[QGIS Commit] r12499 - trunk/qgis/resources/context_help
svn_qgis at osgeo.org
Thu Dec 17 05:46:13 EST 2009
Author: borysiasty
Date: 2009-12-17 05:46:11 -0500 (Thu, 17 Dec 2009)
New Revision: 12499
Added:
trunk/qgis/resources/context_help/MapServerExport-pl_PL
trunk/qgis/resources/context_help/QgsGPSPluginGui-de_DE
trunk/qgis/resources/context_help/QgsGPSPluginGui-en_US
trunk/qgis/resources/context_help/QgsGPSPluginGui-ru_RU
trunk/qgis/resources/context_help/QgsGPSPluginGui-sk_SK
trunk/qgis/resources/context_help/QgsWMSSourceSelect-de_DE
trunk/qgis/resources/context_help/QgsWMSSourceSelect-ru_RU
trunk/qgis/resources/context_help/QgsWMSSourceSelect-sk_SK
trunk/qgis/resources/context_help/QgsWMSSourceSelect-sv_SE
Removed:
trunk/qgis/resources/context_help/QgsGPSPlugin-de_DE
trunk/qgis/resources/context_help/QgsGPSPlugin-en_US
trunk/qgis/resources/context_help/QgsGPSPlugin-ru_RU
trunk/qgis/resources/context_help/QgsGPSPlugin-sk_SK
trunk/qgis/resources/context_help/QgsMapserverExport-en_US
trunk/qgis/resources/context_help/QgsMapserverExport-pl_PL
trunk/qgis/resources/context_help/QgsNewHttpConnection-de_DE
trunk/qgis/resources/context_help/QgsNewHttpConnection-en_US
trunk/qgis/resources/context_help/QgsNewHttpConnection-ru_RU
trunk/qgis/resources/context_help/QgsNewHttpConnection-sk_SK
trunk/qgis/resources/context_help/QgsNewHttpConnection-sv_SE
trunk/qgis/resources/context_help/MapServerExport-en_US
trunk/qgis/resources/context_help/QgsCustomProjectionDialog-en_US
trunk/qgis/resources/context_help/QgsNewVectorLayerDialog-en_US
trunk/qgis/resources/context_help/QgsNewVectorLayerDialog-fr_FR
trunk/qgis/resources/context_help/QgsVectorLayerProperties-en_US
Context help updates from Milena
Modified: trunk/qgis/resources/context_help/MapServerExport-en_US
--- trunk/qgis/resources/context_help/MapServerExport-en_US 2009-12-17 08:51:53 UTC (rev 12498)
+++ trunk/qgis/resources/context_help/MapServerExport-en_US 2009-12-17 10:46:11 UTC (rev 12499)
@@ -1 +1,34 @@
-<h3>MapServer Export</h3>
+<h3>Export a QGIS Project to MapServer Map File</h3>
+<p>
+This tool allows you to export a saved QGIS project file to a MapServer map
+file. The tool is installed in your QGIS binary directory and can be used
+independently of QGIS. Only the <b>Map file</b> and <b>QGIS project file</b> inputs are required.
+</p>
+Tick the <label>Use current project</label> checkbox or enter the full path to the QGIS project file (.qgs) you want to export. You can use the button at the right to browse for the QGIS project file.
+<h4>Map file</h4>
+<label>Map file</label> Enter the name for the map file to be created. You can use the button at the right to browse for the directory where you want the map file created.
+<h4>Map</h4>
+These values are written to the map file in the appropriate spots to set things such as output image size, units and image type.
+<dl>
+ <dt><label>Name</label></dt>
+ <dd>A name for the map. This name is prefixed to all images generated by the MapServer.</dd>
+ <dt><label>Width</label></dt>
+ <dd>Width of the output image in pixels.</dd>
+ <dt><label>Height</label></dt>
+ <dd>Height of the output image in pixels.</dd>
+ <dt><label>Units</label></dt>
+ <dd>Units of measure used for output.</dd>
+ <dt><label>Image type</label></dt>
+ <dd>Format for the output image generated by MapServer</dd>
+</dl>
+<h4>Paths</h4>
+<dl>
+ <dt><label>Template</label></dt>
+ <dd>Full path to the MapServer template file to be used with the map file.</dd>
+ <dt><label>Header</label></dt>
+ <dd>Full path to the MapServer header file to be used with the map file.</dd>
+ <dt><label>Footer</label></dt>
+ <dd>Full path to the MapServer footer file to be used with the map file.</dd>
Added: trunk/qgis/resources/context_help/MapServerExport-pl_PL
--- trunk/qgis/resources/context_help/MapServerExport-pl_PL (rev 0)
+++ trunk/qgis/resources/context_help/MapServerExport-pl_PL 2009-12-17 10:46:11 UTC (rev 12499)
@@ -0,0 +1,32 @@
+<h3>Eksport projektu QGIS do pliku w formacie mapy MapServera</h3>
+<p>
+To narzędzie umożliwia wyeksportowanie zapisanego projetu QGIS
+do pliku w formacie mapy MapServer. Program do eksportu to plik binarny i może być wykorzystany niezależnie od programu głównego QGIS. Należy jedynie podać <b>nazwę pliku mapy MapServera</b> oraz <b>nazwę pliku projektu QGIS</b>.
+<p>
+Zaznacz <label>Użyj bieżącego projektu</label> lub podaj pełną ścieżkę dostępu do pliku projektu QGIS (.qgs), który chcesz wyeksportować. Możesz wykorzystać przycisk znajdujący się po prawej stronie, aby przeglądać katalogi.
+<h4>Plik mapy</h4>
+<label>Plik mapy</label> Podaj nazwę pliku mapy, który zostanie utworzony. Użyj przycisku znajdującego się po prawej stronie, aby wskazać katalog w którym będzie zapisany.
+<h4>Mapa</h4>
+Te parametry zostaną zapisane w pliku mapy, określając takie elementy mapy, jak rozmiar mapy, jednostki, czy też format mapy.
+<dl>
+ <label>Nazwa</label>
+ <dd>Ta nazwa jest prefiksem dla wszystkich map generowanych przez MapServer.</dd>
+ <label>Szerokość</label>
+ <dd>Szerokość mapy wyjściowej w pikselach.</dd>
+ <label>Wysokość</label>
+ <dd>Wysokość mapy wyjściowej w pikselach.</dd>
+ <label>Jednostki</label>
+ <dd>Jednostki miary mapy wyjściowej.</dd>
+ <label>Format mapy</label>
+ <dd>Określa w jakim formacie zostanie wygenerowana mapa MapServera</dd>
+</dl>
+<h4>Ścieżki</h4>
+<dl>
+ <label>Szablon</label>
+ <dd>Pełna ścieżka dostępu do pliku z szablonem MapServera, który ma zostać wykorzystany.</dd>
+ <label>Nagłówek</label>
+ <dd>Pełna ścieżka dostępu do pliku nagłówkowego MapServera, który ma zostać wykorzystany.</dd>
+ <label>Stopka</label>
+ <dd>Pełna ścieżka dostępu do pliku stopki MapServera, który ma zostać wykorzystany.</dd>
Modified: trunk/qgis/resources/context_help/QgsCustomProjectionDialog-en_US
--- trunk/qgis/resources/context_help/QgsCustomProjectionDialog-en_US 2009-12-17 08:51:53 UTC (rev 12498)
+++ trunk/qgis/resources/context_help/QgsCustomProjectionDialog-en_US 2009-12-17 10:46:11 UTC (rev 12499)
@@ -1 +1,16 @@
<h3>Custom Coordinate Reference System Definition</h3>
+If QGIS does not provide the coordinate reference system you need, you can define a custom CRS. <p>
+To define a CRS, select <label>Custom CRS</label> from the <label>Edit</label> (Gnome, OSX) or <label>Settings</label> (KDE, Windows) menu. Custom CRS are stored in your QGIS user database. In addition to your custom CRS, this database also contains your spatial bookmarks and other custom data.
+<h4>Define</h4>
+To create a new CRS, click the <label>New</label> button and enter:
+<ul>
+<li>descriptive name
+<li>CRS parameters
+</ul>
+After that you can save your CRS by clicking the button <label>Save</label>.
+<p>
+Note that the Parameters must begin with a +proj=-block, to represent the new coordinate reference
+system.
+<p>
+Defining a custom CRS in QGIS requires a good understanding of the Proj.4 projection library. To begin, refer to the <i>Cartographic Projection Procedures for the UNIX Environment</i> - A User's Manual by Gerald I. Evenden, U.S. Geological Survey Open-File Report 90-284, 1990 (available at ftp://ftp.remotesensing.org/proj/OF90-284.pdf). This manual describes the use of the <i>proj.4</i> and related command line utilities. The cartographic parameters used with <i>proj.4</i> are described in the user manual, and are the same as those used by QGIS.
\ No newline at end of file
Deleted: trunk/qgis/resources/context_help/QgsGPSPlugin-de_DE
--- trunk/qgis/resources/context_help/QgsGPSPlugin-de_DE 2009-12-17 08:51:53 UTC (rev 12498)
+++ trunk/qgis/resources/context_help/QgsGPSPlugin-de_DE 2009-12-17 10:46:11 UTC (rev 12499)
@@ -1 +0,0 @@
-<h3>GPS-Plugin</h3>
Deleted: trunk/qgis/resources/context_help/QgsGPSPlugin-en_US
--- trunk/qgis/resources/context_help/QgsGPSPlugin-en_US 2009-12-17 08:51:53 UTC (rev 12498)
+++ trunk/qgis/resources/context_help/QgsGPSPlugin-en_US 2009-12-17 10:46:11 UTC (rev 12499)
@@ -1 +0,0 @@
-<h3>GPS Plugin</h3>
Deleted: trunk/qgis/resources/context_help/QgsGPSPlugin-ru_RU
--- trunk/qgis/resources/context_help/QgsGPSPlugin-ru_RU 2009-12-17 08:51:53 UTC (rev 12498)
+++ trunk/qgis/resources/context_help/QgsGPSPlugin-ru_RU 2009-12-17 10:46:11 UTC (rev 12499)
@@ -1 +0,0 @@
-<h3>Инструменты GPS</h3>
Deleted: trunk/qgis/resources/context_help/QgsGPSPlugin-sk_SK
--- trunk/qgis/resources/context_help/QgsGPSPlugin-sk_SK 2009-12-17 08:51:53 UTC (rev 12498)
+++ trunk/qgis/resources/context_help/QgsGPSPlugin-sk_SK 2009-12-17 10:46:11 UTC (rev 12499)
@@ -1 +0,0 @@
-<h3>Zásuvný modul na prácu s GPS</h3>
Copied: trunk/qgis/resources/context_help/QgsGPSPluginGui-de_DE (from rev 12498, trunk/qgis/resources/context_help/QgsGPSPlugin-de_DE)
--- trunk/qgis/resources/context_help/QgsGPSPluginGui-de_DE (rev 0)
+++ trunk/qgis/resources/context_help/QgsGPSPluginGui-de_DE 2009-12-17 10:46:11 UTC (rev 12499)
@@ -0,0 +1 @@
+<h3>GPS-Plugin</h3>
Copied: trunk/qgis/resources/context_help/QgsGPSPluginGui-en_US (from rev 12498, trunk/qgis/resources/context_help/QgsGPSPlugin-en_US)
--- trunk/qgis/resources/context_help/QgsGPSPluginGui-en_US (rev 0)
+++ trunk/qgis/resources/context_help/QgsGPSPluginGui-en_US 2009-12-17 10:46:11 UTC (rev 12499)
@@ -0,0 +1 @@
+<h3>GPS Plugin</h3>
Copied: trunk/qgis/resources/context_help/QgsGPSPluginGui-ru_RU (from rev 12498, trunk/qgis/resources/context_help/QgsGPSPlugin-ru_RU)
--- trunk/qgis/resources/context_help/QgsGPSPluginGui-ru_RU (rev 0)
+++ trunk/qgis/resources/context_help/QgsGPSPluginGui-ru_RU 2009-12-17 10:46:11 UTC (rev 12499)
@@ -0,0 +1 @@
+<h3>Инструменты GPS</h3>
Copied: trunk/qgis/resources/context_help/QgsGPSPluginGui-sk_SK (from rev 12498, trunk/qgis/resources/context_help/QgsGPSPlugin-sk_SK)
--- trunk/qgis/resources/context_help/QgsGPSPluginGui-sk_SK (rev 0)
+++ trunk/qgis/resources/context_help/QgsGPSPluginGui-sk_SK 2009-12-17 10:46:11 UTC (rev 12499)
@@ -0,0 +1 @@
+<h3>Zásuvný modul na prácu s GPS</h3>
Deleted: trunk/qgis/resources/context_help/QgsMapserverExport-en_US
--- trunk/qgis/resources/context_help/QgsMapserverExport-en_US 2009-12-17 08:51:53 UTC (rev 12498)
+++ trunk/qgis/resources/context_help/QgsMapserverExport-en_US 2009-12-17 10:46:11 UTC (rev 12499)
@@ -1,35 +0,0 @@
-<h3>Export a QGIS Project to MapServer Map File</h3>
-<p>
-This tool allows you to export a saved QGIS project file to a MapServer map
-file. The tool is installed in your QGIS binary directory and can be used
-independently of QGIS. Only the <b>Map file</b> and <b>QGIS project file</b> inputs are required.
-</p>
-<h4>File Inputs</h4>
-<dl>
- <dt>Map file</dt>
- <dd>Enter the name for the map file to be created. You can use the button at the right to browse for the directory where you want the map file created.
- <dt>Qgis project file</dt>
- <dd>Enter the full path to the QGIS project file (.qgs) you want to export. You can use the button at the right to browse for the QGIS project file.</dd>
-</dl>
-<h4>Map Parameters</h4>
-These values are written to the map file in the appropriate spots to set things such as output image size, units and image type.
-<dl>
- <dt>Name</dt>
- <dd>A name for the map. This name is prefixed to all images generated by the MapServer.</dd>
- <dt>Width</dt>
- <dd>Width of the output image in pixels.</dd>
- <dt>Height</dt>
- <dd>Height of the output image in pixels.</dd>
- <dt>Units</dt>
- <dd>Units of measure used for output.</dd>
- <dt>Image type</dt>
- <dd>Format for the output image generated by MapServer</dd>
-</dl>
-<h4>Web Interface Definition</h4>
-<dl>
- <dt>Template</dt>
- <dd>Full path to the MapServer template file to be used with the map file.</dd>
- <dt>Header</dt>
- <dd>Full path to the MapServer header file to be used with the map file.</dd>
- <dt>Footer</dt>
- <dd>Full path to the MapServer footer file to be used with the map file.</dd>
Deleted: trunk/qgis/resources/context_help/QgsMapserverExport-pl_PL
--- trunk/qgis/resources/context_help/QgsMapserverExport-pl_PL 2009-12-17 08:51:53 UTC (rev 12498)
+++ trunk/qgis/resources/context_help/QgsMapserverExport-pl_PL 2009-12-17 10:46:11 UTC (rev 12499)
@@ -1,34 +0,0 @@
-<h3>Eksport projektu QGIS do pliku w formacie mapy MapServera</h3>
-<p>
-To narzędzie umożliwia wyeksportowanie zapisanego projetu QGIS
-do pliku w formacie mapy MapServer. Program do eksportu to plik binarny i może być wykorzystany niezależnie od programu głównego QGIS. Należy jedynie podać <b>nazwę pliku mapy MapServera</b> oraz <b>nazwę pliku projektu QGIS</b>.
-</p>
-<h4>Pliki wejściowe</h4>
-<dl>
- <dt>Nazwa pliku mapy MapServera</dt>
- <dd>Podaj nazwę pliku mapy, który zostanie utworzony. Możesz wykorzystać przycisk znajdujący się po prawej stronie, aby wskazać kartotekę w której będzie zapisany.
- <dt>Nazwa pliku projektu QGIS</dt>
- <dd>Podaj pełną ścieżkę dostępu do pliku projektu QGIS (.qgs), który chcesz wyeksportować. Możesz wykorzystać przycisk znajdujący się po prawej stronie, aby przeglądać kartoteki.</dd>
-</dl>
-<h4>Parametry mapy</h4>
-Te parametry zostaną zapisane w pliku mapy, określając takie elementy mapy, jak rozmiar mapy, jednostki, czy też format mapy.
-<dl>
- <dt>Nazwa</dt>
- <dd>Nazwa mapy. Ta nazwa jest prefiksem dla wszystkich map generowanych przez MapServer.</dd>
- <dt>Szerokość</dt>
- <dd>Szerokość mapy wyjściowej w pikselach.</dd>
- <dt>Wysokość</dt>
- <dd>Wysokość mapy wyjściowej w pikselach.</dd>
- <dt>Jednostki</dt>
- <dd>Jednostki miary mapy wyjściowej.</dd>
- <dt>Format mapy</dt>
- <dd>Określa w jakim formacie zostanie wygenerowana mapa MapServera</dd>
-</dl>
-<dl>
- <dt>Szablon</dt>
- <dd>Pełna ścieżka dostępu do pliku z szablonem MapServera, który ma zostać wykorzystany.</dd>
- <dt>Nagłówek</dt>
- <dd>Pełna ścieżka dostępu do pliku nagłówkowego MapServera, który ma zostać wykorzystany.</dd>
- <dt>Stopka</dt>
- <dd>Pełna ścieżka dostępu do pliku stopki MapServera, który ma zostać wykorzystany.</dd>
Deleted: trunk/qgis/resources/context_help/QgsNewHttpConnection-de_DE
--- trunk/qgis/resources/context_help/QgsNewHttpConnection-de_DE 2009-12-17 08:51:53 UTC (rev 12498)
+++ trunk/qgis/resources/context_help/QgsNewHttpConnection-de_DE 2009-12-17 10:46:11 UTC (rev 12499)
@@ -1 +0,0 @@
-<h3>Eine neue WMS-Verbindung anlegen</h3>
Deleted: trunk/qgis/resources/context_help/QgsNewHttpConnection-en_US
--- trunk/qgis/resources/context_help/QgsNewHttpConnection-en_US 2009-12-17 08:51:53 UTC (rev 12498)
+++ trunk/qgis/resources/context_help/QgsNewHttpConnection-en_US 2009-12-17 10:46:11 UTC (rev 12499)
@@ -1 +0,0 @@
-<h3>Create a new WMS connection</h3>
Deleted: trunk/qgis/resources/context_help/QgsNewHttpConnection-ru_RU
(Binary files differ)
Deleted: trunk/qgis/resources/context_help/QgsNewHttpConnection-sk_SK
--- trunk/qgis/resources/context_help/QgsNewHttpConnection-sk_SK 2009-12-17 08:51:53 UTC (rev 12498)
+++ trunk/qgis/resources/context_help/QgsNewHttpConnection-sk_SK 2009-12-17 10:46:11 UTC (rev 12499)
@@ -1 +0,0 @@
-<h3>Vytvorenie nového spojenia WMS</h3>
Deleted: trunk/qgis/resources/context_help/QgsNewHttpConnection-sv_SE
--- trunk/qgis/resources/context_help/QgsNewHttpConnection-sv_SE 2009-12-17 08:51:53 UTC (rev 12498)
+++ trunk/qgis/resources/context_help/QgsNewHttpConnection-sv_SE 2009-12-17 10:46:11 UTC (rev 12499)
@@ -1,2 +0,0 @@
-<h3>Skapa en ny WMS-uppkoppling</h3>
Modified: trunk/qgis/resources/context_help/QgsNewVectorLayerDialog-en_US
--- trunk/qgis/resources/context_help/QgsNewVectorLayerDialog-en_US 2009-12-17 08:51:53 UTC (rev 12498)
+++ trunk/qgis/resources/context_help/QgsNewVectorLayerDialog-en_US 2009-12-17 10:46:11 UTC (rev 12499)
@@ -1,2 +1,5 @@
<h3>Create New Vector Layer</h3>
+To create a new layer for editing, choose <label>New Vector Layer</label> from the <label>Layer</label> menu. <br/>
+Choose the type of layer <label>Point</label>, <label>Line</label> or <label>Polygon</label>.<br/>
+Add the desired attributes by clicking on the <label>Add</label> button and specifying a name and type for the attribute. Only real, integer, and string attributes are supported.<br/>
+You can also define the width and precision of the new attribute column.
Modified: trunk/qgis/resources/context_help/QgsNewVectorLayerDialog-fr_FR
--- trunk/qgis/resources/context_help/QgsNewVectorLayerDialog-fr_FR 2009-12-17 08:51:53 UTC (rev 12498)
+++ trunk/qgis/resources/context_help/QgsNewVectorLayerDialog-fr_FR 2009-12-17 10:46:11 UTC (rev 12499)
@@ -8,77 +8,55 @@
vectorielle, il existe trois possibilités:
</p>
<ul>
-<li>Sur la barre d'outils contrôle des couches de QGIS, appuyer sur
-le bouton <label>Nouvelle couche vectorielle</label>;
+<li>Sur la barre d'outils contrôle des couches de QGIS, appuyer sur le bouton <label>Nouvelle couche vectorielle</label>;
</li>
-<li>ou dans le menu <label>Couche</label>, sélectionner la fonction <label>Nouvelle
-couche vectorielle...</label>;
+<li>ou dans le menu <label>Couche</label>, sélectionner la fonction <label>Nouvelle couche vectorielle...</label>;
</li>
-<li>ou taper directement le raccourci clavier (<label>Shift+Ctrl+N</label>
-sous Mac OSX).
+<li>ou taper directement le raccourci clavier (<label>Shift+Ctrl+N</label> sous Mac OSX).
</li>
</ul>
<h4>Configuration de la couche vectorielle</h4>
<h5><u>Étape 1 : Choix du type</u></h5>
-Dans la boîte de dialogue <label>Nouvelle couche vecteur</label>, sélectionner
-le type de couche à créer en cochant le bouton souhaité:
+Dans la boîte de dialogue <label>Nouvelle couche vecteur</label>, sélectionner le type de couche à créer en cochant le bouton souhaité:
<ul>
-<li><label>Point</label> pour créer une couche contenant des objets de type
-ponctuels;
+<li><label>Point</label> pour créer une couche contenant des objets de type ponctuels;
</li>
-<li><label>Ligne</label> pour créer une couche contenant des objets de type
-linéaires;
+<li><label>Ligne</label> pour créer une couche contenant des objets de type linéaires;
</li>
-<li><label>Polygone</label> pour créer une couche contenant des objets de
-type surfaciques.
+<li><label>Polygone</label> pour créer une couche contenant des objets de type surfaciques.
</li>
</ul>
<h5><u>Étape 2 : Création et configuration des Attributs de couche</u></h5>
-Quel que soit le type de couche choisi, la configuration des attributs
-de la couche se fait toujours de la même manière:
+Quel que soit le type de couche choisi, la configuration des attributs de la couche se fait toujours de la même manière:
<ol>
<li>Entrer un nom pour l'attribut dans la case <label>Nom</label>;
</li>
<li>Choisir le type d'attribut à l'aide du menu déroulant <label>Type</label>
: <br>
<ul>
-<li><tab>Ligne (string) pour un attribut de type chaîne de
-caractère</tab></li>
+<li><tab>Ligne (string) pour un attribut de type chaîne de caractère</tab></li>
<li><tab>Entier (integer) pour un attribut de type nombres entiers</tab></li>
<li><tab>Réel (real) pour un attribut de type nombres réels</tab></li>
</ul>
</li>
-<li>Spécifier la largeur de l'attribut (nombre de caractères maximum)
-en entrant une valeur dans la case <label>Largeur</label> (facultatif);
+<li>Spécifier la largeur de l'attribut (nombre de caractères maximum) en entrant une valeur dans la case <label>Largeur</label> (facultatif);
</li>
-<li>Pour les attributs de type réel uniquement, entrer la précision
-(nombre de chiffres après la virgule) dans la case <label>Précision</label>;
+<li>Pour les attributs de type réel uniquement, entrer la précision (nombre de chiffres après la virgule) dans la case <label>Précision</label>;
</li>
-<li>Créer l'attribut de couche en appuyant sur le bouton <label>Ajouter
-l'attribut</label>.
+<li>Créer l'attribut de couche en appuyant sur le bouton <label>Ajouter l'attribut</label>.
</li>
</ol>
L'attribut créé apparaît alors dans la liste de la boîte de dialogue.<br>
Pour créer les attributs suivants, recommencer les opérations
ci-dessus.
<h5><u>Étape 3 optionnelle : Effacer un attribut de couche</u></h5>
-En cas d'erreur, il est possible d'effacer un attribut créé. Pour cela,
-sélectionner l'attribut dans la liste et appuyer sur le bouton <label>Effacer
-l'attribut sélectionné</label>.
+En cas d'erreur, il est possible d'effacer un attribut créé. Pour cela, sélectionner l'attribut dans la liste et appuyer sur le bouton <label>Effacer l'attribut sélectionné</label>.
<h5><u>Étape 4: Valider et créer la couche vectorielle</u></h5>
-Une fois les étapes 1 et 2 réalisées, valider la création de la couche
-en appuyant sur le bouton <label>OK</label> pour créer la couche ou sur le
-bouton <label>Annuler</label> pour fermer la boîte de dialogue sans créer la
-couche.
-<p>QGIS propose alors de choisir le nom et l'emplacement physique de
-stockage des fichiers shape dans l'arborescence de l'ordinateur :
-choisir un nom et un emplacement pour la couche puis appuyer sur <label>OK</label>
-pour valider le choix, ou sur <label>Annuler</label> pour quitter sans
-enregistrer.</p>
-<p>Une fois cette action réalisée, la couche est chargée dans le projet
-QGIS en cours.</p>
-<p><u>Important : </u> une nouvelle couche créée est forcément vide,
-il est donc normal qu'une couche nouvellement créée apparaisse dans la
-barre d'outils <label>Couches</label>, mais qu'aucune donnée n'apparaisse sur
-la carte du projet. Pour entrer des données dans la couche il est
+Une fois les étapes 1 et 2 réalisées, valider la création de la couche en appuyant sur le bouton <label>OK</label> pour créer la couche ou sur le
+bouton <label>Annuler</label> pour fermer la boîte de dialogue sans créer la couche.
+<p>QGIS propose alors de choisir le nom et l'emplacement physique de stockage des fichiers shape dans l'arborescence de l'ordinateur : choisir un nom et un emplacement pour la couche puis appuyer sur <label>OK</label>
+pour valider le choix, ou sur <label>Annuler</label> pour quitter sans enregistrer.</p>
+<p>Une fois cette action réalisée, la couche est chargée dans le projet QGIS en cours.</p>
+<p><u>Important : </u> une nouvelle couche créée est forcément vide, il est donc normal qu'une couche nouvellement créée apparaisse dans la
+barre d'outils <label>Couches</label>, mais qu'aucune donnée n'apparaisse sur la carte du projet. Pour entrer des données dans la couche il est
nécessaire de passer par la fonction <label>Basculer en mode édition</label>.</p>
Modified: trunk/qgis/resources/context_help/QgsVectorLayerProperties-en_US
--- trunk/qgis/resources/context_help/QgsVectorLayerProperties-en_US 2009-12-17 08:51:53 UTC (rev 12498)
+++ trunk/qgis/resources/context_help/QgsVectorLayerProperties-en_US 2009-12-17 10:46:11 UTC (rev 12499)
@@ -1,26 +1,117 @@
<h3>Vector Layer Properties</h3>
This dialog allows you to work with vector layer settings and properties. There are five tabs:
-<ol>
-<li><a href="#symbology">Symbology</a></li>
-<li><a href="#general">General</a></li>
-<li><a href="#metadata">Metadata</a></li>
-<li><a href="#labels">Labels</a></li>
-<li><a href="#actions">Actions</a></li>
-</ol>
+<p>
+<a href="#symbology">Symbology</a><br/>
+<a href="#labels">Labels</a><br/>
+<a href="#attributes">Attributes</a><br/>
+<a href="#general">General</a><br/>
+<a href="#metadata">Metadata</a><br/>
+<a href="#actions">Actions</a><br/>
+<a href="#diagram">Diagram Overlay</a><br/>
<a name="symbology">
<h4>Symbology</h4>
</a>
+To change the symbology for a layer, simply double click on its legend entry and the vector <label>Layer Properties</label> dialog will be shown.<p>
+Within this dialog you can style your vector layer. Depending on the selected rendering option you have the possibility to also classify your mapfeatures.
+<h5>Legend type</h5>
+QGIS supports a number of symbology renderers to control how vector features are displayed. Currently the following renderers are available:
+<ul>
+<li><label>Single symbol</label> - a single style is applied to every object in the layer.
+<li><label>Graduated symbol</label> - objects within the layer are displayed with different symbols classified by the values of a particular field.
+<li><label>Continuous color</label> - objects within the layer are displayed with a spread of colours classified by the numerical values within a specified field.
+<li><label>Unique value</label> - objects are classified by the unique values within a specified field with each value having a different symbol.
+</ul>
+<h5>New symbology</h5>
+Click <label>New symbology</label> button to use new symbology implementation for the layer.
+<h5>Vector transparency</h5>
+QGIS allows to set a transparency for every vector layer. This can be done with the slider <label>Transparency</label>. This is very useful for overlaying several vector layers.
+<h5>Saving styles</h5>
+Once you have styled your layer you also could save your layer-style to a separate file (with *.qml ending). To do this, use the button <label>Save Style...</label>. No need to say that <label>Load Style...</label> loads your saved layer-style-file.<br/>
+If you wish to always use a particular style whenever the layer is loaded, use the <label>Save As Default</label> button to make your style the default. Also, if you make changes to the style that you are not happy with, use the <label>Restore Default Style</label> button to revert to your default style.
+<a name="labels">
+<h4>Labels</h4>
+</a>
+The Labels tab allows you to enable labeling features and control a number of options related to fonts, placement, style, alignment and buffering.<br/>
+Check the <label>Display labels</label> checkbox to enable labeling.
+<h5>Basic Label options</h5>
+Choose the field to label with.<p>
+Select the use the <label>Font</label> and <label>Color</label> buttons to set the font and color. You can also change the angle and the placement of the text-label.<p>
+If have labels extending over several lines, check <label>Multiline labels?</label>. QGIS will check for a true line return in your label field and insert the line breaks accordingly. A true line return is a single character \n, (not two separate characters, like a backlash \ followed by the character n).
+<h5>Placement</h5>
+Change the label placement by selecting one of the radio buttons in the <label>Placement</label> group.
+<h5>Font size units</h5>
+The <label>Font size units</label> allows you to select between <label>Points</label> or <label>Map units</label>.
+<h5>Buffer labels</h5>
+To buffer the labels means putting a backdrop around them to make them stand out better. To buffer the lakes labels:
+<ol>
+<li>Click the <label>Buffer Labels</label> checkbox to enable buffering.
+<li>Choose a size for the buffer using the spin box.
+<li>Choose a color by clicking on <label>Color</label> and choosing your favorite from the color selector. You can also set some transparency for the buffer if you prefer.
+<li>Click <label>Apply</label> to see if you like the changes.
+</ol>
+Notice you can also specify the buffer size in map
+units if that works out better for you.
+<h5>Data defined placement, properties, buffer, position</h5>
+The remaining entries inside the <label>Label</label> tab allow you control the appearance of the labels using attributes stored in the layer. The entries beginning with <label>Data defined</label> allow you to set all the parameters for the labels using fields in the layer.
+<a name="attributes">
+<h4>Attributes</h4>
+</a>
+Within the <label>Attributes</label> tab the attributes of the selected dataset can be manipulated. The buttons <label>New Column</label> and <label>Delete Column</label> can be used, when the dataset is in editing mode. The OGR library supports to add new columns, but not to remove them, if you have a GDAL version >= 1.6 installed. Otherwise only columns from PostGIS layers can be edited.<p>
+The <label>Toggle editing mode</label> button toggles this mode.<p>
+Within the Attributes tab you also find an edit widget column. This column can be used to define values or a range of values that are allowed to be added to the specific attribute table column. If you click on the <label>edit widget</label> button, a dialog opens, where you can define different widgets. These widgets are:<br/>
+<ul>
+<li><label>Line edit</label> an edit field which allows to enter simple text (or restrict to numbers for numeric attributes).
+<li><label>Classification</label> Displays a combo box with the values used for classification, if you have chosen ’unique value’ as legend type in the symbology tab of the properties dialog.
+<li><label>Range</label> Allows to set numeric values from a specific range. The edit widget can be either a slider or a spin box.
+<li><label>Unique value</label> The user can select one of the values already used in the attribute table. If editable is activated, a line edit is shown with autocompletion support, otherwise a combo box is used.
+<li><label>File name</label> Simplifies the selection by adding a file chooser dialog.
+<li><label>Value map</label> a combo box with predefined items. The value is stored in the attribute, the description is shown in the comboo box. You can define values manually or load them from a layer or a csv file.
+<li><label>Enumeration</label> Opens a combo box with values that can be used within the columns type. This is currently only supported by the postgres provider.
+<li><label>Immutable</label> The immutable attribute column is read-only. The user is not able to modify the content.
+</ul>
<a name="general">
<h4>General</h4>
</a>
+The General tab allows you to change the display name, set scale dependent rendering options, create a spatial index of the vector file (only for OGR supported formats and PostGIS) and view or change the projection of the specific vetor layer.<p>
+If your vector layer has been loaded from a PostgreSQL / PostGIS datastore, you can also alter the underlying SQL for the layer - either by hand editing the SQL on this tab or by invoking the <label>Query Builder</label>.
+<h5>Subset</h5>
+The <label>Query Builder</label> button allows you to create a subset of the features in the layer.
<a name="metadata">
<h4>Metadata</h4>
</a>
-<a name="labels">
-<h4>Labels</h4>
-</a>
+The <label>Metadata</label> tab contains information about the layer, including specifics about the type and location, number of features, feature type, and the editing capabilities. The Layer Spatial Reference System section, providing projection information, is displayed on this tab. This is a quick way to get information about the layer.
<a name="actions">
<h4>Actions</h4>
</a>
+QGIS provides the ability to perform an action based on the attributes of a feature. This can be used to perform any number of actions, for example, running a program with arguments built from theattributes of a feature or passing parameters to a web reporting tool. <br/>
+Actions are useful when you frequently want to run an external application or view a web page based on one or more values in your vector layer. An example is performing a search based on an attribute value.<p>
+See the User Guide for further information.
+<h5>Using Actions</h5>
+Actions can be invoked from either the <label>Identify Results</label> dialog or an <label>Attribute Table</label> dialog.
+<a name="diagram">
+<h4>Diagram Overlay</h4>
+</a>
+The Diagram tab allows you to add a grahic overlay to a vector layer. To activate this feature, open the <label>Plugin Manager</label> and select the <label>Diagram Overlay’</label> plugin. After this, there is a new tab in the vector <label>Layer Properties</label> dialog where the settings for diagrams may be entered.<p>
+The current implementation of diagrams provides support for pie- and barcharts and for linear scaling
+of the diagram size according to a classification attribute.
Copied: trunk/qgis/resources/context_help/QgsWMSSourceSelect-de_DE (from rev 12498, trunk/qgis/resources/context_help/QgsNewHttpConnection-de_DE)
--- trunk/qgis/resources/context_help/QgsWMSSourceSelect-de_DE (rev 0)
+++ trunk/qgis/resources/context_help/QgsWMSSourceSelect-de_DE 2009-12-17 10:46:11 UTC (rev 12499)
@@ -0,0 +1 @@
+<h3>Eine neue WMS-Verbindung anlegen</h3>
Copied: trunk/qgis/resources/context_help/QgsWMSSourceSelect-ru_RU (from rev 12498, trunk/qgis/resources/context_help/QgsNewHttpConnection-ru_RU)
Copied: trunk/qgis/resources/context_help/QgsWMSSourceSelect-sk_SK (from rev 12498, trunk/qgis/resources/context_help/QgsNewHttpConnection-sk_SK)
--- trunk/qgis/resources/context_help/QgsWMSSourceSelect-sk_SK (rev 0)
+++ trunk/qgis/resources/context_help/QgsWMSSourceSelect-sk_SK 2009-12-17 10:46:11 UTC (rev 12499)
@@ -0,0 +1 @@
+<h3>Vytvorenie nového spojenia WMS</h3>
Copied: trunk/qgis/resources/context_help/QgsWMSSourceSelect-sv_SE (from rev 12498, trunk/qgis/resources/context_help/QgsNewHttpConnection-sv_SE)
--- trunk/qgis/resources/context_help/QgsWMSSourceSelect-sv_SE (rev 0)
+++ trunk/qgis/resources/context_help/QgsWMSSourceSelect-sv_SE 2009-12-17 10:46:11 UTC (rev 12499)
@@ -0,0 +1,2 @@
+<h3>Skapa en ny WMS-uppkoppling</h3>
