[QGIS Commit] r12451 - trunk/qgis/resources/context_help
svn_qgis at osgeo.org
Mon Dec 14 08:54:21 EST 2009
Author: borysiasty
Date: 2009-12-14 08:54:20 -0500 (Mon, 14 Dec 2009)
New Revision: 12451
trunk/qgis/resources/context_help/QgsIdentifyResults-de_DE
trunk/qgis/resources/context_help/QgsIdentifyResults-en_US
trunk/qgis/resources/context_help/QgsIdentifyResults-es_ES
trunk/qgis/resources/context_help/QgsIdentifyResults-pl_PL
trunk/qgis/resources/context_help/QgsIdentifyResults-ru_RU
trunk/qgis/resources/context_help/QgsIdentifyResults-sk_SK
trunk/qgis/resources/context_help/QgsIdentifyResults-sv_SE
Context help updates from Milena
Modified: trunk/qgis/resources/context_help/QgsIdentifyResults-de_DE
--- trunk/qgis/resources/context_help/QgsIdentifyResults-de_DE 2009-12-14 13:02:07 UTC (rev 12450)
+++ trunk/qgis/resources/context_help/QgsIdentifyResults-de_DE 2009-12-14 13:54:20 UTC (rev 12451)
@@ -5,5 +5,5 @@
das Pluszeichen (+) links eines jeden Objekts auf.
</p>
<p>
-Der Suchradius kann unter Einstellungen|Optionen eingestellt werden.
+Der Suchradius kann unter <label>Einstellungen > Optionen</label> eingestellt werden.
</p>
Modified: trunk/qgis/resources/context_help/QgsIdentifyResults-en_US
--- trunk/qgis/resources/context_help/QgsIdentifyResults-en_US 2009-12-14 13:02:07 UTC (rev 12450)
+++ trunk/qgis/resources/context_help/QgsIdentifyResults-en_US 2009-12-14 13:54:20 UTC (rev 12451)
@@ -5,5 +5,5 @@
to the left of each feature.
</p>
<p>
-The search radius can be set in the options dialog (Settings|Options).
+The search radius can be set in the options dialog <label>Settings > Options</label>.
</p>
Modified: trunk/qgis/resources/context_help/QgsIdentifyResults-es_ES
--- trunk/qgis/resources/context_help/QgsIdentifyResults-es_ES 2009-12-14 13:02:07 UTC (rev 12450)
+++ trunk/qgis/resources/context_help/QgsIdentifyResults-es_ES 2009-12-14 13:54:20 UTC (rev 12451)
@@ -4,5 +4,5 @@
Para ver los resultados, expanda la información del objeto espacial haciendo clic en el signo más (+) a la izquierda de cada objeto.
</p>
<p>
-El radio de búsqueda se puede establecer en el diálogo de opciones (Configuración>Opciones).
+El radio de búsqueda se puede establecer en el diálogo de opciones <label>Configuración > Opciones</label>.
</p>
Modified: trunk/qgis/resources/context_help/QgsIdentifyResults-pl_PL
--- trunk/qgis/resources/context_help/QgsIdentifyResults-pl_PL 2009-12-14 13:02:07 UTC (rev 12450)
+++ trunk/qgis/resources/context_help/QgsIdentifyResults-pl_PL 2009-12-14 13:54:20 UTC (rev 12451)
@@ -3,5 +3,5 @@
Okno wynikowe pokazuje atrybuty wszystkich obiektów znalezionych w obszarze przeszukiwania. Aby zobaczyć atrybuty poszczególnych obiektów, rozwiń drzewo z informacjami klikając znak + (plus) po prawej stronie obiektu.
</p>
<p>
-Promień przeszukiwania można ustawić w dialogu Opcje (Ustawienia|Opcje)
+Promień przeszukiwania można ustawić w dialogu Opcje <label>Ustawienia > Opcje</label>
</p>
Modified: trunk/qgis/resources/context_help/QgsIdentifyResults-ru_RU
(Binary files differ)
Modified: trunk/qgis/resources/context_help/QgsIdentifyResults-sk_SK
--- trunk/qgis/resources/context_help/QgsIdentifyResults-sk_SK 2009-12-14 13:02:07 UTC (rev 12450)
+++ trunk/qgis/resources/context_help/QgsIdentifyResults-sk_SK 2009-12-14 13:54:20 UTC (rev 12451)
@@ -4,5 +4,5 @@
Detail výsledku si možno prezrieť rozbalením informácie o objekte kliknutím na znamienko plus (+) naľavo od každého objektu.
</p>
<p>
-Polomer vyhľadávania je možné nastaviť v záložke Mapové nástroje v dialógovom okne Vlastnosti (Nastavenia|Vlastnosti).
+Polomer vyhľadávania je možné nastaviť v záložke Mapové nástroje v dialógovom okne Vlastnosti <label>Nastavenia > Vlastnosti</label>.
</p>
Modified: trunk/qgis/resources/context_help/QgsIdentifyResults-sv_SE
--- trunk/qgis/resources/context_help/QgsIdentifyResults-sv_SE 2009-12-14 13:02:07 UTC (rev 12450)
+++ trunk/qgis/resources/context_help/QgsIdentifyResults-sv_SE 2009-12-14 13:54:20 UTC (rev 12451)
@@ -6,6 +6,5 @@
om objektet.
</p>
<p>
-Sökradien kan ställas in under alternativ
- (Inställningar -> Alternativ).
+Sökradien kan ställas in under alternativ <label>Inställningar > Alternativ</label>.
</p>
