[QGIS Commit] r11436 - in trunk/qgis/src: app core gui helpviewer
svn_qgis at osgeo.org
Wed Aug 19 09:45:37 EDT 2009
Author: homann
Date: 2009-08-19 09:45:37 -0400 (Wed, 19 Aug 2009)
New Revision: 11436
trunk/qgis/src/app/qgsbookmarks.cpp
trunk/qgis/src/app/qgscustomprojectiondialog.cpp
trunk/qgis/src/app/qgsoptions.cpp
trunk/qgis/src/core/qgscoordinatereferencesystem.cpp
trunk/qgis/src/core/qgsdistancearea.cpp
trunk/qgis/src/core/qgsmaplayer.cpp
trunk/qgis/src/gui/qgsprojectionselector.cpp
trunk/qgis/src/helpviewer/qgshelpviewer.cpp
Fix a length computation error when doing SQL query with non-ASCII characters
Modified: trunk/qgis/src/app/qgsbookmarks.cpp
--- trunk/qgis/src/app/qgsbookmarks.cpp 2009-08-19 13:44:56 UTC (rev 11435)
+++ trunk/qgis/src/app/qgsbookmarks.cpp 2009-08-19 13:45:37 UTC (rev 11436)
@@ -92,7 +92,7 @@
sqlite3_stmt *ppStmt;
QString sql = "select * from tbl_bookmarks";
- rc = sqlite3_prepare( db, sql.toUtf8(), sql.length(), &ppStmt, &pzTail );
+ rc = sqlite3_prepare( db, sql.toUtf8(), sql.toUtf8().length(), &ppStmt, &pzTail );
// XXX Need to free memory from the error msg if one is set
if ( rc == SQLITE_OK )
@@ -213,7 +213,7 @@
const char *pzTail;
// build the sql statement
QString sql = "select xmin, ymin, xmax, ymax from tbl_bookmarks where bookmark_id = " + item->text( 3 );
if ( sqlite3_step( ppStmt ) == SQLITE_ROW )
Modified: trunk/qgis/src/app/qgscustomprojectiondialog.cpp
--- trunk/qgis/src/app/qgscustomprojectiondialog.cpp 2009-08-19 13:44:56 UTC (rev 11435)
+++ trunk/qgis/src/app/qgscustomprojectiondialog.cpp 2009-08-19 13:45:37 UTC (rev 11436)
@@ -191,7 +191,7 @@
// Set up the query to retrieve the projection information needed to populate the ELLIPSOID list
QString mySql = "delete from tbl_srs where srs_id='" + mCurrentRecordId + "'";
- myResult = sqlite3_prepare( myDatabase, mySql.toUtf8(), mySql.length(), &myPreparedStatement, &myTail );
+ myResult = sqlite3_prepare( myDatabase, mySql.toUtf8(), mySql.toUtf8().length(), &myPreparedStatement, &myTail );
QgsDebugMsg( QString( "Query to delete current:%1" ).arg( mySql ) );
if ( myResult == SQLITE_OK )
@@ -249,7 +249,7 @@
QString mySql = "select count(*) from tbl_srs";
@@ -284,7 +284,7 @@
QString mySql = "select name from tbl_projection where acronym='" + theProjectionFamilyAcronym + "'";
@@ -315,7 +315,7 @@
QString mySql = "select name from tbl_ellipsoid where acronym='" + theEllipsoidAcronym + "'";
@@ -346,7 +346,7 @@
QString mySql = "select acronym from tbl_projection where name='" + theProjectionFamilyName + "'";
@@ -377,7 +377,7 @@
QString mySql = "select acronym from tbl_ellipsoid where name='" + theEllipsoidName + "'";
@@ -410,7 +410,7 @@
QString mySql = "select * from tbl_srs order by srs_id limit 1";
QgsDebugMsg( QString( "Query to move first:%1" ).arg( mySql ) );
@@ -482,7 +482,7 @@
QString mySql = "select * from tbl_srs where srs_id < " + mCurrentRecordId + " order by srs_id desc limit 1";
QgsDebugMsg( QString( "Query to move previous:%1" ).arg( mySql ) );
@@ -555,7 +555,7 @@
QString mySql = "select * from tbl_srs where srs_id > " + mCurrentRecordId + " order by srs_id asc limit 1";
QgsDebugMsg( QString( "Query to move next:%1" ).arg( mySql ) );
@@ -624,7 +624,7 @@
QString mySql = "select * from tbl_srs order by srs_id desc limit 1";
QgsDebugMsg( QString( "Query to move last:%1" ).arg( mySql ) );
@@ -842,7 +842,7 @@
assert( myResult == SQLITE_OK );
QgsDebugMsg( QString( "Update or insert sql \n%1" ).arg( mySql ) );
sqlite3_step( myPreparedStatement );
if ( myResult != SQLITE_OK )
Modified: trunk/qgis/src/app/qgsoptions.cpp
--- trunk/qgis/src/app/qgsoptions.cpp 2009-08-19 13:44:56 UTC (rev 11435)
+++ trunk/qgis/src/app/qgsoptions.cpp 2009-08-19 13:45:37 UTC (rev 11436)
@@ -567,7 +567,7 @@
QString mySql = "select * from tbl_ellipsoid order by name";
@@ -599,7 +599,7 @@
@@ -631,7 +631,7 @@
Modified: trunk/qgis/src/core/qgscoordinatereferencesystem.cpp
--- trunk/qgis/src/core/qgscoordinatereferencesystem.cpp 2009-08-19 13:44:56 UTC (rev 11435)
+++ trunk/qgis/src/core/qgscoordinatereferencesystem.cpp 2009-08-19 13:45:37 UTC (rev 11436)
@@ -221,7 +221,7 @@
QString mySql = "select srs_id,description,projection_acronym,ellipsoid_acronym,parameters,srid,epsg,is_geo from tbl_srs where " + field + "='" + QString::number( id ) + "'";
if ( myResult == SQLITE_OK && sqlite3_step( myPreparedStatement ) == SQLITE_ROW )
@@ -506,7 +506,7 @@
return myMap;
- myResult = sqlite3_prepare( myDatabase, theSql.toUtf8(), theSql.length(), &myPreparedStatement, &myTail );
+ myResult = sqlite3_prepare( myDatabase, theSql.toUtf8(), theSql.toUtf8().length(), &myPreparedStatement, &myTail );
@@ -542,7 +542,7 @@
return myMap;
@@ -799,7 +799,7 @@
return 0;
@@ -839,7 +839,7 @@
return 0;
@@ -1088,7 +1088,7 @@
const char *pzTail;
- rc = sqlite3_prepare( db, mySql.toUtf8(), mySql.length(), &ppStmt, &pzTail );
+ rc = sqlite3_prepare( db, mySql.toUtf8(), mySql.toUtf8().length(), &ppStmt, &pzTail );
@@ -1220,7 +1220,7 @@
return myResult == SQLITE_OK;
@@ -1245,7 +1245,7 @@
Modified: trunk/qgis/src/core/qgsdistancearea.cpp
--- trunk/qgis/src/core/qgsdistancearea.cpp 2009-08-19 13:44:56 UTC (rev 11435)
+++ trunk/qgis/src/core/qgsdistancearea.cpp 2009-08-19 13:45:37 UTC (rev 11436)
@@ -104,7 +104,7 @@
QString mySql = "select radius, parameter2 from tbl_ellipsoid where acronym='" + ellipsoid + "'";
Modified: trunk/qgis/src/core/qgsmaplayer.cpp
--- trunk/qgis/src/core/qgsmaplayer.cpp 2009-08-19 13:44:56 UTC (rev 11435)
+++ trunk/qgis/src/core/qgsmaplayer.cpp 2009-08-19 13:45:37 UTC (rev 11436)
@@ -493,7 +493,7 @@
QString mySql = "select qml from tbl_styles where style=?";
- myResult = sqlite3_prepare( myDatabase, mySql.toUtf8().data(), mySql.length(), &myPreparedStatement, &myTail );
+ myResult = sqlite3_prepare( myDatabase, mySql.toUtf8().data(), mySql.toUtf8().length(), &myPreparedStatement, &myTail );
QByteArray param = theURI.toUtf8();
@@ -655,7 +655,7 @@
QByteArray param1 = qml.toUtf8();
QString mySql = "create table if not exists tbl_styles(style varchar primary key,qml varchar)";
if ( sqlite3_step( myPreparedStatement ) != SQLITE_DONE )
@@ -670,7 +670,7 @@
sqlite3_finalize( myPreparedStatement );
mySql = "insert into tbl_styles(style,qml) values (?,?)";
if ( sqlite3_bind_text( myPreparedStatement, 1, param0.data(), param0.length(), SQLITE_STATIC ) == SQLITE_OK &&
@@ -687,7 +687,7 @@
if ( !theResultFlag )
QString mySql = "update tbl_styles set qml=? where style=?";
if ( sqlite3_bind_text( myPreparedStatement, 2, param0.data(), param0.length(), SQLITE_STATIC ) == SQLITE_OK &&
Modified: trunk/qgis/src/gui/qgsprojectionselector.cpp
--- trunk/qgis/src/gui/qgsprojectionselector.cpp 2009-08-19 13:44:56 UTC (rev 11435)
+++ trunk/qgis/src/gui/qgsprojectionselector.cpp 2009-08-19 13:45:37 UTC (rev 11436)
@@ -454,7 +454,7 @@
QgsDebugMsg( "Selection sql: " + sql );
QString myProjString;
@@ -541,7 +541,7 @@
sql += lvi->text( QGIS_CRS_ID_COLUMN );
QgsDebugMsg( QString( "Finding selected attribute using : %1" ).arg( sql ) );
QString myAttributeValue;
@@ -657,7 +657,7 @@
mySql += "where ";
mySql += sqlFilter;
@@ -736,7 +736,7 @@
// get total count of records in the projection table
QString sql = "select count(*) from tbl_srs";
assert( rc == SQLITE_OK );
sqlite3_step( ppStmt );
@@ -750,7 +750,7 @@
sql += sqlFilter;
sql += " order by name, description";
@@ -924,7 +924,7 @@
return;
@@ -956,7 +956,7 @@
return;
@@ -1004,7 +1004,7 @@
else
@@ -1032,7 +1032,7 @@
return 0;
Modified: trunk/qgis/src/helpviewer/qgshelpviewer.cpp
--- trunk/qgis/src/helpviewer/qgshelpviewer.cpp 2009-08-19 13:44:56 UTC (rev 11435)
+++ trunk/qgis/src/helpviewer/qgshelpviewer.cpp 2009-08-19 13:45:37 UTC (rev 11436)
@@ -173,7 +173,7 @@
QString sql = "select content,title from context_helps where context_id = "
+ contextId;
