[QGIS Commit] r12643 - trunk/qgis/i18n
svn_qgis at osgeo.org
Mon Dec 28 16:52:17 EST 2009
Author: jef
Date: 2009-12-28 16:52:15 -0500 (Mon, 28 Dec 2009)
New Revision: 12643
trunk/qgis/i18n/qgis_de.ts
german translation update
Modified: trunk/qgis/i18n/qgis_de.ts
--- trunk/qgis/i18n/qgis_de.ts 2009-12-28 21:37:07 UTC (rev 12642)
+++ trunk/qgis/i18n/qgis_de.ts 2009-12-28 21:52:15 UTC (rev 12643)
@@ -2371,17 +2371,17 @@
<message>
<location filename="../python/plugins/osm/ui_files/OsmUploadDlg.ui" line="162"/>
<source>Password:</source>
- <translation>Paßwort:</translation>
+ <translation>Passwort:</translation>
</message>
<message>
<location filename="../python/plugins/osm/ui_files/OsmUploadDlg.ui" line="179"/>
<source>Show password</source>
- <translation>Paßwort anzeigen</translation>
+ <translation>Passwort anzeigen</translation>
</message>
<message>
<location filename="../python/plugins/osm/ui_files/OsmUploadDlg.ui" line="186"/>
<source>Save password</source>
- <translation>Paßwort speichern</translation>
+ <translation>Passwort speichern</translation>
</message>
</context>
<context>
@@ -2464,7 +2464,7 @@
<translation>Division durch Null.</translation>
</message>
<message>
- <location filename="../src/core/qgslabelattributes.cpp" line="61"/>
+ <location filename="../src/core/qgslabelattributes.cpp" line="62"/>
<source>Label</source>
<translation>Beschriftung</translation>
</message>
@@ -2489,14 +2489,14 @@
<translation>GPS eXchange Format Provider</translation>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="304"/>
- <location filename="../src/core/qgsdistancearea.cpp" line="329"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="307"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="332"/>
<source>Caught a coordinate system exception while trying to transform a point. Unable to calculate line length.</source>
<translation>Ein Problem beim Versuch einer Koordinatentransformation eines Punktes aus. Konnte daher die Linienlänge nicht berechnen.</translation>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="396"/>
- <location filename="../src/core/qgsdistancearea.cpp" line="425"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="399"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="428"/>
<source>Caught a coordinate system exception while trying to transform a point. Unable to calculate polygon area.</source>
<translation>Ein Problem beim Versuch einer Koordinatentransformation eines Punktes aus. Konnte daher die Fläches des Polygons nicht berechnen.</translation>
</message>
@@ -2639,83 +2639,83 @@
<translation>Fügt einen WFS-Layer zur Kartendarstellung hinzu</translation>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="671"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="674"/>
<source> km2</source>
<translation> km2</translation>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="676"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="679"/>
<source> ha</source>
<translation> ha</translation>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="681"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="684"/>
<source> m2</source>
<translation> m2</translation>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="689"/>
- <location filename="../src/core/qgsdistancearea.cpp" line="709"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="692"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="712"/>
<source> m</source>
<translation> m</translation>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="694"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="697"/>
<source> km</source>
<translation> km</translation>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="699"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="702"/>
<source> mm</source>
<translation> mm</translation>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="704"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="707"/>
<source> cm</source>
<translation> cm</translation>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="718"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="721"/>
<source> sq mile</source>
<translation> Quadratmeile</translation>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="723"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="726"/>
<source> sq ft</source>
<translation> Quadratfuß</translation>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="730"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="733"/>
<source> mile</source>
<translation> Meilen</translation>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="736"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="739"/>
<source> foot</source>
<translation> Fuß</translation>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="738"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="741"/>
<source> feet</source>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="745"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="748"/>
<source> sq.deg.</source>
<translation> sq.deg.</translation>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="750"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="753"/>
<source> degree</source>
<translation> Grad</translation>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="752"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="755"/>
<source> degrees</source>
</message>
<message>
- <location filename="../src/core/qgsdistancearea.cpp" line="756"/>
+ <location filename="../src/core/qgsdistancearea.cpp" line="759"/>
<source> unknown</source>
<translation> unbekannt</translation>
</message>
@@ -3275,12 +3275,12 @@
<translation>Auf OracleSpatial-Georaster zugreifen</translation>
</message>
<message>
- <location filename="../src/app/qgsmaptoolnodetool.cpp" line="944"/>
+ <location filename="../src/app/qgsmaptoolnodetool.cpp" line="947"/>
<source>Deleted vertices</source>
<translation>Gelöschte Stützpunkte</translation>
</message>
<message>
- <location filename="../src/app/qgsmaptoolnodetool.cpp" line="1007"/>
+ <location filename="../src/app/qgsmaptoolnodetool.cpp" line="1010"/>
<source>Moved vertices</source>
<translation>Verschobene Stützpunkte</translation>
</message>
@@ -3502,7 +3502,7 @@
<message>
<location filename="../src/app/qgisapp.cpp" line="1594"/>
<source>Displays the current map scale</source>
- <translation>Zeigt den momentanen Kartenmassstab an</translation>
+ <translation>Zeigt den momentanen Kartenmaßstab an</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="1607"/>
@@ -4837,7 +4837,7 @@
<message>
<location filename="../src/app/qgisapp.cpp" line="2181"/>
<source>A render caching capability has been added to QGIS. This speeds up common operations such as layer re-ordering, changing symbology, WMS / WFS client, hiding / showing layers and opens the door for future enhancements such as threaded rendering and pre-compositing layer cache manipulation. Note that it is disabled by default, and can be enabled in the options dialog.</source>
- <translation>Ein Zeichnungscaching wurde QGIS hinzugefügt. Dies beschleunigt Operationen wie Layerumordnung, Darstellungsänderung, WMS/WFS-Klient, aus-/einblenden von Layer und öffnet die Tür zu zukünftigen Erweiterungen wie paralleles Zeichnen. Zu beachten ist, dass dies im Optionen-Dialog zugeschaltet werden muß.</translation>
+ <translation>Ein Zeichnungscaching wurde QGIS hinzugefügt. Dies beschleunigt Operationen wie Layerumordnung, Darstellungsänderung, WMS/WFS-Klient, aus-/einblenden von Layer und öffnet die Tür zu zukünftigen Erweiterungen wie paralleles Zeichnen. Zu beachten ist, dass dies im Optionen-Dialog zugeschaltet werden muss.</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="2189"/>
@@ -5391,7 +5391,9 @@
<context>
<name>QgsApplication</name>
<message>
- <location filename="../src/core/qgsapplication.cpp" line="89"/>
+ <location filename="../src/core/qgsapplication.cpp" line="93"/>
+ <location filename="../src/core/qgsapplication.cpp" line="97"/>
+ <location filename="../src/core/qgsapplication.cpp" line="101"/>
<source>Exception</source>
<translation>Ausnahme</translation>
</message>
@@ -5875,12 +5877,20 @@
<context>
<name>QgsAttributeTableModel</name>
<message>
- <location filename="../src/app/attributetable/qgsattributetablemodel.cpp" line="441"/>
+ <location filename="../src/app/attributetable/qgsattributetablemodel.cpp" line="446"/>
<source>Attribute changed</source>
<translation>Attribut geändert</translation>
</message>
</context>
<context>
+ <name>QgsAttributeTableView</name>
+ <message>
+ <location filename="../src/app/attributetable/qgsattributetableview.cpp" line="98"/>
+ <source>Run action</source>
+ <translation>Aktion starten</translation>
+ </message>
+</context>
+<context>
<name>QgsAttributeTypeDialog</name>
<message>
<location filename="../src/app/qgsattributetypedialog.cpp" line="124"/>
@@ -6242,7 +6252,7 @@
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="713"/>
- <location filename="../src/app/composer/qgscomposer.cpp" line="1411"/>
+ <location filename="../src/app/composer/qgscomposer.cpp" line="1410"/>
<source>Don't show this message again</source>
<translation>Diese Nachricht nicht mehr anzeigen</translation>
</message>
@@ -6288,17 +6298,17 @@
<translation>Einen Dateinamen zum Speichern des Kartenabbilds wählen</translation>
</message>
<message>
- <location filename="../src/app/composer/qgscomposer.cpp" line="1113"/>
+ <location filename="../src/app/composer/qgscomposer.cpp" line="1111"/>
<source>Composer</source>
<translation>Zusammmenstellung</translation>
</message>
<message>
- <location filename="../src/app/composer/qgscomposer.cpp" line="1409"/>
+ <location filename="../src/app/composer/qgscomposer.cpp" line="1408"/>
<source>Project contains WMS layers</source>
<translation>Projekt enthält WMS-Layer</translation>
</message>
<message>
- <location filename="../src/app/composer/qgscomposer.cpp" line="1410"/>
+ <location filename="../src/app/composer/qgscomposer.cpp" line="1409"/>
<source>Some WMS servers (e.g. UMN mapserver) have a limit for the WIDTH and HEIGHT parameter. Printing layers from such servers may exceed this limit. If this is the case, the WMS layer will not be printed</source>
<translation>Einige WMS-Server (z.B. UMN Mapserver) haben Begrenzungen für die WIDTH- und HEIGHT-Parameter. Falls diese Begrenzungen beim Ausdruck überschritten werden, werden diese WMS-Layer nicht gedruckt</translation>
</message>
@@ -6496,7 +6506,7 @@
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="299"/>
<source>Add new scalebar</source>
- <translation>Neuen Massstab hinzufügen</translation>
+ <translation>Neuen Maßstab hinzufügen</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="311"/>
@@ -6843,7 +6853,7 @@
<message>
<location filename="../src/ui/qgscomposerlegendwidgetbase.ui" line="20"/>
<source>Barscale Options</source>
- <translation>Optionen für Massstabsbalken</translation>
+ <translation>Optionen für Maßstabsbalken</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerlegendwidgetbase.ui" line="56"/>
@@ -6972,27 +6982,27 @@
<context>
<name>QgsComposerManagerBase</name>
<message>
- <location filename="../src/ui/qgscomposermanagerbase.ui" line="14"/>
+ <location filename="../src/ui/qgscomposermanagerbase.ui" line="13"/>
<source>Composer manager</source>
<translation>Druckzusammenstellung verwalten</translation>
</message>
<message>
- <location filename="../src/ui/qgscomposermanagerbase.ui" line="23"/>
+ <location filename="../src/ui/qgscomposermanagerbase.ui" line="43"/>
<source>Add</source>
<translation>Hinzufügen</translation>
</message>
<message>
- <location filename="../src/ui/qgscomposermanagerbase.ui" line="30"/>
+ <location filename="../src/ui/qgscomposermanagerbase.ui" line="29"/>
<source>Remove</source>
<translation>Entfernen</translation>
</message>
<message>
- <location filename="../src/ui/qgscomposermanagerbase.ui" line="37"/>
+ <location filename="../src/ui/qgscomposermanagerbase.ui" line="36"/>
<source>Rename</source>
<translation>Umbenennen</translation>
</message>
<message>
- <location filename="../src/ui/qgscomposermanagerbase.ui" line="44"/>
+ <location filename="../src/ui/qgscomposermanagerbase.ui" line="22"/>
<source>Show</source>
<translation>Anzeigen</translation>
</message>
@@ -7410,7 +7420,7 @@
<message>
<location filename="../src/ui/qgscomposerscalebarwidgetbase.ui" line="20"/>
</message>
<message>
<location filename="../src/ui/qgscomposerscalebarwidgetbase.ui" line="41"/>
@@ -7425,7 +7435,7 @@
<message>
<location filename="../src/ui/qgscomposerscalebarwidgetbase.ui" line="70"/>
<source>Map units per bar unit</source>
- <translation>Karteneinheiten pro Massstabseinheit</translation>
+ <translation>Karteneinheiten pro Maßstabseinheit</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerscalebarwidgetbase.ui" line="90"/>
@@ -8086,33 +8096,39 @@
<context>
<name>QgsCoordinateTransform</name>
<message>
- <location filename="../src/core/qgscoordinatetransform.cpp" line="473"/>
- <source>Failed</source>
- <translation>Fehlgeschlagen</translation>
+ <location filename="../src/core/qgscoordinatetransform.cpp" line="417"/>
+ <source>The source spatial reference system (CRS) is not valid. </source>
+ <translation>Das ursprüngliche Koordinatenbezugssystem (KBS) is ungültig. </translation>
</message>
<message>
- <source>transform of</source>
- <translation>Transformation von</translation>
+ <location filename="../src/core/qgscoordinatetransform.cpp" line="425"/>
+ <source>The destination spatial reference system (CRS) is not valid. </source>
+ <translation>Das Zielkoordinatenbezugssystem (KBS) ist nicht gültig.</translation>
</message>
<message>
- <location filename="../src/core/qgscoordinatetransform.cpp" line="486"/>
- <source>with error: </source>
- <translation>mit Fehler:</translation>
+ <location filename="../src/core/qgscoordinatetransform.cpp" line="456"/>
+ <source>inverse</source>
+ <translation>Rücktransformation</translation>
</message>
<message>
- <location filename="../src/core/qgscoordinatetransform.cpp" line="418"/>
- <source>The source spatial reference system (CRS) is not valid. </source>
- <translation>Das ursprüngliche Koordinatenbezugssystem (KBS) is ungültig. </translation>
+ <location filename="../src/core/qgscoordinatetransform.cpp" line="463"/>
+ <source>forward</source>
+ <translation>Transformation</translation>
</message>
<message>
- <location filename="../src/core/qgscoordinatetransform.cpp" line="426"/>
- <source>The destination spatial reference system (CRS) is not valid. </source>
- <translation>Das Zielkoordinatenbezugssystem (KBS) ist nicht gültig.</translation>
+ <location filename="../src/core/qgscoordinatetransform.cpp" line="483"/>
+ <source>%1 transform of
+%2
+failed with error: %3
+</source>
+ <translation>%1 von
+%2
+scheiterte mit Fehler: %3
+</translation>
</message>
<message>
- <location filename="../src/core/qgscoordinatetransform.cpp" line="419"/>
- <location filename="../src/core/qgscoordinatetransform.cpp" line="427"/>
+ <location filename="../src/core/qgscoordinatetransform.cpp" line="418"/>
+ <location filename="../src/core/qgscoordinatetransform.cpp" line="426"/>
<source>The coordinates can not be reprojected. The CRS is: %1</source>
<translation>Die Koordinaten können nicht projiziert werden. Das KBS ist: %1</translation>
</message>
@@ -8691,12 +8707,12 @@
<context>
<name>QgsDelimitedTextProvider</name>
<message>
- <location filename="../src/providers/delimitedtext/qgsdelimitedtextprovider.cpp" line="400"/>
+ <location filename="../src/providers/delimitedtext/qgsdelimitedtextprovider.cpp" line="445"/>
<source>Error</source>
<translation>Fehler</translation>
</message>
<message>
- <location filename="../src/providers/delimitedtext/qgsdelimitedtextprovider.cpp" line="401"/>
+ <location filename="../src/providers/delimitedtext/qgsdelimitedtextprovider.cpp" line="446"/>
<source>Note: the following lines were not loaded because Qgis was unable to determine values for the x and y coordinates:
</source>
<translation>Beachte: Die folgenden Linien wurden nicht geladen, da QGIS die Werte für die X und Y Koordinaten nicht herausfinden konnte:
@@ -9693,25 +9709,25 @@
<message>
<location filename="../src/app/qgsgraduatedsymboldialog.cpp" line="61"/>
<location filename="../src/app/qgsgraduatedsymboldialog.cpp" line="78"/>
- <location filename="../src/app/qgsgraduatedsymboldialog.cpp" line="292"/>
- <location filename="../src/app/qgsgraduatedsymboldialog.cpp" line="366"/>
+ <location filename="../src/app/qgsgraduatedsymboldialog.cpp" line="294"/>
+ <location filename="../src/app/qgsgraduatedsymboldialog.cpp" line="368"/>
<source>Equal Interval</source>
<translation>Gleiches Intervall</translation>
</message>
<message>
<location filename="../src/app/qgsgraduatedsymboldialog.cpp" line="62"/>
<location filename="../src/app/qgsgraduatedsymboldialog.cpp" line="74"/>
- <location filename="../src/app/qgsgraduatedsymboldialog.cpp" line="179"/>
- <location filename="../src/app/qgsgraduatedsymboldialog.cpp" line="293"/>
- <location filename="../src/app/qgsgraduatedsymboldialog.cpp" line="337"/>
+ <location filename="../src/app/qgsgraduatedsymboldialog.cpp" line="180"/>
+ <location filename="../src/app/qgsgraduatedsymboldialog.cpp" line="295"/>
+ <location filename="../src/app/qgsgraduatedsymboldialog.cpp" line="339"/>
<source>Quantiles</source>
<translation>Quantile</translation>
</message>
<message>
<location filename="../src/app/qgsgraduatedsymboldialog.cpp" line="63"/>
<location filename="../src/app/qgsgraduatedsymboldialog.cpp" line="70"/>
- <location filename="../src/app/qgsgraduatedsymboldialog.cpp" line="175"/>
- <location filename="../src/app/qgsgraduatedsymboldialog.cpp" line="388"/>
+ <location filename="../src/app/qgsgraduatedsymboldialog.cpp" line="176"/>
+ <location filename="../src/app/qgsgraduatedsymboldialog.cpp" line="390"/>
<source>Empty</source>
<translation>Leer</translation>
</message>
@@ -9970,8 +9986,8 @@
<source>Are you sure you want to delete %n selected layer(s)?</source>
<comment>number of layers to delete</comment>
<translation>
- <numerusform>Sind Sie sicher, daß Sie den gewählten Layer löschen wollen?</numerusform>
- <numerusform>Sind Sie sicher, daß Sie die %n gewählten Layer löschen wollen?</numerusform>
+ <numerusform>Sind Sie sicher, dass Sie den gewählten Layer löschen wollen?</numerusform>
+ <numerusform>Sind Sie sicher, dass Sie die %n gewählten Layer löschen wollen?</numerusform>
</translation>
</message>
<message>
@@ -10457,7 +10473,7 @@
<message>
<location filename="../src/plugins/grass/qgsgrassedittools.cpp" line="238"/>
<source>Close line</source>
- <translation>Linie schliessen</translation>
+ <translation>Linie schließen</translation>
</message>
</context>
<context>
@@ -11807,7 +11823,7 @@
<message>
<location filename="../src/plugins/grass/qgsgrassplugin.cpp" line="130"/>
<source>Close mapset</source>
- <translation>Schliesse Mapset</translation>
+ <translation>Schließe Mapset</translation>
</message>
<message>
<location filename="../src/plugins/grass/qgsgrassplugin.cpp" line="132"/>
@@ -11959,12 +11975,12 @@
<message>
<location filename="../src/plugins/grass/qgsgrassplugin.cpp" line="698"/>
<source>Cannot close mapset. %1</source>
- <translation>Kann Mapset nicht schliessen: %1</translation>
+ <translation>Kann Mapset nicht schließen: %1</translation>
</message>
<message>
<location filename="../src/plugins/grass/qgsgrassplugin.cpp" line="752"/>
<source>Cannot close current mapset. %1</source>
- <translation>Kann aktuelles Mapset nicht schliessen: %1</translation>
+ <translation>Kann aktuelles Mapset nicht schließen: %1</translation>
</message>
<message>
<location filename="../src/plugins/grass/qgsgrassplugin.cpp" line="761"/>
@@ -12846,7 +12862,7 @@
<context>
<name>QgsLabelDialog</name>
<message>
- <location filename="../src/app/qgslabeldialog.cpp" line="214"/>
+ <location filename="../src/app/qgslabeldialog.cpp" line="234"/>
<source>Auto</source>
<translation>Auto</translation>
</message>
@@ -12859,275 +12875,299 @@
<translation>Formular1</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="855"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="914"/>
<source>Preview:</source>
<translation>Vorschau:</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="864"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="923"/>
<source>QGIS Rocks!</source>
<translation>QGIS bringt's!</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="98"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="102"/>
<source>Font</source>
<translation>Schrift</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="105"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="109"/>
<source>Font size</source>
<translation>Schriftgröße</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="278"/>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="480"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="452"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="489"/>
<source>Points</source>
<translation>Punkte</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="285"/>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="487"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="459"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="510"/>
<source>Map units</source>
<translation>Karteneinheiten</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="423"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="421"/>
<source>%</source>
<translation>%</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="727"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="782"/>
<source>Transparency:</source>
<translation>Transparenz:</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="750"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="805"/>
<source>Size:</source>
<translation>Grösse:</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="388"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="386"/>
<source>Size is in map units</source>
<translation>Grösse in Karteneinheiten</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="381"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="379"/>
<source>Size is in points</source>
<translation>Grösse in Punkten</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="234"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="242"/>
<source>Above</source>
<translation>Oben</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="224"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="232"/>
<source>Over</source>
<translation>Über</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="241"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="249"/>
<source>Left</source>
<translation>Links</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="217"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="225"/>
<source>Below</source>
<translation>Unten</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="210"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="218"/>
<source>Right</source>
<translation>Rechts</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="255"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="263"/>
<source>Above Right</source>
<translation>Oben rechts</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="203"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="211"/>
<source>Below Right</source>
<translation>Unten rechts</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="262"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="270"/>
<source>Above Left</source>
<translation>Oben links</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="248"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="256"/>
<source>Below Left</source>
<translation>Unten links</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="272"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="446"/>
<source>Font size units</source>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="194"/>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="509"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="202"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="555"/>
<source>Placement</source>
<translation>Platzierung</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="446"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="469"/>
<source>Offset units</source>
<translation>Versatz-Einheiten</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="52"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="56"/>
<source>Field containing label</source>
<translation>Beschreibungsfeld</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="72"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="76"/>
<source>Default label</source>
<translation>Beschriftungsvorgabe</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="706"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="761"/>
<source>Data defined buffer</source>
<translation>Datendefinierter Puffer</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="766"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="827"/>
<source>Data defined position</source>
<translation>Datendefinierte Position</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="149"/>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="436"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="153"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="434"/>
<source>Color</source>
<translation>Farbe</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="156"/>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="525"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="160"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="571"/>
<source>Angle (deg)</source>
<translation>Winkel (Altgrad)</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="371"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="369"/>
<source>Buffer size</source>
<translation>Puffergröße</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="398"/>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="667"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="396"/>
<source>Transparency</source>
<translation>Transparenz</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="459"/>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="810"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="475"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="871"/>
<source>X Offset (pts)</source>
<translation>X-Versatz (Punkte)</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="452"/>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="826"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="496"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="887"/>
<source>Y Offset (pts)</source>
<translation>Y-Versatz (Punkte)</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="46"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="50"/>
<source>Basic label options</source>
<translation>Grundlegende Beschriftungsoptionen</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="359"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="38"/>
+ <source>Basic label options and placement</source>
+ <translation></translation>
+ </message>
+ <message>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="287"/>
+ <source>Scale dependent rendering, buffer labels, font size units and offset</source>
+ <translation>Maßstabsabhängige Darstellung, Beschriftungsfreistellung, Schriftgröße und -versatz</translation>
+ </message>
+ <message>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="357"/>
<source>Buffer labels</source>
<translation>Beschriftungen freistellen</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="497"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="531"/>
+ <source>Data defined settings (placement and properties)</source>
+ <translation>Datendefinierte Einstellungen (Platzierung und Eigenschaften)</translation>
+ </message>
+ <message>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="543"/>
<source>Data defined placement</source>
<translation>Datendefinierte Platzierung</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="538"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="590"/>
<source>Data defined properties</source>
<translation>Datendefinierte Eigenschaften</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="550"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="602"/>
<source>&Font family</source>
<translation>&Schriftfamilie</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="569"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="621"/>
<source>&Bold</source>
<translation>&Fett</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="588"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="640"/>
<source>&Italic</source>
<translation>&Kursiv</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="607"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="659"/>
<source>&Underline</source>
<translation>&Unterstrichen</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="626"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="678"/>
<source>&Size</source>
<translation>&Größe</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="645"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="697"/>
<source>Size units</source>
<translation>Größeneinheit</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="778"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="732"/>
+ <source>Strikeout</source>
+ <translation>Durchgestrichen</translation>
+ </message>
+ <message>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="749"/>
+ <source>Data defined settings: buffer and position</source>
+ <translation>Datendefinierte Einstellungen: Freistellung und Position</translation>
+ </message>
+ <message>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="839"/>
<source>X Coordinate</source>
<translation>X-Koordinate</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="794"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="855"/>
<source>Y Coordinate</source>
<translation>Y-Koordinate</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="179"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="183"/>
<source>Multiline labels?</source>
<translation>Mehrzeilige Beschriftungen?</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="295"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="293"/>
<source>Use scale dependent rendering</source>
- <translation>Massstabsabhängig zeichnen</translation>
+ <translation>Maßstabsabhängig zeichnen</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="307"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="305"/>
<source>Maximum</source>
<translation>Maximum</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="317"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="315"/>
<source>Minimum</source>
<translation>Minimum</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="327"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="325"/>
<source>Minimum scale at which this layer will be displayed. </source>
- <translation>Minimaler Massstab ab dem dieser Layer angezeigt wird.</translation>
+ <translation>Minimaler Maßstab ab dem dieser Layer angezeigt wird.</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="340"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="338"/>
<source>Maximum scale at which this layer will be displayed. </source>
- <translation>Maximaler Massstab bis zu dem dieser Layer angezeigt wird.</translation>
+ <translation>Maximaler Maßstab bis zu dem dieser Layer angezeigt wird.</translation>
</message>
<message utf8="true">
- <location filename="../src/ui/qgslabeldialogbase.ui" line="166"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="170"/>
<source>°</source>
<translation>°</translation>
</message>
<message>
- <location filename="../src/ui/qgslabeldialogbase.ui" line="690"/>
+ <location filename="../src/ui/qgslabeldialogbase.ui" line="716"/>
<source>&Color</source>
<translation>&Farbe</translation>
</message>
@@ -13170,24 +13210,24 @@
<translation>&Alles zusammenfalten</translation>
</message>
<message>
+ <location filename="../src/app/legend/qgslegend.cpp" line="651"/>
<location filename="../src/app/legend/qgslegend.cpp" line="662"/>
- <location filename="../src/app/legend/qgslegend.cpp" line="673"/>
<source>Stop editing</source>
<translation>Bearbeitung beenden</translation>
</message>
<message>
+ <location filename="../src/app/legend/qgslegend.cpp" line="652"/>
<location filename="../src/app/legend/qgslegend.cpp" line="663"/>
- <location filename="../src/app/legend/qgslegend.cpp" line="674"/>
<source>Do you want to save the changes to layer %1?</source>
<translation>Wollen Sie die Änderung am Layer %1 speichern?</translation>
</message>
<message>
- <location filename="../src/app/legend/qgslegend.cpp" line="1729"/>
+ <location filename="../src/app/legend/qgslegend.cpp" line="1707"/>
<source>No Layer Selected</source>
<translation>Keinen Layer ausgewählt</translation>
</message>
<message>
- <location filename="../src/app/legend/qgslegend.cpp" line="1730"/>
+ <location filename="../src/app/legend/qgslegend.cpp" line="1708"/>
<source>To open an attribute table, you must select a vector layer in the legend</source>
<translation>Um eine Attributtabelle zu öffnen, müssen Sie einen Vektorlayer in der Legende auswählen</translation>
</message>
@@ -13740,95 +13780,90 @@
<context>
<name>QgsMapToolIdentify</name>
<message>
- <location filename="../src/app/qgsmaptoolidentify.cpp" line="201"/>
- <location filename="../src/app/qgsmaptoolidentify.cpp" line="388"/>
+ <location filename="../src/app/qgsmaptoolidentify.cpp" line="202"/>
+ <location filename="../src/app/qgsmaptoolidentify.cpp" line="392"/>
<source>(clicked coordinate)</source>
<translation>(Angeklickte Koordinate)</translation>
</message>
<message>
- <location filename="../src/app/qgsmaptoolidentify.cpp" line="95"/>
+ <location filename="../src/app/qgsmaptoolidentify.cpp" line="96"/>
<source>No active layer</source>
<translation>Kein aktiver Layer</translation>
</message>
<message>
- <location filename="../src/app/qgsmaptoolidentify.cpp" line="96"/>
+ <location filename="../src/app/qgsmaptoolidentify.cpp" line="97"/>
<source>To identify features, you must choose an active layer by clicking on its name in the legend</source>
<translation>Um Objekte zu identifizieren müssen Sie einen Layer in der Legende auswählen</translation>
</message>
<message>
- <location filename="../src/app/qgsmaptoolidentify.cpp" line="120"/>
+ <location filename="../src/app/qgsmaptoolidentify.cpp" line="121"/>
<source>Identifying on %1...</source>
<translation>%1 wird abgefragt...</translation>
</message>
<message>
- <location filename="../src/app/qgsmaptoolidentify.cpp" line="134"/>
+ <location filename="../src/app/qgsmaptoolidentify.cpp" line="135"/>
<source>Identifying done.</source>
<translation>Abfrage beendet.</translation>
</message>
<message>
- <location filename="../src/app/qgsmaptoolidentify.cpp" line="159"/>
- <source>Identify results</source>
- <translation>Abfrageergebnis</translation>
- </message>
- <message>
+ <location filename="../src/app/qgsmaptoolidentify.cpp" line="160"/>
<source>No features at this position found.</source>
<translation>Kein Objekt an dieser Position gefunden.</translation>
</message>
<message>
- <location filename="../src/app/qgsmaptoolidentify.cpp" line="294"/>
+ <location filename="../src/app/qgsmaptoolidentify.cpp" line="298"/>
<source>Length</source>
<translation>Länge</translation>
</message>
<message>
- <location filename="../src/app/qgsmaptoolidentify.cpp" line="299"/>
+ <location filename="../src/app/qgsmaptoolidentify.cpp" line="303"/>
<source>firstX</source>
<comment>attributes get sorted; translation for lastX should be lexically larger than this one</comment>
<translation>erstesX</translation>
</message>
<message>
- <location filename="../src/app/qgsmaptoolidentify.cpp" line="301"/>
+ <location filename="../src/app/qgsmaptoolidentify.cpp" line="305"/>
<source>firstY</source>
<translation>erstesY</translation>
</message>
<message>
- <location filename="../src/app/qgsmaptoolidentify.cpp" line="303"/>
+ <location filename="../src/app/qgsmaptoolidentify.cpp" line="307"/>
<source>lastX</source>
<comment>attributes get sorted; translation for firstX should be lexically smaller than this one</comment>
<translation>letztesX</translation>
</message>
<message>
- <location filename="../src/app/qgsmaptoolidentify.cpp" line="305"/>
+ <location filename="../src/app/qgsmaptoolidentify.cpp" line="309"/>
<source>lastY</source>
<translation>letztesY</translation>
</message>
<message>
- <location filename="../src/app/qgsmaptoolidentify.cpp" line="314"/>
+ <location filename="../src/app/qgsmaptoolidentify.cpp" line="318"/>
<source>Area</source>
<translation>Fläche</translation>
</message>
<message>
- <location filename="../src/app/qgsmaptoolidentify.cpp" line="326"/>
+ <location filename="../src/app/qgsmaptoolidentify.cpp" line="330"/>
<source>feature id</source>
<translation>Objektkennung</translation>
</message>
<message>
<source>new feature</source>
<translation>Neues Objekt</translation>
</message>
<message>
- <location filename="../src/app/qgsmaptoolidentify.cpp" line="353"/>
+ <location filename="../src/app/qgsmaptoolidentify.cpp" line="357"/>
<source>WMS layer</source>
<translation>WMS-Layer</translation>
</message>
<message>
- <location filename="../src/app/qgsmaptoolidentify.cpp" line="373"/>
+ <location filename="../src/app/qgsmaptoolidentify.cpp" line="377"/>
<source>Feature info</source>
<translation>Objektinformation</translation>
</message>
<message>
- <location filename="../src/app/qgsmaptoolidentify.cpp" line="382"/>
+ <location filename="../src/app/qgsmaptoolidentify.cpp" line="386"/>
<source>Raster</source>
<translation>Raster</translation>
</message>
@@ -14251,12 +14286,12 @@
<message>
<location filename="../src/ui/qgsmapserverexportbase.ui" line="156"/>
<source>MinScale</source>
- <translation>Minimalmassstab</translation>
+ <translation>Minimalmaßstab</translation>
</message>
<message>
<location filename="../src/ui/qgsmapserverexportbase.ui" line="166"/>
<source>MaxScale</source>
- <translation>Maximalmassstab</translation>
+ <translation>Maximalmaßstab</translation>
</message>
<message>
<location filename="../src/ui/qgsmapserverexportbase.ui" line="182"/>
@@ -14355,7 +14390,7 @@
<message>
<location filename="../python/plugins/mapserver_export/qgsmapserverexportbase.ui" line="116"/>
<source>Prefix attached to map, scalebar and legend GIF filenames created using this MapFile</source>
- <translation>Präfix, der Namen der GIF-Dateien für Karte, Massstabsleisten und Legenden, die mit diesem Mapfile erzeugt werden</translation>
+ <translation>Präfix, der Namen der GIF-Dateien für Karte, Maßstabsleisten und Legenden, die mit diesem Mapfile erzeugt werden</translation>
</message>
<message>
<location filename="../python/plugins/mapserver_export/qgsmapserverexportbase.ui" line="37"/>
@@ -14519,18 +14554,18 @@
<context>
<name>QgsNewConnection</name>
<message>
- <location filename="../src/app/qgsnewconnection.cpp" line="148"/>
- <location filename="../src/app/qgsnewconnection.cpp" line="152"/>
+ <location filename="../src/app/qgsnewconnection.cpp" line="175"/>
+ <location filename="../src/app/qgsnewconnection.cpp" line="179"/>
<source>Test connection</source>
<translation>Verbindung testen</translation>
</message>
<message>
<source>Connection to %1 was successful</source>
<translation>Verbindung zu %1 war erfolgreich</translation>
</message>
<message>
<source>Connection failed - Check settings and try again.
Extended error information:
@@ -14541,35 +14576,45 @@
%1</translation>
</message>
<message>
- <location filename="../src/app/qgsnewconnection.cpp" line="39"/>
+ <location filename="../src/app/qgsnewconnection.cpp" line="40"/>
<source>prefer</source>
<translation>bevorzugen</translation>
</message>
<message>
- <location filename="../src/app/qgsnewconnection.cpp" line="40"/>
+ <location filename="../src/app/qgsnewconnection.cpp" line="41"/>
<source>require</source>
<translation>verlangen</translation>
</message>
<message>
- <location filename="../src/app/qgsnewconnection.cpp" line="38"/>
+ <location filename="../src/app/qgsnewconnection.cpp" line="39"/>
<source>allow</source>
<translation>erlauben</translation>
</message>
<message>
- <location filename="../src/app/qgsnewconnection.cpp" line="37"/>
+ <location filename="../src/app/qgsnewconnection.cpp" line="38"/>
<source>disable</source>
<translation>abschalten</translation>
</message>
<message>
- <location filename="../src/app/qgsnewconnection.cpp" line="90"/>
+ <location filename="../src/app/qgsnewconnection.cpp" line="91"/>
<source>Save connection</source>
<translation>Verbindung speichern</translation>
</message>
<message>
- <location filename="../src/app/qgsnewconnection.cpp" line="91"/>
+ <location filename="../src/app/qgsnewconnection.cpp" line="92"/>
<source>Should the existing connection %1 be overwritten?</source>
<translation>Soll die bereits existierende Verbindung %1 überschieben werden?</translation>
</message>
+ <message>
+ <location filename="../src/app/qgsnewconnection.cpp" line="155"/>
+ <source>Enter password</source>
+ <translation>Passwort eingeben</translation>
+ </message>
+ <message>
+ <location filename="../src/app/qgsnewconnection.cpp" line="156"/>
+ <source>Error: %1Enter password for %2</source>
+ <translation>Fehler: %1Passwort für %2</translation>
+ </message>
</context>
<context>
<name>QgsNewConnectionBase</name>
@@ -14717,7 +14762,7 @@
<message>
<location filename="../src/ui/qgsnewhttpconnectionbase.ui" line="84"/>
<source>If the WMS requires basic authentication, enter a user name and optional password</source>
- <translation>Geben Sie einen Benutzernamen und ein optionales Paßwort ein, wenn der WMS Basic-Authentifikation erfordert</translation>
+ <translation>Geben Sie einen Benutzernamen und ein optionales Passwort ein, wenn der WMS Basic-Authentifikation erfordert</translation>
</message>
<message>
<location filename="../src/ui/qgsnewhttpconnectionbase.ui" line="97"/>
@@ -14727,7 +14772,7 @@
<message>
<location filename="../src/ui/qgsnewhttpconnectionbase.ui" line="117"/>
<source>Password</source>
- <translation>Paßwort</translation>
+ <translation>Passwort</translation>
</message>
</context>
<context>
@@ -15116,17 +15161,17 @@
<context>
<name>QgsOgrProvider</name>
<message>
- <location filename="../src/providers/ogr/qgsogrprovider.cpp" line="172"/>
+ <location filename="../src/providers/ogr/qgsogrprovider.cpp" line="173"/>
<source>Whole number (integer)</source>
<translation>Ganzzahl (integer)</translation>
</message>
<message>
- <location filename="../src/providers/ogr/qgsogrprovider.cpp" line="173"/>
+ <location filename="../src/providers/ogr/qgsogrprovider.cpp" line="174"/>
<source>Decimal number (real)</source>
<translation>Dezimalzahl (real)</translation>
</message>
<message>
- <location filename="../src/providers/ogr/qgsogrprovider.cpp" line="174"/>
+ <location filename="../src/providers/ogr/qgsogrprovider.cpp" line="175"/>
<source>Text (string)</source>
<translation>Text (string)</translation>
</message>
@@ -15502,21 +15547,21 @@
<context>
<name>QgsOptions</name>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="264"/>
- <location filename="../src/app/qgsoptions.cpp" line="271"/>
- <location filename="../src/app/qgsoptions.cpp" line="541"/>
+ <location filename="../src/app/qgsoptions.cpp" line="267"/>
+ <location filename="../src/app/qgsoptions.cpp" line="274"/>
+ <location filename="../src/app/qgsoptions.cpp" line="544"/>
<source>Semi transparent circle</source>
<translation>Teiltransparenter Kreis</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="265"/>
- <location filename="../src/app/qgsoptions.cpp" line="275"/>
- <location filename="../src/app/qgsoptions.cpp" line="545"/>
+ <location filename="../src/app/qgsoptions.cpp" line="268"/>
+ <location filename="../src/app/qgsoptions.cpp" line="278"/>
+ <location filename="../src/app/qgsoptions.cpp" line="548"/>
<source>Cross</source>
<translation>Kreuz</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="214"/>
+ <location filename="../src/app/qgsoptions.cpp" line="217"/>
<source>Detected active locale on your system: %1</source>
<translation>Festgestellte Spracheinstellung des Systems: %1</translation>
</message>
@@ -15536,66 +15581,66 @@
<translation>Von oben nach unten</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="234"/>
+ <location filename="../src/app/qgsoptions.cpp" line="237"/>
<source>To vertex</source>
<translation>Zum Stützpunkt</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="235"/>
+ <location filename="../src/app/qgsoptions.cpp" line="238"/>
<source>To segment</source>
<translation>Zum Segment</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="236"/>
+ <location filename="../src/app/qgsoptions.cpp" line="239"/>
<source>To vertex and segment</source>
<translation>Zum Stützpunkt und Segment</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="266"/>
- <location filename="../src/app/qgsoptions.cpp" line="279"/>
- <location filename="../src/app/qgsoptions.cpp" line="549"/>
+ <location filename="../src/app/qgsoptions.cpp" line="269"/>
+ <location filename="../src/app/qgsoptions.cpp" line="282"/>
+ <location filename="../src/app/qgsoptions.cpp" line="552"/>
<source>None</source>
<translation>Keine</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="746"/>
+ <location filename="../src/app/qgsoptions.cpp" line="749"/>
<source>Choose a directory</source>
<translation>Verzeichnis wählen</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="244"/>
- <location filename="../src/app/qgsoptions.cpp" line="253"/>
+ <location filename="../src/app/qgsoptions.cpp" line="247"/>
+ <location filename="../src/app/qgsoptions.cpp" line="256"/>
<source>map units</source>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="248"/>
- <location filename="../src/app/qgsoptions.cpp" line="257"/>
+ <location filename="../src/app/qgsoptions.cpp" line="251"/>
+ <location filename="../src/app/qgsoptions.cpp" line="260"/>
<source>pixels</source>
<translation>Pixel</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="290"/>
+ <location filename="../src/app/qgsoptions.cpp" line="293"/>
<source>Central point (fastest)</source>
<translation>Zentrum (am schnellsten)</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="291"/>
+ <location filename="../src/app/qgsoptions.cpp" line="294"/>
<source>Chain (fast)</source>
<translation>Kette (schnell)</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="292"/>
+ <location filename="../src/app/qgsoptions.cpp" line="295"/>
<source>Popmusic tabu chain (slow)</source>
<translation>Popmusik-Tabu-Kette (langsam)</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="293"/>
+ <location filename="../src/app/qgsoptions.cpp" line="296"/>
<source>Popmusic tabu (slow)</source>
<translation>Popmusik-Tabu (langsam)</translation>
</message>
<message>
- <location filename="../src/app/qgsoptions.cpp" line="294"/>
+ <location filename="../src/app/qgsoptions.cpp" line="297"/>
<source>Popmusic chain (very slow)</source>
<translation>Popmusik-Kette (sehr langsam)</translation>
</message>
@@ -16121,7 +16166,7 @@
<message>
<location filename="../src/plugins/oracle_raster/qgsselectgeoraster_ui.cpp" line="152"/>
<source>Password for %1/<password>@%2</source>
- <translation>Passwort für %1/<Paßwort>@%2</translation>
+ <translation>Passwort für %1/<Passwort>@%2</translation>
</message>
<message>
<location filename="../src/plugins/oracle_raster/qgsselectgeoraster_ui.cpp" line="153"/>
@@ -16369,22 +16414,22 @@
<translation>Um einen Layer hinzuzufügen, muss eine Tabelle gewählt sein.</translation>
</message>
<message>
- <location filename="../src/app/qgspgsourceselect.cpp" line="421"/>
- <source>Password for </source>
- <translation>Passwort für </translation>
+ <location filename="../src/app/qgspgsourceselect.cpp" line="419"/>
</message>
<message>
- <location filename="../src/app/qgspgsourceselect.cpp" line="422"/>
- <source>Please enter your password:</source>
- <translation>Bitte Passwort eingeben:</translation>
+ <location filename="../src/app/qgspgsourceselect.cpp" line="420"/>
+ <translation>Fehler: %1Passwort für %2 eingeben</translation>
</message>
<message>
- <location filename="../src/app/qgspgsourceselect.cpp" line="473"/>
+ <location filename="../src/app/qgspgsourceselect.cpp" line="469"/>
<source>Connection failed</source>
<translation>Verbindungsfehler</translation>
</message>
<message>
- <location filename="../src/app/qgspgsourceselect.cpp" line="474"/>
+ <location filename="../src/app/qgspgsourceselect.cpp" line="470"/>
<source>Connection to %1 on %2 failed. Either the database is down or your settings are incorrect.
Check your username and password and try again.
@@ -16393,20 +16438,20 @@
%3</source>
<translation>Verbindung zu %1 auf %2 schlug fehl. Entweder ist die Datenbank heruntergefahren oder Ihre Einstellunge sind fehlerhaft.
-Überprüfen Sie Benutzername und Paßwort und versuchen Sie es nocheinmal.
+Überprüfen Sie Benutzername und Passwort und versuchen Sie es nocheinmal.
Die Datenbank meldete:
%3</translation>
</message>
<message>
- <location filename="../src/app/qgspgsourceselect.cpp" line="604"/>
- <location filename="../src/app/qgspgsourceselect.cpp" line="682"/>
+ <location filename="../src/app/qgspgsourceselect.cpp" line="600"/>
+ <location filename="../src/app/qgspgsourceselect.cpp" line="678"/>
<source>Accessible tables could not be determined</source>
<translation>Zugreifbare Tabellen konnten nicht festgestellt werden</translation>
</message>
<message>
- <location filename="../src/app/qgspgsourceselect.cpp" line="605"/>
- <location filename="../src/app/qgspgsourceselect.cpp" line="683"/>
+ <location filename="../src/app/qgspgsourceselect.cpp" line="601"/>
+ <location filename="../src/app/qgspgsourceselect.cpp" line="679"/>
<source>Database connection was successful, but the accessible tables could not be determined.
The error message from the database was:
@@ -16419,12 +16464,12 @@
</translation>
</message>
<message>
- <location filename="../src/app/qgspgsourceselect.cpp" line="718"/>
+ <location filename="../src/app/qgspgsourceselect.cpp" line="714"/>
<source>No accessible tables found</source>
<translation>Keine zugänglichen Tabellen gefunden</translation>
</message>
<message>
- <location filename="../src/app/qgspgsourceselect.cpp" line="719"/>
+ <location filename="../src/app/qgspgsourceselect.cpp" line="715"/>
<source>Database connection was successful, but no accessible tables were found.
Please verify that you have SELECT privilege on a table carrying PostGIS
@@ -17702,13 +17747,13 @@
<context>
<name>QgsPostgresProvider</name>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="105"/>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="125"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="107"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="127"/>
<source>Unable to access relation</source>
<translation>Auf die Relation kann nicht zugegriffen werden</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="106"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="108"/>
<source>Unable to access the %1 relation.
%2.
@@ -17719,7 +17764,7 @@
SQL: %3</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="126"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="128"/>
<source>Unable to determine table access privileges for the %1 relation.
%2.
@@ -17730,114 +17775,114 @@
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="232"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="234"/>
<source>Whole number (smallint - 16bit)</source>
<translation>Kleine Ganzzahl (16bit)</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="235"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="237"/>
<source>Decimal number (numeric)</source>
<translation>Dezimalzahl (numeric)</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="236"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="238"/>
<source>Decimal number (decimal)</source>
<translation>Dezimalzahl (decimal)</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="239"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="241"/>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="240"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="242"/>
<source>Decimal number (double)</source>
<translation>Dezimalzahl (double)</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="243"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="245"/>
<source>Text, fixed length (char)</source>
<translation>Text, feste Länge (char)</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1059"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1087"/>
<source>No suitable key column in table</source>
<translation>Keine passende Schlüsselspalte in der Tabelle</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1157"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1185"/>
<source>and </source>
<translation>und </translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1206"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1234"/>
<source>Unable to find a key column</source>
<translation>Kann die Schlüsselspalte nicht finden</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1347"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1375"/>
<source>and is suitable.</source>
<translation>und ist geeignet.</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1353"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1381"/>
<source> and has a suitable constraint)</source>
<translation> und hat einen geeigneten Constraint)</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1355"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1383"/>
<source> and does not have a suitable constraint)</source>
<translation> und hat keinen geeigneten Constraint)</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1458"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1486"/>
<source>No suitable key column in view</source>
<translation>Keine geeignete Schlüsselspalte im View</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2964"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2992"/>
<source>Unknown geometry type</source>
<translation>Unbekannter Geometrietyp</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2972"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="3000"/>
<source>Qgis was unable to determine the type and srid of column %1 in %2. The database communication log was:
%3</source>
<translation>QGIS konnte den Typ und die SRID der Spalte %1 in %2 nicht bestimmen. Das Datenbankkommunikationsprotokoll war:
%3</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2976"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="3004"/>
<source>Unable to get feature type and srid</source>
<translation>Kann den Objekttyp und die SRID nicht ermitteln</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2261"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2289"/>
<source>Error while adding features</source>
<translation>Fehler beim Hinzufügen von Objekten</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2301"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2329"/>
<source>Error while deleting features</source>
<translation>Fehler beim Löschen von Objekten</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2361"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2389"/>
<source>Error while adding attributes</source>
<translation>Fehler beim Hinzufügen von Attributen</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2406"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2434"/>
<source>Error while deleting attributes</source>
<translation>Fehler beim Löschen von Attributen</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2474"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2502"/>
<source>Error while changing attributes</source>
<translation>Fehler beim Ändern von Attributen</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2560"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2588"/>
<source>Error while changing geometry values</source>
<translation>Fehler beim Ändern von Geometrien</translation>
</message>
@@ -17847,37 +17892,37 @@
<translation>Nicht erwarteter PostgeSQL-Fehler</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1135"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1163"/>
<source>The unique index on column '%1' is unsuitable because Qgis does not currently support non-int4 type columns as a key into the table.
</source>
<translation>Der eindeutige Index auf Spalte '%1' ist ungeeignet, weil QGIS zur Zeit nur Spalten vom Typ int4 als Tabellenschlüssel unterstützt.
</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1163"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1191"/>
<source>The unique index based on columns %1 is unsuitable because Qgis does not currently support multiple columns as a key into the table.
</source>
<translation>Der eindeutige Index auf den Spalten '%1' ist ungeeignet, weil QGIS zur Zeit nur einzelne Spalten als Tabellenschlüssel unterstützt.
</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1343"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1371"/>
<source>'%1' derives from '%2.%3.%4' </source>
<translation>'%1' ist von '%2.%3.%4' abgeleitet </translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1351"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1379"/>
<source>and is not suitable (type is %1)</source>
<translation>und ist ungeeignet (Typ ist %1)</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1439"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1467"/>
<source>Note: '%1' initially appeared suitable but does not contain unique data, so is not suitable.
</source>
<translation>Bemerkung: '%1' schien anfänglich geeignet, ist es allerdings nicht, da sie keine eindeutigen Daten enthält.</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1450"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1478"/>
<source>The view '%1.%2' has no column suitable for use as a unique key.
Qgis requires that the view has a column that can be used as a unique key. Such a column should be derived from a table column of type int4 and be a primary key, have a unique constraint on it, or be a PostgreSQL oid column. To improve performance the column should also be indexed.
The view you selected has the following columns, none of which satisfy the above conditions:</source>
@@ -17886,32 +17931,32 @@
Der ausgewählte View hat folgende Spalten von denen keine die obigen Bedingungen erfüllt:</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2965"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2993"/>
<source>Column %1 in %2 has a geometry type of %3, which Qgis does not currently support.</source>
<translation>Spalte %1 in %2 hat den Geometrietyp %3, den QGIS zur Zeit nicht unterstützt.</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="233"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="235"/>
<source>Whole number (integer - 32bit)</source>
<translation>Ganzzahl (32bit)</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="234"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="236"/>
<source>Whole number (integer - 64bit)</source>
<translation>Ganzzahl (64bit)</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="244"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="246"/>
<source>Text, limited variable length (varchar)</source>
<translation>Text, begrenzte variable Länge (varchar)</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="245"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="247"/>
<source>Text, unlimited length (text)</source>
<translation>Text, unbegrenzte Länge (text)</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1060"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1088"/>
<source>The table has no column suitable for use as a key.
Qgis requires that the table either has a column of type
@@ -17921,7 +17966,7 @@
</source>
<translation>Die Tabelle verfügt über keine als Schlüssel verwendbare Spalte.
-QGIS erfordert, daß die Tabelle entweder eine Spalte des
+QGIS erfordert, dass die Tabelle entweder eine Spalte des
Typs int4 mit einer Eindeutigkeitsbedingung (die den Primärschlüssel
einschließt), eine PostgreSQL-oid-Spalte oder eine ctid-Spalte
mit einer 16bit-Blocknummer hat.</translation>
@@ -17930,12 +17975,22 @@
<context>
<name>QgsPostgresProvider::Conn</name>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="353"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="317"/>
+ </message>
+ <message>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="318"/>
+ </message>
+ <message>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="381"/>
<source>No GEOS Support!</source>
<translation>Keine GEOS Unterstützung!</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="354"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="382"/>
<source>Your PostGIS installation has no GEOS support.
Feature selection and identification will not work properly.
Please install PostGIS with GEOS support (http://geos.refractions.net)</source>
@@ -17944,12 +17999,12 @@
Bitte PostGIS mit GEOSunterstützung installieren (http://geos.refractions.net)</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="338"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="366"/>
<source>No PostGIS Support!</source>
<translation>Keine PostGIS-Unterstützung!</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="339"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="367"/>
<source>Your database has no working PostGIS support.
</source>
<translation>Ihre Datenbank hat keine funktionsfähige PostGIS-Unterstützung.</translation>
@@ -19720,7 +19775,7 @@
<message>
<location filename="../src/ui/qgsrasterlayerpropertiesbase.ui" line="1575"/>
</message>
<message>
<location filename="../src/ui/qgsrasterlayerpropertiesbase.ui" line="1588"/>
@@ -19730,7 +19785,7 @@
<message>
<location filename="../src/ui/qgsrasterlayerpropertiesbase.ui" line="1595"/>
</message>
<message>
<location filename="../src/ui/qgsrasterlayerpropertiesbase.ui" line="1608"/>
@@ -21045,7 +21100,7 @@
<message>
<location filename="../src/plugins/spit/qgsspit.cpp" line="411"/>
<source>Password for %1</source>
- <translation>Paßwort für %1</translation>
+ <translation>Passwort für %1</translation>
</message>
<message>
<location filename="../src/plugins/spit/qgsspit.cpp" line="412"/>
@@ -21468,17 +21523,17 @@
<context>
<name>QgsUniqueValueDialog</name>
<message>
- <location filename="../src/app/qgsuniquevaluedialog.cpp" line="212"/>
+ <location filename="../src/app/qgsuniquevaluedialog.cpp" line="214"/>
<source>default</source>
<translation>Andere</translation>
</message>
<message>
- <location filename="../src/app/qgsuniquevaluedialog.cpp" line="283"/>
+ <location filename="../src/app/qgsuniquevaluedialog.cpp" line="285"/>
<source>Confirm Delete</source>
<translation>Löschen bestätigen</translation>
</message>
<message>
- <location filename="../src/app/qgsuniquevaluedialog.cpp" line="284"/>
+ <location filename="../src/app/qgsuniquevaluedialog.cpp" line="286"/>
<source>The classification field was changed from '%1' to '%2'.
Should the existing classes be deleted before classification?</source>
<translation>Das Klassifizierungsfeld wurde von '%1' auf '%2' geändert.
@@ -21583,27 +21638,27 @@
<context>
<name>QgsVectorLayer</name>
<message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="2636"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="2657"/>
<source>No renderer object</source>
<translation>Kein Darstellungsobjekt</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="2640"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="2661"/>
<source>Classification field not found</source>
<translation>Klassifikationsfeld nicht gefunden</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3119"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3140"/>
<source>ERROR: no provider</source>
<translation>FEHLER: kein Datenlieferant</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3125"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3146"/>
<source>ERROR: layer not editable</source>
<translation>FEHLER: Layer ist nicht veränderbar</translation>
</message>
<message numerus="yes">
- <location filename="../src/core/qgsvectorlayer.cpp" line="3139"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3160"/>
<source>SUCCESS: %n attribute(s) deleted.</source>
<comment>deleted attributes count</comment>
<translation>
@@ -21612,7 +21667,7 @@
</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3145"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3166"/>
<source>ERROR: %n attribute(s) not deleted.</source>
<comment>not deleted attributes count</comment>
<translation>
@@ -21621,7 +21676,7 @@
</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3161"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3182"/>
<source>SUCCESS: %n attribute(s) added.</source>
<comment>added attributes count</comment>
<translation>
@@ -21630,7 +21685,7 @@
</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3167"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3188"/>
<source>ERROR: %n new attribute(s) not added</source>
<comment>not added attributes count</comment>
<translation>
@@ -21639,17 +21694,17 @@
</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3208"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3229"/>
<source>SUCCESS: attribute %1 was added.</source>
<translation>ERFOLG: Attribut %1 hinzugefügt.</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3215"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3236"/>
<source>ERROR: attribute %1 not added</source>
<translation>FEHLER: Attribut %1 nicht hinzugefügt</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3277"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3298"/>
<source>SUCCESS: %n attribute value(s) changed.</source>
<comment>changed attribute values count</comment>
<translation>
@@ -21658,7 +21713,7 @@
</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3282"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3303"/>
<source>ERROR: %n attribute value change(s) not applied.</source>
<comment>not changed attribute values count</comment>
<translation>
@@ -21667,7 +21722,7 @@
</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3314"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3335"/>
<source>SUCCESS: %n feature(s) added.</source>
<comment>added features count</comment>
<translation>
@@ -21676,7 +21731,7 @@
</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3319"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3340"/>
<source>ERROR: %n feature(s) not added.</source>
<comment>not added features count</comment>
<translation>
@@ -21685,7 +21740,7 @@
</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3332"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3353"/>
<source>SUCCESS: %n geometries were changed.</source>
<comment>changed geometries count</comment>
<translation>
@@ -21694,7 +21749,7 @@
</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3337"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3358"/>
<source>ERROR: %n geometries not changed.</source>
<comment>not changed geometries count</comment>
<translation>
@@ -21703,7 +21758,7 @@
</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3349"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3370"/>
<source>SUCCESS: %n feature(s) deleted.</source>
<comment>deleted features count</comment>
<translation>
@@ -21712,7 +21767,7 @@
</translation>
</message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="3359"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="3380"/>
<source>ERROR: %n feature(s) not deleted.</source>
<comment>not deleted features count</comment>
<translation>
@@ -21721,7 +21776,7 @@
</translation>
</message>
<message>
- <location filename="../src/core/qgsvectorlayer.cpp" line="2630"/>
+ <location filename="../src/core/qgsvectorlayer.cpp" line="2651"/>
<source>Unknown renderer</source>
<translation>Unbekannte Darstellung</translation>
</message>
@@ -22160,7 +22215,7 @@
<message>
<location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="537"/>
</message>
<message>
<location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="549"/>
@@ -22175,12 +22230,12 @@
<message>
<location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="569"/>
</message>
<message>
<location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="582"/>
</message>
<message>
<location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="598"/>
@@ -22492,7 +22547,7 @@
<message>
<location filename="../src/app/qgswmssourceselect.cpp" line="388"/>
<source>WMS Password for %1</source>
- <translation>WMS-Paßwort für %1</translation>
+ <translation>WMS-Passwort für %1</translation>
</message>
<message>
<location filename="../src/app/qgswmssourceselect.cpp" line="423"/>
@@ -23165,14 +23220,14 @@
<context>
<name>SelectionFeature</name>
<message>
- <location filename="../src/app/qgsmaptoolnodetool.cpp" line="986"/>
- <location filename="../src/app/qgsmaptoolnodetool.cpp" line="1057"/>
+ <location filename="../src/app/qgsmaptoolnodetool.cpp" line="989"/>
+ <location filename="../src/app/qgsmaptoolnodetool.cpp" line="1060"/>
<source>Node tool</source>
<translation>Knotenwerkzeug</translation>
</message>
<message>
- <location filename="../src/app/qgsmaptoolnodetool.cpp" line="987"/>
- <location filename="../src/app/qgsmaptoolnodetool.cpp" line="1058"/>
+ <location filename="../src/app/qgsmaptoolnodetool.cpp" line="990"/>
+ <location filename="../src/app/qgsmaptoolnodetool.cpp" line="1061"/>
<source>Result geometry is invalid. Reverting last changes.
</source>
<translation>Ergebnisgeometrie ist ungültig. Letzte Änderungen werden zurückgenommen.
@@ -23765,7 +23820,7 @@
<message>
<location filename="../src/plugins/evis/ui/evisdatabaseconnectionguibase.ui" line="202"/>
<source>Password to access the database.</source>
- <translation>Paßwort zum Zugriff auf die Datenbank.</translation>
+ <translation>Passwort zum Zugriff auf die Datenbank.</translation>
</message>
<message>
<location filename="../src/plugins/evis/ui/evisdatabaseconnectionguibase.ui" line="212"/>
@@ -23810,7 +23865,7 @@
<message>
<location filename="../src/plugins/evis/ui/evisdatabaseconnectionguibase.ui" line="296"/>
</message>
<message>
<location filename="../src/plugins/evis/ui/evisdatabaseconnectionguibase.ui" line="303"/>
