[QGIS Commit] r11140 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org
Tue Jul 21 18:58:37 EDT 2009
Author: jef
Date: 2009-07-21 18:58:36 -0400 (Tue, 21 Jul 2009)
New Revision: 11140
trunk/qgis/src/app/qgsdbsourceselect.cpp
trunk/qgis/src/app/qgsdbsourceselect.h
trunk/qgis/src/app/qgsoptions.cpp
trunk/qgis/src/ui/qgsdbsourceselectbase.ui
trunk/qgis/src/ui/qgsoptionsbase.ui
optionally allow adding postgis table addition with double click and extended selection of tables (fixes #1801)
Modified: trunk/qgis/src/app/qgsdbsourceselect.cpp
--- trunk/qgis/src/app/qgsdbsourceselect.cpp 2009-07-21 22:26:40 UTC (rev 11139)
+++ trunk/qgis/src/app/qgsdbsourceselect.cpp 2009-07-21 22:58:36 UTC (rev 11140)
@@ -67,8 +67,12 @@
mTablesTreeView->setModel( &mProxyModel );
mTablesTreeView->setSortingEnabled( true );
+ QSettings settings;
+ mTablesTreeView->setSelectionMode( settings.value( "/qgis/addPostgisDC", false ).toBool() ?
+ QAbstractItemView::ExtendedSelection :
+ QAbstractItemView::MultiSelection );
mSearchGroupBox->hide();
- connect( mTablesTreeView, SIGNAL( doubleClicked( const QModelIndex& ) ), this, SLOT( setSql( const QModelIndex& ) ) );
//for Qt < 4.3.2, passing -1 to include all model columns
//in search does not seem to work
@@ -110,6 +114,29 @@
dbChanged();
+void QgsDbSourceSelect::on_btnBuildQuery_clicked()
+ setSql( mTablesTreeView->currentIndex() );
+void QgsDbSourceSelect::on_mTablesTreeView_clicked( const QModelIndex &index )
+ btnBuildQuery->setEnabled( index.parent().isValid() );
+void QgsDbSourceSelect::on_mTablesTreeView_doubleClicked( const QModelIndex &index )
+ if ( settings.value( "/qgis/addPostgisDC", false ).toBool() )
+ addTables();
+ else
+ setSql( index );
void QgsDbSourceSelect::on_mSearchOptionsButton_clicked()
if ( mSearchGroupBox->isVisible() )
Modified: trunk/qgis/src/app/qgsdbsourceselect.h
--- trunk/qgis/src/app/qgsdbsourceselect.h 2009-07-21 22:26:40 UTC (rev 11139)
+++ trunk/qgis/src/app/qgsdbsourceselect.h 2009-07-21 22:58:36 UTC (rev 11140)
@@ -85,6 +85,7 @@
void on_btnAdd_clicked();
void on_btnNew_clicked();
void on_btnEdit_clicked();
+ void on_btnBuildQuery_clicked();
void on_btnDelete_clicked();
void on_mSearchOptionsButton_clicked();
void on_mSearchTableEdit_textChanged( const QString & text );
@@ -95,6 +96,8 @@
void on_cmbConnections_activated( int );
void setLayerType( QString schema, QString table, QString column,
QString type );
+ void on_mTablesTreeView_clicked( const QModelIndex &index );
+ void on_mTablesTreeView_doubleClicked( const QModelIndex &index );
//!Sets a new regular expression to the model
void setSearchExpression( const QString& regexp );
Modified: trunk/qgis/src/app/qgsoptions.cpp
--- trunk/qgis/src/app/qgsoptions.cpp 2009-07-21 22:26:40 UTC (rev 11139)
+++ trunk/qgis/src/app/qgsoptions.cpp 2009-07-21 22:58:36 UTC (rev 11140)
@@ -139,6 +139,7 @@
cbxLegendClassifiers->setChecked( settings.value( "/qgis/showLegendClassifiers", false ).toBool() );
cbxHideSplash->setChecked( settings.value( "/qgis/hideSplash", false ).toBool() );
cbxAttributeTableDocked->setChecked( settings.value( "/qgis/dockAttributeTable", false ).toBool() );
+ cbxAddPostgisDC->setChecked( settings.value( "/qgis/addPostgisDC", false ).toBool() );
//set the colour for selections
int myRed = settings.value( "/qgis/default_selection_color_red", 255 ).toInt();
@@ -218,7 +219,7 @@
mSearchRadiusVertexEditComboBox->setCurrentIndex( settings.value( "/qgis/digitizing/search_radius_vertex_edit_unit", 0 ).toInt() );
//vertex marker
- mMarkersOnlyForSelectedCheckBox->setChecked(settings.value( "/qgis/digitizing/marker_only_for_selected", false ).toBool());
+ mMarkersOnlyForSelectedCheckBox->setChecked( settings.value( "/qgis/digitizing/marker_only_for_selected", false ).toBool() );
mMarkerStyleComboBox->addItem( tr( "Semi transparent circle" ) );
mMarkerStyleComboBox->addItem( tr( "Cross" ) );
@@ -339,6 +340,7 @@
settings.setValue( "/qgis/showLegendClassifiers", cbxLegendClassifiers->isChecked() );
settings.setValue( "/qgis/hideSplash", cbxHideSplash->isChecked() );
settings.setValue( "/qgis/dockAttributeTable", cbxAttributeTableDocked->isChecked() );
+ settings.setValue( "/qgis/addPostgisDC", cbxAddPostgisDC->isChecked() );
settings.setValue( "/qgis/new_layers_visible", chkAddedVisibility->isChecked() );
settings.setValue( "/qgis/enable_anti_aliasing", chkAntiAliasing->isChecked() );
settings.setValue( "/qgis/use_qimage_to_render", !( chkUseQPixmap->isChecked() ) );
Modified: trunk/qgis/src/ui/qgsdbsourceselectbase.ui
--- trunk/qgis/src/ui/qgsdbsourceselectbase.ui 2009-07-21 22:26:40 UTC (rev 11139)
+++ trunk/qgis/src/ui/qgsdbsourceselectbase.ui 2009-07-21 22:58:36 UTC (rev 11140)
@@ -1,7 +1,8 @@
-<ui version="4.0" >
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
<class>QgsDbSourceSelectBase</class>
- <widget class="QDialog" name="QgsDbSourceSelectBase" >
- <property name="geometry" >
+ <widget class="QDialog" name="QgsDbSourceSelectBase">
+ <property name="geometry">
<rect>
<x>0</x>
<y>0</y>
@@ -9,124 +10,113 @@
<height>687</height>
</rect>
</property>
- <property name="windowTitle" >
+ <property name="windowTitle">
<string>Add PostGIS Table(s)</string>
</property>
- <property name="windowIcon" >
- <iconset/>
+ <property name="windowIcon">
+ <iconset>
+ <normaloff/>
+ </iconset>
</property>
- <property name="sizeGripEnabled" >
+ <property name="sizeGripEnabled">
<bool>true</bool>
</property>
- <property name="modal" >
+ <property name="modal">
<bool>true</bool>
</property>
- <layout class="QGridLayout" >
- <property name="margin" >
+ <layout class="QGridLayout">
+ <property name="margin">
<number>9</number>
</property>
- <property name="spacing" >
+ <property name="spacing">
<number>6</number>
</property>
- <item row="2" column="0" >
- <spacer>
- <property name="orientation" >
- <enum>Qt::Horizontal</enum>
+ <item row="1" column="0" colspan="6">
+ <widget class="QTreeView" name="mTablesTreeView">
+ <property name="selectionMode">
+ <enum>QAbstractItemView::ExtendedSelection</enum>
</property>
- <property name="sizeHint" >
- <size>
- <width>271</width>
- <height>20</height>
- </size>
- </property>
- </spacer>
- </item>
- <item row="1" column="0" colspan="2" >
- <widget class="QTreeView" name="mTablesTreeView" >
- <property name="selectionMode" >
- <enum>QAbstractItemView::MultiSelection</enum>
- </property>
</widget>
</item>
- <item row="0" column="0" colspan="2" >
- <widget class="QGroupBox" name="groupBox" >
- <property name="title" >
+ <item row="0" column="0" colspan="6">
+ <widget class="QGroupBox" name="groupBox">
+ <property name="title">
<string>PostgreSQL Connections</string>
</property>
<number>11</number>
</property>
<number>6</number>
</property>
- <item row="1" column="3" >
- <widget class="QPushButton" name="btnDelete" >
- <property name="text" >
+ <item row="1" column="3">
+ <widget class="QPushButton" name="btnDelete">
+ <property name="text">
<string>Delete</string>
</property>
</widget>
</item>
- <item row="1" column="2" >
- <widget class="QPushButton" name="btnEdit" >
+ <item row="1" column="2">
+ <widget class="QPushButton" name="btnEdit">
<string>Edit</string>
</property>
</widget>
</item>
- <item row="1" column="1" >
- <widget class="QPushButton" name="btnNew" >
+ <item row="1" column="1">
+ <widget class="QPushButton" name="btnNew">
<string>New</string>
</property>
</widget>
</item>
- <item row="1" column="0" >
- <widget class="QPushButton" name="btnConnect" >
+ <item row="1" column="0">
+ <widget class="QPushButton" name="btnConnect">
<string>Connect</string>
</property>
</widget>
</item>
- <item row="0" column="0" colspan="4" >
- <widget class="QComboBox" name="cmbConnections" />
+ <item row="0" column="0" colspan="4">
+ <widget class="QComboBox" name="cmbConnections"/>
</item>
</layout>
</widget>
</item>
- <item row="4" column="0" colspan="2" >
- <layout class="QHBoxLayout" >
+ <item row="4" column="0" colspan="6">
+ <layout class="QHBoxLayout">
+ <number>6</number>
+ </property>
<number>11</number>
</property>
- <number>6</number>
- </property>
<item>
- <widget class="QPushButton" name="btnHelp" >
- <property name="enabled" >
+ <widget class="QPushButton" name="btnHelp">
+ <property name="enabled">
<bool>true</bool>
</property>
<string>Help</string>
</property>
- <property name="shortcut" >
+ <property name="shortcut">
<string>F1</string>
</property>
- <property name="autoDefault" >
+ <property name="autoDefault">
<bool>true</bool>
</property>
</widget>
</item>
<item>
<spacer>
+ <property name="orientation">
</property>
- <property name="sizeType" >
+ <property name="sizeType">
<enum>QSizePolicy::Expanding</enum>
</property>
+ <property name="sizeHint" stdset="0">
<size>
<width>141</width>
<height>21</height>
@@ -135,91 +125,114 @@
</spacer>
</item>
<item>
- <widget class="QPushButton" name="btnAdd" >
+ <widget class="QPushButton" name="btnAdd">
<string>Add</string>
</property>
<string/>
</property>
<bool>true</bool>
</property>
- <property name="default" >
+ <property name="default">
<bool>true</bool>
</property>
</widget>
</item>
<item>
- <widget class="QPushButton" name="btnCancel" >
+ <widget class="QPushButton" name="btnCancel">
<string>Close</string>
</property>
<string/>
</property>
<bool>true</bool>
</property>
</widget>
</item>
</layout>
</item>
- <item row="3" column="0" colspan="2" >
- <widget class="QGroupBox" name="mSearchGroupBox" >
+ <item row="3" column="0" colspan="6">
+ <widget class="QGroupBox" name="mSearchGroupBox">
<string/>
</property>
<number>9</number>
</property>
<number>6</number>
</property>
- <item row="0" column="0" >
- <widget class="QLabel" name="mSearchLabel" >
+ <item row="0" column="0">
+ <widget class="QLabel" name="mSearchLabel">
<string>Search:</string>
</property>
</widget>
</item>
- <item row="2" column="0" colspan="2" >
- <widget class="QLabel" name="mSearchModeLabel" >
+ <item row="2" column="0" colspan="2">
+ <widget class="QLabel" name="mSearchModeLabel">
<string>Search mode:</string>
</property>
</widget>
</item>
- <item row="2" column="2" >
- <widget class="QComboBox" name="mSearchModeComboBox" />
+ <item row="2" column="2">
+ <widget class="QComboBox" name="mSearchModeComboBox"/>
</item>
- <widget class="QLabel" name="mSearchColumnsLabel" >
+ <item row="1" column="0" colspan="2">
+ <widget class="QLabel" name="mSearchColumnsLabel">
<string>Search in columns:</string>
</property>
</widget>
</item>
- <widget class="QComboBox" name="mSearchColumnComboBox" />
+ <widget class="QComboBox" name="mSearchColumnComboBox"/>
</item>
- <item row="0" column="1" colspan="2" >
- <widget class="QLineEdit" name="mSearchTableEdit" />
+ <item row="0" column="1" colspan="2">
+ <widget class="QLineEdit" name="mSearchTableEdit"/>
</item>
</layout>
</widget>
</item>
- <item row="2" column="1" >
- <widget class="QPushButton" name="mSearchOptionsButton" >
+ <item row="2" column="4">
+ <widget class="QPushButton" name="btnBuildQuery">
+ <bool>false</bool>
+ </property>
+ <string>Build query</string>
+ </property>
+ </widget>
+ </item>
+ <widget class="QPushButton" name="mSearchOptionsButton">
<string>Search options...</string>
</property>
</widget>
</item>
+ <item row="2" column="3">
+ <spacer>
+ <enum>Qt::Horizontal</enum>
+ </property>
+ <size>
+ <width>271</width>
+ <height>20</height>
+ </size>
+ </property>
+ </spacer>
+ </item>
</layout>
</widget>
- <layoutdefault spacing="6" margin="11" />
+ <layoutdefault spacing="6" margin="11"/>
<tabstops>
<tabstop>cmbConnections</tabstop>
<tabstop>btnConnect</tabstop>
@@ -238,11 +251,11 @@
<receiver>QgsDbSourceSelectBase</receiver>
<slot>reject()</slot>
<hints>
- <hint type="sourcelabel" >
+ <hint type="sourcelabel">
<x>404</x>
<y>446</y>
</hint>
- <hint type="destinationlabel" >
+ <hint type="destinationlabel">
<x>229</x>
<y>236</y>
</hint>
Modified: trunk/qgis/src/ui/qgsoptionsbase.ui
--- trunk/qgis/src/ui/qgsoptionsbase.ui 2009-07-21 22:26:40 UTC (rev 11139)
+++ trunk/qgis/src/ui/qgsoptionsbase.ui 2009-07-21 22:58:36 UTC (rev 11140)
@@ -1,68 +1,69 @@
+<ui version="4.0">
<class>QgsOptionsBase</class>
- <widget class="QDialog" name="QgsOptionsBase" >
+ <widget class="QDialog" name="QgsOptionsBase">
<rect>
<x>0</x>
<y>0</y>
- <width>645</width>
- <height>517</height>
+ <width>617</width>
+ <height>521</height>
</rect>
</property>
<string>QGIS Options</string>
</property>
<iconset>
<normaloff/>
</iconset>
</property>
<bool>true</bool>
</property>
<bool>true</bool>
</property>
- <widget class="QDialogButtonBox" name="buttonBox" >
+ <widget class="QDialogButtonBox" name="buttonBox">
</property>
- <property name="standardButtons" >
+ <property name="standardButtons">
<set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
</property>
</widget>
</item>
- <widget class="QTabWidget" name="tabWidget" >
- <property name="currentIndex" >
+ <widget class="QTabWidget" name="tabWidget">
+ <property name="currentIndex">
<number>0</number>
</property>
- <widget class="QWidget" name="tabGeneral" >
- <attribute name="title" >
+ <widget class="QWidget" name="tabGeneral">
+ <attribute name="title">
<string>&General</string>
</attribute>
- <widget class="QGroupBox" name="groupBox_11" >
+ <widget class="QGroupBox" name="groupBox_11">
<string>Project files</string>
</property>
- <layout class="QVBoxLayout" >
+ <layout class="QVBoxLayout">
<number>11</number>
</property>
<item>
- <widget class="QCheckBox" name="chbAskToSaveProjectChanges" >
+ <widget class="QCheckBox" name="chbAskToSaveProjectChanges">
<string>Prompt to save project changes when required</string>
</property>
</widget>
</item>
<item>
- <widget class="QCheckBox" name="chbWarnOldProjectVersion" >
+ <widget class="QCheckBox" name="chbWarnOldProjectVersion">
<string>Warn when opening a project file saved with an older version of QGIS</string>
</property>
</widget>
@@ -70,28 +71,28 @@
</layout>
</widget>
</item>
- <widget class="QGroupBox" name="groupBox_9" >
+ <widget class="QGroupBox" name="groupBox_9">
<string>Default Map Appearance (overridden by project properties)</string>
</property>
- <widget class="QLabel" name="textLabel1_9" >
+ <widget class="QLabel" name="textLabel1_9">
<string>Selection color</string>
</property>
- <property name="buddy" >
+ <property name="buddy">
<cstring>pbnMeasureColour</cstring>
</property>
</widget>
</item>
- <item row="0" column="1" >
+ <item row="0" column="1">
<spacer>
</property>
- <property name="sizeHint" stdset="0" >
<size>
<width>40</width>
<height>20</height>
@@ -99,35 +100,35 @@
</property>
</spacer>
</item>
- <item row="0" column="3" >
- <widget class="QgsColorButton" name="pbnSelectionColour" >
- <property name="minimumSize" >
+ <item row="0" column="3">
+ <widget class="QgsColorButton" name="pbnSelectionColour">
+ <property name="minimumSize">
<size>
<width>100</width>
<height>0</height>
</size>
</property>
<string/>
</property>
</widget>
</item>
- <widget class="QLabel" name="label" >
+ <widget class="QLabel" name="label">
<string>Background color</string>
</property>
<cstring>pbnCanvasColor</cstring>
</property>
</widget>
</item>
<spacer>
</property>
<size>
<width>40</width>
<height>20</height>
@@ -135,15 +136,15 @@
</property>
</spacer>
</item>
- <widget class="QgsColorButton" name="pbnCanvasColor" >
+ <widget class="QgsColorButton" name="pbnCanvasColor">
<size>
<width>100</width>
<height>0</height>
</size>
</property>
<string/>
</property>
</widget>
@@ -151,90 +152,97 @@
</layout>
</widget>
</item>
+ <item row="2" column="0">
<string>&Application</string>
</property>
- <widget class="QLabel" name="textLabel1_4" >
- <property name="sizePolicy" >
- <sizepolicy vsizetype="Fixed" hsizetype="Fixed" >
+ <widget class="QLabel" name="textLabel1_4">
+ <property name="sizePolicy">
+ <sizepolicy hsizetype="Fixed" vsizetype="Fixed">
<horstretch>0</horstretch>
<verstretch>0</verstretch>
</sizepolicy>
</property>
<string>Icon theme</string>
</property>
<cstring>cmbTheme</cstring>
</property>
</widget>
</item>
- <widget class="QComboBox" name="cmbTheme" >
- <property name="duplicatesEnabled" >
+ <widget class="QComboBox" name="cmbTheme">
+ <property name="duplicatesEnabled">
<bool>false</bool>
</property>
<item>
<string/>
</property>
</item>
</widget>
</item>
- <widget class="QLabel" name="textLabel1_5" >
- <string><b>Note: </b>Theme changes take effect the next time QGIS is started</string>
+ <widget class="QLabel" name="textLabel1_5">
+ <string><b>Note: </b>Theme changes take effect the next time QGIS is started</string>
</property>
- <property name="alignment" >
+ <property name="alignment">
<set>Qt::AlignVCenter</set>
</property>
</widget>
</item>
- <widget class="QCheckBox" name="capitaliseCheckBox" >
+ <widget class="QCheckBox" name="capitaliseCheckBox">
<string>Capitalise layer names in legend</string>
</property>
</widget>
</item>
- <widget class="QCheckBox" name="cbxLegendClassifiers" >
+ <item row="3" column="0" colspan="2">
+ <widget class="QCheckBox" name="cbxLegendClassifiers">
<string>Display classification attribute names in legend</string>
</property>
</widget>
</item>
- <widget class="QCheckBox" name="cbxHideSplash" >
+ <item row="4" column="0" colspan="2">
+ <widget class="QCheckBox" name="cbxHideSplash">
<string>Hide splash screen at startup</string>
</property>
</widget>
</item>
- <item row="5" column="0" colspan="2" >
- <widget class="QCheckBox" name="cbxAttributeTableDocked" >
+ <item row="5" column="0" colspan="2">
+ <widget class="QCheckBox" name="cbxAttributeTableDocked">
<string>Open attribute table in a dock window</string>
</property>
</widget>
</item>
+ <item row="6" column="0" colspan="2">
+ <widget class="QCheckBox" name="cbxAddPostgisDC">
+ <string>Add PostGIS layers with double click and select in extended mode</string>
+ </property>
+ </widget>
+ </item>
</layout>
</widget>
</item>
- <item row="3" column="0" >
+ <item row="3" column="0">
<spacer>
<enum>Qt::Vertical</enum>
</property>
<enum>QSizePolicy::Minimum</enum>
</property>
<size>
<width>577</width>
<height>21</height>
@@ -244,79 +252,79 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="tabRendering" >
+ <widget class="QWidget" name="tabRendering">
<string>&Rendering</string>
</attribute>
- <widget class="QGroupBox" name="groupBox_5" >
+ <widget class="QGroupBox" name="groupBox_5">
<string>Rendering behavior</string>
</property>
- <widget class="QCheckBox" name="chkAddedVisibility" >
+ <widget class="QCheckBox" name="chkAddedVisibility">
<string>By default new la&yers added to the map should be displayed</string>
</property>
</widget>
</item>
- <widget class="QLabel" name="textLabel1_6" >
+ <widget class="QLabel" name="textLabel1_6">
<string>Number of features to draw before updating the display</string>
</property>
<cstring>spinBoxUpdateThreshold</cstring>
</property>
</widget>
</item>
- <widget class="QSpinBox" name="spinBoxUpdateThreshold" >
- <property name="toolTip" >
+ <widget class="QSpinBox" name="spinBoxUpdateThreshold">
+ <property name="toolTip">
<string>Map display will be updated (drawn) after this many features have been read from the data source</string>
</property>
- <property name="maximum" >
+ <property name="maximum">
<number>1000000</number>
</property>
- <property name="value" >
+ <property name="value">
<number>1000</number>
</property>
</widget>
</item>
- <widget class="QLabel" name="textLabel3" >
- <string><b>Note:</b> Use zero to prevent display updates until all features have been rendered</string>
+ <widget class="QLabel" name="textLabel3">
+ <string><b>Note:</b> Use zero to prevent display updates until all features have been rendered</string>
</property>
</widget>
</item>
</layout>
</widget>
</item>
- <widget class="QGroupBox" name="groupBox_8" >
+ <widget class="QGroupBox" name="groupBox_8">
<string>Rendering quality</string>
</property>
<number>11</number>
</property>
<item>
- <widget class="QCheckBox" name="chkAntiAliasing" >
+ <widget class="QCheckBox" name="chkAntiAliasing">
<string>Make lines appear less jagged at the expense of some drawing performance</string>
</property>
</widget>
</item>
<item>
- <widget class="QCheckBox" name="chkUseQPixmap" >
+ <widget class="QCheckBox" name="chkUseQPixmap">
<string>Selecting this will unselect the 'make lines less' jagged toggle</string>
</property>
<string>Fix problems with incorrectly filled polygons</string>
</property>
</widget>
@@ -324,12 +332,12 @@
</layout>
</widget>
</item>
<spacer>
</property>
<size>
<width>20</width>
<height>40</height>
@@ -339,70 +347,70 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="tabMap" >
+ <widget class="QWidget" name="tabMap">
<string>&Map tools</string>
</attribute>
<number>11</number>
</property>
- <widget class="QGroupBox" name="groupBox_10" >
+ <widget class="QGroupBox" name="groupBox_10">
<string>Panning and zooming</string>
</property>
<number>11</number>
</property>
- <widget class="QComboBox" name="cmbWheelAction" >
+ <widget class="QComboBox" name="cmbWheelAction">
<item>
<string>Zoom</string>
</property>
</item>
<item>
<string>Zoom and recenter</string>
</property>
</item>
<item>
<string>Zoom to mouse cursor</string>
</property>
</item>
<item>
<string>Nothing</string>
</property>
</item>
</widget>
</item>
- <widget class="QLabel" name="label_3" >
+ <widget class="QLabel" name="label_3">
<string>Zoom factor</string>
</property>
</widget>
</item>
- <widget class="QLabel" name="label_2" >
+ <widget class="QLabel" name="label_2">
<string>Mouse wheel action</string>
</property>
</widget>
</item>
- <widget class="QDoubleSpinBox" name="spinZoomFactor" >
- <property name="decimals" >
+ <widget class="QDoubleSpinBox" name="spinZoomFactor">
+ <property name="decimals">
<number>1</number>
</property>
- <property name="minimum" >
+ <property name="minimum">
<double>1.100000000000000</double>
</property>
<double>2.000000000000000</double>
</property>
</widget>
@@ -410,21 +418,21 @@
</layout>
</widget>
</item>
- <widget class="QGroupBox" name="groupBox_6" >
+ <widget class="QGroupBox" name="groupBox_6">
<string>Measure tool</string>
</property>
<number>11</number>
</property>
<spacer>
</property>
<size>
<width>191</width>
<height>20</height>
@@ -432,38 +440,38 @@
</property>
</spacer>
</item>
- <widget class="QgsColorButton" name="pbnMeasureColour" >
+ <widget class="QgsColorButton" name="pbnMeasureColour">
<size>
<width>100</width>
<height>0</height>
</size>
</property>
<string/>
</property>
</widget>
</item>
- <widget class="QComboBox" name="cmbEllipsoid" />
+ <widget class="QComboBox" name="cmbEllipsoid"/>
</item>
- <widget class="QLabel" name="textLabel1_10" >
+ <widget class="QLabel" name="textLabel1_10">
<string>Rubberband color</string>
</property>
<cstring>cmbEllipsoid</cstring>
</property>
</widget>
</item>
- <widget class="QLabel" name="textLabel1_8" >
+ <widget class="QLabel" name="textLabel1_8">
<string>Ellipsoid for distance calculations</string>
</property>
</property>
</widget>
@@ -471,47 +479,47 @@
</layout>
</widget>
</item>
- <widget class="QGroupBox" name="groupBox_7" >
+ <widget class="QGroupBox" name="groupBox_7">
<string>Search radius</string>
</property>
<number>11</number>
</property>
- <widget class="QLabel" name="textLabel2" >
- <string><b>Note:</b> Specify the search radius as a percentage of the map width</string>
+ <widget class="QLabel" name="textLabel2">
+ <string><b>Note:</b> Specify the search radius as a percentage of the map width</string>
</property>
- <property name="wordWrap" >
+ <property name="wordWrap">
<bool>true</bool>
</property>
</widget>
</item>
- <widget class="QLabel" name="textLabel1_3" >
+ <widget class="QLabel" name="textLabel1_3">
<string>Search radius for identifying features and displaying map tips</string>
</property>
<cstring>spinBoxIdentifyValue</cstring>
</property>
</widget>
</item>
- <widget class="QDoubleSpinBox" name="spinBoxIdentifyValue" >
- <property name="suffix" >
+ <widget class="QDoubleSpinBox" name="spinBoxIdentifyValue">
+ <property name="suffix">
<string>%</string>
</property>
<double>100.000000000000000</double>
</property>
- <property name="singleStep" >
+ <property name="singleStep">
<double>0.010000000000000</double>
</property>
<double>5.000000000000000</double>
</property>
</widget>
@@ -519,12 +527,12 @@
</layout>
</widget>
</item>
<spacer>
</property>
<size>
<width>20</width>
<height>40</height>
@@ -534,12 +542,12 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="mOverlayTab" >
+ <widget class="QWidget" name="mOverlayTab">
<string>Overlay</string>
</attribute>
- <widget class="QGroupBox" name="mPositionGroupBox" >
+ <widget class="QGroupBox" name="mPositionGroupBox">
<rect>
<x>10</x>
<y>10</y>
@@ -547,11 +555,11 @@
<height>111</height>
</rect>
</property>
<string>Position</string>
</property>
- <widget class="QWidget" name="layoutWidget" >
+ <widget class="QWidget" name="layoutWidget">
<rect>
<x>20</x>
<y>40</y>
@@ -559,23 +567,23 @@
<height>42</height>
</rect>
</property>
<item>
- <widget class="QLabel" name="mAlgorithmLabel" >
+ <widget class="QLabel" name="mAlgorithmLabel">
<string>Placement algorithm:</string>
</property>
</widget>
</item>
<item>
- <widget class="QComboBox" name="mOverlayAlgorithmComboBox" />
+ <widget class="QComboBox" name="mOverlayAlgorithmComboBox"/>
</item>
<item>
<spacer>
</property>
<size>
<width>221</width>
<height>20</height>
@@ -587,56 +595,56 @@
</widget>
</widget>
</widget>
- <widget class="QWidget" name="tabDigitizing" >
+ <widget class="QWidget" name="tabDigitizing">
<string>Digitizing</string>
</attribute>
- <layout class="QGridLayout" name="gridLayout_2" >
- <widget class="QGroupBox" name="mRubberBandGroupBox" >
+ <layout class="QGridLayout" name="gridLayout_2">
+ <widget class="QGroupBox" name="mRubberBandGroupBox">
<string>Rubberband</string>
</property>
- <widget class="QLabel" name="mLineWidthTextLabel" >
+ <widget class="QLabel" name="mLineWidthTextLabel">
<string>Line width</string>
</property>
<cstring>mLineWidthSpinBox</cstring>
</property>
</widget>
</item>
- <widget class="QSpinBox" name="mLineWidthSpinBox" >
+ <widget class="QSpinBox" name="mLineWidthSpinBox">
<string>Line width in pixels</string>
</property>
<number>1</number>
</property>
</widget>
</item>
- <widget class="QLabel" name="mLineColourTextLabel" >
+ <widget class="QLabel" name="mLineColourTextLabel">
<string>Line colour</string>
</property>
<cstring>mLineColourToolButton</cstring>
</property>
</widget>
</item>
- <widget class="QgsColorButton" name="mLineColourToolButton" >
+ <widget class="QgsColorButton" name="mLineColourToolButton">
<size>
<width>100</width>
<height>0</height>
</size>
</property>
<string/>
</property>
</widget>
@@ -644,25 +652,25 @@
</layout>
</widget>
</item>
- <widget class="QGroupBox" name="mSnappingGroupBox" >
+ <widget class="QGroupBox" name="mSnappingGroupBox">
<string>Snapping</string>
</property>
- <widget class="QLabel" name="mDefaultSnapModeLabel" >
+ <widget class="QLabel" name="mDefaultSnapModeLabel">
<string>Default snap mode</string>
</property>
</widget>
</item>
- <item row="0" column="1" colspan="3" >
+ <item row="0" column="1" colspan="3">
<spacer>
</property>
<size>
<width>311</width>
<height>20</height>
@@ -670,29 +678,29 @@
</property>
</spacer>
</item>
- <item row="0" column="4" colspan="2" >
- <widget class="QComboBox" name="mDefaultSnapModeComboBox" >
- <sizepolicy vsizetype="Fixed" hsizetype="Expanding" >
+ <item row="0" column="4" colspan="2">
+ <widget class="QComboBox" name="mDefaultSnapModeComboBox">
+ <sizepolicy hsizetype="Expanding" vsizetype="Fixed">
</sizepolicy>
</property>
</widget>
</item>
- <widget class="QLabel" name="mDefaultSnappingToleranceTextLabel" >
+ <widget class="QLabel" name="mDefaultSnappingToleranceTextLabel">
<string>Default snapping tolerance in layer units</string>
</property>
</widget>
</item>
- <item row="1" column="2" colspan="2" >
+ <item row="1" column="2" colspan="2">
<spacer>
</property>
<size>
<width>241</width>
<height>20</height>
@@ -700,29 +708,29 @@
</property>
</spacer>
</item>
- <item row="1" column="4" >
- <widget class="QDoubleSpinBox" name="mDefaultSnappingToleranceSpinBox" >
+ <item row="1" column="4">
+ <widget class="QDoubleSpinBox" name="mDefaultSnappingToleranceSpinBox">
<number>5</number>
</property>
<double>99999999.989999994635582</double>
</property>
</widget>
</item>
- <item row="2" column="0" colspan="3" >
- <widget class="QLabel" name="mVertexSearchRadiusVertexEditLabel" >
+ <item row="2" column="0" colspan="3">
+ <widget class="QLabel" name="mVertexSearchRadiusVertexEditLabel">
<string>Search radius for vertex edits in layer units</string>
</property>
</widget>
</item>
- <item row="2" column="3" >
<spacer>
</property>
<size>
<width>61</width>
<height>20</height>
@@ -730,45 +738,45 @@
</property>
</spacer>
</item>
- <item row="2" column="4" >
- <widget class="QDoubleSpinBox" name="mSearchRadiusVertexEditSpinBox" >
+ <widget class="QDoubleSpinBox" name="mSearchRadiusVertexEditSpinBox">
<number>5</number>
</property>
</property>
</widget>
</item>
- <item row="1" column="5" >
- <widget class="QComboBox" name="mDefaultSnappingToleranceComboBox" >
+ <item row="1" column="5">
+ <widget class="QComboBox" name="mDefaultSnappingToleranceComboBox">
</sizepolicy>
</property>
<item>
<string>map units</string>
</property>
</item>
<item>
<string>pixels</string>
</property>
</item>
</widget>
</item>
- <item row="2" column="5" >
- <widget class="QComboBox" name="mSearchRadiusVertexEditComboBox" >
+ <item row="2" column="5">
+ <widget class="QComboBox" name="mSearchRadiusVertexEditComboBox">
<item>
</property>
</item>
<item>
</property>
</item>
@@ -777,32 +785,32 @@
</layout>
</widget>
</item>
- <widget class="QGroupBox" name="mVertexMarkerGroupBox" >
+ <widget class="QGroupBox" name="mVertexMarkerGroupBox">
<string>Vertex markers</string>
</property>
- <layout class="QGridLayout" name="gridLayout" >
- <widget class="QCheckBox" name="mMarkersOnlyForSelectedCheckBox" >
+ <layout class="QGridLayout" name="gridLayout">
+ <item row="0" column="0" colspan="2">
+ <widget class="QCheckBox" name="mMarkersOnlyForSelectedCheckBox">
<string>Show markers only for selected features</string>
</property>
</widget>
</item>
- <widget class="QLabel" name="mMarkerStyleLabel" >
+ <widget class="QLabel" name="mMarkerStyleLabel">
<string>Marker style</string>
</property>
</widget>
</item>
<spacer>
</property>
<size>
<width>281</width>
<height>20</height>
@@ -810,10 +818,10 @@
</property>
</spacer>
</item>
- <widget class="QComboBox" name="mMarkerStyleComboBox" >
+ <widget class="QComboBox" name="mMarkerStyleComboBox">
</sizepolicy>
@@ -823,18 +831,18 @@
</layout>
</widget>
</item>
- <widget class="QGroupBox" name="mEnterAttributeValuesGroupBox" >
+ <widget class="QGroupBox" name="mEnterAttributeValuesGroupBox">
<string>Enter attribute values</string>
</property>
<item>
- <widget class="QCheckBox" name="chkDisableAttributeValuesDlg" >
+ <widget class="QCheckBox" name="chkDisableAttributeValuesDlg">
<string>Suppress attributes pop-up windows after each created feature</string>
</property>
- <property name="tristate" >
+ <property name="tristate">
<bool>false</bool>
</property>
</widget>
@@ -842,12 +850,12 @@
</layout>
</widget>
</item>
- <item row="4" column="0" >
+ <item row="4" column="0">
<spacer>
</property>
<size>
<width>547</width>
<height>71</height>
@@ -857,20 +865,20 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="tabCRS" >
+ <widget class="QWidget" name="tabCRS">
<string>CRS</string>
</attribute>
<number>11</number>
</property>
<spacer>
</property>
<size>
<width>51</width>
<height>31</height>
@@ -878,42 +886,42 @@
</property>
</spacer>
</item>
- <widget class="QPushButton" name="pbnSelectProjection" >
+ <widget class="QPushButton" name="pbnSelectProjection">
<string>Select Global Default ...</string>
</property>
</widget>
</item>
- <widget class="QTextBrowser" name="txtGlobalWkt" />
+ <widget class="QTextBrowser" name="txtGlobalWkt"/>
</item>
- <widget class="QGroupBox" name="grpProjectionBehaviour" >
+ <widget class="QGroupBox" name="grpProjectionBehaviour">
<string>When layer is loaded that has no coordinate reference system (CRS)</string>
</property>
<number>11</number>
</property>
<item>
- <widget class="QRadioButton" name="radPromptForProjection" >
+ <widget class="QRadioButton" name="radPromptForProjection">
<string>Prompt for CRS</string>
</property>
</widget>
</item>
<item>
- <widget class="QRadioButton" name="radUseProjectProjection" >
+ <widget class="QRadioButton" name="radUseProjectProjection">
<string>Project wide default CRS will be used</string>
</property>
</widget>
</item>
<item>
- <widget class="QRadioButton" name="radUseGlobalProjection" >
+ <widget class="QRadioButton" name="radUseGlobalProjection">
<string>Global default CRS displa&yed below will be used</string>
</property>
</widget>
@@ -923,39 +931,39 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="tabLocale" >
+ <widget class="QWidget" name="tabLocale">
<string>Locale</string>
</attribute>
- <widget class="QGroupBox" name="grpLocale" >
+ <widget class="QGroupBox" name="grpLocale">
<string>Override system locale</string>
</property>
- <property name="checkable" >
+ <property name="checkable">
<bool>true</bool>
</property>
- <widget class="QLabel" name="label_5" >
+ <widget class="QLabel" name="label_5">
<string>Locale to use instead</string>
</property>
<cstring>cboLocale</cstring>
</property>
</widget>
</item>
- <widget class="QComboBox" name="cboLocale" />
+ <widget class="QComboBox" name="cboLocale"/>
</item>
- <widget class="QLabel" name="label_7" >
- <string><b>Note:</b> Enabling / changing overide on local requires an application restart</string>
+ <widget class="QLabel" name="label_7">
+ <string><b>Note:</b> Enabling / changing overide on local requires an application restart</string>
</property>
<bool>true</bool>
</property>
</widget>
@@ -963,12 +971,12 @@
</layout>
</widget>
</item>
<spacer>
</property>
<size>
<width>501</width>
<height>51</height>
@@ -976,15 +984,15 @@
</property>
</spacer>
</item>
- <widget class="QGroupBox" name="groupBox_12" >
+ <widget class="QGroupBox" name="groupBox_12">
<string>Additional Info</string>
</property>
- <widget class="QLabel" name="lblSystemLocale" >
+ <widget class="QLabel" name="lblSystemLocale">
<string>Detected active locale on your system:</string>
</property>
</widget>
@@ -994,102 +1002,102 @@
</item>
</layout>
</widget>
- <widget class="QWidget" name="tab" >
+ <widget class="QWidget" name="tab">
<string>Proxy</string>
</attribute>
- <widget class="QGroupBox" name="grpProxy" >
+ <widget class="QGroupBox" name="grpProxy">
<string>Use proxy for web access</string>
</property>
- <property name="flat" >
+ <property name="flat">
<bool>false</bool>
</property>
<bool>true</bool>
</property>
- <widget class="QLabel" name="lblProxyHost" >
+ <widget class="QLabel" name="lblProxyHost">
<string>Host</string>
</property>
<cstring>leProxyHost</cstring>
</property>
</widget>
</item>
- <item row="0" column="1" colspan="5" >
- <widget class="QLineEdit" name="leProxyHost" />
+ <item row="0" column="1" colspan="5">
+ <widget class="QLineEdit" name="leProxyHost"/>
</item>
- <widget class="QLabel" name="lblProxyPort" >
+ <widget class="QLabel" name="lblProxyPort">
<string>Port</string>
</property>
<cstring>leProxyPort</cstring>
</property>
</widget>
</item>
- <item row="1" column="1" colspan="5" >
- <widget class="QLineEdit" name="leProxyPort" />
+ <item row="1" column="1" colspan="5">
+ <widget class="QLineEdit" name="leProxyPort"/>
</item>
- <widget class="QLabel" name="lblUser" >
+ <widget class="QLabel" name="lblUser">
<string>User</string>
</property>
<cstring>leProxyUser</cstring>
</property>
</widget>
</item>
- <item row="2" column="1" colspan="5" >
- <widget class="QLineEdit" name="leProxyUser" >
+ <item row="2" column="1" colspan="5">
+ <widget class="QLineEdit" name="leProxyUser">
<string>Leave this blank if no proxy username / password are required</string>
</property>
</widget>
</item>
- <widget class="QLabel" name="lblPassword" >
+ <widget class="QLabel" name="lblPassword">
<string>Password</string>
</property>
<cstring>leProxyPassword</cstring>
</property>
</widget>
</item>
- <item row="3" column="1" colspan="5" >
- <widget class="QLineEdit" name="leProxyPassword" >
+ <item row="3" column="1" colspan="5">
+ <widget class="QLineEdit" name="leProxyPassword">
</property>
- <property name="echoMode" >
+ <property name="echoMode">
<enum>QLineEdit::Password</enum>
</property>
</widget>
</item>
- <widget class="QLabel" name="mTypeLabel" >
+ <widget class="QLabel" name="mTypeLabel">
<string>Proxy type</string>
</property>
</widget>
</item>
- <item row="4" column="1" colspan="2" >
- <widget class="QComboBox" name="mProxyTypeComboBox" />
+ <item row="4" column="1" colspan="2">
+ <widget class="QComboBox" name="mProxyTypeComboBox"/>
</item>
- <item row="4" column="3" colspan="3" >
+ <item row="4" column="3" colspan="3">
<spacer>
</property>
<size>
<width>241</width>
<height>20</height>
@@ -1097,33 +1105,33 @@
</property>
</spacer>
</item>
- <widget class="QLabel" name="mExcludeUrlsLabel" >
+ <widget class="QLabel" name="mExcludeUrlsLabel">
<string>Exclude URLs:</string>
</property>
</widget>
</item>
- <item row="5" column="2" colspan="2" >
- <widget class="QPushButton" name="mAddUrlPushButton" >
+ <item row="5" column="2" colspan="2">
+ <widget class="QPushButton" name="mAddUrlPushButton">
</property>
</widget>
</item>
- <item row="5" column="4" >
- <widget class="QPushButton" name="mRemoveUrlPushButton" >
+ <item row="5" column="4">
+ <widget class="QPushButton" name="mRemoveUrlPushButton">
<string>Remove</string>
</property>
</widget>
</item>
- <item row="5" column="5" >
+ <item row="5" column="5">
<spacer>
</property>
<size>
<width>391</width>
<height>20</height>
@@ -1131,8 +1139,8 @@
</property>
</spacer>
</item>
- <item row="6" column="0" colspan="6" >
- <widget class="QListWidget" name="mExcludeUrlListWidget" />
+ <item row="6" column="0" colspan="6">
+ <widget class="QListWidget" name="mExcludeUrlListWidget"/>
</item>
</layout>
</widget>
@@ -1143,7 +1151,7 @@
</item>
</layout>
</widget>
<customwidgets>
<customwidget>
<class>QgsColorButton</class>
