[QGIS Commit] r11424 - in trunk/qgis: cmake ms-windows/osgeo4w
python
svn_qgis at osgeo.org
Tue Aug 18 07:59:43 EDT 2009
Author: jef
Date: 2009-08-18 07:59:43 -0400 (Tue, 18 Aug 2009)
New Revision: 11424
trunk/qgis/cmake/Bison.cmake
trunk/qgis/cmake/Flex.cmake
trunk/qgis/cmake/Python.cmake
trunk/qgis/ms-windows/osgeo4w/package.cmd
trunk/qgis/python/CMakeLists.txt
cmake improvements
Modified: trunk/qgis/cmake/Bison.cmake
--- trunk/qgis/cmake/Bison.cmake 2009-08-18 11:55:05 UTC (rev 11423)
+++ trunk/qgis/cmake/Bison.cmake 2009-08-18 11:59:43 UTC (rev 11424)
@@ -4,7 +4,10 @@
MACRO(FIND_BISON)
IF(NOT BISON_EXECUTABLE)
IF (MSVC)
- FIND_PROGRAM(BISON_EXECUTABLE "$ENV{LIB_DIR}/bin/bison.exe")
+ FIND_PROGRAM(BISON_EXECUTABLE PATHS
+ NAMES bison.exe
+ PATHS $ENV{LIB_DIR} $ENV{PROGRAMFILES}/GnuWin32/bin
ELSE (MSVC)
FIND_PROGRAM(BISON_EXECUTABLE bison)
ENDIF (MSVC)
Modified: trunk/qgis/cmake/Flex.cmake
--- trunk/qgis/cmake/Flex.cmake 2009-08-18 11:55:05 UTC (rev 11423)
+++ trunk/qgis/cmake/Flex.cmake 2009-08-18 11:59:43 UTC (rev 11424)
@@ -4,9 +4,10 @@
MACRO(FIND_FLEX)
IF(NOT FLEX_EXECUTABLE)
IF (MSVC)
- FIND_PROGRAM(FLEX_EXECUTABLE
- "$ENV{LIB_DIR}/bin/flex.exe"
+ FIND_PROGRAM(FLEX_EXECUTABLE
+ NAMES flex.exe
+ PATHS $ENV{LIB_DIR}/bin $ENV{PROGRAMFILES}/GnuWin32/bin
ELSE(MSVC)
FIND_PROGRAM(FLEX_EXECUTABLE flex)
ENDIF (MSVC)
Modified: trunk/qgis/cmake/Python.cmake
--- trunk/qgis/cmake/Python.cmake 2009-08-18 11:55:05 UTC (rev 11423)
+++ trunk/qgis/cmake/Python.cmake 2009-08-18 11:59:43 UTC (rev 11424)
@@ -7,11 +7,20 @@
FIND_PACKAGE(PythonLibs) # MapServer export tool
FIND_PACKAGE(PythonInterp) # test for sip and PyQt4
-FIND_PROGRAM(PYUIC4_PROGRAM pyuic4)
+IF(NOT PYUIC4_PROGRAM)
+ IF (MSVC)
+ FIND_PROGRAM(PYUIC4_PROGRAM
+ NAMES pyuic4.bat
+ ELSE(MSVC)
+ FIND_PROGRAM(PYUIC4_PROGRAM pyuic4)
+ ENDIF (MSVC)
-IF(${PYUIC4_PROGRAM} STREQUAL "PYUIC4_PROGRAM-NOTFOUND")
- MESSAGE(ERROR "pyuic4 is required")
-ENDIF(${PYUIC4_PROGRAM} STREQUAL "PYUIC4_PROGRAM-NOTFOUND")
+ IF (NOT PYUIC4_PROGRAM)
+ MESSAGE(FATAL_ERROR "pyuic4 not found - aborting")
+ ENDIF (NOT PYUIC4_PROGRAM)
+ENDIF(NOT PYUIC4_PROGRAM)
# Adapted from QT4_WRAP_UI
MACRO(PYQT4_WRAP_UI outfiles )
@@ -27,8 +36,21 @@
ENDFOREACH(it)
ENDMACRO(PYQT4_WRAP_UI)
-FIND_PROGRAM(PYRCC4_PROGRAM pyrcc4)
+IF(NOT PYRCC4_PROGRAM)
+ IF (MSVC)
+ FIND_PROGRAM(PYRCC4_PROGRAM
+ NAMES pyrcc4.exe
+ ELSE(MSVC)
+ FIND_PROGRAM(PYRCC4_PROGRAM pyrcc4)
+ ENDIF (MSVC)
+ IF (NOT PYRCC4_PROGRAM)
+ MESSAGE(FATAL_ERROR "pyrcc4 not found - aborting")
+ ENDIF (NOT PYRCC4_PROGRAM)
+ENDIF(NOT PYRCC4_PROGRAM)
# Adapted from QT4_ADD_RESOURCES
MACRO (PYQT4_ADD_RESOURCES outfiles )
FOREACH (it ${ARGN})
Modified: trunk/qgis/ms-windows/osgeo4w/package.cmd
--- trunk/qgis/ms-windows/osgeo4w/package.cmd 2009-08-18 11:55:05 UTC (rev 11423)
+++ trunk/qgis/ms-windows/osgeo4w/package.cmd 2009-08-18 11:59:43 UTC (rev 11424)
@@ -1,35 +1,47 @@
@echo off
set GRASS_VERSION=6.4.0svn
+set VERSION=%1
+set PACKAGE=%2
+if "%VERSION%"=="" goto error
+if "%PACKAGE%"=="" goto error
path %SYSTEMROOT%\system32;%SYSTEMROOT%;%SYSTEMROOT%\System32\Wbem;%PROGRAMFILES%\CMake 2.6\bin
set PYTHONPATH=
set VS90COMNTOOLS=%PROGRAMFILES%\Microsoft Visual Studio 9.0\Common7\Tools\
call "%PROGRAMFILES%\Microsoft Visual Studio 9.0\VC\vcvarsall.bat" x86
-set OSGEO4W_ROOT=%PROGRAMFILES%\OSGeo4W
+if "%OSGEO4W_ROOT%"=="" set OSGEO4W_ROOT=%PROGRAMFILES%\OSGeo4W
+if not exist "%OSGEO4W_ROOT%\bin\o4w_env.bat" goto error
call "%OSGEO4W_ROOT%\bin\o4w_env.bat"
+set BUILDDIR=%CD%\build
+REM set BUILDDIR=%TEMP%\qgis_unstable
set O4W_ROOT=%OSGEO4W_ROOT:\=/%
set LIB_DIR=%O4W_ROOT%
-set FLEX=%PROGRAMFILES%\GnuWin32\bin\flex.exe
-set BISON=%PROGRAMFILES%\GnuWin32\bin\bison.exe
-set PYUIC4=%O4W_ROOT%/bin/pyuic4.bat
+set DEVENV=
+if exist "%DevEnvDir%\vcexpress.exe" set DEVENV=vcexpress
+if exist "%DevEnvDir%\devenv.exe" set DEVENV=devenv
+if "%DEVENV%"=="" goto error
-set VERSION=%1
-set PACKAGE=%2
-if %VERSION%=="" goto error
-if %PACKAGE%=="" goto error
PROMPT qgis%VERSION%$g
set BUILDCONF=RelWithDebInfo
REM set BUILDCONF=Release
-if not exist build mkdir build
-if not exist build goto error
+if not exist "%BUILDDIR%" mkdir %BUILDDIR%
+if not exist "%BUILDDIR%" goto error
+cd ..\..
+set SRCDIR=%CD%
+if "%BUILDDIR:~1,1%"==":" %BUILDDIR:~0,2%
+cd %BUILDDIR%
if not exist build.log goto build
REM
@@ -55,10 +67,8 @@
goto error
:build
-set LOG=%CD%\build.log
+set LOG=%BUILDDIR%\build.log
-cd build
echo Logging to %LOG%
echo BEGIN: %DATE% %TIME%>>%LOG% 2>&1
if errorlevel 1 goto error
@@ -76,9 +86,6 @@
-D WITH_INTERNAL_SPATIALITE=TRUE ^
-D CMAKE_CONFIGURATION_TYPE=%BUILDCONF% ^
-D CMAKE_BUILDCONFIGURATION_TYPES=%BUILDCONF% ^
- -D FLEX_EXECUTABLE=%FLEX% ^
- -D BISON_EXECUTABLE=%BISON% ^
- -D PYUIC4_PROGRAM=%PYUIC4% ^
-D GDAL_INCLUDE_DIR=%O4W_ROOT%/apps/gdal-16/include ^
-D GDAL_LIBRARY=%O4W_ROOT%/apps/gdal-16/lib/gdal_i.lib ^
-D PYTHON_EXECUTABLE=%O4W_ROOT%/bin/python.exe ^
@@ -92,7 +99,7 @@
-D QT_ZLIB_LIBRARY=%O4W_ROOT%/lib/zlib.lib ^
-D QT_PNG_LIBRARY=%O4W_ROOT%/lib/libpng13.lib ^
-D CMAKE_INSTALL_PREFIX=%O4W_ROOT%/apps/qgis-dev ^
- ../../..>>%LOG% 2>&1
+ %SRCDIR%>>%LOG% 2>&1
REM bail out if python or grass was not found
@@ -102,15 +109,15 @@
:skipcmake
echo ZERO_CHECK: %DATE% %TIME%>>%LOG% 2>&1
-devenv qgis%VERSION%.sln /Project ZERO_CHECK /Build %BUILDCONF% /Out %LOG%>>%LOG% 2>&1
+%DEVENV% qgis%VERSION%.sln /Project ZERO_CHECK /Build %BUILDCONF% /Out %LOG%>>%LOG% 2>&1
echo ALL_BUILD: %DATE% %TIME%>>%LOG% 2>&1
-devenv qgis%VERSION%.sln /Project ALL_BUILD /Build %BUILDCONF% /Out %LOG%>>%LOG% 2>&1
+%DEVENV% qgis%VERSION%.sln /Project ALL_BUILD /Build %BUILDCONF% /Out %LOG%>>%LOG% 2>&1
echo INSTALL: %DATE% %TIME%>>%LOG% 2>&1
-devenv qgis%VERSION%.sln /Project INSTALL /Build %BUILDCONF% /Out %LOG%>>%LOG% 2>&1
+%DEVENV% qgis%VERSION%.sln /Project INSTALL /Build %BUILDCONF% /Out %LOG%>>%LOG% 2>&1
echo PACKAGE: %DATE% %TIME%>>%LOG% 2>&1
Modified: trunk/qgis/python/CMakeLists.txt
--- trunk/qgis/python/CMakeLists.txt 2009-08-18 11:55:05 UTC (rev 11423)
+++ trunk/qgis/python/CMakeLists.txt 2009-08-18 11:59:43 UTC (rev 11424)
@@ -26,7 +26,6 @@
SET (BINDINGS_CORE_MAKEFILE ${CMAKE_CURRENT_BINARY_DIR}/core/Makefile)
SET (BINDINGS_GUI_MAKEFILE ${CMAKE_CURRENT_BINARY_DIR}/gui/Makefile)
# 'python' target will force to build bindings libs for core and gui
ADD_CUSTOM_TARGET (python ALL DEPENDS ${BINDINGS_CORE_LIB} ${BINDINGS_GUI_LIB})
@@ -36,13 +35,6 @@
FILE(GLOB CORE_SIP_FILES "${CMAKE_CURRENT_SOURCE_DIR}/core/*.sip")
FILE(GLOB GUI_SIP_FILES "${CMAKE_CURRENT_SOURCE_DIR}/gui/*.sip")
-# Extract GDAL library path and name for configure.py.in
-STRING(REGEX REPLACE "^(.*)/.*$" "\\1" GDAL_LIB_PATH ${GDAL_LIBRARY})
-STRING(REGEX REPLACE "^.*/(lib)?(.*)\\.[^.]+$" "\\2" GDAL_LIB_NAME ${GDAL_LIBRARY})
-# Extract GEOS library path and name for configure.py.in
-STRING(REGEX REPLACE "^(.*)/.*$" "\\1" GEOS_LIB_PATH ${GEOS_LIBRARY})
-STRING(REGEX REPLACE "^.*/(lib)?(.*)\\.[^.]+$" "\\2" GEOS_LIB_NAME ${GEOS_LIBRARY})
# Step 1: during configuration
# create file configure.py from configure.py.in
CONFIGURE_FILE(${CMAKE_CURRENT_SOURCE_DIR}/configure.py.in
