[QGIS Commit] r11531 - trunk/qgis/src/ui
svn_qgis at osgeo.org
Mon Aug 31 05:09:06 EDT 2009
Author: homann
Date: 2009-08-31 05:09:06 -0400 (Mon, 31 Aug 2009)
New Revision: 11531
trunk/qgis/src/ui/qgscustomprojectiondialogbase.ui
trunk/qgis/src/ui/qgslabeldialogbase.ui
trunk/qgis/src/ui/qgsmeasurebase.ui
trunk/qgis/src/ui/qgsoptionsbase.ui
trunk/qgis/src/ui/qgspgquerybuilderbase.ui
trunk/qgis/src/ui/qgsprojectionselectorbase.ui
trunk/qgis/src/ui/qgsserversourceselectbase.ui
trunk/qgis/src/ui/qgssinglesymboldialogbase.ui
trunk/qgis/src/ui/qgsspatialitesourceselectbase.ui
trunk/qgis/src/ui/qgsvectorlayerpropertiesbase.ui
Fix uic warnings
Modified: trunk/qgis/src/ui/qgscustomprojectiondialogbase.ui
--- trunk/qgis/src/ui/qgscustomprojectiondialogbase.ui 2009-08-31 08:41:55 UTC (rev 11530)
+++ trunk/qgis/src/ui/qgscustomprojectiondialogbase.ui 2009-08-31 09:09:06 UTC (rev 11531)
@@ -13,7 +13,9 @@
<string>Custom Coordinate Reference System Definition</string>
</property>
<property name="windowIcon" >
- <iconset/>
+ <iconset>
+ <normaloff/>
+ </iconset>
</property>
<layout class="QGridLayout" >
<item row="0" column="0" >
Modified: trunk/qgis/src/ui/qgslabeldialogbase.ui
--- trunk/qgis/src/ui/qgslabeldialogbase.ui 2009-08-31 08:41:55 UTC (rev 11530)
+++ trunk/qgis/src/ui/qgslabeldialogbase.ui 2009-08-31 09:09:06 UTC (rev 11531)
@@ -630,7 +630,7 @@
<height>399</height>
</rect>
</property>
- <layout class="QGridLayout" name="gridLayout" >
+ <layout class="QGridLayout" name="gridLayout_1" >
<widget class="QLabel" name="lblFont" >
<property name="sizePolicy" >
Modified: trunk/qgis/src/ui/qgsmeasurebase.ui
--- trunk/qgis/src/ui/qgsmeasurebase.ui 2009-08-31 08:41:55 UTC (rev 11530)
+++ trunk/qgis/src/ui/qgsmeasurebase.ui 2009-08-31 09:09:06 UTC (rev 11531)
@@ -19,7 +19,9 @@
<string>Measure</string>
</property>
- <iconset/>
+ <iconset>
+ <normaloff/>
+ </iconset>
</property>
<property name="margin" >
Modified: trunk/qgis/src/ui/qgsoptionsbase.ui
--- trunk/qgis/src/ui/qgsoptionsbase.ui 2009-08-31 08:41:55 UTC (rev 11530)
+++ trunk/qgis/src/ui/qgsoptionsbase.ui 2009-08-31 09:09:06 UTC (rev 11531)
@@ -811,7 +811,7 @@
<property name="title">
<string>Vertex markers</string>
</property>
- <layout class="QGridLayout" name="gridLayout">
+ <layout class="QGridLayout" name="gridLayout_1">
<item row="0" column="0" colspan="2">
<widget class="QCheckBox" name="mMarkersOnlyForSelectedCheckBox">
<property name="text">
Modified: trunk/qgis/src/ui/qgspgquerybuilderbase.ui
--- trunk/qgis/src/ui/qgspgquerybuilderbase.ui 2009-08-31 08:41:55 UTC (rev 11530)
+++ trunk/qgis/src/ui/qgspgquerybuilderbase.ui 2009-08-31 09:09:06 UTC (rev 11531)
@@ -21,7 +21,9 @@
<string>PostgreSQL Query Builder</string>
</property>
- <iconset/>
+ <iconset>
+ <normaloff/>
+ </iconset>
</property>
<property name="modal" >
<bool>true</bool>
Modified: trunk/qgis/src/ui/qgsprojectionselectorbase.ui
--- trunk/qgis/src/ui/qgsprojectionselectorbase.ui 2009-08-31 08:41:55 UTC (rev 11530)
+++ trunk/qgis/src/ui/qgsprojectionselectorbase.ui 2009-08-31 09:09:06 UTC (rev 11531)
@@ -19,7 +19,9 @@
<string>Coordinate Reference System Selector</string>
</property>
- <iconset/>
+ <iconset>
+ <normaloff/>
+ </iconset>
</property>
<property name="leftMargin" >
Modified: trunk/qgis/src/ui/qgsserversourceselectbase.ui
--- trunk/qgis/src/ui/qgsserversourceselectbase.ui 2009-08-31 08:41:55 UTC (rev 11530)
+++ trunk/qgis/src/ui/qgsserversourceselectbase.ui 2009-08-31 09:09:06 UTC (rev 11531)
@@ -146,7 +146,7 @@
<attribute name="title">
<string>Layer Order</string>
</attribute>
<item row="0" column="0">
<widget class="QPushButton" name="mLayerUpButton">
@@ -194,7 +194,6 @@
</layout>
<zorder>mLayerUpButton</zorder>
<zorder>mLayerDownButton</zorder>
- <zorder>horizontalSpacer</zorder>
<zorder>mLayerOrderTreeWidget</zorder>
</widget>
<widget class="QWidget" name="tab_2">
Modified: trunk/qgis/src/ui/qgssinglesymboldialogbase.ui
--- trunk/qgis/src/ui/qgssinglesymboldialogbase.ui 2009-08-31 08:41:55 UTC (rev 11530)
+++ trunk/qgis/src/ui/qgssinglesymboldialogbase.ui 2009-08-31 09:09:06 UTC (rev 11531)
@@ -251,7 +251,6 @@
<zorder>fillcolorlabel</zorder>
<zorder>btnFillColor</zorder>
<zorder>fillcolorlabel_2</zorder>
- <zorder>mGroupPoint</zorder>
</widget>
</item>
<item row="1" column="0" >
Modified: trunk/qgis/src/ui/qgsspatialitesourceselectbase.ui
--- trunk/qgis/src/ui/qgsspatialitesourceselectbase.ui 2009-08-31 08:41:55 UTC (rev 11530)
+++ trunk/qgis/src/ui/qgsspatialitesourceselectbase.ui 2009-08-31 09:09:06 UTC (rev 11531)
@@ -13,7 +13,9 @@
<string>Add SpatiaLite Table(s)</string>
</property>
- <iconset/>
+ <iconset>
+ <normaloff/>
+ </iconset>
</property>
<property name="sizeGripEnabled" >
<bool>true</bool>
Modified: trunk/qgis/src/ui/qgsvectorlayerpropertiesbase.ui
--- trunk/qgis/src/ui/qgsvectorlayerpropertiesbase.ui 2009-08-31 08:41:55 UTC (rev 11530)
+++ trunk/qgis/src/ui/qgsvectorlayerpropertiesbase.ui 2009-08-31 09:09:06 UTC (rev 11531)
@@ -19,7 +19,9 @@
<string>Layer Properties</string>
</property>
- <iconset/>
+ <iconset>
+ <normaloff/>
+ </iconset>
</property>
<bool>true</bool>
