[QGIS Commit] r12657 - trunk/qgis/src/plugins/grass/modules-common
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Dec 31 06:52:47 EST 2009
Author: pcav
Date: 2009-12-31 06:52:45 -0500 (Thu, 31 Dec 2009)
New Revision: 12657
   trunk/qgis/src/plugins/grass/modules-common/r.los.qgm
   trunk/qgis/src/plugins/grass/modules-common/r.watershed.qgm
Two typos in GRASS modules
Modified: trunk/qgis/src/plugins/grass/modules-common/r.los.qgm
--- trunk/qgis/src/plugins/grass/modules-common/r.los.qgm	2009-12-31 09:58:02 UTC (rev 12656)
+++ trunk/qgis/src/plugins/grass/modules-common/r.los.qgm	2009-12-31 11:52:45 UTC (rev 12657)
@@ -6,6 +6,6 @@
 	<option key="input"/>
 	<option key="coordinate" />
 	<option key="obs_elev" answer="1.75" hidden="no" />
-	<option key="max_dist" answer="1000" hidden="no" />
+	<option key="max_dist" answer="10000" hidden="no" />
 	<option key="output" />
 </qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules-common/r.watershed.qgm
--- trunk/qgis/src/plugins/grass/modules-common/r.watershed.qgm	2009-12-31 09:58:02 UTC (rev 12656)
+++ trunk/qgis/src/plugins/grass/modules-common/r.watershed.qgm	2009-12-31 11:52:45 UTC (rev 12657)
@@ -2,7 +2,7 @@
 <!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
-<qgisgrassmodule label="Watershed Analysis." module="r.watershed">
+<qgisgrassmodule label="Watershed Analysis" module="r.watershed">
 	<option key="elevation" />
 	<option key="threshold" />
@@ -10,7 +10,6 @@
 	<option key="accumulation" />
 	<option key="drainage" />
 	<option key="stream" />
 	<option key="basin" />
 </qgisgrassmodule>
More information about the QGIS-commit mailing list
