[QGIS Commit] r11451 - in trunk/qgis: . cmake_templates
ms-windows/osgeo4w
svn_qgis at osgeo.org
Thu Aug 20 11:31:45 EDT 2009
Author: jef
Date: 2009-08-20 11:31:45 -0400 (Thu, 20 Aug 2009)
New Revision: 11451
Removed:
trunk/qgis/cmake_templates/qgssvnversion.h.in_cmake
trunk/qgis/cmake_templates/svnscript.cmake.in_cmake
trunk/qgis/CMakeLists.txt
trunk/qgis/ms-windows/osgeo4w/package.cmd
improve qgssvnversion.h creation
Modified: trunk/qgis/CMakeLists.txt
--- trunk/qgis/CMakeLists.txt 2009-08-20 10:04:10 UTC (rev 11450)
+++ trunk/qgis/CMakeLists.txt 2009-08-20 15:31:45 UTC (rev 11451)
@@ -340,20 +340,33 @@
FIND_FILE(SVN_MARKER entries PATHS ${CMAKE_SOURCE_DIR}/.svn)
-IF (NOT SVN_MARKER)
- SET (SVN_MARKER ${CMAKE_SOURCE_DIR}/CMakeLists.txt) # Dummy file
-ENDIF (NOT SVN_MARKER)
- # Add a custom command to drive the svn script whenever the svn entries
- # file changes.
- CONFIGURE_FILE(${CMAKE_CURRENT_SOURCE_DIR}/cmake_templates/svnscript.cmake.in_cmake
- ${CMAKE_CURRENT_BINARY_DIR}/svnscript.cmake
- @ONLY)
+IF (SVN_MARKER)
+ # See if we have svn installed
+ FIND_PROGRAM(SVNVERSION svnversion PATHS c:/cygwin/bin)
- ADD_CUSTOM_COMMAND (
- OUTPUT ${CMAKE_CURRENT_BINARY_DIR}/qgssvnversion.h
- DEPENDS ${SVN_MARKER}
- COMMAND ${CMAKE_COMMAND} -P ${CMAKE_CURRENT_BINARY_DIR}/svnscript.cmake
+ IF(SVNVERSION)
+ IF(MSVC)
+ ADD_CUSTOM_COMMAND(
+ OUTPUT ${CMAKE_CURRENT_BINARY_DIR}/qgssvnversion.h
+ COMMAND for /f usebackq %%a in "(`${SVNVERSION}`)" do echo \#define QGSSVNVERSION \"%%a\" >${CMAKE_CURRENT_BINARY_DIR}/qgssvnversion.h
+ MAIN_DEPENDENCY ${SVN_MARKER}
+ WORKING_DIRECTORY ${CMAKE_SOURCE_DIR}
+ ELSE(MSVC)
+ COMMAND echo \\\#define QGSSVNVERSION \\\"`${SVNVERSION}`\\\" >${CMAKE_CURRENT_BINARY_DIR}/qgssvnversion.h
+ ENDIF(MSVC)
+ ELSE(SVNVERSION)
+ MESSAGE(STATUS "svnversion not found - version will be unknown")
+ FILE(WRITE ${CMAKE_CURRENT_BINARY_DIR}/qgssvnversion.h "#define QGSSVNVERSION \"unknown\"")
+ ENDIF (SVNVERSION)
+ELSE (SVN_MARKER)
+ FILE(WRITE ${CMAKE_CURRENT_BINARY_DIR}/qgssvnversion.h "#define QGSSVNVERSION \"exported\"")
+ENDIF (SVN_MARKER)
ADD_CUSTOM_TARGET(svnversion ALL DEPENDS ${CMAKE_CURRENT_BINARY_DIR}/qgssvnversion.h)
Deleted: trunk/qgis/cmake_templates/qgssvnversion.h.in_cmake
--- trunk/qgis/cmake_templates/qgssvnversion.h.in_cmake 2009-08-20 10:04:10 UTC (rev 11450)
+++ trunk/qgis/cmake_templates/qgssvnversion.h.in_cmake 2009-08-20 15:31:45 UTC (rev 11451)
@@ -1 +0,0 @@
-#define QGSSVNVERSION "@MYVERSION@"
Deleted: trunk/qgis/cmake_templates/svnscript.cmake.in_cmake
--- trunk/qgis/cmake_templates/svnscript.cmake.in_cmake 2009-08-20 10:04:10 UTC (rev 11450)
+++ trunk/qgis/cmake_templates/svnscript.cmake.in_cmake 2009-08-20 15:31:45 UTC (rev 11451)
@@ -1,17 +0,0 @@
-# Magnus Homann svn hack
-# Required?
-SET(CMAKE_BACKWARDS_COMPATIBILITY "2.4")
-# See if we have svn installed
-FIND_PROGRAM(SVNVERSION svnversion)
-# Read the version if installed, else set to "unknown"
-IF (SVNVERSION)
- EXEC_PROGRAM(${SVNVERSION} ARGS "@CMAKE_CURRENT_SOURCE_DIR@" OUTPUT_VARIABLE MYVERSION)
-ELSE (SVNVERSION)
- SET(MYVERSION unknown)
-ENDIF (SVNVERSION)
-# Configure the qgssvnversion.h
-CONFIGURE_FILE("@CMAKE_CURRENT_SOURCE_DIR@/cmake_templates/qgssvnversion.h.in_cmake"
- "@CMAKE_CURRENT_BINARY_DIR@/qgssvnversion.h")
Modified: trunk/qgis/ms-windows/osgeo4w/package.cmd
--- trunk/qgis/ms-windows/osgeo4w/package.cmd 2009-08-20 10:04:10 UTC (rev 11450)
+++ trunk/qgis/ms-windows/osgeo4w/package.cmd 2009-08-20 15:31:45 UTC (rev 11451)
@@ -1,5 +1,6 @@
@echo off
set GRASS_VERSION=6.4.0svn
+set SVNVERSION=c:/cygwin/bin/svnversion
set BUILDDIR=%CD%\build
REM set BUILDDIR=%TEMP%\qgis_unstable
@@ -99,6 +100,8 @@
-D QT_ZLIB_LIBRARY=%O4W_ROOT%/lib/zlib.lib ^
-D QT_PNG_LIBRARY=%O4W_ROOT%/lib/libpng13.lib ^
-D CMAKE_INSTALL_PREFIX=%O4W_ROOT%/apps/qgis-dev ^
+ -D CMAKE_CXX_FLAGS_RELWITHDEBINFO="/MD /ZI /Od /D NDEBUG" ^
+ -D SVNVERSION="%SVNVERSION%" ^
%SRCDIR%>>%LOG% 2>&1
if errorlevel 1 goto error
