[QGIS Commit] r12209 - trunk/qgis/src/plugins/scale_bar
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Nov 20 14:44:55 EST 2009
Author: timlinux
Date: 2009-11-20 14:44:53 -0500 (Fri, 20 Nov 2009)
New Revision: 12209
   trunk/qgis/src/plugins/scale_bar/pluginguibase.ui
Dont use form layout use grid layout (for  #2121)
Modified: trunk/qgis/src/plugins/scale_bar/pluginguibase.ui
--- trunk/qgis/src/plugins/scale_bar/pluginguibase.ui	2009-11-20 17:25:46 UTC (rev 12208)
+++ trunk/qgis/src/plugins/scale_bar/pluginguibase.ui	2009-11-20 19:44:53 UTC (rev 12209)
@@ -6,8 +6,8 @@
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>270</width>
-    <height>199</height>
+    <width>342</width>
+    <height>255</height>
    </rect>
   </property>
   <property name="windowTitle">
@@ -18,8 +18,8 @@
     <normaloff/>
    </iconset>
   </property>
-  <layout class="QVBoxLayout" name="verticalLayout">
-   <item>
+  <layout class="QGridLayout" name="gridLayout">
+   <item row="0" column="0">
     <layout class="QFormLayout" name="formLayout">
      <property name="fieldGrowthPolicy">
       <enum>QFormLayout::AllNonFixedFieldsGrow</enum>
@@ -182,7 +182,7 @@
      </item>
     </layout>
    </item>
-   <item>
+   <item row="1" column="0">
     <widget class="QCheckBox" name="chkEnable">
      <property name="sizePolicy">
       <sizepolicy hsizetype="Minimum" vsizetype="Minimum">
@@ -198,7 +198,7 @@
      </property>
     </widget>
    </item>
-   <item>
+   <item row="2" column="0">
     <widget class="QCheckBox" name="chkSnapping">
@@ -214,7 +214,7 @@
      </property>
     </widget>
    </item>
-   <item>
+   <item row="3" column="0">
     <widget class="QDialogButtonBox" name="buttonBox">
      <property name="orientation">
       <enum>Qt::Horizontal</enum>
More information about the QGIS-commit mailing list
