[QGIS Commit] r11086 - trunk/qgis/src/plugins/grass/modules-common
svn_qgis at osgeo.org
Wed Jul 15 07:41:53 EDT 2009
Author: pcav
Date: 2009-07-15 07:41:53 -0400 (Wed, 15 Jul 2009)
New Revision: 11086
trunk/qgis/src/plugins/grass/modules-common/db.connect.schema.qgm
Better description for db.connect.schema
Modified: trunk/qgis/src/plugins/grass/modules-common/db.connect.schema.qgm
--- trunk/qgis/src/plugins/grass/modules-common/db.connect.schema.qgm 2009-07-15 11:41:25 UTC (rev 11085)
+++ trunk/qgis/src/plugins/grass/modules-common/db.connect.schema.qgm 2009-07-15 11:41:53 UTC (rev 11086)
@@ -1,7 +1,7 @@
<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
-<qgisgrassmodule label="Set general DB connection with a schema" module="db.connect">
+<qgisgrassmodule label="Set general DB connection with a schema (PostgreSQL only)" module="db.connect">
<option key="driver" answer="dbf" hidden="no"/>
<option key="database" answer="$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/" hidden="no"/>
<option key="schema" answer=" " hidden="no"/>
