[QGIS Commit] r12644 - in trunk/qgis: i18n src/core
svn_qgis at osgeo.org
Mon Dec 28 17:08:04 EST 2009
Author: jef
Date: 2009-12-28 17:08:03 -0500 (Mon, 28 Dec 2009)
New Revision: 12644
trunk/qgis/i18n/qgis_de.ts
trunk/qgis/src/core/qgscoordinatetransform.cpp
fix compile error
Modified: trunk/qgis/i18n/qgis_de.ts
--- trunk/qgis/i18n/qgis_de.ts 2009-12-28 21:52:15 UTC (rev 12643)
+++ trunk/qgis/i18n/qgis_de.ts 2009-12-28 22:08:03 UTC (rev 12644)
@@ -8107,17 +8107,17 @@
</message>
<message>
<location filename="../src/core/qgscoordinatetransform.cpp" line="456"/>
- <source>inverse</source>
+ <source>inverse transform</source>
<translation>Rücktransformation</translation>
</message>
<message>
<location filename="../src/core/qgscoordinatetransform.cpp" line="463"/>
- <source>forward</source>
+ <source>forward transform</source>
<translation>Transformation</translation>
</message>
<message>
<location filename="../src/core/qgscoordinatetransform.cpp" line="483"/>
- <source>%1 transform of
+ <source>%1 of
%2
failed with error: %3
</source>
Modified: trunk/qgis/src/core/qgscoordinatetransform.cpp
--- trunk/qgis/src/core/qgscoordinatetransform.cpp 2009-12-28 21:52:15 UTC (rev 12643)
+++ trunk/qgis/src/core/qgscoordinatetransform.cpp 2009-12-28 22:08:03 UTC (rev 12644)
@@ -453,14 +453,14 @@
if ( direction == ReverseTransform )
projResult = pj_transform( mDestinationProjection, mSourceProjection, numPoints, 0, x, y, z );
- dir = tr( "inverse" );
+ dir = tr( "inverse transform" );
else
assert( mSourceProjection != 0 );
assert( mDestinationProjection != 0 );
projResult = pj_transform( mSourceProjection, mDestinationProjection, numPoints, 0, x, y, z );
- dir = tr( "forward" );
+ dir = tr( "forward transform" );
if ( projResult != 0 )
@@ -480,10 +480,10 @@
- QString msg = tr("%1 transform of\n%2\nfailed with error: %3\n")
+ QString msg = tr("%1 of\n%2\nfailed with error: %3\n")
.arg( dir )
.arg( points )
- .arg( QString::fromUtf8( pj_strerrno( projResult ) ) ) );
+ .arg( QString::fromUtf8( pj_strerrno( projResult ) ) );
QgsDebugMsg( "Projection failed emitting invalid transform signal: " + msg );
