[QGIS Commit] r11532 - trunk/qgis/src/core
svn_qgis at osgeo.org
Mon Aug 31 06:17:59 EDT 2009
Author: mhugent
Date: 2009-08-31 06:17:58 -0400 (Mon, 31 Aug 2009)
New Revision: 11532
trunk/qgis/src/core/qgsvectorlayer.cpp
Apply coordinate clipping also for windows (probably fixes bug #1344)
Modified: trunk/qgis/src/core/qgsvectorlayer.cpp
--- trunk/qgis/src/core/qgsvectorlayer.cpp 2009-08-31 09:09:06 UTC (rev 11531)
+++ trunk/qgis/src/core/qgsvectorlayer.cpp 2009-08-31 10:17:58 UTC (rev 11532)
@@ -71,10 +71,7 @@
#include "qgsvectoroverlay.h"
#include "qgslogger.h"
#include "qgsmaplayerregistry.h"
-#ifdef Q_WS_X11
#include "qgsclipper.h"
-#endif
#ifdef TESTPROVIDERLIB
#include <dlfcn.h>
@@ -380,9 +377,7 @@
transformPoints( x, y, z, renderContext );
-#if defined(Q_WS_X11)
- // Work around a +/- 32768 limitation on coordinates in X11
+ // Work around a +/- 32768 limitation on coordinates
// Look through the x and y coordinates and see if there are any
// that need trimming. If one is found, there's no need to look at
// the rest of them so end the loop at that point.
@@ -396,7 +391,6 @@
break;
-#endif
// set up QPolygonF class with transformed points
QPolygonF pa( nPoints );
@@ -512,9 +506,7 @@
transformPoints( ring->first, ring->second, zVector, renderContext );
@@ -527,7 +519,6 @@
break;
-#endif
// Don't bother keeping the ring if it has been trimmed out of
// existence.
@@ -3483,9 +3474,7 @@
// executed, but never used, in a bit of code where performance is
// critical).
if ( ! fet.isValid() ) { return; }
bool needToTrim = false;
-#endif
QgsGeometry* geom = fet.geometry();
unsigned char* feature = geom->asWkb();
@@ -3501,6 +3490,12 @@
double y = *(( double * )( feature + 5 + sizeof( double ) ) );
transformPoint( x, y, &renderContext.mapToPixel(), renderContext.coordinateTransform() );
+ if ( std::abs( x ) > QgsClipper::MAX_X ||
+ std::abs( y ) > QgsClipper::MAX_Y )
+ break;
//QPointF pt(x - (marker->width()/2), y - (marker->height()/2));
QPointF pt( x*renderContext.rasterScaleFactor() - ( marker->width() / 2 ),
y*renderContext.rasterScaleFactor() - ( marker->height() / 2 ) );
@@ -3542,13 +3537,11 @@
//QPointF pt( x, y );
needToTrim = true;
else
-#endif
p->drawImage( pt, *marker );
p->restore();
