[QGIS Commit] r11413 - branches/symbology-ng-branch/src/core/pal
svn_qgis at osgeo.org
Mon Aug 17 15:25:52 EDT 2009
Author: wonder
Date: 2009-08-17 15:25:51 -0400 (Mon, 17 Aug 2009)
New Revision: 11413
branches/symbology-ng-branch/src/core/pal/pal.cpp
branches/symbology-ng-branch/src/core/pal/pointset.cpp
branches/symbology-ng-branch/src/core/pal/pointset.h
pal: ditched code for clipping of linestrings and polygons to current extent. Reasons for doing this:
1. the code was buggy, long and hard to comprehend
2. clipping should be done during the registration to honour layer settings (e.g. one label per feature)
3. clipping can be implemented easily as an intersection of feature with bounding box using GEOS
Modified: branches/symbology-ng-branch/src/core/pal/pal.cpp
--- branches/symbology-ng-branch/src/core/pal/pal.cpp 2009-08-17 19:15:33 UTC (rev 11412)
+++ branches/symbology-ng-branch/src/core/pal/pal.cpp 2009-08-17 19:25:51 UTC (rev 11413)
@@ -219,10 +219,8 @@
bool extractFeatCallback( FeaturePart *ft_ptr, void *ctx )
+ double amin[2], amax[2];
- double min[2];
- double max[2];
FeatCallBackCtx *context = ( FeatCallBackCtx* ) ctx;
#ifdef _EXPORT_MAP_
@@ -238,146 +236,63 @@
// all feature which are obstacle will be inserted into obstacles
if ( context->layer->obstacle )
- ft_ptr->getBoundingBox(min, max);
- context->obstacles->Insert( min, max, ft_ptr );
+ ft_ptr->getBoundingBox(amin, amax);
+ context->obstacles->Insert( amin, amax, ft_ptr );
+ // first do some checks whether to extract candidates or not
// feature has to be labeled ?
- if ( context->layer->toLabel && context->layer->isScaleValid( context->scale ) )
- // is the feature well defined ? // TODO Check epsilon
- if ( ft_ptr->getLabelWidth() > 0.0000001 && ft_ptr->getLabelHeight() > 0.0000001 )
+ if ( !context->layer->toLabel )
+ return true;
- int i;
- // Hole of the feature are obstacles
- for ( i = 0;i < ft_ptr->getNumSelfObstacles();i++ )
- ft_ptr->getSelfObstacle(i)->getBoundingBox(min, max);
- context->obstacles->Insert( min, max, ft_ptr->getSelfObstacle(i) );
+ // are we in a valid scale range for the layer?
+ if ( !context->layer->isScaleValid( context->scale ) )
+ return true;
- if ( !ft_ptr->getSelfObstacle(i)->getHoleOf() )
- std::cout << "ERROR: SHOULD HAVE A PARENT!!!!!" << std::endl;
+ // is the feature well defined ? // TODO Check epsilon
+ if ( ft_ptr->getLabelWidth() < 0.0000001 || ft_ptr->getLabelHeight() < 0.0000001 )
+ return true;
+ // OK, everything's fine, let's process the feature part
- LinkedList<Feats*> *feats = new LinkedList<Feats*> ( ptrFeatsCompare );
+ // Holes of the feature are obstacles
+ for ( int i = 0;i < ft_ptr->getNumSelfObstacles();i++ )
+ ft_ptr->getSelfObstacle(i)->getBoundingBox(amin, amax);
+ context->obstacles->Insert( amin, amax, ft_ptr->getSelfObstacle(i) );
- QTime t;
- t.start();
+ if ( !ft_ptr->getSelfObstacle(i)->getHoleOf() )
+ std::cout << "ERROR: SHOULD HAVE A PARENT!!!!!" << std::endl;
- if (( ft_ptr->getGeosType() == GEOS_LINESTRING )
- || ft_ptr->getGeosType() == GEOS_POLYGON )
- double bbx[4], bby[4];
- bbx[0] = context->bbox_min[0]; bbx[1] = context->bbox_max[0];
- bbx[2] = context->bbox_max[0]; bbx[3] = context->bbox_min[0];
- bby[0] = context->bbox_min[1]; bby[1] = context->bbox_min[1];
- bby[2] = context->bbox_max[1]; bby[3] = context->bbox_max[1];
- LinkedList<PointSet*> *shapes = new LinkedList<PointSet*> ( ptrPSetCompare );
- bool outside, inside;
- PointSet *shape = ft_ptr->createProblemSpecificPointSet( bbx, bby, &outside, &inside );
- if ( inside )
- // no extra treatment required
- shapes->push_back( shape );
- else
- // feature isn't completly in the math
- if ( ft_ptr->getGeosType() == GEOS_LINESTRING )
- PointSet::reduceLine( shape, shapes, bbx, bby );
- else
- PointSet::reducePolygon( shape, shapes, bbx, bby );
- while ( shapes->size() > 0 )
- shape = shapes->pop_front();
- Feats *ft = new Feats();
- ft->feature = ft_ptr;
- ft->shape = shape;
- feats->push_back( ft );
+ // generate candidates for the feature part
+ LabelPosition** lPos;
+ int nblp = ft_ptr->setPosition( context->scale, &lPos, context->bbox_min, context->bbox_max, ft_ptr, context->candidates
#ifdef _EXPORT_MAP_
- if ( !svged )
- toSVGPath( shape->nbPoints, shape->type, shape->x, shape->y,
- dpi , context->scale,
- convert2pt( context->bbox_min[0], context->scale, dpi ),
- convert2pt( context->bbox_max[1], context->scale, dpi ),
- context->layer->name, ft_ptr->uid, *context->svgmap );
-#endif
- delete shapes;
- else
- // Feat is a point
- ft->shape = NULL;
- // for earch feature part extracted : generate candidates
- while ( feats->size() > 0 )
- Feats *ft = feats->pop_front();
-#ifdef _DEBUG_
- std::cout << "Compute candidates for feat " << ft->feature->layer->name << "/" << ft->feature->uid << std::endl;
-#endif
- ft->nblp = ft->feature->setPosition( context->scale, & ( ft->lPos ), context->bbox_min, context->bbox_max, ft->shape, context->candidates
-#ifdef _EXPORT_MAP_
, *context->svgmap
#endif
- delete ft->shape;
- ft->shape = NULL;
- if ( ft->nblp > 0 )
- // valid features are added to fFeats
- ft->priority = context->priority;
- context->fFeats->push_back( ft );
-#ifdef _DEBUG_
- std::cout << ft->nblp << " labelPositions for feature : " << ft->feature->layer->name << "/" << ft->feature->uid << std::endl;
-#endif
- else
- // Others are deleted
-#ifdef _VERBOSE_
- std::cout << "Unable to generate labelPosition for feature : " << ft->feature->layer->name << "/" << ft->feature->uid << std::endl;
-#endif
- delete[] ft->lPos;
- delete ft;
- delete feats;
- else // check labelsize
-#ifdef _VERBOSE_
- std::cerr << "Feature " << ft_ptr->layer->name << "/" << ft_ptr->uid << " is skipped (label size = 0)" << std::endl;
-#endif
+ if ( nblp > 0 )
+ // valid features are added to fFeats
+ Feats *ft = new Feats();
+ ft->feature = ft_ptr;
+ ft->shape = NULL;
+ ft->nblp = nblp;
+ ft->lPos = lPos;
+ ft->priority = context->priority;
+ context->fFeats->push_back( ft );
+ else
+ // Others are deleted
+ delete[] lPos;
return true;
Modified: branches/symbology-ng-branch/src/core/pal/pointset.cpp
--- branches/symbology-ng-branch/src/core/pal/pointset.cpp 2009-08-17 19:15:33 UTC (rev 11412)
+++ branches/symbology-ng-branch/src/core/pal/pointset.cpp 2009-08-17 19:25:51 UTC (rev 11413)
@@ -55,7 +55,6 @@
nbPoints = cHullSize = 0;
x = NULL;
y = NULL;
- status = NULL;
cHull = NULL;
type = -1;
@@ -73,7 +72,6 @@
this->y[i] = y[i];
type = GEOS_POLYGON;
- status = NULL;
cHull = NULL;
@@ -85,7 +83,6 @@
this->x[0] = x;
this->y[0] = y;
- status = NULL;
cHull = NULL;
parent = NULL;
holeOf = NULL;
@@ -101,18 +98,11 @@
x = new double[nbPoints];
y = new double[nbPoints];
- if ( ps.status )
- status = new int[nbPoints];
- else
- status = NULL;
for ( i = 0;i < nbPoints;i++ )
x[i] = ps.x[i];
y[i] = ps.y[i];
- if ( status )
- status[i] = ps.status[i];
if ( ps.cHull )
@@ -138,8 +128,6 @@
deleteCoords();
- if ( status )
- delete[] status;
if ( cHull )
delete[] cHull;
@@ -155,709 +143,8 @@
- int PointSet::getPath( int start, int stop, int *path_val )
- int nbPt = 0;
- int i;
-#ifdef _DEBUG_FULL_
- std::cout << "start: " << start << std::endl;
- std::cout << "stop: " << stop << std::endl;
- std::cout << "nbPoints: " << nbPoints << std::endl;
-#endif
- for ( i = start; i != stop; i = ( i + 1 ) % nbPoints, nbPt++ )
- if ( status[i] < 10 && status[i] != *path_val )
- *path_val = 0;
- std::cout << "new nbPoints: " << nbPt << std::endl;
-#endif
- return nbPt;
- PointSet * PointSet::extractPath( int path, int nbPtPath, int nbBboxPt, double bbx[4], double bby[4], Crossing *start, Crossing *stop, int startPt )
- if ( path == -1 || path == 0 )
- int k, j, l;
- PointSet *newShape = new PointSet();
- newShape->nbPoints = nbPtPath + nbBboxPt + 2;
- newShape->x = new double[newShape->nbPoints];
- newShape->y = new double[newShape->nbPoints];
- newShape->status = new int[newShape->nbPoints];
- newShape->type = GEOS_POLYGON;
- k = 0;
- std::cout << "Keep # ot: " << newShape->nbPoints << " :: " << path << std::endl;
- std::cout << "path point:" << nbPtPath << std::endl;
-#endif
- // start => b
- // stop => a
- newShape->xmin = DBL_MAX;
- newShape->xmax = -DBL_MAX;
- newShape->ymin = DBL_MAX;
- newShape->ymax = -DBL_MAX;
- for ( k = 0, j = startPt; k < nbPtPath; j = ( j + 1 ) % nbPoints, k++ )
- newShape->x[k] = x[j];
- newShape->y[k] = y[j];
- newShape->status[k] = status[j];
- std::cout << " " << x[j] << ";" << y[j] << std::endl;
-#endif
- newShape->xmin = ( newShape->xmin < x[j] ? newShape->xmin : x[j] );
- newShape->xmax = ( newShape->xmax > x[j] ? newShape->xmax : x[j] );
- newShape->ymin = ( newShape->ymin < y[j] ? newShape->ymin : y[j] );
- newShape->ymax = ( newShape->ymax > y[j] ? newShape->ymax : y[j] );
- if (start->pt != stop->pt){
- #ifdef _DEBUG_
- #endif
- k++;
- std::cout << "pta:" << std::endl;
-#endif
- newShape->x[k] = stop->x;
- newShape->y[k] = stop->y;
- newShape->xmin = ( newShape->xmin < stop->x ? newShape->xmin : stop->x );
- newShape->xmax = ( newShape->xmax > stop->x ? newShape->xmax : stop->x );
- newShape->ymin = ( newShape->ymin < stop->y ? newShape->ymin : stop->y );
- newShape->ymax = ( newShape->ymax > stop->y ? newShape->ymax : stop->y );
- if ( stop->way == -1 )
- newShape->status[k] = stop->nextCorner + 10;
- else
- newShape->status[k] = (( stop->nextCorner + 3 ) % 4 ) + 10;
- k++;
- std::cout << " " << stop->x << ";" << stop->y << std::endl;
- std::cout << "corner:" << std::endl;
-#endif
- for ( j = 0, l = stop->nextCorner;j < nbBboxPt;j++, l = ( l + stop->way + 4 ) % 4, k++ )
- newShape->x[k] = bbx[l];
- newShape->y[k] = bby[l];
- newShape->status[k] = 15;
- std::cout << " " << bbx[l] << ";" << bby[l] << std::endl;
-#endif
- newShape->xmin = ( newShape->xmin < bbx[l] ? newShape->xmin : bbx[l] );
- newShape->xmax = ( newShape->xmax > bbx[l] ? newShape->xmax : bbx[l] );
- newShape->ymin = ( newShape->ymin < bby[l] ? newShape->ymin : bby[l] );
- newShape->ymax = ( newShape->ymax > bby[l] ? newShape->ymax : bby[l] );
- newShape->x[k] = start->x;
- newShape->y[k] = start->y;
- newShape->xmin = ( newShape->xmin < start->x ? newShape->xmin : start->x );
- newShape->xmax = ( newShape->xmax > start->x ? newShape->xmax : start->x );
- newShape->ymin = ( newShape->ymin < start->y ? newShape->ymin : start->y );
- newShape->ymax = ( newShape->ymax > start->y ? newShape->ymax : start->y );
- if ( start->way == -1 )
- newShape->status[k] = start->nextCorner + 10;
- else
- newShape->status[k] = (( start->nextCorner + 3 ) % 4 ) + 10;
- std::cout << "ptb:" << std::endl;
- std::cout << " " << start->x << ";" << start->y << std::endl;
- std::cout << "k: " << k << " nbPoints: " << newShape->nbPoints << std::endl;
-#endif
- return newShape;
- else
- return NULL;
- void PointSet::reduceLine( PointSet *line,
- LinkedList<PointSet*> *shapes_final,
- double bbx[4], double bby[4] )
-#ifdef _DEBUG_
- std::cout << "reduceLine" << std::endl;
-#endif
- int i, j;
- int ba, bb;
- Crossing *crossing;
- double crossingX, crossingY;
- LinkedList<Crossing*> *crossings = new LinkedList<Crossing*> ( ptrCrossingCompare );
- int nbPoints = line->nbPoints;
- double *x = line->x;
- double *y = line->y;
- int *status = line->status;
- std::cout << "Coord:" << std::endl;
- for ( i = 0;i < nbPoints;i++ )
- std::cout << x[i] << ";" << y[i] << std::endl;
-#endif
- for ( i = 0, j = i + 1;i < nbPoints - 1;i++, j++ )
- for ( ba = 0;ba < 4;ba++ ) // for each bbox segement
- bb = ( ba + 1 ) % 4;
- std::cout << "Test: " << i << "->" << j << " and " << ba << "-->" << bb << std::endl;
-#endif
- if ( computeSegIntersection( x[i], y[i], x[j], y[j],
- bbx[ba], bby[ba], bbx[bb], bby[bb],
- &crossingX, &crossingY ) ) // seg[i->j] crossing bbox[ba->bb]
- crossing = new Crossing();
- crossing->pt = i;
- crossing->x = crossingX; // cross coordinate
- crossing->y = crossingY;
- std::cout << "Crossing: " << std::endl;
- std::cout << " cross point: " << crossingX << ";" << crossingY << std::endl;
- std::cout << " pt: " << i << " (" << status[i] << ")" << std::endl;
-#endif
- crossings->push_back( crossing );
- if ( crossings->size() > 0 )
- int start, stop;
- double startX, startY;
- double stopX, stopY;
- bool seg_complete = false;
- startX = x[0];
- startY = y[0];
- start = 1;
- while ( crossings->size() > 0 )
- crossing = crossings->pop_front();
- // TODO
- if ( status[crossing->pt] == -1 ) // inside
- stop = crossing->pt;
- stopX = crossing->x;
- stopY = crossing->y;
- PointSet *new_line = new PointSet();
- new_line->nbPoints = stop - start + 3;
- new_line->type = GEOS_LINESTRING;
- new_line->x = new double [new_line->nbPoints];
- new_line->y = new double [new_line->nbPoints];
- new_line->x[0] = startX;
- new_line->y[0] = startY;
- new_line->xmin = new_line->x[0];
- new_line->xmax = new_line->x[0];
- new_line->ymin = new_line->y[0];
- new_line->ymax = new_line->y[0];
- for ( j = start, i = 1;j <= stop;j++, i++ )
- new_line->x[i] = x[j];
- new_line->y[i] = y[j];
- new_line->xmin = ( new_line->xmin < x[j] ? new_line->xmin : x[j] );
- new_line->xmax = ( new_line->xmax > x[j] ? new_line->xmax : x[j] );
- new_line->ymin = ( new_line->ymin < y[j] ? new_line->ymin : y[j] );
- new_line->ymax = ( new_line->ymax > y[j] ? new_line->ymax : y[j] );
- new_line->x[new_line->nbPoints-1] = stopX;
- new_line->y[new_line->nbPoints-1] = stopY;
- new_line->xmin = ( new_line->xmin < stopX ? new_line->xmin : stopX );
- new_line->xmax = ( new_line->xmax > stopX ? new_line->xmax : stopX );
- new_line->ymin = ( new_line->ymin < stopY ? new_line->ymin : stopY );
- new_line->ymax = ( new_line->ymax > stopY ? new_line->ymax : stopY );
- shapes_final->push_back( new_line );
- seg_complete = true;
- else
- start = crossing->pt + 1;
- startX = crossing->x;
- startY = crossing->y;
- seg_complete = false;
- delete crossing;
- if ( !seg_complete )
- PointSet * new_line = new PointSet();
- new_line->nbPoints = nbPoints - start + 1;
- new_line->x = new double[new_line->nbPoints];
- new_line->y = new double[new_line->nbPoints];
- new_line->xmin = startX;
- new_line->xmax = startX;
- new_line->ymin = startY;
- new_line->ymax = startY;
- for ( j = start, i = 1;j < nbPoints;j++, i++ )
- delete line;
- else
- // line is out
- std::cout << "Line is completely outside" << std::endl;
-#endif
- delete line;
- delete crossings;
- * \brief takes shapes from shapes_toProcess, compute intersection with bbox
- * and puts new shapes into shapes_final
- void PointSet::reducePolygon( PointSet *shape_toProcess, LinkedList<PointSet*> *shapes_final, double bbx[4], double bby[4] )
-//#define _DEBUG_
-//#define _DEBUG_FULL_
-#ifdef _DEBUG_
- std::cout << "reducePolygon" << std::endl;
-#endif
- int i, j;
- int nbCrossingIter = 0;
- LinkedList<PointSet*> *shapes_toProcess = new LinkedList<PointSet*> ( ptrPSetCompare );
- shapes_toProcess->push_back( shape_toProcess );
- // only keep inside bbox part of feature
- PointSet *shape;
- while ( shapes_toProcess->size() > 0 ) // foreach feature in toProcess
- nbCrossingIter++;
- int ba, bb;
- int k;
- shape = shapes_toProcess->pop_front();
- std::cout << "ShapeToReduce:" << std::endl;
-#endif
- // search point where polygon and bbox cross
- for ( i = 0;i < shape->nbPoints;i++ ) // foreach polygon segment
- std::cout << shape->x[i] << ";" << shape->y[i] << std::endl;
-#endif
- j = ( i + 1 ) % shape->nbPoints;
- if ( computeSegIntersection( shape->x[i], shape->y[i], shape->x[j], shape->y[j],
- if ( vabs( cross_product( bbx[ba], bby[ba], bbx[bb], bby[bb], shape->x[i], shape->y[i] ) ) > 0.00001 )
- // perhaps shape had previuosly been splitted
- // => new points generated by this operation are on the bbox border
- // => avoid to consider this cross as valid ('status' for these new points are == bboxSegNumber + 10 and 15 for bbox corner
- if ( shape->status[i] != ba + 10 && shape->status[j] != ba + 10
- && shape->status[i] != 15 && shape->status[j] != 15 )
- crossing->pt = i;
- crossing->seg = ba; // wich bbox edge ? 0=south, 1 = east, 2 = west, 3=west
- // cross->nextCorner denote on which bbox corner we fall first when following bbox inside the polygon
- if ( cross_product( shape->x[crossing->pt], shape->y[crossing->pt],
- shape->x[( crossing->pt+1 ) %shape->nbPoints],
- shape->y[( crossing->pt+1 ) %shape->nbPoints],
- bbx[ba], bby[ba] ) > 0 )
- crossing->nextCorner = ba; // next corner is ba
- crossing->way = -1; // have to go counter-clockwise
- else
- crossing->nextCorner = bb; // next corner is bb
- crossing->way = 1; // go clockwise
- //break;
- i = 0;
- int crossingTabSize = crossings->size();
- Crossing ** crossingTab = new Crossing*[crossingTabSize];
- // put crosses in crossTab
- crossingTab[i] = crossing;
- i++;
- if ( crossingTabSize > 1 )
- double initialDist;
- double nextX;
- double nextY;
- double startX;
- double startY;
- initialDist = 0;
- // sort cross points, order counterclockwise by following bbox from down-left corner
- for ( k = 0;k < 4;k++ )
- startX = bbx[k];
- startY = bby[k];
- nextX = bbx[( k+1 ) %4];
- nextY = bby[( k+1 ) %4];
- for ( j = 0;j < crossingTabSize;j++ )
- // if the crossing point is colinear with bbox seg
- if ( crossingTab[j]->seg == k )
- crossingTab[j]->d = initialDist + dist_euc2d_sq( startX, startY, crossingTab[j]->x, crossingTab[j]->y );
- initialDist += dist_euc2d_sq( startX, startY, nextX, nextY );
- sort(( void** ) crossingTab, crossingTabSize, crossingDist );
- // crossing are sorted
- for ( i = 0;i < crossingTabSize;i++ )
- std::cout << "Crossing # " << i << ":" << std::endl;
- std::cout << " pt: " << crossingTab[i]->pt << std::endl;
- std::cout << " d: " << crossingTab[i]->d << std::endl;
- std::cout << " (x,y): (" << crossingTab[i]->x << "," << crossingTab[i]->y << ")" << std::endl;
- std::cout << " next corner: " << crossingTab[i]->nextCorner << std::endl;
- std::cout << " way: " << crossingTab[i]->way << std::endl;
- std::cout << std::endl;
-#endif
- // select tros crosses
- Crossing *a = crossingTab[0];
- Crossing *b = crossingTab[( a->way + crossingTabSize ) %crossingTabSize];
- if ( vabs( a->x - b->x ) > 0.00001 || vabs( a->y - b->y ) > 0.00001 )
- std::cout << "crossing: " << a->x << ";" << a->y << std::endl;
- std::cout << "d: " << a->d << std::endl;
- std::cout << "a: 0 " << " b: " << ( a->way + crossingTabSize ) % crossingTabSize << std::endl;
-#endif
- int cornerA = a->nextCorner;
- j = 1;
- while ( cornerA != b->nextCorner )
- j++;
- cornerA = ( cornerA + a->way + 4 ) % 4;
- if ( j == 4 )
- if ( isSegIntersects( a->x, a->y,
- bbx[a->nextCorner], bby[a->nextCorner],
- shape->x[b->pt], shape->y[b->pt],
- shape->x[( b->pt + 1 ) %shape->nbPoints], shape->y[( b->pt + 1 ) %shape->nbPoints] ) )
- j = 0;
- int nbBboxPoint = j;
- int nbPtPathA = 0;
- int nbPtPathB = 0;
-#endif
- int path_a;
- int path_b;
- if ( shape->status[a->pt] == -1 ) // ok
- path_a = -1; // a is inside so...
- path_b = 1; // b is outside
- else if ( shape->status[b->pt] == -1 ) // ok
- path_a = 1;
- path_b = -1;
- else if ( shape->status[a->pt] == 1 && shape->status[b->pt] == 1 )
- path_a = -1;
- path_b = -1;
- else if ( shape->status[a->pt] == 1 )
- path_a = 1;
- path_b = -1;
- else if ( shape->status[b->pt] == 1 )
- path_a = -1;
- path_b = 1;
- else
- std::cout << "OULALA C EST UN PROBLEMEM CA!!!!!!!!!!!!!!!!!!!!!!!!!!" << std::endl;
- path_a = 0;
- path_b = 0;
- std::cout << "Path_a: " << path_a << std::endl;
- std::cout << "Path_b: " << path_b << std::endl;
-#endif
- nbPtPathA = shape->getPath(( b->pt + 1 ) % shape->nbPoints,
- a->pt,
- &path_a );
- nbPtPathB = shape->getPath(( a->pt + 1 ) % shape->nbPoints,
- ( b->pt + 1 ) % shape->nbPoints,
- &path_b );
- if ( a->pt != b->pt )
- nbPtPathA++;
-#endif
- PointSet *newShape = NULL;
- Crossing *tmp;
- if (( a->pt == b->pt ) && ( a->way == 1 ) )
- tmp = a;
- a = b;
- b = tmp;
- // split shape into two new shape
- newShape = shape->extractPath( path_a, nbPtPathA, nbBboxPoint, bbx, bby, b, a, ( b->pt + 1 ) % shape->nbPoints );
- if ( newShape )
- if ( path_a == -1 ) // new shape inside => push into shapes_final
- shapes_final->push_back( newShape );
- else // to drop or to resplit...
- shapes_toProcess->push_back( newShape );
- newShape = shape->extractPath( path_b, nbPtPathB, nbBboxPoint, bbx, bby, a, b, ( a->pt + 1 ) % shape->nbPoints );
- if ( newShape )
- if ( path_b == -1 )
- else
- delete shape;
- else
- if ( vabs( a->x - shape->x[a->pt] ) < 0.00001 && vabs( a->y - shape->y[a->pt] ) < 0.00001 )
- shape->status[a->pt] = a->seg + 10;
- if ( vabs( a->x - shape->x[( a->pt+1 ) %shape->nbPoints] ) < 0.00001 && vabs( a->y - shape->y[( a->pt+1 ) %shape->nbPoints] ) < 0.00001 )
- if ( vabs( a->x - shape->x[b->pt] ) < 0.00001 && vabs( a->y - shape->y[b->pt] ) < 0.00001 )
- if ( vabs( a->x - shape->x[( b->pt+1 ) %shape->nbPoints] ) < 0.00001 && vabs( a->y - shape->y[( b->pt+1 ) %shape->nbPoints] ) < 0.00001 )
- shapes_toProcess->push_back( shape );
- else if ( nbCrossingIter == 1 || crossingTabSize == 1 ) // First shape dont cross the bbox => outside or bbox is inside shape
- bool check = false, ok = false;
- if ( crossingTabSize == 1 )
- std::cout << "WARN : one crossing !!!!! " << std::endl;
- bool in = true;
- bool out = true;
- std::cout << shape->x[i] << ";" << shape->y[i] << ";" << shape->status[i] << std::endl;
-#endif
- if ( shape->status[i] == -1 )
- out = false;
- else if ( shape->status[i] == 1 )
- in = false;
- if ( in )
- // shape is totally inside
- shapes_final->push_back( shape );
- ok = true;
- else
- check = true;
- else
- check = true;
- if ( check && isPointInPolygon( shape->nbPoints,
- shape->x, shape->y,
- ( bbx[0] + bbx[2] ) / 2,
- ( bby[0] + bby[2] ) / 2 ) )
- // bbox is inside the shape => reduce shape to bbox
- delete[] shape->status;
- delete[] shape->x;
- delete[] shape->y;
- shape->status = new int[4];
- shape->x = new double[4];
- shape->y = new double[4];
- shape->nbPoints = 4;
- for ( i = 0;i < 4;i++ )
- shape->status[i] = 0;
- shape->x[i] = bbx[i];
- shape->y[i] = bby[i];
- shapes_final->push_back( shape ); // keep the bbox as shape
- else if ( ok == false )
- delete shape;
- else
- int stat = -1;
- if ( shape->status[i] == 1 )
- stat = 1;
- break;
- if ( stat > 0 )
- delete shape;
- else
- delete crossingTab[i];
- delete[] crossingTab;
- delete shapes_toProcess;
- delete crossings;
-//#undef _DEBUG_
-//#undef _DEBUG_FULL_
PointSet* PointSet::extractShape( int nbPtSh, int imin, int imax, int fps, int fpe, double fptx, double fpty )
@@ -871,7 +158,6 @@
- newShape->status = NULL;
#ifdef _DEBUG_FULL_
std::cout << "New shape: ";
#endif
@@ -1268,14 +554,12 @@
- PointSet * PointSet::createProblemSpecificPointSet( double bbx[4], double bby[4], bool *outside, bool *inside )
+ PointSet* PointSet::createProblemSpecificPointSet( double bbmin[2], double bbmax[2], bool *inside )
- int i;
#ifdef _DEBUG_FULL_
std::cout << "CreateProblemSpecific:" << std::endl;
#endif
PointSet *shape = new PointSet();
- shape->status = new int[nbPoints];
shape->x = new double[nbPoints];
shape->y = new double[nbPoints];
shape->nbPoints = nbPoints;
@@ -1286,79 +570,16 @@
shape->ymin = ymin;
shape->ymax = ymax;
- *outside = true;
*inside = true;
- // Build PointSet from geom => (x,y) coord, status[i] -> -1 inside, 1 outside , 0 on border
- double epsilon = 0.000001;
+ for ( int i = 0;i < nbPoints;i++ )
shape->x[i] = this->x[i];
shape->y[i] = this->y[i];
- double cp0 = cross_product( bbx[0], bby[0], bbx[1], bby[1],
- shape->x[i], shape->y[i] );
- double cp1 = cross_product( bbx[1], bby[1], bbx[2], bby[2],
- double cp2 = cross_product( bbx[2], bby[2], bbx[3], bby[3],
- double cp3 = cross_product( bbx[3], bby[3], bbx[0], bby[0],
- if ( cp0 > epsilon && cp1 > epsilon && cp2 > epsilon && cp3 > epsilon )
- shape->status[i] = -1; // point is inside the map extent
- *outside = false;
- else if ( vabs( cp0 ) < epsilon && cp1 > epsilon && cp2 > epsilon && cp3 > epsilon )
- shape->status[i] = 10; // Point is on the bottom border
- *outside = false;
- else if ( cp0 > epsilon && vabs( cp1 ) < epsilon && cp2 > epsilon && cp3 > epsilon )
- shape->status[i] = 11; // point is on the right border
- *outside = false;
- else if ( cp0 > epsilon && cp1 > epsilon && vabs( cp2 ) < epsilon && cp3 > epsilon )
- shape->status[i] = 12; // point is on the top border
- *outside = false;
- else if ( cp0 > epsilon && cp1 > epsilon && cp2 > epsilon && vabs( cp3 ) < epsilon )
- shape->status[i] = 13; // point is on the left border
- *outside = false;
- else if ( vabs( cp0 ) < epsilon && vabs( cp1 ) < epsilon && cp2 > epsilon && cp3 > epsilon )
- shape->status[i] = 15; // point is on the bottom right corner
- *outside = false;
- else if ( cp0 > epsilon && vabs( cp1 ) < epsilon && vabs( cp2 ) < epsilon && cp3 > epsilon )
- shape->status[i] = 15; // point is on the top right corner
- *outside = false;
- else if ( cp0 > epsilon && cp1 > epsilon && vabs( cp2 ) < epsilon && vabs( cp3 ) < epsilon )
- shape->status[i] = 15; // point is on the top left corner
- *outside = false;
- else if ( vabs( cp0 ) < epsilon && cp1 > epsilon && cp2 > epsilon && vabs( cp3 ) < epsilon )
- shape->status[i] = 15; // point is on the bottom left corner
- *outside = false;
- else
- shape->status[i] = 1; // point is not in the map extent
+ // check whether it's not outside
+ if (x[i] < bbmin[0] || x[i] > bbmax[0] || y[i] < bbmin[1] || y[i] > bbmax[1])
*inside = false;
- std::cout << shape->x[i] << ";" << shape->y[i] << ";" << shape->status[i] << ";" << cp0 << ";" << cp1 << ";" << cp2 << ";" << cp3 << std::endl;
-#endif
shape->holeOf = NULL;
Modified: branches/symbology-ng-branch/src/core/pal/pointset.h
--- branches/symbology-ng-branch/src/core/pal/pointset.h 2009-08-17 19:15:33 UTC (rev 11412)
+++ branches/symbology-ng-branch/src/core/pal/pointset.h 2009-08-17 19:25:51 UTC (rev 11413)
@@ -102,7 +102,6 @@
double *x;
double *y; // points order is counterclockwise
- int *status; // -1 means inside the bbox, +1 means outside and 0 is either in either out
int *cHull;
int cHullSize;
@@ -127,33 +126,13 @@
PointSet( int nbPoints, double *x, double *y );
virtual ~PointSet();
- int getPath( int start, int stop, int *path_val );
- PointSet *extractPath( int path, int nbPtPath, int nbBboxPt, double bbx[4], double bby[4], Crossing *start, Crossing *stop, int startPt );
PointSet* extractShape( int nbPtSh, int imin, int imax, int fps, int fpe, double fptx, double fpty );
- PointSet *createProblemSpecificPointSet( double bbx[4], double bby[4], bool *outside, bool *inside );
+ PointSet* createProblemSpecificPointSet( double bbmin[2], double bbmax[2], bool *inside );
CHullBox * compute_chull_bbox();
- * \brief Take each line in shape_toProcess and only keep inside bbox line parts
- static void reduceLine( PointSet *line,
- double bbx[4], double bby[4] );
- static void reducePolygon( PointSet* shape_toProcess,
* split a concave shape into several convex shapes
