as:
-ftp://ftp.trolltech.com/qt/source/qt-mac-opensource-4.3.2-debug-libs.dmg
+qt-mac-opensource-x.y.z.dmg
-I am going to proceed using only release libs at this stage as the download for
-the debug dmg is substantially bigger. If you plan to do any debugging though
-you probably want to get the debug libs dmg. Once downloaded open the dmg and
-run the installer. Note you need admin access to install.
+x, y, z being the major, minor and revision version.
+If you want debug frameworks, Qt also provide a dmg with these.  These are in
+addition to the non-debug frameworks.
+Once downloaded open the dmg and run the installer. Note you need admin
+privileges to install.
 After installing you need to make two small changes:
 First edit ``/Library/Frameworks/QtCore.framework/Headers/qconfig.h`` and
 change
-/!\ Note this doesnt seem to be needed since version 4.2.3
+/!\ Note: this isn't needed since version 4.2.3
 ``QT_EDITION_Unknown`` to ``QT_EDITION_OPENSOURCE``
@@ -415,6 +418,7 @@
 sudo ln -sf macx-g++ default
+/!\ Note: this doesn't seem to be needed since version 4.4.
 == Install development frameworks for QGIS dependencies ==
@@ -427,33 +431,37 @@
 Once downloaded, open and install the frameworks.
-William provides an additional installer package for Postgresql/PostGIS. Its
+William provides an additional installer package for Postgresql/PostGIS. It's
 available here:
 http://www.kyngchaos.com/wiki/software:postgres
+Also available is a GRASS application:
+http://www.kyngchaos.com/wiki/software:grass
 There are some additional dependencies that at the time of writing are not
-provided as frameworks so we will need to build these from source.
+provided as frameworks or installers so we will need to build these from source.
 === Additional Dependencies : GSL ===
-Retrieve the Gnu Scientific Library from
+Retrieve the current version of the Gnu Scientific Library from:
-curl -O ftp://ftp.gnu.org/gnu/gsl/gsl-1.8.tar.gz
+ftp://ftp.gnu.org/gnu/gsl/
-Then extract it and build it to a prefix of /usr/local:
+Then extract it and build it to a prefix of /usr/local.  Double-click the source
+tarball to unpack it, then cd to the source folder and:
-tar xvfz gsl-1.8.tar.gz
-cd gsl-1.8
-./configure --prefix=/usr/local
+./configure
 make
 sudo make install
-cd ..
 === Additional Dependencies : Expat ===
@@ -464,18 +472,17 @@
 http://sourceforge.net/project/showfiles.php?group_id=10127
+Double-click the source tarball to unpack, then cd to the source folder and:
-tar xvfz expat-2.0.0.tar.gz
-cd expat-2.0.0
+./configure
 make
 sudo make install
-cd ..
 === Additional Dependencies : SIP ===
-Make sure you have the latest Python fom
+Make sure you have the latest Python 2.5 fom
 http://www.python.org/download/mac/
@@ -489,15 +496,13 @@
 http://www.riverbankcomputing.com/software/sip/download
-Then extract and build it (this installs by default into the Python framework):
+Double-click the source tarball to unpack it, then cd to the source folder
+and (this installs by default into the Python framework):
-tar xvfz sip-<version number>.tar.gz
-cd sip-<version number>
 python configure.py
 make
 sudo make install
-cd ..
 __Leopard notes__
@@ -515,7 +520,7 @@
 explicitly to your path e.g.
-export PATH=/Library/Frameworks/Python.framework/Versions/Current/bin:$PATH$
+export PATH=/Library/Frameworks/Python.framework/Versions/Current/bin:$PATH
 Retrieve the python bindings toolkit for Qt from
@@ -524,17 +529,15 @@
 http://www.riverbankcomputing.com/software/pyqt/download
-tar xvfz PyQt-mac<version number here>
-cd PyQt-mac<version number here>
 export QTDIR=/Developer/Applications/Qt
 python configure.py
 yes
 make
 sudo make install
-cd ..
 __Leopard notes__
@@ -545,46 +548,49 @@
 python configure.py -d /Library/Python/2.5/site-packages -b /usr/local/bin
-There may be a problem with undefined symbols in QtOpenGL on Leopard.  Edit QtOpenGL/makefile and add ""-undefined dynamic_lookup"" to LFLAGS.
+If there is a problem with undefined symbols in QtOpenGL on Leopard, edit
+QtOpenGL/makefile and add ""-undefined dynamic_lookup"" to LFLAGS.
+Then make again.
 === Additional Dependencies : Bison ===
 __Leopard note:__ Leopard includes Bison 2.3, so this step can be skipped on Leopard.
 The version of bison available by default on Mac OSX is too old so you need to
-get a more recent one on your system. Download if from:
+get a more recent one on your system. Download at least version 2.3 from:
-curl -O http://ftp.gnu.org/gnu/bison/bison-2.3.tar.gz
+ftp.gnu.org/gnu/bison/
-Now build and install it to a prefix of /usr/local :
+Now build and install it to a prefix of /usr/local.Ê Double-click the source
-tar xvfz bison-2.3.tar.gz
-cd bison-2.3
 make
 sudo make install
-cd ..
 == Install CMAKE for OSX ==
-Get the latest release from here:
+Get the latest source release from here:
-http://www.cmake.org/HTML/Download.html
+http://www.cmake.org/cmake/resources/software.html
-At the time of writing the file I grabbed was:
+Binary installers are available for OS X, but they are not recommended
+(2.4 versions install in /usr instead of /usr/local, and 2.6 versions are a
+strange application).Ê Download the source.Ê Double-click the source tarball,
+then cd to the source folder and:
-curl -O http://www.cmake.org/files/v2.4/cmake-2.4.6-Darwin-universal.dmg
+./bootstrap --docdir=/share/doc/CMake --mandir=/share/man
+make
+sudo make install
-Once downloaded open the dmg and run the installer
 == Install subversion for OSX ==
 __Leopard note:__ Leopard includes SVN, so this step can be skipped on Leopard.
@@ -646,16 +652,11 @@
 svn co https://svn.osgeo.org/qgis/trunk/qgis qgis
-For svn 0.8 branch
+For a release branch version x.y.z:
-svn co https://svn.osgeo.org/qgis/branches/Release-0_8_0 qgis0.8
+svn co https://svn.qgis.org/qgis/branches/Release-x_y_z qgis-x.y.z
-For svn 0.9 branch
-svn co https://svn.qgis.org/qgis/branches/Release-0_9_0 qgis0.9
 The first time you check out QGIS sources you will probably get a message like
 this:
@@ -672,9 +673,16 @@
 I suggest you press 'p' to accept the key permanently.
 == Configure the build ==
+There are 2 different methods to build QGIS.Ê The traditional Cmake method,
+and the new Xcode project (starting with QGIS 1.1). The Xcode project has
+additional bundling steps, though some optional QGIS features are required due
+to limited conditional compilation.Ê The Cmake build handles optional features,
+and some bundling steps are available with scripts in the mac directory.
+=== Configure the Cmake build ===
 CMake supports out of source build so we will create a 'build' dir for the
 build process. By convention I build my software into a dir called 'apps' in
 my home directory. If you have the correct permissions you may want to build
@@ -703,9 +711,9 @@
 cmake -D CMAKE_INSTALL_PREFIX=${HOME}/apps/ \
-      -D GRASS_INCLUDE_DIR=/Applications/GRASS-6.3.app/Contents/MacOS/
+      -D GRASS_INCLUDE_DIR=/Applications/GRASS-6.4.app/Contents/MacOS/
       include \
-      -D GRASS_PREFIX=/Applications/GRASS-6.3.app/Contents/MacOS \
+      -D GRASS_PREFIX=/Applications/GRASS-6.4.app/Contents/MacOS \
       -D CMAKE_BUILD_TYPE=Release \
@@ -716,14 +724,30 @@
-  -D GRASS_INCLUDE_DIR=/user/local/grass-6.3.0/include \
-  -D GRASS_PREFIX=/user/local/grass-6.3.0 \
+  -D GRASS_INCLUDE_DIR=/user/local/grass-6.4.0/include \
+  -D GRASS_PREFIX=/user/local/grass-6.4.0 \
+=== Configure the Xcode build ===
+In the mac/xcode folder in the source, duplicate the 'qgis_user-template.xcconfig'
+file and name it 'qgis_user.xcconfig'.Ê A default build will use the KyngChaos
+frameworks, Postgres, GRASS 6.4, the python.org Python 2.5 and extra dependencies
+as described above, and compile for the build OSX version, so no extra configuration
+is necessary. If building on Leopard, you may want to use the system Python, which
+requires editing qgis_user.xcconfig.
+See the mac/xcode/readme.rtf for details, if you need to customize the build.
+The default build will also bundle the Qt frameworks, Postgres library, and
+other dependency libraries to create a self-contained package.Ê The KyngChaos
+frameworks and GRASS application are not bundled.
 == Building ==
+=== Building with Cmake ===
 Now we can start the build process:
@@ -733,9 +757,17 @@
 If all built without errors you can then install it:
-make install
+sudo make install
+=== Building with Xcode ===
+Open the xcode project file in Xcode.Ê Select 'Release' build configuration
+and select the 'Full Qgis' target, then build.
+The Qgis application will be found in the 'build/Release' folder in the xcode folder.
+Copy this to whereever you like.
 % ----Please leave this break marker here for clarity - it wont be rendered ---
More information about the QGIS-commit mailing list
