[QGIS Commit] r12477 - in trunk/qgis/src/plugins/grass: modules-6.4
scripts
svn_qgis at osgeo.org
Tue Dec 15 12:47:17 EST 2009
Author: pcav
Date: 2009-12-15 12:47:16 -0500 (Tue, 15 Dec 2009)
New Revision: 12477
trunk/qgis/src/plugins/grass/modules-6.4/v.out.ogr.pg.qgm
trunk/qgis/src/plugins/grass/scripts/v.out.ogr.pg.py
Reverted change to v.out.ogr.pg due to a possible bug in GRASS
Modified: trunk/qgis/src/plugins/grass/modules-6.4/v.out.ogr.pg.qgm
--- trunk/qgis/src/plugins/grass/modules-6.4/v.out.ogr.pg.qgm 2009-12-15 17:47:00 UTC (rev 12476)
+++ trunk/qgis/src/plugins/grass/modules-6.4/v.out.ogr.pg.qgm 2009-12-15 17:47:16 UTC (rev 12477)
@@ -1,8 +1,7 @@
<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
-<qgisgrassmodule label="Export vector to PostGIS (PostgreSQL) database table." module="v.out.ogr.pg.py" manual="v.out.ogr">
- <flag key="c" answer="off" hidden="no"/>
+<qgisgrassmodule label="Export vector to PostGIS (PostgreSQL) database table" module="v.out.ogr.pg.py" manual="v.out.ogr">
<option key="input" layeroption="layer" typeoption="type" />
<option key="olayer" />
<option key="database" />
Modified: trunk/qgis/src/plugins/grass/scripts/v.out.ogr.pg.py
--- trunk/qgis/src/plugins/grass/scripts/v.out.ogr.pg.py 2009-12-15 17:47:00 UTC (rev 12476)
+++ trunk/qgis/src/plugins/grass/scripts/v.out.ogr.pg.py 2009-12-15 17:47:16 UTC (rev 12477)
@@ -137,7 +137,7 @@
if user: dsn += " user=" + user
if password: dsn += " password=" + password
- if grass.run_command('v.out.ogr', flags=flags_string, input=input, layer=layer, type=type, format="PostgreSQL", dsn=dsn, olayer=olayer ) != 0:
+ if grass.run_command('v.out.ogr', input=input, layer=layer, type=type, format="PostgreSQL", dsn=dsn, olayer=olayer ) != 0:
grass.fatal("Cannot export vector to database.")
if __name__ == "__main__":
