[QGIS Commit] r12658 - in trunk/qgis: scripts src/plugins/grass
svn_qgis at osgeo.org
Thu Dec 31 11:51:37 EST 2009
Author: jef
Date: 2009-12-31 11:51:36 -0500 (Thu, 31 Dec 2009)
New Revision: 12658
Added:
trunk/qgis/scripts/qgm2cpp.pl
trunk/qgis/scripts/ts2cpp.pl
trunk/qgis/scripts/update_ts_files.sh
trunk/qgis/src/plugins/grass/qgsgrassmapcalc.cpp
trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp
trunk/qgis/src/plugins/grass/qgsgrasstools.cpp
grass modules i18n
Added: trunk/qgis/scripts/qgm2cpp.pl
--- trunk/qgis/scripts/qgm2cpp.pl (rev 0)
+++ trunk/qgis/scripts/qgm2cpp.pl 2009-12-31 16:51:36 UTC (rev 12658)
@@ -0,0 +1,58 @@
+#!/usr/bin/perl
+use XML::Simple;
+use Data::Dumper;
+print <<EOF;
+ This is NOT a proper c++ source code. This file is only designed to be caught
+ by qmake and included in lupdate. It contains all translateable strings collected
+ by pylupdate4.
+EOF
+my %labels;
+my $file;
+sub parse {
+ foreach my $a (@_) {
+ if( ref($a) eq "ARRAY" ) {
+ foreach my $b ( @$a ) {
+ parse($b);
+ } elsif( ref($a) eq "HASH" ) {
+ foreach my $b ( keys %$a ) {
+ if( $b eq "label" ) {
+ my $label = $a->{$b};
+ die "expected string" unless ref($label) eq "";
+ print STDERR "warning[$file]: '$label' should start with a uppercase character or digit and not start or end with whitespaces"
+ if $label =~ /^\s+/ || $label =~ /\s+$/ || $label !~ /^[A-Z0-9(]/;
+ $label =~ s/^\s+//;
+ $label =~ s/\s+$//;
+ $label =~ ucfirst $label;
+ $labels{$label} = 1;
+ } else {
+ parse($a->{$b});
+# } elsif(ref($a) eq "") {
+# warn "found: " . $a;
+# } else {
+# warn "found: " . ref($a) . " " . Dumper($a);
+open I, "find src/plugins/grass -name '*.qgm' -o -name '*.qgc'|";
+while($file = <I>) {
+ print STDERR "$file\n";
+ chop $file;
+ parse XMLin($file, ForceArray=>1);
+ print STDERR "$file DONE\n";
+close I;
+foreach (sort keys %labels) {
+ print "translate( \"grasslabel\", \"$_\" );\n";
Modified: trunk/qgis/scripts/ts2cpp.pl
--- trunk/qgis/scripts/ts2cpp.pl 2009-12-31 11:52:45 UTC (rev 12657)
+++ trunk/qgis/scripts/ts2cpp.pl 2009-12-31 16:51:36 UTC (rev 12658)
@@ -1,7 +1,6 @@
#!/usr/bin/perl
use XML::Simple;
-use Data::Dumper;
die "usage: $0 source.ts dest.cpp\n" unless @ARGV==2 && -f $ARGV[0];
Modified: trunk/qgis/scripts/update_ts_files.sh
--- trunk/qgis/scripts/update_ts_files.sh 2009-12-31 11:52:45 UTC (rev 12657)
+++ trunk/qgis/scripts/update_ts_files.sh 2009-12-31 16:51:36 UTC (rev 12658)
@@ -40,13 +40,14 @@
rm python-i18n.ts
cd ../../..
done
+perl scripts/qgm2cpp.pl >src/plugins/grass/grasslabels-i18n.cpp
echo Creating qmake project file
qmake -project -o qgis_ts.pro -nopwd src python i18n
echo Updating translation files
lupdate$opts -verbose qgis_ts.pro
echo Removing temporary python translation files
perl -i.bak -ne 'print unless /^\s+<location.*python-i18n\.cpp.*$/;' i18n/qgis_*.ts
-rm python/python-i18n.cpp python/plugins/*/python-i18n.cpp i18n/qgis_*.ts.bak
+rm python/python-i18n.cpp python/plugins/*/python-i18n.cpp i18n/qgis_*.ts.bak src/plugins/grass/grasslabels-i18n.cpp
echo Removing qmake project file
rm qgis_ts.pro
echo Unpacking qt_ts.tar
Modified: trunk/qgis/src/plugins/grass/qgsgrassmapcalc.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassmapcalc.cpp 2009-12-31 11:52:45 UTC (rev 12657)
+++ trunk/qgis/src/plugins/grass/qgsgrassmapcalc.cpp 2009-12-31 16:51:36 UTC (rev 12658)
@@ -1314,7 +1314,7 @@
case QgsGrassMapcalcObject::Map:
- QString label = e.attribute( "label", "???" );
+ QString label = QApplication::translate( "grasslabel", e.attribute( "label", "???" ).toUtf8() );
obj->setValue( value, label );
break;
Modified: trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp 2009-12-31 11:52:45 UTC (rev 12657)
+++ trunk/qgis/src/plugins/grass/qgsgrassmodule.cpp 2009-12-31 16:51:36 UTC (rev 12658)
@@ -941,7 +941,7 @@
qFile.close();
QDomElement qDocElem = qDoc.documentElement();
- return ( qDocElem.attribute( "label" ) );
+ return QApplication::translate( "grasslabel", qDocElem.attribute( "label" ).toUtf8() );
QPixmap QgsGrassModule::pixmap( QString path, int height )
@@ -2503,7 +2503,7 @@
QString label, description;
if ( !qdesc.attribute( "label" ).isEmpty() )
- label = qdesc.attribute( "label" );
+ label = QApplication::translate( "grasslabel", qdesc.attribute( "label" ).toUtf8() );
if ( label.isEmpty() )
@@ -2511,16 +2511,14 @@
if ( !n.isNull() )
QDomElement e = n.toElement();
- label = e.text().trimmed();
- label.replace( 0, 1, label.left( 1 ).toUpper() );
+ label = QApplication::translate( "grasslabel", e.text().toUtf8() );
QDomNode n = gnode.namedItem( "description" );
if ( !n.isNull() )
- description = e.text().trimmed();
- description.replace( 0, 1, description.left( 1 ).toUpper() );
+ description = QApplication::translate( "grasslabel", e.text().toUtf8() );
if ( !label.isEmpty() )
Modified: trunk/qgis/src/plugins/grass/qgsgrasstools.cpp
--- trunk/qgis/src/plugins/grass/qgsgrasstools.cpp 2009-12-31 11:52:45 UTC (rev 12657)
+++ trunk/qgis/src/plugins/grass/qgsgrasstools.cpp 2009-12-31 16:51:36 UTC (rev 12658)
@@ -276,7 +276,7 @@
if ( e.tagName() == "section" )
- QString label = e.attribute( "label" );
+ QString label = QApplication::translate( "grasslabel", e.attribute( "label" ).toUtf8() );
QgsDebugMsg( QString( "label = %1" ).arg( label ) );
item->setText( 0, label );
item->setExpanded( false );
