[QGIS Commit] r12476 - in trunk/qgis/python: .
plugins/plugin_installer
svn_qgis at osgeo.org
Tue Dec 15 12:47:01 EST 2009
Author: borysiasty
Date: 2009-12-15 12:47:00 -0500 (Tue, 15 Dec 2009)
New Revision: 12476
trunk/qgis/python/plugins/plugin_installer/__init__.py
trunk/qgis/python/plugins/plugin_installer/installer_data.py
trunk/qgis/python/plugins/plugin_installer/installer_gui.py
trunk/qgis/python/plugins/plugin_installer/installer_plugin.py
trunk/qgis/python/plugins/plugin_installer/qgsplugininstallerbase.ui
trunk/qgis/python/utils.py
Plugin installer update: one-step plugin install and uninstall in QGIS>=1.4
Modified: trunk/qgis/python/plugins/plugin_installer/__init__.py
--- trunk/qgis/python/plugins/plugin_installer/__init__.py 2009-12-15 17:00:36 UTC (rev 12475)
+++ trunk/qgis/python/plugins/plugin_installer/__init__.py 2009-12-15 17:47:00 UTC (rev 12476)
@@ -1,3 +1,4 @@
+# -*- coding: utf-8 -*-
Copyright (C) 2007-2008 Matthew Perry
Copyright (C) 2008-2009 Borys Jurgiel
@@ -14,7 +15,7 @@
return "Plugin Installer"
def version():
- return "Version 1.0.5"
+ return "Version 1.0.6"
def description():
return "Downloads and installs QGIS python plugins"
Modified: trunk/qgis/python/plugins/plugin_installer/installer_data.py
--- trunk/qgis/python/plugins/plugin_installer/installer_data.py 2009-12-15 17:00:36 UTC (rev 12475)
+++ trunk/qgis/python/plugins/plugin_installer/installer_data.py 2009-12-15 17:47:00 UTC (rev 12476)
@@ -57,9 +57,11 @@
QGIS_MAJOR_VER = 1
else:
QGIS_MAJOR_VER = 0
+ QGIS_14 = False
except:
QGIS_VER = QGis.QGIS_VERSION
QGIS_MAJOR_VER = 1
+ QGIS_14 = (QGIS_VER[2] > 3)
Modified: trunk/qgis/python/plugins/plugin_installer/installer_gui.py
--- trunk/qgis/python/plugins/plugin_installer/installer_gui.py 2009-12-15 17:00:36 UTC (rev 12475)
+++ trunk/qgis/python/plugins/plugin_installer/installer_gui.py 2009-12-15 17:47:00 UTC (rev 12476)
@@ -25,6 +25,10 @@
from ui_qgsplugininstallerbase import Ui_QgsPluginInstallerDialogBase
from installer_data import *
+try:
+ from qgis.utils import startPlugin, unloadPlugin
+except Exception:
+ pass
# --- common functions ------------------------------------------------------------------- #
@@ -259,6 +263,8 @@
self.connect(self.buttonUninstall, SIGNAL("clicked()"), self.uninstallPlugin)
self.buttonInstall.setEnabled(False)
self.buttonUninstall.setEnabled(False)
+ self.buttonHelp.setEnabled(QGIS_14)
+ self.connect(self.buttonHelp, SIGNAL("clicked()"), self.runHelp)
# repositories handling
self.connect(self.treeRepositories, SIGNAL("doubleClicked(QModelIndex)"), self.editRepository)
self.connect(self.buttonFetchRepositories, SIGNAL("clicked()"), self.addKnownRepositories)
@@ -593,9 +599,11 @@
plugin = plugins.all()[key]
if not plugin["error"]:
if previousStatus in ["not installed", "new"]:
- infoString = (self.tr("Plugin installed successfully"), self.tr("Python plugin installed.\nNow you need to enable it in Plugin Manager."))
+ if QGIS_14: infoString = (self.tr("Plugin installed successfully"), self.tr("Plugin installed successfully"))
+ else: infoString = (self.tr("Plugin installed successfully"), self.tr("Python plugin installed.\nNow you need to enable it in Plugin Manager."))
else:
infoString = (self.tr("Plugin reinstalled successfully"), self.tr("Python plugin reinstalled.\nYou need to restart Quantum GIS in order to reload it."))
+ startPlugin(plugin["localdir"])
else:
if plugin["error"] == "incompatible":
message = self.tr("The plugin is designed for a newer version of Quantum GIS. The minimum required version is:")
@@ -649,7 +657,7 @@
if not plugin:
return
- warning = self.tr("Are you sure you want to uninstall the following plugin?") + "\n" + plugin["name"]
+ warning = self.tr("Are you sure you want to uninstall the following plugin?") + "\n(" + plugin["name"] + ")"
if plugin["status"] == "orphan" and not plugin["error"]:
warning += "\n\n"+self.tr("Warning: this plugin isn't available in any accessible repository!")
if QMessageBox.warning(self, self.tr("QGIS Python Plugin Installer"), warning , QMessageBox.Yes, QMessageBox.No) == QMessageBox.No:
@@ -661,6 +669,10 @@
else:
# safe remove
try:
+ unloadPlugin(plugin["localdir"])
+ except:
+ pass
+ try:
exec ("plugins[%s].unload()" % plugin["localdir"])
exec ("del plugins[%s]" % plugin["localdir"])
except:
@@ -672,7 +684,8 @@
plugins.getAllInstalled()
plugins.rebuild()
self.populatePluginTree()
- QMessageBox.information(self, self.tr("Plugin uninstalled successfully"), self.tr("Python plugin uninstalled. Note that you may need to restart Quantum GIS in order to remove it completely."))
+ if QGIS_14: QMessageBox.information(self, self.tr("Plugin uninstalled successfully"), self.tr("Plugin uninstalled successfully"))
+ else: QMessageBox.information(self, self.tr("Plugin uninstalled successfully"), self.tr("Python plugin uninstalled. Note that you may need to restart Quantum GIS in order to remove it completely."))
history.markChange(key,'D')
@@ -835,6 +848,12 @@
+ def runHelp(self):
+ """ open the context help browser """
+ QgsContextHelp.run("QgsPluginInstallerDialog")
def reject(self):
""" update the list of seen plugins before exit (both 'done' and 'x' buttons emit 'reject' signal) """
plugins.updateSeenPluginsList()
Modified: trunk/qgis/python/plugins/plugin_installer/installer_plugin.py
--- trunk/qgis/python/plugins/plugin_installer/installer_plugin.py 2009-12-15 17:00:36 UTC (rev 12475)
+++ trunk/qgis/python/plugins/plugin_installer/installer_plugin.py 2009-12-15 17:47:00 UTC (rev 12476)
@@ -1,3 +1,4 @@
Modified: trunk/qgis/python/plugins/plugin_installer/qgsplugininstallerbase.ui
--- trunk/qgis/python/plugins/plugin_installer/qgsplugininstallerbase.ui 2009-12-15 17:00:36 UTC (rev 12475)
+++ trunk/qgis/python/plugins/plugin_installer/qgsplugininstallerbase.ui 2009-12-15 17:47:00 UTC (rev 12476)
@@ -1,8 +1,9 @@
-<ui version="4.0" >
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
<author>Matthew Perry, Borys Jurgiel</author>
<class>QgsPluginInstallerDialogBase</class>
- <widget class="QDialog" name="QgsPluginInstallerDialogBase" >
- <property name="geometry" >
+ <widget class="QDialog" name="QgsPluginInstallerDialogBase">
+ <property name="geometry">
<rect>
<x>0</x>
<y>0</y>
@@ -10,135 +11,175 @@
<height>382</height>
</rect>
</property>
- <property name="windowTitle" >
+ <property name="windowTitle">
<string>QGIS Python Plugin Installer</string>
</property>
- <property name="windowIcon" >
- <iconset resource="resources.qrc" >:/plugins/installer/qgis-icon.png</iconset>
+ <property name="windowIcon">
+ <iconset resource="resources.qrc">
+ <normaloff>:/plugins/installer/qgis-icon.png</normaloff>:/plugins/installer/qgis-icon.png</iconset>
</property>
- <property name="whatsThis" >
+ <property name="whatsThis">
</property>
- <layout class="QGridLayout" >
- <item row="1" column="0" >
- <layout class="QHBoxLayout" >
+ <layout class="QGridLayout">
+ <item row="1" column="0">
+ <layout class="QHBoxLayout">
<item>
- <widget class="QLabel" name="label_3" >
+ <widget class="QPushButton" name="buttonHelp">
+ <property name="text">
+ <string>Help</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <spacer name="horizontalSpacer_2">
+ <property name="orientation">
+ <enum>Qt::Horizontal</enum>
+ </property>
+ <property name="sizeType">
+ <enum>QSizePolicy::Fixed</enum>
+ </property>
+ <property name="sizeHint" stdset="0">
+ <size>
+ <width>20</width>
+ <height>20</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ <item>
+ <widget class="QLabel" name="label_3">
<string/>
</property>
- <property name="text" >
<string>The plugins will be installed to ~/.qgis/python/plugins</string>
</property>
</widget>
</item>
<item>
- <widget class="QPushButton" name="buttonClose" >
- <property name="sizePolicy" >
- <sizepolicy vsizetype="Fixed" hsizetype="Fixed" >
+ <spacer name="horizontalSpacer">
+ </property>
+ <size>
+ <width>40</width>
+ </size>
+ </property>
+ </spacer>
+ </item>
+ <item>
+ <widget class="QPushButton" name="buttonClose">
+ <property name="sizePolicy">
+ <sizepolicy hsizetype="Fixed" vsizetype="Fixed">
<horstretch>0</horstretch>
<verstretch>0</verstretch>
</sizepolicy>
</property>
- <property name="toolTip" >
+ <property name="toolTip">
<string>Close the Installer window</string>
</property>
</property>
<string>Close</string>
</property>
</widget>
</item>
</layout>
</item>
- <item row="0" column="0" >
- <widget class="QTabWidget" name="tabWidget" >
+ <item row="0" column="0">
+ <widget class="QTabWidget" name="tabWidget">
<string/>
</property>
<string/>
</property>
- <property name="currentIndex" >
+ <property name="currentIndex">
<number>0</number>
</property>
- <widget class="QWidget" name="tab" >
- <attribute name="title" >
+ <widget class="QWidget" name="tab">
+ <attribute name="title">
<string>Plugins</string>
</attribute>
- <attribute name="toolTip" >
+ <attribute name="toolTip">
<string>List of available and installed plugins</string>
</attribute>
- <layout class="QVBoxLayout" >
+ <layout class="QVBoxLayout">
<item>
<item>
- <widget class="QLabel" name="label_5" >
- <property name="enabled" >
+ <widget class="QLabel" name="label_5">
+ <property name="enabled">
<bool>true</bool>
</property>
<string>Filter:</string>
</property>
+ <property name="buddy">
+ <cstring>lineFilter</cstring>
+ </property>
</widget>
</item>
<item>
- <widget class="QLineEdit" name="lineFilter" >
+ <widget class="QLineEdit" name="lineFilter">
<bool>true</bool>
</property>
<string>Display only plugins containing this word in their metadata</string>
</property>
</property>
</widget>
</item>
<item>
- <widget class="QComboBox" name="comboFilter1" >
+ <widget class="QComboBox" name="comboFilter1">
<bool>true</bool>
</property>
- <sizepolicy vsizetype="Fixed" hsizetype="Expanding" >
+ <sizepolicy hsizetype="Expanding" vsizetype="Fixed">
</sizepolicy>
</property>
<string>Display only plugins from given repository</string>
</property>
- <property name="statusTip" >
+ <property name="statusTip">
<string/>
</property>
</property>
<item>
<string>all repositories</string>
</property>
</item>
</widget>
</item>
<item>
- <widget class="QComboBox" name="comboFilter2" >
+ <widget class="QComboBox" name="comboFilter2">
<bool>true</bool>
</property>
- <sizepolicy vsizetype="Fixed" hsizetype="Preferred" >
+ <sizepolicy hsizetype="Preferred" vsizetype="Fixed">
</sizepolicy>
</property>
<string>Display only plugins with matching status</string>
</property>
</property>
</widget>
@@ -146,62 +187,62 @@
</layout>
</item>
<item>
- <widget class="QTreeWidget" name="treePlugins" >
- <property name="alternatingRowColors" >
+ <widget class="QTreeWidget" name="treePlugins">
+ <property name="alternatingRowColors">
<bool>true</bool>
</property>
- <property name="rootIsDecorated" >
+ <property name="rootIsDecorated">
<bool>false</bool>
</property>
- <property name="itemsExpandable" >
+ <property name="itemsExpandable">
<bool>false</bool>
</property>
- <property name="sortingEnabled" >
+ <property name="sortingEnabled">
<bool>true</bool>
</property>
- <property name="allColumnsShowFocus" >
+ <property name="allColumnsShowFocus">
<bool>true</bool>
</property>
<column>
<string>Status</string>
</property>
</column>
<column>
<string>Name</string>
</property>
</column>
<column>
<string>Version</string>
</property>
</column>
<column>
<string>Description</string>
</property>
</column>
<column>
<string>Author</string>
</property>
</column>
<column>
<string>Repository</string>
</property>
</column>
</widget>
</item>
<item>
<item>
<spacer>
- <property name="orientation" >
</property>
- <property name="sizeHint" stdset="0" >
<size>
<width>40</width>
<height>20</height>
@@ -210,42 +251,42 @@
</spacer>
</item>
<item>
- <widget class="QPushButton" name="buttonInstall" >
+ <widget class="QPushButton" name="buttonInstall">
</sizepolicy>
</property>
- <property name="minimumSize" >
+ <property name="minimumSize">
<size>
<width>160</width>
<height>0</height>
</size>
</property>
<string>Install, reinstall or upgrade the selected plugin</string>
</property>
</property>
<string>Install/upgrade plugin</string>
</property>
</widget>
</item>
<item>
- <widget class="QPushButton" name="buttonUninstall" >
+ <widget class="QPushButton" name="buttonUninstall">
<bool>true</bool>
</property>
<string>Uninstall the selected plugin</string>
</property>
</property>
<string>Uninstall plugin</string>
</property>
</widget>
@@ -254,48 +295,48 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="tab_2" >
+ <widget class="QWidget" name="tab_2">
<string>Repositories</string>
</attribute>
<string>List of plugin repositories</string>
</attribute>
- <item row="0" column="0" colspan="7" >
- <widget class="QTreeWidget" name="treeRepositories" >
+ <item row="0" column="0" colspan="7">
+ <widget class="QTreeWidget" name="treeRepositories">
<bool>false</bool>
</property>
<bool>false</bool>
</property>
<column>
</property>
</column>
<column>
</property>
</column>
<column>
<string>URL</string>
</property>
</column>
</widget>
</item>
- <item row="1" column="1" >
+ <item row="1" column="1">
<spacer>
</property>
- <property name="sizeType" >
<enum>QSizePolicy::Preferred</enum>
</property>
<size>
<width>20</width>
<height>20</height>
@@ -303,28 +344,28 @@
</property>
</spacer>
</item>
- <item row="1" column="2" >
- <widget class="QPushButton" name="buttonFetchRepositories" >
+ <item row="1" column="2">
+ <widget class="QPushButton" name="buttonFetchRepositories">
<bool>true</bool>
</property>
<string>Add third party plugin repositories to the list</string>
</property>
</property>
<string>Add 3rd party repositories</string>
</property>
</widget>
</item>
- <item row="1" column="3" >
+ <item row="1" column="3">
<spacer>
</property>
<size>
<width>40</width>
<height>20</height>
@@ -332,119 +373,119 @@
</property>
</spacer>
</item>
- <item row="1" column="4" >
- <widget class="QPushButton" name="buttonAddRep" >
+ <item row="1" column="4">
+ <widget class="QPushButton" name="buttonAddRep">
<string>Add a new plugin repository</string>
</property>
</property>
<string>Add...</string>
</property>
</widget>
</item>
- <item row="1" column="5" >
- <widget class="QPushButton" name="buttonEditRep" >
+ <item row="1" column="5">
+ <widget class="QPushButton" name="buttonEditRep">
<string>Edit the selected repository</string>
</property>
</property>
<string>Edit...</string>
</property>
</widget>
</item>
- <item row="1" column="6" >
- <widget class="QPushButton" name="buttonDeleteRep" >
+ <item row="1" column="6">
+ <widget class="QPushButton" name="buttonDeleteRep">
<string>Remove the selected repository</string>
</property>
</property>
<string>Delete</string>
</property>
</widget>
</item>
</layout>
</widget>
- <widget class="QWidget" name="tab_3" >
+ <widget class="QWidget" name="tab_3">
<string>Options</string>
</attribute>
<string>Configuration of the plugin installer</string>
</attribute>
- <layout class="QVBoxLayout" name="verticalLayout" >
+ <layout class="QVBoxLayout" name="verticalLayout">
<item>
- <widget class="QGroupBox" name="checkUpdates" >
+ <widget class="QGroupBox" name="checkUpdates">
<bool>true</bool>
</property>
- <sizepolicy vsizetype="Preferred" hsizetype="Preferred" >
+ <sizepolicy hsizetype="Preferred" vsizetype="Preferred">
</sizepolicy>
</property>
- <property name="title" >
+ <property name="title">
<string>Check for updates on startup</string>
</property>
- <property name="checkable" >
+ <property name="checkable">
<bool>true</bool>
</property>
- <property name="checked" >
+ <property name="checked">
<bool>false</bool>
</property>
- <layout class="QGridLayout" name="gridLayout" >
- <widget class="QComboBox" name="comboInterval" >
+ <layout class="QGridLayout" name="gridLayout">
+ <widget class="QComboBox" name="comboInterval">
<item>
<string>every time QGIS starts</string>
</property>
</item>
<item>
<string>once a day</string>
</property>
</item>
<item>
<string>every 3 days</string>
</property>
</item>
<item>
<string>every week</string>
</property>
</item>
<item>
<string>every 2 weeks</string>
</property>
</item>
<item>
<string>every month</string>
</property>
</item>
</widget>
</item>
- <item row="2" column="0" >
- <spacer name="verticalSpacer_3" >
+ <item row="2" column="0">
+ <spacer name="verticalSpacer_3">
<enum>Qt::Vertical</enum>
</property>
</property>
<size>
<width>20</width>
<height>10</height>
@@ -452,22 +493,22 @@
</property>
</spacer>
</item>
- <widget class="QLabel" name="label" >
+ <widget class="QLabel" name="label">
</sizepolicy>
</property>
- <string><!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
-<html><head><meta name="qrichtext" content="1" /><style type="text/css">
+ <string><!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><meta name="qrichtext" content="1" /><style type="text/css">
p, li { white-space: pre-wrap; }
-</style></head><body style=" font-family:'DejaVu Sans'; font-size:9pt; font-weight:400; font-style:normal;">
-<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-weight:600;">Note:</span> If this function is enabled, Quantum GIS will inform you whenever a new plugin or plugin update is available. Otherwise, fetching repositories will be performed during opening of the Plugin Installer window.</p></body></html></string>
+</style></head><body style=" font-family:'DejaVu Sans'; font-size:9pt; font-weight:400; font-style:normal;">
+<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-weight:600;">Note:</span> If this function is enabled, Quantum GIS will inform you whenever a new plugin or plugin update is available. Otherwise, fetching repositories will be performed during opening of the Plugin Installer window.</p></body></html></string>
</property>
- <property name="wordWrap" >
+ <property name="wordWrap">
<bool>true</bool>
</property>
</widget>
@@ -476,81 +517,81 @@
</widget>
</item>
<item>
- <widget class="QGroupBox" name="groupBox_2" >
+ <widget class="QGroupBox" name="groupBox_2">
<verstretch>1</verstretch>
</sizepolicy>
</property>
<string>Allowed plugins</string>
</property>
- <layout class="QGridLayout" name="gridLayout_2" >
- <widget class="QRadioButton" name="radioPluginType0" >
+ <layout class="QGridLayout" name="gridLayout_2">
+ <widget class="QRadioButton" name="radioPluginType0">
<bool>false</bool>
</property>
<string>Only show plugins from the official repository</string>
</property>
<bool>true</bool>
</property>
</widget>
</item>
- <widget class="QRadioButton" name="radioPluginType1" >
+ <widget class="QRadioButton" name="radioPluginType1">
<bool>false</bool>
</property>
<string>Show all plugins except those marked as experimental</string>
</property>
<bool>false</bool>
</property>
</widget>
</item>
- <widget class="QRadioButton" name="radioPluginType2" >
+ <widget class="QRadioButton" name="radioPluginType2">
<bool>false</bool>
</property>
<string>Show all plugins, even those marked as experimental</string>
</property>
</widget>
</item>
- <item row="3" column="0" >
- <widget class="QLabel" name="label_2" >
- <sizepolicy vsizetype="MinimumExpanding" hsizetype="Preferred" >
+ <item row="3" column="0">
+ <widget class="QLabel" name="label_2">
+ <sizepolicy hsizetype="Preferred" vsizetype="MinimumExpanding">
</sizepolicy>
</property>
<size>
<width>0</width>
<height>75</height>
</size>
</property>
-<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-weight:600;">Note:</span> Experimental plugins are generally unsuitable for production use. These plugins are in early stages of development, and should be considered 'incomplete' or 'proof of concept' tools. QGIS does not recommend installing these plugins unless you intend to use them for testing purposes.</p></body></html></string>
+<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-weight:600;">Note:</span> Experimental plugins are generally unsuitable for production use. These plugins are in early stages of development, and should be considered 'incomplete' or 'proof of concept' tools. QGIS does not recommend installing these plugins unless you intend to use them for testing purposes.</p></body></html></string>
</property>
- <property name="textFormat" >
+ <property name="textFormat">
<enum>Qt::RichText</enum>
</property>
- <property name="alignment" >
+ <property name="alignment">
<set>Qt::AlignLeading|Qt::AlignLeft|Qt::AlignTop</set>
</property>
<bool>true</bool>
</property>
</widget>
@@ -573,6 +614,7 @@
<tabstop>buttonInstall</tabstop>
<tabstop>buttonUninstall</tabstop>
<tabstop>buttonClose</tabstop>
+ <tabstop>buttonHelp</tabstop>
<tabstop>treeRepositories</tabstop>
<tabstop>buttonFetchRepositories</tabstop>
<tabstop>buttonAddRep</tabstop>
@@ -585,7 +627,7 @@
<tabstop>radioPluginType2</tabstop>
</tabstops>
<resources>
- <include location="resources.qrc" />
+ <include location="resources.qrc"/>
</resources>
<connections>
<connection>
@@ -594,11 +636,11 @@
<receiver>QgsPluginInstallerDialogBase</receiver>
<slot>close()</slot>
<hints>
- <hint type="sourcelabel" >
- <x>710</x>
- <y>447</y>
+ <hint type="sourcelabel">
+ <x>790</x>
+ <y>372</y>
</hint>
- <hint type="destinationlabel" >
+ <hint type="destinationlabel">
<x>380</x>
<y>235</y>
</hint>
Modified: trunk/qgis/python/utils.py
--- trunk/qgis/python/utils.py 2009-12-15 17:00:36 UTC (rev 12475)
+++ trunk/qgis/python/utils.py 2009-12-15 17:47:00 UTC (rev 12476)
@@ -159,6 +159,6 @@
del plugins[packageName]
return True
except Exception, e:
- errMsg = QCoreApplication.translate("Python", "Error while unloading plugin %1").arg(packageName)
+ msg = QCoreApplication.translate("Python", "Error while unloading plugin %1").arg(packageName)
showException(sys.exc_type, sys.exc_value, sys.exc_traceback, msg)
return False
