[QGIS Commit] r12210 - trunk/qgis/src/ui
svn_qgis at osgeo.org
Fri Nov 20 14:49:06 EST 2009
Author: timlinux
Date: 2009-11-20 14:49:06 -0500 (Fri, 20 Nov 2009)
New Revision: 12210
trunk/qgis/src/ui/qgscontinuouscolordialogbase.ui
trunk/qgis/src/ui/qgsludialogbase.ui
Dont use form layout use grid layout (for #2121)
Modified: trunk/qgis/src/ui/qgscontinuouscolordialogbase.ui
--- trunk/qgis/src/ui/qgscontinuouscolordialogbase.ui 2009-11-20 19:44:53 UTC (rev 12209)
+++ trunk/qgis/src/ui/qgscontinuouscolordialogbase.ui 2009-11-20 19:49:06 UTC (rev 12210)
@@ -13,133 +13,47 @@
<property name="windowTitle">
<string>Continuous color</string>
</property>
- <layout class="QGridLayout" name="gridLayout_2">
- <item row="0" column="1">
- <layout class="QGridLayout" name="gridLayout">
- <item row="0" column="0">
- <layout class="QFormLayout" name="formLayout">
- <widget class="QLabel" name="classvarlabel">
- <property name="minimumSize">
- <size>
- <width>0</width>
- <height>20</height>
- </size>
- </property>
- <property name="text">
- <string>Classification field</string>
- </property>
- <property name="buddy">
- <cstring>classificationComboBox</cstring>
- </property>
- </widget>
- </item>
- <widget class="QComboBox" name="classificationComboBox">
- <size>
- <width>0</width>
- </size>
- </property>
- </widget>
- </item>
- <item row="1" column="0">
- <widget class="QLabel" name="mincolorlabel">
- <size>
- <width>0</width>
- </size>
- </property>
- <string>Minimum value</string>
- </property>
- <cstring>btnMinValue</cstring>
- </property>
- </widget>
- </item>
- <item row="2" column="0">
- <widget class="QLabel" name="maxcolorlabel">
- <size>
- <width>0</width>
- </size>
- </property>
- <string>Maximum value</string>
- </property>
- <cstring>btnMaxValue</cstring>
- </property>
- </widget>
- </item>
- <item row="1" column="1">
- <widget class="QgsColorButton" name="btnMinValue">
- <size>
- <width>100</width>
- <height>0</height>
- </size>
- </property>
- </widget>
- </item>
- <item row="2" column="1">
- <widget class="QgsColorButton" name="btnMaxValue">
- <size>
- </size>
- </property>
- </widget>
- </item>
- <item row="3" column="0">
- <widget class="QLabel" name="outlinewidthlabel">
- <size>
- <width>0</width>
- </size>
- </property>
- <string>Outline width</string>
- </property>
- <cstring>outlinewidthspinbox</cstring>
- </property>
- </widget>
- </item>
- <item row="3" column="1">
- <widget class="QDoubleSpinBox" name="outlinewidthspinbox"/>
- </item>
- </layout>
- </item>
- <widget class="QCheckBox" name="cb_polygonOutline">
- <string>Draw polygon outline</string>
- </property>
- </widget>
- </item>
- </layout>
- </item>
- <spacer name="verticalSpacer">
+ <layout class="QGridLayout" name="gridLayout">
+ <item row="0" column="0">
+ <spacer name="horizontalSpacer_2">
<property name="orientation">
- <enum>Qt::Vertical</enum>
+ <enum>Qt::Horizontal</enum>
</property>
<property name="sizeHint" stdset="0">
<size>
- <width>20</width>
- <height>40</height>
+ <width>40</width>
+ <height>20</height>
</size>
</property>
</spacer>
</item>
+ <item row="0" column="1">
+ <widget class="QLabel" name="classvarlabel">
+ <property name="minimumSize">
+ <size>
+ <width>0</width>
+ </size>
+ </property>
+ <property name="text">
+ <string>Classification field</string>
+ </property>
+ <property name="buddy">
+ <cstring>classificationComboBox</cstring>
+ </property>
+ </widget>
+ </item>
<item row="0" column="2">
+ <widget class="QComboBox" name="classificationComboBox">
+ <size>
+ <width>0</width>
+ </size>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="3">
<spacer name="horizontalSpacer">
@@ -152,15 +66,93 @@
</property>
</spacer>
</item>
- <spacer name="horizontalSpacer_2">
+ <item row="1" column="1">
+ <widget class="QLabel" name="mincolorlabel">
+ <size>
+ <width>0</width>
+ </size>
+ </property>
+ <string>Minimum value</string>
+ </property>
+ <cstring>btnMinValue</cstring>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="2">
+ <widget class="QgsColorButton" name="btnMinValue">
+ <size>
+ <width>100</width>
+ <height>0</height>
+ </size>
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="1">
+ <widget class="QLabel" name="maxcolorlabel">
+ <size>
+ <width>0</width>
+ </size>
+ </property>
+ <string>Maximum value</string>
+ </property>
+ <cstring>btnMaxValue</cstring>
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="2">
+ <widget class="QgsColorButton" name="btnMaxValue">
+ <size>
+ </size>
+ </property>
+ </widget>
+ </item>
+ <item row="3" column="1">
+ <widget class="QLabel" name="outlinewidthlabel">
+ <size>
+ <width>0</width>
+ </size>
+ </property>
+ <string>Outline width</string>
+ </property>
+ <cstring>outlinewidthspinbox</cstring>
+ </property>
+ </widget>
+ </item>
+ <item row="3" column="2">
+ <widget class="QDoubleSpinBox" name="outlinewidthspinbox"/>
+ </item>
+ <item row="4" column="1" colspan="2">
+ <widget class="QCheckBox" name="cb_polygonOutline">
+ <string>Draw polygon outline</string>
+ </property>
+ </widget>
+ </item>
+ <item row="5" column="1" colspan="2">
+ <spacer name="verticalSpacer">
- <enum>Qt::Horizontal</enum>
+ <enum>Qt::Vertical</enum>
</property>
<size>
- <width>40</width>
+ <width>20</width>
+ <height>40</height>
</size>
</property>
</spacer>
Modified: trunk/qgis/src/ui/qgsludialogbase.ui
--- trunk/qgis/src/ui/qgsludialogbase.ui 2009-11-20 19:44:53 UTC (rev 12209)
+++ trunk/qgis/src/ui/qgsludialogbase.ui 2009-11-20 19:49:06 UTC (rev 12210)
@@ -7,7 +7,7 @@
<x>0</x>
<y>0</y>
<width>227</width>
- <height>117</height>
+ <height>122</height>
</rect>
</property>
@@ -16,38 +16,41 @@
<property name="modal">
<bool>true</bool>
</property>
- <layout class="QVBoxLayout" name="verticalLayout">
- <item>
- <widget class="QLabel" name="mLowerLabel">
- <string>Lower value</string>
- </property>
- <cstring>mLowerEdit</cstring>
- </property>
- </widget>
- </item>
- <widget class="QLineEdit" name="mLowerEdit"/>
- </item>
- <widget class="QLabel" name="mUpperLabel">
- <string>Upper value</string>
- </property>
- <cstring>mUpperEdit</cstring>
- </property>
- </widget>
- </item>
- <widget class="QLineEdit" name="mUpperEdit"/>
- </item>
- </layout>
+ <widget class="QLabel" name="mLowerLabel">
+ <string>Lower value</string>
+ </property>
+ <cstring>mLowerEdit</cstring>
+ </property>
+ </widget>
</item>
- <item>
+ <widget class="QLineEdit" name="mLowerEdit"/>
+ </item>
+ <item row="1" column="0">
+ <widget class="QLabel" name="mUpperLabel">
+ <string>Upper value</string>
+ </property>
+ <cstring>mUpperEdit</cstring>
+ </property>
+ </widget>
+ </item>
+ <widget class="QLineEdit" name="mUpperEdit"/>
+ </item>
+ <item row="3" column="0" colspan="2">
+ <widget class="QDialogButtonBox" name="buttonBox">
+ <property name="standardButtons">
+ <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="0">
@@ -55,18 +58,11 @@
<size>
<width>20</width>
- <height>10</height>
</size>
</property>
</spacer>
</item>
- <item>
- <widget class="QDialogButtonBox" name="buttonBox">
- <property name="standardButtons">
- <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
- </property>
- </widget>
- </item>
</layout>
</widget>
<layoutdefault spacing="6" margin="11"/>
