[QGIS Commit] r11079 - in trunk/qgis/src/plugins/grass: modules-6.3 modules-6.4
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Jul 15 04:50:42 EDT 2009
Author: rugginoso
Date: 2009-07-15 04:50:41 -0400 (Wed, 15 Jul 2009)
New Revision: 11079
   trunk/qgis/src/plugins/grass/modules-6.3/default.qgc
   trunk/qgis/src/plugins/grass/modules-6.4/default.qgc
Fixed a commit mistake of r11052.
Modified: trunk/qgis/src/plugins/grass/modules-6.3/default.qgc
--- trunk/qgis/src/plugins/grass/modules-6.3/default.qgc	2009-07-15 08:26:28 UTC (rev 11078)
+++ trunk/qgis/src/plugins/grass/modules-6.3/default.qgc	2009-07-15 08:50:41 UTC (rev 11079)
@@ -41,6 +41,7 @@
 		</section>
 		<section label="Export">
 			<section label="Export raster">
+				<grass name="r.out.gdal.gtiff"/>
 				<grass name="r.out.gdal"/>
 				<grass name="r.out.ascii"/>
 				<grass name="r.out.xyz"/>
@@ -60,6 +61,8 @@
 			<section label="Export vector">
 				<grass name="v.out.ogr"/>
 				<grass name="qgis.v.out.ogr.pg"/>
+				<grass name="v.out.ogr.gml"/>
+				<grass name="v.out.ogr.mapinfo"/>
 				<grass name="v.out.ogr.postgis"/>
 				<grass name="v.out.ascii"/>
 				<grass name="v.out.dxf"/>
@@ -90,7 +93,8 @@
                                 <grass name="g.region.multiple.vector"/>
 			</section>
 			<section label="Projection management">
-                                <section label="Print projection information of the current location"> 					<grass name="g.proj.print"/>
+                                <section label="Print projection information of the current location">
+ 					<grass name="g.proj.print"/>
 				</section>
                                 <section label="Print projection information from a georeferenced file">
 					<grass name="g.proj.geo"/>
@@ -103,7 +107,7 @@
 					<grass name="g.proj.proj.new"/>
 				</section>
 			</section>
-			<section label="Converte coordinates">
+			<section label="Convert coordinates">
 				<grass name="m.cogo"/>
 			</section>
 		</section>
@@ -192,6 +196,7 @@
 		</section>
 		<section label="Spatial models">
 			<section label="Hydrologic modelling">
+				<grass name="r.watershed"/>
 				<grass name="r.carve"/>
 				<grass name="r.fill.dir"/>
 				<grass name="r.lake.xy"/>
Modified: trunk/qgis/src/plugins/grass/modules-6.4/default.qgc
--- trunk/qgis/src/plugins/grass/modules-6.4/default.qgc	2009-07-15 08:26:28 UTC (rev 11078)
+++ trunk/qgis/src/plugins/grass/modules-6.4/default.qgc	2009-07-15 08:50:41 UTC (rev 11079)
@@ -23,6 +23,10 @@
 				<grass name="r.in.srtm"/>
 				<grass name="r.in.aster"/>
 				<grass name="r.in.wms"/>
+				<grass name="r.external"/>
+				<grass name="r.external.qgis"/>
+				<grass name="r.external.qgis.all"/>
+				<grass name="r.in.wms"/>
 			</section>
 			<section label="Import vector">
                                 <grass name="v.in.ogr.qgis"/>
@@ -43,6 +47,7 @@
 		</section>
@@ -62,6 +67,8 @@
@@ -95,7 +102,8 @@
 			</section>
 				</section>
@@ -108,7 +116,7 @@
 				</section>
 			</section>
 			</section>
 		</section>
@@ -199,6 +207,7 @@
 		</section>
More information about the QGIS-commit mailing list
