[QGIS Commit] r12450 - trunk/qgis/src/providers/postgres
svn_qgis at osgeo.org
Mon Dec 14 08:02:08 EST 2009
Author: jef
Date: 2009-12-14 08:02:07 -0500 (Mon, 14 Dec 2009)
New Revision: 12450
trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
trunk/qgis/src/providers/postgres/qgspostgresprovider.h
better fix for slowdown of r12418
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2009-12-14 10:51:02 UTC (rev 12449)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2009-12-14 13:02:07 UTC (rev 12450)
@@ -55,7 +55,8 @@
: QgsVectorDataProvider( uri ),
mFetching( false ),
geomType( QGis::WKBUnknown ),
- mFeatureQueueSize( 200 )
+ mFeatureQueueSize( 200 ),
+ mPrimaryKeyDefault( QString::null )
// assume this is a valid layer until we determine otherwise
valid = true;
@@ -1064,13 +1065,13 @@
else
- primaryKeyDefault = defaultValue( primaryKey ).toString();
- if ( primaryKeyDefault.isNull() )
+ mPrimaryKeyDefault = defaultValue( primaryKey ).toString();
+ if ( mPrimaryKeyDefault.isNull() )
- primaryKeyDefault = QString( "max(%1)+1 from %2.%3" )
- .arg( quotedIdentifier( primaryKey ) )
- .arg( quotedIdentifier( mSchemaName ) )
- .arg( quotedIdentifier( mTableName ) );
+ mPrimaryKeyDefault = QString( "max(%1)+1 from %2.%3" )
+ .arg( quotedIdentifier( primaryKey ) )
+ .arg( quotedIdentifier( mSchemaName ) )
+ .arg( quotedIdentifier( mTableName ) );
@@ -1093,6 +1094,8 @@
type = PQgetvalue( result, 0, 0 );
+ // mPrimaryKeyDefault stays null and is retrieved later on demand
if (( type != "int4" && type != "oid" ) ||
!uniqueData( mSchemaName, mTableName, primaryKey ) )
@@ -1100,33 +1103,10 @@
- // Have a poke around the view to see if any of the columns
- // could be used as the primary key.
- tableCols cols;
- // Given a schema.view, populate the cols variable with the
- // schema.table.column's that underly the view columns.
- findColumns( cols );
if ( primaryKey.isEmpty() )
- // From the view columns, choose one for which the underlying
- // column is suitable for use as a key into the view.
- primaryKey = chooseViewColumn( cols );
+ parseView();
- tableCols::const_iterator it = cols.find( primaryKey );
- if ( it != cols.end() )
- primaryKeyDefault = defaultValue( it->second.column, it->second.relation, it->second.schema ).toString();
- .arg( quotedIdentifier( it->second.column ) )
- .arg( quotedIdentifier( it->second.schema ) )
- .arg( quotedIdentifier( it->second.relation ) );
else
QgsDebugMsg( "Unexpected relation type of '" + type + "'." );
@@ -1227,13 +1207,13 @@
else
@@ -1250,11 +1230,58 @@
return primaryKey;
+void QgsPostgresProvider::parseView()
+ // Have a poke around the view to see if any of the columns
+ // could be used as the primary key.
+ tableCols cols;
+ // Given a schema.view, populate the cols variable with the
+ // schema.table.column's that underly the view columns.
+ findColumns( cols );
+ // pick the primary key, if we don't have one yet
+ if ( primaryKey.isEmpty() )
+ // From the view columns, choose one for which the underlying
+ // column is suitable for use as a key into the view.
+ primaryKey = chooseViewColumn( cols );
+ tableCols::const_iterator it = cols.find( primaryKey );
+ if ( it != cols.end() )
+ mPrimaryKeyDefault = defaultValue( it->second.column, it->second.relation, it->second.schema ).toString();
+ .arg( quotedIdentifier( it->second.column ) )
+ .arg( quotedIdentifier( it->second.schema ) )
+ .arg( quotedIdentifier( it->second.relation ) );
+ else
+QString QgsPostgresProvider::primaryKeyDefault()
+ parseView();
+ return mPrimaryKeyDefault;
// Given the table and column that each column in the view refers to,
// choose one. Prefers column with an index on them, but will
// otherwise choose something suitable.
-QString QgsPostgresProvider::chooseViewColumn( const tableCols& cols )
+QString QgsPostgresProvider::chooseViewColumn( const tableCols &cols )
// For each relation name and column name need to see if it
// has unique constraints on it, or is a primary key (if not,
@@ -2206,7 +2233,7 @@
if ( primaryKeyType != "tid" )
- int id = paramValue( primaryKeyDefault, primaryKeyDefault ).toInt();
+ int id = paramValue( primaryKeyDefault(), primaryKeyDefault() ).toInt();
params << QString::number( id );
newIds << id;
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.h
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.h 2009-12-14 10:51:02 UTC (rev 12449)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.h 2009-12-14 13:02:07 UTC (rev 12450)
@@ -409,10 +409,6 @@
QString primaryKey;
- * Default value for primary key
- QString primaryKeyDefault;
* Data type for the primary key
QString primaryKeyType;
@@ -699,6 +695,14 @@
void disconnectDb();
static int providerIds;
+ QString primaryKeyDefault();
+ void parseView();
+ * Default value for primary key
+ QString mPrimaryKeyDefault;
#endif
