[QGIS Commit] r11085 - trunk/qgis/src/plugins/grass/modules-common
svn_qgis at osgeo.org
Wed Jul 15 07:41:25 EDT 2009
Author: rugginoso
Date: 2009-07-15 07:41:25 -0400 (Wed, 15 Jul 2009)
New Revision: 11085
trunk/qgis/src/plugins/grass/modules-common/db.connect.qgm
Changed the behavior of db.connect which reset the schema.
Modified: trunk/qgis/src/plugins/grass/modules-common/db.connect.qgm
--- trunk/qgis/src/plugins/grass/modules-common/db.connect.qgm 2009-07-15 11:33:17 UTC (rev 11084)
+++ trunk/qgis/src/plugins/grass/modules-common/db.connect.qgm 2009-07-15 11:41:25 UTC (rev 11085)
@@ -2,6 +2,7 @@
<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
<qgisgrassmodule label="Set general DB connection" module="db.connect">
+ <option key="schema" answer="" hidden="yes"/>
<option key="driver" answer="dbf" hidden="no"/>
<option key="database" answer="$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/" hidden="no"/>
</qgisgrassmodule>
