[QGIS Commit] r11081 - in trunk/qgis/src/plugins/grass: modules-6.4
scripts
svn_qgis at osgeo.org
Wed Jul 15 06:14:18 EDT 2009
Author: rugginoso
Date: 2009-07-15 06:14:17 -0400 (Wed, 15 Jul 2009)
New Revision: 11081
Added:
trunk/qgis/src/plugins/grass/modules-6.4/db.connect-login.pg.1.png
trunk/qgis/src/plugins/grass/modules-6.4/db.connect-login.pg.qgm
trunk/qgis/src/plugins/grass/modules-6.4/r.external.all.1.png
trunk/qgis/src/plugins/grass/modules-6.4/r.external.all.qgm
trunk/qgis/src/plugins/grass/modules-6.4/v.out.ogr.pg.1.png
trunk/qgis/src/plugins/grass/modules-6.4/v.out.ogr.pg.2.png
trunk/qgis/src/plugins/grass/modules-6.4/v.out.ogr.pg.qgm
trunk/qgis/src/plugins/grass/scripts/db.connect-login.pg.py
trunk/qgis/src/plugins/grass/scripts/r.external.all.py
trunk/qgis/src/plugins/grass/scripts/v.out.ogr.pg.py
Removed:
trunk/qgis/src/plugins/grass/modules-6.4/qgis.db.connect-login.pg.1.png
trunk/qgis/src/plugins/grass/modules-6.4/qgis.db.connect-login.pg.qgm
trunk/qgis/src/plugins/grass/modules-6.4/qgis.r.external.all.1.png
trunk/qgis/src/plugins/grass/modules-6.4/qgis.r.external.all.qgm
trunk/qgis/src/plugins/grass/modules-6.4/qgis.v.out.ogr.pg.1.png
trunk/qgis/src/plugins/grass/modules-6.4/qgis.v.out.ogr.pg.2.png
trunk/qgis/src/plugins/grass/modules-6.4/qgis.v.out.ogr.pg.qgm
trunk/qgis/src/plugins/grass/scripts/qgis.db.connect-login.pg.py
trunk/qgis/src/plugins/grass/scripts/qgis.r.external.all.py
trunk/qgis/src/plugins/grass/scripts/qgis.v.out.ogr.pg.py
trunk/qgis/src/plugins/grass/modules-6.4/default.qgc
Renamed some modules.
Copied: trunk/qgis/src/plugins/grass/modules-6.4/db.connect-login.pg.1.png (from rev 11077, trunk/qgis/src/plugins/grass/modules-6.4/qgis.db.connect-login.pg.1.png)
(Binary files differ)
Copied: trunk/qgis/src/plugins/grass/modules-6.4/db.connect-login.pg.qgm (from rev 11078, trunk/qgis/src/plugins/grass/modules-6.4/qgis.db.connect-login.pg.qgm)
--- trunk/qgis/src/plugins/grass/modules-6.4/db.connect-login.pg.qgm (rev 0)
+++ trunk/qgis/src/plugins/grass/modules-6.4/db.connect-login.pg.qgm 2009-07-15 10:14:17 UTC (rev 11081)
@@ -0,0 +1,11 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
+<qgisgrassmodule label="Set PostgreSQL DB connection" module="db.connect-login.pg.py" manual="db.connect">
+ <option key="database" />
+ <option key="schema" />
+ <option key="host" />
+ <option key="port" answer="5432"/>
+ <option key="user"/>
+ <option key="password"/>
+</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules-6.4/default.qgc
--- trunk/qgis/src/plugins/grass/modules-6.4/default.qgc 2009-07-15 09:50:25 UTC (rev 11080)
+++ trunk/qgis/src/plugins/grass/modules-6.4/default.qgc 2009-07-15 10:14:17 UTC (rev 11081)
@@ -25,7 +25,7 @@
<grass name="r.in.wms"/>
<grass name="r.external"/>
<grass name="r.external.qgis"/>
- <grass name="r.external.qgis.all"/>
+ <grass name="r.external.all"/>
</section>
<section label="Import vector">
@@ -66,7 +66,7 @@
</section>
<section label="Export vector">
<grass name="v.out.ogr"/>
- <grass name="qgis.v.out.ogr.pg"/>
+ <grass name="v.out.ogr.pg"/>
<grass name="v.out.ogr.gml"/>
<grass name="v.out.ogr.mapinfo"/>
<grass name="v.out.ogr.postgis"/>
@@ -439,7 +439,7 @@
<section label="Database management">
<grass name="db.connect"/>
<grass name="db.connect.schema"/>
- <grass name="qgis.db.connect-login.pg"/>
+ <grass name="db.connect-login.pg"/>
<grass name="v.db.reconnect.all"/>
<grass name="db.login"/>
<grass name="db.in.ogr"/>
Deleted: trunk/qgis/src/plugins/grass/modules-6.4/qgis.db.connect-login.pg.1.png
Deleted: trunk/qgis/src/plugins/grass/modules-6.4/qgis.db.connect-login.pg.qgm
--- trunk/qgis/src/plugins/grass/modules-6.4/qgis.db.connect-login.pg.qgm 2009-07-15 09:50:25 UTC (rev 11080)
+++ trunk/qgis/src/plugins/grass/modules-6.4/qgis.db.connect-login.pg.qgm 2009-07-15 10:14:17 UTC (rev 11081)
@@ -1,11 +0,0 @@
-<?xml version="1.0" encoding="UTF-8"?>
-<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
-<qgisgrassmodule label="Set PostgreSQL DB connection" module="qgis.db.connect-login.pg.py" manual="db.connect">
- <option key="database" />
- <option key="schema" />
- <option key="host" />
- <option key="port" answer="5432"/>
- <option key="user"/>
- <option key="password"/>
-</qgisgrassmodule>
Deleted: trunk/qgis/src/plugins/grass/modules-6.4/qgis.r.external.all.1.png
Deleted: trunk/qgis/src/plugins/grass/modules-6.4/qgis.r.external.all.qgm
--- trunk/qgis/src/plugins/grass/modules-6.4/qgis.r.external.all.qgm 2009-07-15 09:50:25 UTC (rev 11080)
+++ trunk/qgis/src/plugins/grass/modules-6.4/qgis.r.external.all.qgm 2009-07-15 10:14:17 UTC (rev 11081)
@@ -1,9 +0,0 @@
-<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassdatamodule.dtd">
-<qgisgrassmodule label="Link all GDAL supported raster files into a directory to binary raster map layers." module="qgis.r.external.all.py" manual="r.external">
- <flag key="o"/>
- <flag key="e"/>
- <flag key="r"/>
- <file key="input" type="directory" />
- <option key="band"/>
-</qgisgrassmodule>
Deleted: trunk/qgis/src/plugins/grass/modules-6.4/qgis.v.out.ogr.pg.1.png
Deleted: trunk/qgis/src/plugins/grass/modules-6.4/qgis.v.out.ogr.pg.2.png
Deleted: trunk/qgis/src/plugins/grass/modules-6.4/qgis.v.out.ogr.pg.qgm
--- trunk/qgis/src/plugins/grass/modules-6.4/qgis.v.out.ogr.pg.qgm 2009-07-15 09:50:25 UTC (rev 11080)
+++ trunk/qgis/src/plugins/grass/modules-6.4/qgis.v.out.ogr.pg.qgm 2009-07-15 10:14:17 UTC (rev 11081)
@@ -1,13 +0,0 @@
-<qgisgrassmodule label="Export vector to PostGIS (PostgreSQL) database table." module="qgis.v.out.ogr.pg.py" manual="v.out.ogr">
- <option key="input" layeroption="layer" typeoption="type" />
- <option key="olayer" />
- <!--option key="schema" /-->
-</qgisgrassmodule>
Copied: trunk/qgis/src/plugins/grass/modules-6.4/r.external.all.1.png (from rev 11077, trunk/qgis/src/plugins/grass/modules-6.4/qgis.r.external.all.1.png)
Copied: trunk/qgis/src/plugins/grass/modules-6.4/r.external.all.qgm (from rev 11078, trunk/qgis/src/plugins/grass/modules-6.4/qgis.r.external.all.qgm)
--- trunk/qgis/src/plugins/grass/modules-6.4/r.external.all.qgm (rev 0)
+++ trunk/qgis/src/plugins/grass/modules-6.4/r.external.all.qgm 2009-07-15 10:14:17 UTC (rev 11081)
@@ -0,0 +1,9 @@
+<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassdatamodule.dtd">
+<qgisgrassmodule label="Link all GDAL supported raster files into a directory to binary raster map layers." module="r.external.all.py" manual="r.external">
+ <flag key="o"/>
+ <flag key="e"/>
+ <flag key="r"/>
+ <file key="input" type="directory" />
+ <option key="band"/>
+</qgisgrassmodule>
Copied: trunk/qgis/src/plugins/grass/modules-6.4/v.out.ogr.pg.1.png (from rev 11077, trunk/qgis/src/plugins/grass/modules-6.4/qgis.v.out.ogr.pg.1.png)
Copied: trunk/qgis/src/plugins/grass/modules-6.4/v.out.ogr.pg.2.png (from rev 11077, trunk/qgis/src/plugins/grass/modules-6.4/qgis.v.out.ogr.pg.2.png)
Copied: trunk/qgis/src/plugins/grass/modules-6.4/v.out.ogr.pg.qgm (from rev 11078, trunk/qgis/src/plugins/grass/modules-6.4/qgis.v.out.ogr.pg.qgm)
--- trunk/qgis/src/plugins/grass/modules-6.4/v.out.ogr.pg.qgm (rev 0)
+++ trunk/qgis/src/plugins/grass/modules-6.4/v.out.ogr.pg.qgm 2009-07-15 10:14:17 UTC (rev 11081)
@@ -0,0 +1,13 @@
+<qgisgrassmodule label="Export vector to PostGIS (PostgreSQL) database table." module="v.out.ogr.pg.py" manual="v.out.ogr">
+ <option key="input" layeroption="layer" typeoption="type" />
+ <option key="olayer" />
+ <!--option key="schema" /-->
+</qgisgrassmodule>
Copied: trunk/qgis/src/plugins/grass/scripts/db.connect-login.pg.py (from rev 11077, trunk/qgis/src/plugins/grass/scripts/qgis.db.connect-login.pg.py)
--- trunk/qgis/src/plugins/grass/scripts/db.connect-login.pg.py (rev 0)
+++ trunk/qgis/src/plugins/grass/scripts/db.connect-login.pg.py 2009-07-15 10:14:17 UTC (rev 11081)
@@ -0,0 +1,119 @@
+#!/usr/bin/env python
+# MODULE: qgis.db.connect-login.py
+# AUTHOR(S): Radim Blazek
+# PURPOSE: Connect to Postgresql
+# COPYRIGHT: (C) 2009 by Radim Blazek
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%Module
+#% description: Make connection to PostgreSQL database and login.
+#% keywords: database
+#%End
+#%option
+#% key: host
+#% type: string
+#% label: Host
+#% description: Host name of the machine on which the server is running.
+#% required : no
+#%end
+#%option
+#% key: port
+#% type: integer
+#% label: Port
+#% description: TCP port on which the server is listening, usually 5432.
+#% required : no
+#%end
+#%option
+#% key: database
+#% type: string
+#% key_desc : name
+#% gisprompt: old_dbname,dbname,dbname
+#% label: Database
+#% description: Database name
+#% required : yes
+#%end
+#%option
+#% key: schema
+#% type: string
+#% label: Schema
+#% description: Database schema.
+#% required : no
+#%end
+#%option
+#% key: user
+#% type: string
+#% label: User
+#% description: Connect to the database as the user username instead of the default.
+#% required : no
+#%end
+#%option
+#% key: password
+#% type: string
+#% label: Password
+#% description: Password will be stored in file!
+#% required : no
+#%end
+import sys
+import os
+import string
+try:
+ from grass.script import core as grass
+except ImportError:
+ import grass
+except:
+ raise Exception ("Cannot find 'grass' Python module. Python is supported by GRASS from version >= 6.4" )
+def main():
+ host = options['host']
+ port = options['port']
+ database = options['database']
+ schema = options['schema']
+ user = options['user']
+ password = options['password']
+ # Test connection
+ conn = "dbname=" + database
+ if host: conn += ",host=" + host
+ if port: conn += ",port=" + port
+ # Unfortunately we cannot test untill user/password is set
+ if user or password:
+ print "Setting login (db.login) ... "
+ sys.stdout.flush()
+ if grass.run_command('db.login', driver = "pg", database = conn, user = user, password = password) != 0:
+ grass.fatal("Cannot login")
+ # Try to connect
+ print "Testing connection ..."
+ if grass.run_command('db.select', quiet = True, flags='c', driver= "pg", database=conn, sql="select version()" ) != 0:
+ print "Deleting login (db.login) ..."
+ if grass.run_command('db.login', quiet = True, driver = "pg", database = conn, user = "", password = "") != 0:
+ print "Cannot delete login."
+ grass.fatal("Cannot connect to database.")
+ if grass.run_command('db.connect', driver = "pg", database = conn, schema = schema) != 0:
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
Deleted: trunk/qgis/src/plugins/grass/scripts/qgis.db.connect-login.pg.py
--- trunk/qgis/src/plugins/grass/scripts/qgis.db.connect-login.pg.py 2009-07-15 09:50:25 UTC (rev 11080)
+++ trunk/qgis/src/plugins/grass/scripts/qgis.db.connect-login.pg.py 2009-07-15 10:14:17 UTC (rev 11081)
@@ -1,119 +0,0 @@
-#!/usr/bin/env python
-# MODULE: qgis.db.connect-login.py
-# AUTHOR(S): Radim Blazek
-# PURPOSE: Connect to Postgresql
-# COPYRIGHT: (C) 2009 by Radim Blazek
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
-#%Module
-#% description: Make connection to PostgreSQL database and login.
-#% keywords: database
-#%End
-#%option
-#% key: host
-#% type: string
-#% label: Host
-#% description: Host name of the machine on which the server is running.
-#% required : no
-#%end
-#%option
-#% key: port
-#% type: integer
-#% label: Port
-#% description: TCP port on which the server is listening, usually 5432.
-#% required : no
-#%end
-#%option
-#% key: database
-#% type: string
-#% key_desc : name
-#% gisprompt: old_dbname,dbname,dbname
-#% label: Database
-#% description: Database name
-#% required : yes
-#%end
-#%option
-#% key: schema
-#% type: string
-#% label: Schema
-#% description: Database schema.
-#% required : no
-#%end
-#%option
-#% key: user
-#% type: string
-#% label: User
-#% description: Connect to the database as the user username instead of the default.
-#% required : no
-#%end
-#%option
-#% key: password
-#% type: string
-#% label: Password
-#% description: Password will be stored in file!
-#% required : no
-#%end
-import sys
-import os
-import string
-try:
- from grass.script import core as grass
-except ImportError:
- import grass
-except:
- raise Exception ("Cannot find 'grass' Python module. Python is supported by GRASS from version >= 6.4" )
-def main():
- host = options['host']
- port = options['port']
- database = options['database']
- schema = options['schema']
- user = options['user']
- password = options['password']
- # Test connection
- conn = "dbname=" + database
- if host: conn += ",host=" + host
- if port: conn += ",port=" + port
- # Unfortunately we cannot test untill user/password is set
- if user or password:
- print "Setting login (db.login) ... "
- sys.stdout.flush()
- if grass.run_command('db.login', driver = "pg", database = conn, user = user, password = password) != 0:
- grass.fatal("Cannot login")
- # Try to connect
- print "Testing connection ..."
- if grass.run_command('db.select', quiet = True, flags='c', driver= "pg", database=conn, sql="select version()" ) != 0:
- print "Deleting login (db.login) ..."
- if grass.run_command('db.login', quiet = True, driver = "pg", database = conn, user = "", password = "") != 0:
- print "Cannot delete login."
- grass.fatal("Cannot connect to database.")
- if grass.run_command('db.connect', driver = "pg", database = conn, schema = schema) != 0:
-if __name__ == "__main__":
- options, flags = grass.parser()
- main()
Deleted: trunk/qgis/src/plugins/grass/scripts/qgis.r.external.all.py
--- trunk/qgis/src/plugins/grass/scripts/qgis.r.external.all.py 2009-07-15 09:50:25 UTC (rev 11080)
+++ trunk/qgis/src/plugins/grass/scripts/qgis.r.external.all.py 2009-07-15 10:14:17 UTC (rev 11081)
@@ -1,84 +0,0 @@
-# MODULE: qgis.r.external.all.py
-# AUTHOR(S): Lorenzo Masini
-# PURPOSE: Link all GDAL supported raster files into a directory
-# to binary raster map layers.
-# COPYRIGHT: (C) 2009 by Lorenzo Masini
-# for details.
-#%Module
-#% description: Link all GDAL supported raster files into a directory to binary raster map layers.
-#% keywords: raster, import
-#%End
-#%option
-#% key: input
-#% type: string
-#% gisprompt: input
-#% key_desc : name
-#% description: Directory containing raster files
-#% required : yes
-#%end
-#%option
-#% key: band
-#% type: integer
-#% description: Band to select
-#% answer: 1
-#% required : no
-#%end
-#%flag
-#% key: o
-#% description: Override projection (use location's projection)
-#%end
-#%flag
-#% key: e
-#% description: Extend location extents based on new dataset
-#%end
-#%flag
-#% key: r
-#% description: Recursively scan subdirectories
-import sys
-import os
-try:
- import grass
-except:
-def import_directory_of_rasters(directory, recursive):
- for dir, dirnames, filenames in os.walk(directory):
- for filename in filenames:
- if grass.run_command('r.external', flags=flags_string, input=os.path.join(dir, filename), band=options['band'], output=filename[:-4], title=filename[:-4]) != 0:
- grass.warning('Cannot import file' + filename)
- if not recursive:
- break
- for dirname in dirnames:
- import_directory_of_rasters(dirname, recursive)
-def main():
- input = options['input']
- recursive = flags['r']
- import_directory_of_rasters(input, recursive)
- flags_string = "".join([k for k in flags.keys() if flags[k] and k != 'r'])
- main()
Deleted: trunk/qgis/src/plugins/grass/scripts/qgis.v.out.ogr.pg.py
--- trunk/qgis/src/plugins/grass/scripts/qgis.v.out.ogr.pg.py 2009-07-15 09:50:25 UTC (rev 11080)
+++ trunk/qgis/src/plugins/grass/scripts/qgis.v.out.ogr.pg.py 2009-07-15 10:14:17 UTC (rev 11081)
@@ -1,140 +0,0 @@
-# MODULE: qgis.v.out.ogr.pg.py
-# PURPOSE: Export a vectore to PostGIS (PostgreSQL) database table
-# for details.
-#%Module
-#% description: Export vector to PostGIS (PostgreSQL) database table.
-#% keywords: vector, export, database
-#%End
-#%option
-#% key: input
-#% type: string
-#% gisprompt: old,vector,vector
-#% key_desc : name
-#% description: Name of input vector map
-#% required : yes
-#%end
-#%option
-#% key: layer
-#% type: integer
-#% description: Number of input layer
-#% answer: 1
-#% required : yes
-#%end
-#%option
-#% key: type
-#% type: string
-#% description: Feature type(s)
-#% options: point,kernel,centroid,line,boundary,area,face
-#% multiple: yes
-#% required : yes
-#%end
-#%option
-#% key: olayer
-#% type: string
-#% description: Name of output database table
-#% required : yes
-#%end
-#%option
-#% key: host
-#% type: string
-#% label: Host
-#% required : no
-#%end
-#%option
-#% key: port
-#% type: integer
-#% label: Port
-#% required : no
-#%end
-#%option
-#% key: database
-#% type: string
-#% key_desc : name
-#% label: Database
-#% required : yes
-#%end
-# AFAIK scheme is not supported well by OGR
-##%option
-##% key: schema
-##% type: string
-##% label: Schema
-##% description: Database schema.
-##% required : no
-##%end
-#%option
-#% key: user
-#% type: string
-#% label: User
-#% required : no
-#%end
-#%option
-#% key: password
-#% type: string
-#% label: Password
-#% required : no
-#%end
-import sys
-import os
-import string
-try:
- import grass
-except:
-def main():
- layer = options['layer']
- type = options['type']
- olayer = options['olayer']
- #schema = options['schema']
- # Construct dsn string
- dsn = "PG:dbname=" + database
- if host: dsn += " host=" + host
- if port: dsn += " port=" + port
- if user: dsn += " user=" + user
- if password: dsn += " password=" + password
- if grass.run_command('v.out.ogr', input=input, layer=layer, type=type, format="PostgreSQL", dsn=dsn, olayer=olayer ) != 0:
- grass.fatal("Cannot export vector to database.")
- main()
Copied: trunk/qgis/src/plugins/grass/scripts/r.external.all.py (from rev 11077, trunk/qgis/src/plugins/grass/scripts/qgis.r.external.all.py)
--- trunk/qgis/src/plugins/grass/scripts/r.external.all.py (rev 0)
+++ trunk/qgis/src/plugins/grass/scripts/r.external.all.py 2009-07-15 10:14:17 UTC (rev 11081)
@@ -0,0 +1,84 @@
+# MODULE: qgis.r.external.all.py
+# AUTHOR(S): Lorenzo Masini
+# PURPOSE: Link all GDAL supported raster files into a directory
+# to binary raster map layers.
+# COPYRIGHT: (C) 2009 by Lorenzo Masini
+# for details.
+#%Module
+#% description: Link all GDAL supported raster files into a directory to binary raster map layers.
+#% keywords: raster, import
+#%End
+#%option
+#% key: input
+#% type: string
+#% gisprompt: input
+#% key_desc : name
+#% description: Directory containing raster files
+#% required : yes
+#%end
+#%option
+#% key: band
+#% type: integer
+#% description: Band to select
+#% answer: 1
+#% required : no
+#%end
+#%flag
+#% key: o
+#% description: Override projection (use location's projection)
+#%end
+#%flag
+#% key: e
+#% description: Extend location extents based on new dataset
+#%end
+#%flag
+#% key: r
+#% description: Recursively scan subdirectories
+import sys
+import os
+try:
+ import grass
+except:
+def import_directory_of_rasters(directory, recursive):
+ for dir, dirnames, filenames in os.walk(directory):
+ for filename in filenames:
+ if grass.run_command('r.external', flags=flags_string, input=os.path.join(dir, filename), band=options['band'], output=filename[:-4], title=filename[:-4]) != 0:
+ grass.warning('Cannot import file' + filename)
+ if not recursive:
+ break
+ for dirname in dirnames:
+ import_directory_of_rasters(dirname, recursive)
+def main():
+ input = options['input']
+ recursive = flags['r']
+ import_directory_of_rasters(input, recursive)
+ flags_string = "".join([k for k in flags.keys() if flags[k] and k != 'r'])
+ main()
Copied: trunk/qgis/src/plugins/grass/scripts/v.out.ogr.pg.py (from rev 11077, trunk/qgis/src/plugins/grass/scripts/qgis.v.out.ogr.pg.py)
--- trunk/qgis/src/plugins/grass/scripts/v.out.ogr.pg.py (rev 0)
+++ trunk/qgis/src/plugins/grass/scripts/v.out.ogr.pg.py 2009-07-15 10:14:17 UTC (rev 11081)
@@ -0,0 +1,140 @@
+# MODULE: qgis.v.out.ogr.pg.py
+# PURPOSE: Export a vectore to PostGIS (PostgreSQL) database table
+# for details.
+#%Module
+#% description: Export vector to PostGIS (PostgreSQL) database table.
+#% keywords: vector, export, database
+#%End
+#%option
+#% key: input
+#% type: string
+#% gisprompt: old,vector,vector
+#% key_desc : name
+#% description: Name of input vector map
+#% required : yes
+#%end
+#%option
+#% key: layer
+#% type: integer
+#% description: Number of input layer
+#% answer: 1
+#% required : yes
+#%end
+#%option
+#% key: type
+#% type: string
+#% description: Feature type(s)
+#% options: point,kernel,centroid,line,boundary,area,face
+#% multiple: yes
+#% required : yes
+#%end
+#%option
+#% key: olayer
+#% type: string
+#% description: Name of output database table
+#% required : yes
+#%end
+#%option
+#% key: host
+#% type: string
+#% label: Host
+#% required : no
+#%end
+#%option
+#% key: port
+#% type: integer
+#% label: Port
+#% required : no
+#%end
+#%option
+#% key: database
+#% type: string
+#% key_desc : name
+#% label: Database
+#% required : yes
+#%end
+# AFAIK scheme is not supported well by OGR
+##%option
+##% key: schema
+##% type: string
+##% label: Schema
+##% description: Database schema.
+##% required : no
+##%end
+#%option
+#% key: user
+#% type: string
+#% label: User
+#% required : no
+#%end
+#%option
+#% key: password
+#% type: string
+#% label: Password
+#% required : no
+#%end
+import sys
+import os
+import string
+try:
+ import grass
+except:
+def main():
+ layer = options['layer']
+ type = options['type']
+ olayer = options['olayer']
+ #schema = options['schema']
+ # Construct dsn string
+ dsn = "PG:dbname=" + database
+ if host: dsn += " host=" + host
+ if port: dsn += " port=" + port
+ if user: dsn += " user=" + user
+ if password: dsn += " password=" + password
+ if grass.run_command('v.out.ogr', input=input, layer=layer, type=type, format="PostgreSQL", dsn=dsn, olayer=olayer ) != 0:
+ grass.fatal("Cannot export vector to database.")
+ main()
