[QGIS Commit] r10809 - in branches/symbology-ng-branch/src:
core/symbology-ng gui/symbology-ng ui/symbollayer
svn_qgis at osgeo.org
Sun May 17 10:28:12 EDT 2009
Author: wonder
Date: 2009-05-17 10:28:12 -0400 (Sun, 17 May 2009)
New Revision: 10809
branches/symbology-ng-branch/src/core/symbology-ng/qgsmarkersymbollayerv2.cpp
branches/symbology-ng-branch/src/core/symbology-ng/qgssymbollayerv2.h
branches/symbology-ng-branch/src/core/symbology-ng/qgssymbollayerv2utils.cpp
branches/symbology-ng-branch/src/core/symbology-ng/qgssymbollayerv2utils.h
branches/symbology-ng-branch/src/gui/symbology-ng/qgssymbollayerv2widget.cpp
branches/symbology-ng-branch/src/gui/symbology-ng/qgssymbollayerv2widget.h
branches/symbology-ng-branch/src/ui/symbollayer/widget_simplemarker.ui
branches/symbology-ng-branch/src/ui/symbollayer/widget_svgmarker.ui
Added offset property (X,Y) also for marker symbol layers.
Modified: branches/symbology-ng-branch/src/core/symbology-ng/qgsmarkersymbollayerv2.cpp
--- branches/symbology-ng-branch/src/core/symbology-ng/qgsmarkersymbollayerv2.cpp 2009-05-17 13:57:09 UTC (rev 10808)
+++ branches/symbology-ng-branch/src/core/symbology-ng/qgsmarkersymbollayerv2.cpp 2009-05-17 14:28:12 UTC (rev 10809)
@@ -26,6 +26,7 @@
mBorderColor = borderColor;
mSize = size;
mAngle = angle;
+ mOffset = QPointF(0,0);
QgsSymbolLayerV2* QgsSimpleMarkerSymbolLayerV2::create(const QgsStringMap& props)
@@ -47,7 +48,10 @@
if (props.contains("angle"))
angle = props["angle"].toDouble();
- return new QgsSimpleMarkerSymbolLayerV2(name, color, borderColor, size, angle);
+ QgsSimpleMarkerSymbolLayerV2* m = new QgsSimpleMarkerSymbolLayerV2(name, color, borderColor, size, angle);
+ if (props.contains("offset"))
+ m->setOffset( QgsSymbolLayerV2Utils::decodePoint(props["offset"]) );
+ return m;
@@ -184,7 +188,7 @@
//drawMarker(p);
double s = mCache.width();
//if (mCache.isValid())
- p->drawImage(point + QPointF(-s/2.0, -s/2.0), mCache);
+ p->drawImage(point + QPointF(-s/2.0, -s/2.0) + mOffset, mCache);
//p->restore();
@@ -198,12 +202,15 @@
map["color_border"] = QgsSymbolLayerV2Utils::encodeColor(mBorderColor);
map["size"] = QString::number(mSize);
map["angle"] = QString::number(mAngle);
+ map["offset"] = QgsSymbolLayerV2Utils::encodePoint(mOffset);
return map;
QgsSymbolLayerV2* QgsSimpleMarkerSymbolLayerV2::clone() const
- return new QgsSimpleMarkerSymbolLayerV2(mName, mColor, mBorderColor, mSize, mAngle);
+ QgsSimpleMarkerSymbolLayerV2* m = new QgsSimpleMarkerSymbolLayerV2(mName, mColor, mBorderColor, mSize, mAngle);
+ m->setOffset( mOffset );
+ return m;
void QgsSimpleMarkerSymbolLayerV2::drawMarker(QPainter* p)
@@ -244,6 +251,7 @@
mName = name;
mSize = size;
mAngle = angle;
@@ -260,7 +268,10 @@
- return new QgsSvgMarkerSymbolLayerV2(name, size, angle);
+ QgsSvgMarkerSymbolLayerV2* m = new QgsSvgMarkerSymbolLayerV2(name, size, angle);
+ return m;
@@ -288,7 +299,9 @@
void QgsSvgMarkerSymbolLayerV2::renderPoint(const QPointF& point, QgsRenderContext& context)
QPainter* p = context.painter();
- p->translate(point);
+ p->save();
+ p->translate(point + mOffset);
if (mAngle != 0)
p->rotate(mAngle);
@@ -296,7 +309,8 @@
if (mAngle != 0)
p->rotate(-mAngle);
- p->translate(-point); // TODO: maybe save+restore is faster?
+ p->restore();
@@ -306,10 +320,13 @@
map["name"] = mName;
return map;
QgsSymbolLayerV2* QgsSvgMarkerSymbolLayerV2::clone() const
- return new QgsSvgMarkerSymbolLayerV2(mName, mSize, mAngle);
+ QgsSvgMarkerSymbolLayerV2* m = new QgsSvgMarkerSymbolLayerV2(mName, mSize, mAngle);
+ return m;
Modified: branches/symbology-ng-branch/src/core/symbology-ng/qgssymbollayerv2.h
--- branches/symbology-ng-branch/src/core/symbology-ng/qgssymbollayerv2.h 2009-05-17 13:57:09 UTC (rev 10808)
+++ branches/symbology-ng-branch/src/core/symbology-ng/qgssymbollayerv2.h 2009-05-17 14:28:12 UTC (rev 10809)
@@ -5,6 +5,7 @@
#include <QMap>
#include <QColor>
+#include <QPointF>
#include "qgssymbolv2.h"
@@ -12,7 +13,6 @@
class QPainter;
class QSize;
-class QPointF;
class QPolygonF;
class QgsRenderContext;
@@ -72,12 +72,16 @@
void setSize(double size) { mSize = size; }
double size() const { return mSize; }
+ void setOffset(QPointF offset) { mOffset = offset; }
+ QPointF offset() { return mOffset; }
protected:
QgsMarkerSymbolLayerV2(bool locked = false);
double mAngle;
double mSize;
+ QPointF mOffset;
class QgsLineSymbolLayerV2 : public QgsSymbolLayerV2
Modified: branches/symbology-ng-branch/src/core/symbology-ng/qgssymbollayerv2utils.cpp
--- branches/symbology-ng-branch/src/core/symbology-ng/qgssymbollayerv2utils.cpp 2009-05-17 13:57:09 UTC (rev 10808)
+++ branches/symbology-ng-branch/src/core/symbology-ng/qgssymbollayerv2utils.cpp 2009-05-17 14:28:12 UTC (rev 10809)
@@ -87,7 +87,19 @@
return Qt::SolidPattern;
+QString QgsSymbolLayerV2Utils::encodePoint(QPointF point)
+ return QString("%1,%2").arg(point.x()).arg(point.y());
+QPointF QgsSymbolLayerV2Utils::decodePoint(QString str)
+ QStringList lst = str.split(',');
+ if (lst.count() != 2)
+ return QPointF(0,0);
+ return QPointF( lst[0].toDouble(), lst[1].toDouble() );
QIcon QgsSymbolLayerV2Utils::symbolPreviewIcon(QgsSymbolV2* symbol, QSize size)
QPixmap pixmap(size);
Modified: branches/symbology-ng-branch/src/core/symbology-ng/qgssymbollayerv2utils.h
--- branches/symbology-ng-branch/src/core/symbology-ng/qgssymbollayerv2utils.h 2009-05-17 13:57:09 UTC (rev 10808)
+++ branches/symbology-ng-branch/src/core/symbology-ng/qgssymbollayerv2utils.h 2009-05-17 14:28:12 UTC (rev 10809)
@@ -15,6 +15,7 @@
class QColor;
class QIcon;
class QPixmap;
+class QPointF;
class QSize;
class QgsSymbolLayerV2Utils
@@ -29,6 +30,9 @@
static QString encodeBrushStyle(Qt::BrushStyle style);
static Qt::BrushStyle decodeBrushStyle(QString str);
+ static QString encodePoint(QPointF point);
+ static QPointF decodePoint(QString str);
static QIcon symbolPreviewIcon(QgsSymbolV2* symbol, QSize size);
static QIcon symbolLayerPreviewIcon(QgsSymbolLayerV2* layer, QSize size);
Modified: branches/symbology-ng-branch/src/gui/symbology-ng/qgssymbollayerv2widget.cpp
--- branches/symbology-ng-branch/src/gui/symbology-ng/qgssymbollayerv2widget.cpp 2009-05-17 13:57:09 UTC (rev 10808)
+++ branches/symbology-ng-branch/src/gui/symbology-ng/qgssymbollayerv2widget.cpp 2009-05-17 14:28:12 UTC (rev 10809)
@@ -116,6 +116,8 @@
connect(btnChangeColorFill, SIGNAL(clicked()), this, SLOT(setColorFill()));
connect(spinSize, SIGNAL(valueChanged(int)), this, SLOT(setSize()));
connect(spinAngle, SIGNAL(valueChanged(double)), this, SLOT(setAngle()));
+ connect(spinOffsetX, SIGNAL(valueChanged(double)), this, SLOT(setOffset()));
+ connect(spinOffsetY, SIGNAL(valueChanged(double)), this, SLOT(setOffset()));
void QgsSimpleMarkerSymbolLayerV2Widget::setSymbolLayer(QgsSymbolLayerV2* layer)
@@ -140,6 +142,14 @@
updateColorButton(btnChangeColorFill, mLayer->color());
spinSize->setValue(mLayer->size());
spinAngle->setValue(mLayer->angle());
+ // without blocking signals the value gets changed because of slot setOffset()
+ spinOffsetX->blockSignals(true);
+ spinOffsetX->setValue(mLayer->offset().x());
+ spinOffsetX->blockSignals(false);
+ spinOffsetY->blockSignals(true);
+ spinOffsetY->setValue(mLayer->offset().y());
+ spinOffsetY->blockSignals(false);
QgsSymbolLayerV2* QgsSimpleMarkerSymbolLayerV2Widget::symbolLayer()
@@ -185,7 +195,13 @@
emit changed();
+void QgsSimpleMarkerSymbolLayerV2Widget::setOffset()
+ mLayer->setOffset( QPointF( spinOffsetX->value(), spinOffsetY->value() ) );
+ emit changed();
QgsSimpleFillSymbolLayerV2Widget::QgsSimpleFillSymbolLayerV2Widget(QWidget* parent)
@@ -331,6 +347,8 @@
connect(viewImages->selectionModel(), SIGNAL(currentChanged(const QModelIndex&, const QModelIndex&)), this, SLOT(setName(const QModelIndex&)));
void QgsSvgMarkerSymbolLayerV2Widget::populateList()
@@ -395,6 +413,14 @@
QgsSymbolLayerV2* QgsSvgMarkerSymbolLayerV2Widget::symbolLayer()
@@ -422,6 +448,12 @@
emit changed();
+void QgsSvgMarkerSymbolLayerV2Widget::setOffset()
+ emit changed();
QgsLineDecorationSymbolLayerV2Widget::QgsLineDecorationSymbolLayerV2Widget(QWidget* parent)
Modified: branches/symbology-ng-branch/src/gui/symbology-ng/qgssymbollayerv2widget.h
--- branches/symbology-ng-branch/src/gui/symbology-ng/qgssymbollayerv2widget.h 2009-05-17 13:57:09 UTC (rev 10808)
+++ branches/symbology-ng-branch/src/gui/symbology-ng/qgssymbollayerv2widget.h 2009-05-17 14:28:12 UTC (rev 10809)
@@ -75,7 +75,8 @@
void setColorFill();
void setSize();
void setAngle();
+ void setOffset();
protected:
QgsSimpleMarkerSymbolLayerV2* mLayer;
@@ -166,7 +167,8 @@
void setName(const QModelIndex& idx);
void setSize();
void setAngle();
+ void setOffset();
protected:
void populateList();
Modified: branches/symbology-ng-branch/src/ui/symbollayer/widget_simplemarker.ui
--- branches/symbology-ng-branch/src/ui/symbollayer/widget_simplemarker.ui 2009-05-17 13:57:09 UTC (rev 10808)
+++ branches/symbology-ng-branch/src/ui/symbollayer/widget_simplemarker.ui 2009-05-17 14:28:12 UTC (rev 10809)
@@ -1,7 +1,8 @@
-<ui version="4.0" >
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
<class>WidgetSimpleMarker</class>
- <widget class="QWidget" name="WidgetSimpleMarker" >
- <property name="geometry" >
+ <widget class="QWidget" name="WidgetSimpleMarker">
+ <property name="geometry">
<rect>
<x>0</x>
<y>0</y>
@@ -9,35 +10,35 @@
<height>270</height>
</rect>
</property>
- <property name="windowTitle" >
+ <property name="windowTitle">
<string>Form</string>
</property>
- <layout class="QVBoxLayout" >
+ <layout class="QVBoxLayout" name="verticalLayout">
<item>
- <layout class="QGridLayout" >
- <item row="0" column="0" >
- <widget class="QLabel" name="label" >
- <property name="text" >
+ <layout class="QGridLayout" name="gridLayout">
+ <item row="0" column="0">
+ <widget class="QLabel" name="label">
+ <property name="text">
<string>Border color:</string>
</property>
</widget>
</item>
- <item row="0" column="1" >
- <widget class="QPushButton" name="btnChangeColorBorder" >
+ <item row="0" column="1">
+ <widget class="QPushButton" name="btnChangeColorBorder">
<string>change</string>
</property>
</widget>
</item>
- <item rowspan="4" row="0" column="2" >
+ <item row="0" column="2" rowspan="2">
<spacer>
- <property name="orientation" >
+ <property name="orientation">
<enum>Qt::Horizontal</enum>
</property>
- <property name="sizeType" >
+ <property name="sizeType">
<enum>QSizePolicy::Preferred</enum>
</property>
- <property name="sizeHint" >
+ <property name="sizeHint" stdset="0">
<size>
<width>61</width>
<height>61</height>
@@ -45,105 +46,136 @@
</property>
</spacer>
</item>
- <item row="1" column="0" >
- <widget class="QLabel" name="label_2" >
+ <item row="1" column="0">
+ <widget class="QLabel" name="label_2">
<string>Fill color:</string>
</property>
</widget>
</item>
- <item row="1" column="1" >
- <widget class="QPushButton" name="btnChangeColorFill" >
+ <item row="1" column="1">
+ <widget class="QPushButton" name="btnChangeColorFill">
</property>
</widget>
</item>
- <item row="2" column="0" >
- <widget class="QLabel" name="label_3" >
+ <item row="2" column="0">
+ <widget class="QLabel" name="label_3">
<string>Size:</string>
</property>
</widget>
</item>
- <item row="2" column="1" >
- <widget class="QSpinBox" name="spinSize" >
- <property name="minimum" >
+ <item row="2" column="1">
+ <widget class="QSpinBox" name="spinSize">
+ <property name="minimum">
<number>1</number>
</property>
</widget>
</item>
- <item row="3" column="0" >
- <widget class="QLabel" name="label_4" >
+ <item row="3" column="0">
+ <widget class="QLabel" name="label_4">
<string>Angle:</string>
</property>
</widget>
</item>
- <item row="3" column="1" >
- <widget class="QDoubleSpinBox" name="spinAngle" >
- <property name="decimals" >
+ <item row="3" column="1">
+ <widget class="QDoubleSpinBox" name="spinAngle">
+ <property name="decimals">
<number>1</number>
</property>
- <property name="maximum" >
+ <property name="maximum">
<double>360.000000000000000</double>
</property>
</widget>
</item>
+ <item row="4" column="0">
+ <widget class="QLabel" name="label_5">
+ <string>Offset X,Y:</string>
+ </property>
+ </widget>
+ </item>
+ <item row="4" column="1">
+ <layout class="QHBoxLayout" name="horizontalLayout">
+ <item>
+ <widget class="QDoubleSpinBox" name="spinOffsetX">
+ <number>1</number>
+ </property>
+ <double>-100.000000000000000</double>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QDoubleSpinBox" name="spinOffsetY">
+ </property>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
</layout>
</item>
<item>
- <widget class="QListWidget" name="lstNames" >
- <property name="sizePolicy" >
- <sizepolicy vsizetype="Expanding" hsizetype="Preferred" >
+ <widget class="QListWidget" name="lstNames">
+ <property name="sizePolicy">
+ <sizepolicy hsizetype="Preferred" vsizetype="Expanding">
<horstretch>0</horstretch>
<verstretch>0</verstretch>
</sizepolicy>
</property>
- <property name="editTriggers" >
+ <property name="editTriggers">
<set>QAbstractItemView::NoEditTriggers</set>
</property>
- <property name="iconSize" >
+ <property name="iconSize">
<size>
<width>20</width>
<height>20</height>
</size>
</property>
- <property name="movement" >
+ <property name="movement">
<enum>QListView::Static</enum>
</property>
- <property name="flow" >
+ <property name="flow">
<enum>QListView::LeftToRight</enum>
</property>
- <property name="spacing" >
+ <property name="spacing">
<number>4</number>
</property>
- <property name="gridSize" >
+ <property name="gridSize">
<size>
<width>30</width>
<height>25</height>
</size>
</property>
- <property name="viewMode" >
+ <property name="viewMode">
<enum>QListView::IconMode</enum>
</property>
- <property name="uniformItemSizes" >
+ <property name="uniformItemSizes">
<bool>true</bool>
</property>
- <property name="wordWrap" >
+ <property name="wordWrap">
<bool>true</bool>
</property>
</widget>
</item>
<item>
<spacer>
<enum>Qt::Vertical</enum>
</property>
</property>
<size>
<width>376</width>
<height>16</height>
Modified: branches/symbology-ng-branch/src/ui/symbollayer/widget_svgmarker.ui
--- branches/symbology-ng-branch/src/ui/symbollayer/widget_svgmarker.ui 2009-05-17 13:57:09 UTC (rev 10808)
+++ branches/symbology-ng-branch/src/ui/symbollayer/widget_svgmarker.ui 2009-05-17 14:28:12 UTC (rev 10809)
@@ -1,55 +1,56 @@
+<ui version="4.0">
<class>WidgetSvgMarker</class>
- <widget class="QWidget" name="WidgetSvgMarker" >
+ <widget class="QWidget" name="WidgetSvgMarker">
<rect>
<x>0</x>
<y>0</y>
- <width>378</width>
+ <width>391</width>
<height>276</height>
</rect>
</property>
</property>
<item>
- <sizepolicy vsizetype="Preferred" hsizetype="MinimumExpanding" >
+ <layout class="QGridLayout">
+ <sizepolicy hsizetype="MinimumExpanding" vsizetype="Preferred">
</sizepolicy>
</property>
</property>
</widget>
</item>
- <sizepolicy vsizetype="Fixed" hsizetype="MinimumExpanding" >
+ <sizepolicy hsizetype="MinimumExpanding" vsizetype="Fixed">
</sizepolicy>
</property>
<number>1</number>
</property>
- <property name="value" >
+ <property name="value">
<number>5</number>
</property>
</widget>
</item>
- <item rowspan="2" row="0" column="2" >
+ <item row="0" column="2" rowspan="3">
<spacer>
</property>
<size>
<width>115</width>
<height>51</height>
@@ -57,69 +58,100 @@
</property>
</spacer>
</item>
</property>
</widget>
</item>
<number>1</number>
</property>
</property>
</widget>
</item>
+ <item>
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item>
+ </property>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ </property>
+ </widget>
+ </item>
</layout>
</item>
<item>
<string>SVG Image:</string>
</property>
</widget>
</item>
<item>
- <widget class="QListView" name="viewImages" >
+ <widget class="QListView" name="viewImages">
</property>
<size>
<width>32</width>
<height>32</height>
</size>
</property>
</property>
<number>2</number>
</property>
<size>
<width>36</width>
<height>36</height>
</size>
</property>
</property>
<bool>true</bool>
</property>
</widget>
</item>
<item>
<spacer>
</property>
<size>
<width>20</width>
<height>40</height>
