[QGIS Commit] r12288 - trunk/qgis/i18n
svn_qgis at osgeo.org
Sun Nov 29 10:41:23 EST 2009
Author: macho
Date: 2009-11-29 10:41:22 -0500 (Sun, 29 Nov 2009)
New Revision: 12288
trunk/qgis/i18n/qgis_fr.ts
translation update: fre by jean roc
Modified: trunk/qgis/i18n/qgis_fr.ts
--- trunk/qgis/i18n/qgis_fr.ts 2009-11-29 15:22:00 UTC (rev 12287)
+++ trunk/qgis/i18n/qgis_fr.ts 2009-11-29 15:41:22 UTC (rev 12288)
@@ -1732,57 +1732,57 @@
<message>
<location filename="../src/ui/qgssymbolv2propertiesdialogbase.ui" line="14"/>
<source>Symbol properties</source>
- <translation type="unfinished"></translation>
+ <translation>Propriétés du symbole</translation>
</message>
<message>
<location filename="../src/ui/qgssymbolv2propertiesdialogbase.ui" line="20"/>
<source>Symbol preview:</source>
+ <translation>Aperçu :</translation>
</message>
<message>
<location filename="../src/ui/qgssymbolv2propertiesdialogbase.ui" line="31"/>
<source>Symbol layer type:</source>
+ <translation>Type de symbole :</translation>
</message>
<message>
<location filename="../src/ui/qgssymbolv2propertiesdialogbase.ui" line="49"/>
<source>Symbol layer properties</source>
+ <translation>Propriétés de la couche de symbole</translation>
</message>
<message>
<location filename="../src/ui/qgssymbolv2propertiesdialogbase.ui" line="65"/>
<source>This symbol layer doesn't have GUI for settings.</source>
+ <translation>Cette couche de symboles n'a pas d'interface graphique pour la paramètrage.</translation>
</message>
<message>
<location filename="../src/ui/qgssymbolv2propertiesdialogbase.ui" line="100"/>
<source>Symbol layers:</source>
+ <translation>Couches de symboles :</translation>
</message>
<message>
<location filename="../src/ui/qgssymbolv2propertiesdialogbase.ui" line="125"/>
<source>Add symbol layer</source>
+ <translation>Ajouter un couche de symbole</translation>
</message>
<message>
<location filename="../src/ui/qgssymbolv2propertiesdialogbase.ui" line="138"/>
<source>Remove symbol layer</source>
+ <translation>Supprimer une couche de symbole</translation>
</message>
<message>
<location filename="../src/ui/qgssymbolv2propertiesdialogbase.ui" line="167"/>
<source>Lock layer's color</source>
+ <translation>Verrouiller la couleur de la couche</translation>
</message>
<message>
<location filename="../src/ui/qgssymbolv2propertiesdialogbase.ui" line="199"/>
<source>Move up</source>
- <translation type="unfinished">Monter</translation>
+ <translation>Monter</translation>
</message>
<message>
<location filename="../src/ui/qgssymbolv2propertiesdialogbase.ui" line="212"/>
<source>Move down</source>
- <translation type="unfinished">Descendre</translation>
+ <translation>Descendre</translation>
</message>
</context>
<context>
@@ -1884,67 +1884,67 @@
<message>
<location filename="../src/plugins/labeling/engineconfigdialog.ui" line="14"/>
<source>Dialog</source>
- <translation type="unfinished">Dialogue</translation>
+ <translation>Dialogue</translation>
</message>
<message>
<location filename="../src/plugins/labeling/engineconfigdialog.ui" line="22"/>
<source>Search method</source>
+ <translation>Méthode de recherche</translation>
</message>
<message>
<location filename="../src/plugins/labeling/engineconfigdialog.ui" line="30"/>
<source>Chain (fast)</source>
- <translation type="unfinished">Chaîne (rapide)</translation>
+ <translation>Chaîne (rapide)</translation>
</message>
<message>
<location filename="../src/plugins/labeling/engineconfigdialog.ui" line="35"/>
<source>Popmusic Tabu</source>
+ <translation>Popmusic Tabu</translation>
</message>
<message>
<location filename="../src/plugins/labeling/engineconfigdialog.ui" line="40"/>
<source>Popmusic Chain</source>
+ <translation>Popmusic Chain</translation>
</message>
<message>
<location filename="../src/plugins/labeling/engineconfigdialog.ui" line="45"/>
<source>Popmusic Tabu Chain</source>
+ <translation>Popmusic Tabu Chain</translation>
</message>
<message>
<location filename="../src/plugins/labeling/engineconfigdialog.ui" line="50"/>
<source>FALP (fastest)</source>
+ <translation>FALP (la plus rapide)</translation>
</message>
<message>
<location filename="../src/plugins/labeling/engineconfigdialog.ui" line="78"/>
<source>Number of candidates</source>
+ <translation>Nombre de possibilités</translation>
</message>
<message>
<location filename="../src/plugins/labeling/engineconfigdialog.ui" line="84"/>
<source>Point</source>
- <translation type="unfinished">Point</translation>
+ <translation>Point</translation>
</message>
<message>
<location filename="../src/plugins/labeling/engineconfigdialog.ui" line="104"/>
<source>Line</source>
- <translation type="unfinished">Ligne</translation>
+ <translation>Ligne</translation>
</message>
<message>
<location filename="../src/plugins/labeling/engineconfigdialog.ui" line="124"/>
<source>Polygon</source>
- <translation type="unfinished">Polygone</translation>
+ <translation>Polygone</translation>
</message>
<message>
<location filename="../src/plugins/labeling/engineconfigdialog.ui" line="178"/>
<source>Show all labels (i.e. including colliding labels)</source>
+ <translation>Afficher toutes les étiquettes (même celles en conflit)</translation>
</message>
<message>
<location filename="../src/plugins/labeling/engineconfigdialog.ui" line="185"/>
<source>Show label candidates (for debugging)</source>
+ <translation>Afficher toutes les possibilités (pour le débogage)</translation>
</message>
</context>
<context>
@@ -2330,17 +2330,17 @@
<message>
<location filename="../src/plugins/labeling/labeling.cpp" line="111"/>
<source>Labeling</source>
+ <translation>Étiquetage</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labeling.cpp" line="113"/>
<source>Replace this with a short description of what the plugin does</source>
- <translation type="unfinished">Remplacez ceci par une description courte de cette extension</translation>
+ <translation>Remplacez ceci par une description courte de cette extension</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labeling.cpp" line="118"/>
<source>&Labeling</source>
+ <translation>&Etiquetage</translation>
</message>
</context>
<context>
@@ -2348,226 +2348,226 @@
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="14"/>
<source>Layer labeling settings</source>
+ <translation>Paramètres de l'étiquetage de la couche</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="25"/>
<source>Label this layer</source>
+ <translation>Étiqueter cette couche</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="34"/>
<source>Field with labels</source>
+ <translation>Champ</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="62"/>
<source>Placement</source>
+ <translation>Emplacement</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="87"/>
<source>around point</source>
+ <translation>autour du point</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="97"/>
<source>over point</source>
+ <translation>sur le point</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="108"/>
<source>parallel</source>
+ <translation>parallèle</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="118"/>
<source>curved</source>
+ <translation>courbe</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="125"/>
<source>horizontal</source>
+ <translation>horizontal</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="136"/>
<source>over centroid</source>
+ <translation>sur le centroïde</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="146"/>
<source>around centroid</source>
+ <translation>autour du centroïde</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="153"/>
<source>horizontal (slow)</source>
+ <translation>horizontal (lent)</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="160"/>
<source>free (slow)</source>
+ <translation>libre (lent)</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="167"/>
<source>using perimeter</source>
+ <translation>selon le périmètre</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="192"/>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="298"/>
<source>Label distance</source>
+ <translation>Distance</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="209"/>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="315"/>
<source>pixels</source>
+ <translation>pixels</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="216"/>
<source>Rotation</source>
- <translation type="unfinished">Rotation</translation>
+ <translation>Rotation</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="233"/>
<source>degrees</source>
+ <translation>degrés</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="244"/>
<source>above line</source>
+ <translation>au-dessus de la ligne</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="254"/>
<source>on line</source>
+ <translation>sur la ligne</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="261"/>
<source>below line</source>
+ <translation>en-dessous de la ligne</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="270"/>
<source>Orientation</source>
- <translation type="unfinished">Orientation</translation>
+ <translation>Orientation</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="277"/>
<source>map</source>
+ <translation>carte</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="287"/>
<source>line</source>
+ <translation>ligne</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="334"/>
<source>Text style</source>
+ <translation>Style du texte</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="346"/>
<source>Font</source>
- <translation type="unfinished">Police</translation>
+ <translation>Police</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="364"/>
<source>TextLabel</source>
- <translation type="unfinished">Étiquette</translation>
+ <translation>Étiquette</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="384"/>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="500"/>
<source>...</source>
- <translation type="unfinished">...</translation>
+ <translation>...</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="399"/>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="484"/>
<source>Color</source>
- <translation type="unfinished">Couleur</translation>
+ <translation>Couleur</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="442"/>
<source>Buffer</source>
- <translation type="unfinished">Buffer</translation>
+ <translation>Buffer</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="467"/>
<source>Size</source>
- <translation type="unfinished">Taille</translation>
+ <translation>Taille</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="515"/>
<source>Sample</source>
+ <translation>Échantillon</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="531"/>
<source>Lorem Ipsum</source>
+ <translation>Lorem Ipsum</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="551"/>
<source>Priority</source>
+ <translation>Priorité</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="557"/>
<source>Low</source>
+ <translation>Basse</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="583"/>
<source>High</source>
+ <translation>Haute</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="593"/>
<source>Scale-based visibility</source>
+ <translation>Visibilité selon une échelle</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="599"/>
<source>Enabled</source>
- <translation type="unfinished">Activé</translation>
+ <translation>Activée</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="606"/>
<source>Minimum</source>
+ <translation>Minimum</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="626"/>
<source>Maximum</source>
+ <translation>Maximum</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="654"/>
<source>label every part of multi-part features</source>
+ <translation>étiqueter toutes les parts d'une entité multi-parties</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="661"/>
<source>merge connected lines to avoid duplicate labels</source>
+ <translation>fusionner les lignes connectées pour éviter la duplication d'étiquettes</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="673"/>
<source>features don't act as obstacles for labels</source>
+ <translation>les entités ne sont pas des obstacles pour les étiquettes</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labelingguibase.ui" line="696"/>
<source>Engine settings</source>
+ <translation>paramètres</translation>
</message>
</context>
<context>
@@ -5058,7 +5058,7 @@
<message>
<location filename="../src/analysis/interpolation/qgstininterpolator.cpp" line="149"/>
<source>Estimating normal derivatives...</source>
+ <translation>Estimation des dérivés normaux...</translation>
</message>
<message>
<location filename="../src/core/qgscoordinatereferencesystem.cpp" line="1211"/>
@@ -5114,27 +5114,27 @@
<message>
<location filename="../src/core/symbology-ng/qgsrendererv2registry.cpp" line="15"/>
<source>Single Symbol</source>
- <translation type="unfinished">Symbole Unique</translation>
+ <translation>Symbole Unique</translation>
</message>
<message>
<location filename="../src/core/symbology-ng/qgsrendererv2registry.cpp" line="19"/>
<source>Categorized</source>
+ <translation>Catégorisé</translation>
</message>
<message>
<location filename="../src/core/symbology-ng/qgsrendererv2registry.cpp" line="23"/>
<source>Graduated</source>
+ <translation>Gradué</translation>
</message>
<message>
<location filename="../src/plugins/labeling/labeling.cpp" line="43"/>
</message>
<message>
<location filename="../src/plugins/labeling/labeling.cpp" line="44"/>
<source>Smart labeling for vector layers</source>
+ <translation>Étiquetage intelligent pour les couches vecteurs</translation>
</message>
</context>
<context>
@@ -7324,12 +7324,12 @@
<message>
<location filename="../src/app/qgisapp.cpp" line="602"/>
<source>Composer manager...</source>
+ <translation>Gestionnaire de composeur...</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="603"/>
<source>Composer manager</source>
+ <translation>Gestionnaire de composeur</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="662"/>
@@ -7385,7 +7385,7 @@
<location filename="../src/app/qgisapp.cpp" line="795"/>
<location filename="../src/app/qgisapp.cpp" line="797"/>
<source>Deselect features from all layers</source>
+ <translation>Désélectionner les entités de toutes les couches</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="802"/>
@@ -7480,12 +7480,12 @@
<message>
<location filename="../src/app/qgisapp.cpp" line="1067"/>
<source>Style manager...</source>
+ <translation>Gestionnaire de style...</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="1069"/>
<source>Show style manager V2</source>
+ <translation>Afficher le gestionnaire de style V2</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="1552"/>
@@ -7767,7 +7767,7 @@
<location filename="../src/app/qgisapp.cpp" line="4234"/>
<location filename="../src/app/qgisapp.cpp" line="4270"/>
<source>Composer %1</source>
+ <translation>Composeur %1</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="4303"/>
@@ -8500,13 +8500,13 @@
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="29"/>
<source>Action list</source>
+ <translation>Liste d'actions</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="54"/>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="265"/>
<source>Type</source>
+ <translation>Type</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="184"/>
@@ -8526,27 +8526,27 @@
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="237"/>
<source>Generic</source>
+ <translation>Générique</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="242"/>
<source>Python</source>
+ <translation>Python</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="247"/>
<source>Windows</source>
+ <translation>Windows</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="252"/>
<source>Mac</source>
+ <translation>Mac</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="257"/>
<source>Unix</source>
+ <translation>Unix</translation>
</message>
<message>
<location filename="../src/ui/qgsattributeactiondialogbase.ui" line="69"/>
@@ -9282,12 +9282,12 @@
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="66"/>
<source>Checkbox</source>
+ <translation>Boîte à cocher</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="71"/>
<source>Text edit</source>
+ <translation>Édition de texte</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="92"/>
@@ -9393,17 +9393,17 @@
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="521"/>
<source>Representation for checked state</source>
+ <translation>Représentation d'un état coché</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="528"/>
<source>Representation for unchecked state</source>
+ <translation>Représentation d'un état non-coché</translation>
</message>
<message>
<location filename="../src/ui/qgsattributetypeedit.ui" line="557"/>
<source>A text edit field that accepts multiple lines will be used.</source>
+ <translation>Un champ d'édition de texte acceptant plusieurs lignes sera utilisé.</translation>
</message>
<message>
<source>Immutable attribute is read-only - user is not able to modify the contents.</source>
@@ -9541,57 +9541,57 @@
<location filename="../src/gui/symbology-ng/qgscategorizedsymbolrendererv2widget.cpp" line="263"/>
<location filename="../src/gui/symbology-ng/qgscategorizedsymbolrendererv2widget.cpp" line="265"/>
<source>Error</source>
- <translation type="unfinished">Erreur</translation>
+ <translation>Erreur</translation>
</message>
<message>
<source>There are no available color ramps. You can add them in Style Manager.</source>
+ <translation>Il n'y a pas de rampe de couleur disponible. Vous pouvez en ajouter via le Gestionnaire de Style.</translation>
</message>
<message>
<source>The selected color ramp is not available.</source>
+ <translation>La rampe de couleur sélectionnée n'est pas disponible.</translation>
</message>
<message>
<location filename="../src/ui/qgscategorizedsymbolrendererv2widget.ui" line="19"/>
<source>Column:</source>
+ <translation>Colonne :</translation>
</message>
<message>
<location filename="../src/ui/qgscategorizedsymbolrendererv2widget.ui" line="56"/>
<source>Symbol:</source>
+ <translation>Symbole :</translation>
</message>
<message>
<location filename="../src/ui/qgscategorizedsymbolrendererv2widget.ui" line="69"/>
<source>change</source>
+ <translation>changer</translation>
</message>
<message>
<location filename="../src/ui/qgscategorizedsymbolrendererv2widget.ui" line="76"/>
<source>Color ramp:</source>
+ <translation>Rampe de couleur :</translation>
</message>
<message>
<location filename="../src/ui/qgscategorizedsymbolrendererv2widget.ui" line="113"/>
<source>Classify</source>
- <translation type="unfinished">Classer</translation>
+ <translation>Classer</translation>
</message>
<message>
<location filename="../src/ui/qgscategorizedsymbolrendererv2widget.ui" line="120"/>
<source>Delete</source>
- <translation type="unfinished">Effacer</translation>
+ <translation>Effacer</translation>
</message>
<message>
<location filename="../src/ui/qgscategorizedsymbolrendererv2widget.ui" line="127"/>
<source>Delete all</source>
+ <translation>Effacer tout</translation>
</message>
<message>
<location filename="../src/ui/qgscategorizedsymbolrendererv2widget.ui" line="150"/>
<source>Join</source>
+ <translation>Joindre</translation>
</message>
</context>
<context>
@@ -9845,7 +9845,7 @@
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="1099"/>
<source>Composer</source>
+ <translation>Composeur</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="1395"/>
@@ -9936,22 +9936,22 @@
<message>
<location filename="../src/app/composer/qgscomposerarrowwidget.cpp" line="39"/>
<source>General options</source>
- <translation type="unfinished">Options globales</translation>
+ <translation>Options globales</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposerarrowwidget.cpp" line="79"/>
<source>Arrow color</source>
+ <translation>Flèche de couleur</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposerarrowwidget.cpp" line="207"/>
<source>Start marker svg file</source>
+ <translation>Débuter un fichier svg de marqueur</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposerarrowwidget.cpp" line="217"/>
<source>End marker svg file</source>
+ <translation>Terminer un fichier svg de marqueur</translation>
</message>
</context>
<context>
@@ -9959,63 +9959,63 @@
<message>
<location filename="../src/ui/qgscomposerarrowwidgetbase.ui" line="14"/>
<source>Form</source>
+ <translation>Formulaire</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerarrowwidgetbase.ui" line="32"/>
<source>Arrow</source>
+ <translation>Flèche</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerarrowwidgetbase.ui" line="38"/>
<source>Arrow color...</source>
+ <translation>Flèche de couleur...</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerarrowwidgetbase.ui" line="45"/>
<source>Outline width </source>
+ <translation>Largeur de bordure</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerarrowwidgetbase.ui" line="52"/>
<source>Arrow head width </source>
+ <translation>Largeur de la tête</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerarrowwidgetbase.ui" line="59"/>
<source>Arrow markers</source>
+ <translation>Marqueur de flèche</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerarrowwidgetbase.ui" line="65"/>
<source>Default marker</source>
+ <translation>Marqueur par défaut</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerarrowwidgetbase.ui" line="72"/>
<source>No marker</source>
+ <translation>Pas de marqueur</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerarrowwidgetbase.ui" line="79"/>
<source>SVG markers</source>
+ <translation>Marqueur SVG</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerarrowwidgetbase.ui" line="86"/>
<source>Start marker</source>
+ <translation>Débuter un marqueur</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerarrowwidgetbase.ui" line="96"/>
<location filename="../src/ui/qgscomposerarrowwidgetbase.ui" line="113"/>
</message>
<message>
<location filename="../src/ui/qgscomposerarrowwidgetbase.ui" line="103"/>
<source>End marker</source>
+ <translation>Terminer un marqueur</translation>
</message>
</context>
<context>
@@ -10326,12 +10326,12 @@
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="453"/>
<source>Add Basic Shape</source>
+ <translation>Ajouter une forme basique</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerbase.ui" line="461"/>
<source>Add arrow</source>
+ <translation>Ajouter une flèche</translation>
</message>
</context>
<context>
@@ -10428,7 +10428,7 @@
<message>
<location filename="../src/app/composer/qgscomposerlabelwidget.cpp" line="31"/>
</message>
</context>
<context>
@@ -10451,7 +10451,7 @@
<message>
<location filename="../src/ui/qgscomposerlabelwidgetbase.ui" line="64"/>
<source>Font color...</source>
+ <translation>Couleur de police...</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerlabelwidgetbase.ui" line="71"/>
@@ -10729,22 +10729,22 @@
<message>
<location filename="../src/app/composer/qgscomposermanager.cpp" line="83"/>
<source>Remove composer</source>
+ <translation>Supprimer ce composeur</translation>
</message>
<message>
<source>Do you really want to remove the map composer '%1'?</source>
+ <translation>Voulez-vous vraiment supprimer l'instance '%1' du composeur ?</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposermanager.cpp" line="143"/>
<source>Change title</source>
+ <translation>Changer le titre</translation>
</message>
<message>
<source>Title</source>
- <translation type="unfinished">Titre</translation>
+ <translation>Titre</translation>
</message>
</context>
<context>
@@ -10752,27 +10752,27 @@
<message>
<location filename="../src/ui/qgscomposermanagerbase.ui" line="14"/>
</message>
<message>
<location filename="../src/ui/qgscomposermanagerbase.ui" line="23"/>
<source>Add</source>
- <translation type="unfinished">Ajouter</translation>
+ <translation>Ajouter</translation>
</message>
<message>
<location filename="../src/ui/qgscomposermanagerbase.ui" line="30"/>
<source>Remove</source>
- <translation type="unfinished">Supprimer</translation>
+ <translation>Supprimer</translation>
</message>
<message>
<location filename="../src/ui/qgscomposermanagerbase.ui" line="37"/>
<source>Rename</source>
+ <translation>Renommer</translation>
</message>
<message>
<location filename="../src/ui/qgscomposermanagerbase.ui" line="44"/>
<source>Show</source>
+ <translation>Afficher</translation>
</message>
</context>
<context>
@@ -11488,12 +11488,12 @@
<message>
<location filename="../src/ui/qgscomposerscalebarwidgetbase.ui" line="90"/>
<source> Right segments</source>
+ <translation>segments de droite</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerscalebarwidgetbase.ui" line="97"/>
<source> Left segments</source>
+ <translation>segments de gauche</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerscalebarwidgetbase.ui" line="149"/>
@@ -11501,27 +11501,27 @@
<location filename="../src/ui/qgscomposerscalebarwidgetbase.ui" line="187"/>
<location filename="../src/ui/qgscomposerscalebarwidgetbase.ui" line="197"/>
<source> mm</source>
- <translation type="unfinished"> mm</translation>
+ <translation> mm</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerscalebarwidgetbase.ui" line="152"/>
<source>Height </source>
+ <translation>Hauteur</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerscalebarwidgetbase.ui" line="165"/>
<source>Line width </source>
+ <translation>Largeur de ligne</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerscalebarwidgetbase.ui" line="184"/>
<source>Label space </source>
+ <translation>Emplacement des étiquettes</translation>
</message>
<message>
<location filename="../src/ui/qgscomposerscalebarwidgetbase.ui" line="194"/>
<source>Box space </source>
- <translation type="unfinished">Taille de la boite</translation>
+ <translation>Taille de la boite</translation>
</message>
<message>
<source>Number of segments</source>
@@ -11613,38 +11613,38 @@
<message>
<location filename="../src/app/composer/qgscomposershapewidget.cpp" line="29"/>
</message>
<message>
<location filename="../src/app/composer/qgscomposershapewidget.cpp" line="34"/>
<location filename="../src/app/composer/qgscomposershapewidget.cpp" line="68"/>
<location filename="../src/app/composer/qgscomposershapewidget.cpp" line="107"/>
<source>Ellipse</source>
+ <translation>Ellipse</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposershapewidget.cpp" line="35"/>
<location filename="../src/app/composer/qgscomposershapewidget.cpp" line="72"/>
<location filename="../src/app/composer/qgscomposershapewidget.cpp" line="111"/>
<source>Rectangle</source>
- <translation type="unfinished">Rectangle</translation>
+ <translation>Rectangle</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposershapewidget.cpp" line="36"/>
<location filename="../src/app/composer/qgscomposershapewidget.cpp" line="76"/>
<location filename="../src/app/composer/qgscomposershapewidget.cpp" line="115"/>
<source>Triangle</source>
+ <translation>Triangle</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposershapewidget.cpp" line="130"/>
<source>Select outline color</source>
+ <translation>Sélectionner la couleur de la bordure</translation>
</message>
<message>
<location filename="../src/app/composer/qgscomposershapewidget.cpp" line="179"/>
<source>Select fill color</source>
+ <translation>Sélectionner la couleur de remplissage</translation>
</message>
</context>
<context>
@@ -11652,39 +11652,39 @@
<message>
<location filename="../src/ui/qgscomposershapewidgetbase.ui" line="14"/>
</message>
<message>
<location filename="../src/ui/qgscomposershapewidgetbase.ui" line="32"/>
<source>Shape</source>
+ <translation>Forme</translation>
</message>
<message>
<location filename="../src/ui/qgscomposershapewidgetbase.ui" line="41"/>
<source>Shape outline color...</source>
+ <translation>Couleur de la bordure...</translation>
</message>
<message>
<location filename="../src/ui/qgscomposershapewidgetbase.ui" line="48"/>
</message>
<message>
<location filename="../src/ui/qgscomposershapewidgetbase.ui" line="55"/>
<source>Transparent fill</source>
+ <translation>Transparence du remplissage</translation>
</message>
<message>
<location filename="../src/ui/qgscomposershapewidgetbase.ui" line="62"/>
<source>Shape fill Color...</source>
+ <translation>Couleur de remplissage...</translation>
</message>
<message>
<location filename="../src/ui/qgscomposershapewidgetbase.ui" line="69"/>
<source>Rotation </source>
<comment>Rotation</comment>
<extracomment>Rotation</extracomment>
</message>
</context>
<context>
@@ -12123,42 +12123,42 @@
<message>
<location filename="../src/ui/qgscompositionwidgetbase.ui" line="153"/>
<source> dpi</source>
+ <translation>dpi (ppp)</translation>
</message>
<message>
<location filename="../src/ui/qgscompositionwidgetbase.ui" line="156"/>
<source>Quality </source>
+ <translation>Qualité</translation>
</message>
<message>
<location filename="../src/ui/qgscompositionwidgetbase.ui" line="166"/>
<source>Width </source>
+ <translation>Largeur</translation>
</message>
<message>
<location filename="../src/ui/qgscompositionwidgetbase.ui" line="179"/>
</message>
<message>
<location filename="../src/ui/qgscompositionwidgetbase.ui" line="208"/>
<source>Spacing </source>
+ <translation>Espacement</translation>
</message>
<message>
<location filename="../src/ui/qgscompositionwidgetbase.ui" line="221"/>
<source>X offset </source>
+ <translation>Décalage X</translation>
</message>
<message>
<location filename="../src/ui/qgscompositionwidgetbase.ui" line="231"/>
<source>Y offset </source>
+ <translation>Décalage Y</translation>
</message>
<message>
<location filename="../src/ui/qgscompositionwidgetbase.ui" line="238"/>
<source>Pen width </source>
+ <translation>Largeur du crayon</translation>
</message>
<message>
<source>Print quality (dpi)</source>
@@ -12635,7 +12635,11 @@
p, li { white-space: pre-wrap; }
</style></head><body style=" font-family:'Sans'; font-size:10pt; font-weight:400; font-style:normal;">
<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-family:'Verdana';">© QGIS 2009</span></p></body></html></source>
+ <translation><!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><meta name="qrichtext" content="1" /><style type="text/css">
+p, li { white-space: pre-wrap; }
+</style></head><body style=" font-family:'Sans'; font-size:10pt; font-weight:400; font-style:normal;">
+<p style=" margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-family:'Verdana';">© QGIS 2009</span></p></body></html></translation>
</message>
<message>
<location filename="../src/plugins/copyright_label/pluginguibase.ui" line="56"/>
@@ -15401,72 +15405,72 @@
<location filename="../src/gui/symbology-ng/qgsgraduatedsymbolrendererv2widget.cpp" line="171"/>
<location filename="../src/gui/symbology-ng/qgsgraduatedsymbolrendererv2widget.cpp" line="173"/>
</message>
<message>
</message>
<message>
</message>
<message>
<location filename="../src/ui/qgsgraduatedsymbolrendererv2widget.ui" line="19"/>
</message>
<message>
<location filename="../src/ui/qgsgraduatedsymbolrendererv2widget.ui" line="29"/>
</message>
<message>
<location filename="../src/ui/qgsgraduatedsymbolrendererv2widget.ui" line="42"/>
</message>
<message>
<location filename="../src/ui/qgsgraduatedsymbolrendererv2widget.ui" line="49"/>
<source>Classes:</source>
</message>
<message>
<location filename="../src/ui/qgsgraduatedsymbolrendererv2widget.ui" line="72"/>
</message>
<message>
<location filename="../src/ui/qgsgraduatedsymbolrendererv2widget.ui" line="82"/>
<source>Mode:</source>
- <translation type="unfinished">Mode:</translation>
+ <translation>Mode :</translation>
</message>
<message>
<location filename="../src/ui/qgsgraduatedsymbolrendererv2widget.ui" line="93"/>
<source>Equal Interval</source>
- <translation type="unfinished">Intervalle égal</translation>
+ <translation>Intervalles égaux</translation>
</message>
<message>
<location filename="../src/ui/qgsgraduatedsymbolrendererv2widget.ui" line="98"/>
<source>Quantile</source>
+ <translation>Quantiles</translation>
</message>
<message>
<location filename="../src/ui/qgsgraduatedsymbolrendererv2widget.ui" line="130"/>
</message>
<message>
<location filename="../src/ui/qgsgraduatedsymbolrendererv2widget.ui" line="137"/>
<source>Add class</source>
- <translation type="unfinished">Ajouter une classe</translation>
+ <translation>Ajouter une classe</translation>
</message>
<message>
<location filename="../src/ui/qgsgraduatedsymbolrendererv2widget.ui" line="144"/>
<source>Delete class</source>
+ <translation>Effacer la classe</translation>
</message>
</context>
<context>
@@ -18869,14 +18873,14 @@
<location filename="../src/app/qgsidentifyresults.cpp" line="250"/>
<location filename="../src/app/qgsidentifyresults.cpp" line="339"/>
<source>Edit feature form</source>
+ <translation>Éditer le formulaire de l'entité</translation>
</message>
<message>
<location filename="../src/app/qgsidentifyresults.cpp" line="197"/>
<source>View feature form</source>
+ <translation>Afficher le formulaire de l'entité</translation>
</message>
<message>
<location filename="../src/app/qgsidentifyresults.cpp" line="340"/>
@@ -18916,7 +18920,7 @@
<message>
<location filename="../src/app/qgsidentifyresults.cpp" line="729"/>
<source>Run actions</source>
+ <translation>Exécuter une action</translation>
</message>
<message>
<location filename="../src/app/qgsidentifyresults.cpp" line="181"/>
@@ -19471,17 +19475,17 @@
<message>
<location filename="../src/ui/qgslabeldialogbase.ui" line="46"/>
<source>Basic label options</source>
+ <translation>Options basiques des étiquettes</translation>
</message>
<message>
<location filename="../src/ui/qgslabeldialogbase.ui" line="498"/>
<source>Data defined placement</source>
+ <translation>Emplacement défini des données</translation>
</message>
<message>
<location filename="../src/ui/qgslabeldialogbase.ui" line="539"/>
<source>Data defined properties</source>
+ <translation>Propriétés définies des données</translation>
</message>
<message>
<location filename="../src/ui/qgslabeldialogbase.ui" line="551"/>
@@ -20034,7 +20038,7 @@
<message>
<location filename="../src/plugins/diagram_overlay/qgslinearlyscalingdialogbase.ui" line="23"/>
<source>Scale linearly between 0 and the following attribute value / diagram size:</source>
+ <translation>Mettre à l'échelle linéairement entre 0 et la valeur suivante / taille du diagramme :</translation>
</message>
<message>
<location filename="../src/plugins/diagram_overlay/qgslinearlyscalingdialogbase.ui" line="35"/>
@@ -21089,22 +21093,22 @@
<message>
<location filename="../python/plugins/mapserver_export/qgsmapserverexportbase.ui" line="15"/>
<source>MapServer Export: Save project to MapFile</source>
+ <translation>Export MapServer : Enregistrer le projet dans un MapFile</translation>
</message>
<message>
<location filename="../python/plugins/mapserver_export/qgsmapserverexportbase.ui" line="24"/>
<source>Use current project</source>
+ <translation>Utiliser le projet courant</translation>
</message>
<message>
<location filename="../python/plugins/mapserver_export/qgsmapserverexportbase.ui" line="87"/>
<source>LAYER information only</source>
+ <translation>que les informations de la couche</translation>
</message>
<message>
<location filename="../python/plugins/mapserver_export/qgsmapserverexportbase.ui" line="142"/>
<source>Rendering</source>
- <translation type="unfinished">Rendu</translation>
+ <translation>Rendu</translation>
</message>
<message>
<location filename="../python/plugins/mapserver_export/qgsmapserverexportbase.ui" line="204"/>
@@ -21248,7 +21252,10 @@
For example:
http://my.host.com/cgi-bin/mapserv.exe</source>
+ <translation>L'adresse de l'exécutable MapServer
+Par Exemple :
+http://my.host.com/cgi-bin/mapserv.exe</translation>
</message>
<message>
<location filename="../python/plugins/mapserver_export/qgsmapserverexportbase.ui" line="239"/>
@@ -21258,12 +21265,12 @@
<message>
<location filename="../python/plugins/mapserver_export/qgsmapserverexportbase.ui" line="258"/>
<source>Symbolset</source>
+ <translation>Jeu de symboles</translation>
</message>
<message>
<location filename="../python/plugins/mapserver_export/qgsmapserverexportbase.ui" line="271"/>
<source>Use templates</source>
+ <translation>Utiliser les modèles</translation>
</message>
<message>
<location filename="../python/plugins/mapserver_export/qgsmapserverexportbase.ui" line="281"/>
@@ -21273,22 +21280,22 @@
<message>
<location filename="../python/plugins/mapserver_export/qgsmapserverexportbase.ui" line="335"/>
<source>The file name of the fonts file.</source>
+ <translation>Nom du fichier de police.</translation>
</message>
<message>
<location filename="../python/plugins/mapserver_export/qgsmapserverexportbase.ui" line="354"/>
<source>Fontset</source>
+ <translation>Jeu de polices</translation>
</message>
<message>
<location filename="../python/plugins/mapserver_export/qgsmapserverexportbase.ui" line="367"/>
<source>The file name of the symbols file.</source>
+ <translation>Nom de fichiers des symboles</translation>
</message>
<message>
<location filename="../python/plugins/mapserver_export/qgsmapserverexportbase.ui" line="450"/>
<source>Layer/label options</source>
+ <translation>Options des étiquettes/couches</translation>
</message>
<message>
<location filename="../python/plugins/mapserver_export/qgsmapserverexportbase.ui" line="116"/>
@@ -21391,7 +21398,7 @@
<message>
<location filename="../src/app/qgsmeasuredialog.cpp" line="39"/>
<source>&New</source>
- <translation type="unfinished">&Nouveau</translation>
+ <translation>&Nouveau</translation>
</message>
<message>
<location filename="../src/app/qgsmeasuredialog.cpp" line="202"/>
@@ -22030,7 +22037,7 @@
<message>
<location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="208"/>
<source>Remove selected attribute</source>
+ <translation>Effacer l'attribut sélectionné</translation>
</message>
<message>
<location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="241"/>
@@ -22045,18 +22052,18 @@
<message>
<location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="274"/>
<source>CRS ID</source>
+ <translation>SCR ID</translation>
</message>
<message>
<location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="291"/>
<location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="294"/>
<source>Specify the coordinate reference system of the layer's geometry.</source>
- <translation type="unfinished">Spécifier le système de coordonnées de référence de la géométrie de la couche.</translation>
+ <translation>Spécifier le système de coordonnées de référence de la géométrie de la couche.</translation>
</message>
<message>
<location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="297"/>
<source>Specify CRS</source>
- <translation type="unfinished">Spécifier le SCR</translation>
+ <translation>Spécifier le SCR</translation>
</message>
<message>
<location filename="../src/ui/qgsnewvectorlayerdialogbase.ui" line="141"/>
@@ -23080,7 +23087,7 @@
<message>
<location filename="../src/ui/qgsoptionsbase.ui" line="1314"/>
<source>General</source>
- <translation type="unfinished">Général</translation>
+ <translation>Général</translation>
</message>
<message>
<source>Ask to save project changes when required</source>
@@ -23273,12 +23280,12 @@
<message>
<location filename="../src/ui/qgsoptionsbase.ui" line="361"/>
<source>Compatibility</source>
+ <translation>Compatibilité</translation>
</message>
<message>
<location filename="../src/ui/qgsoptionsbase.ui" line="367"/>
<source>Use new generation symbology for rendering</source>
+ <translation>Utiliser la nouvelle génération de symbologie pour le rendu</translation>
</message>
<message>
<location filename="../src/ui/qgsoptionsbase.ui" line="417"/>
@@ -23293,7 +23300,7 @@
<message>
<location filename="../src/ui/qgsoptionsbase.ui" line="499"/>
<source>Open feature form, if a single feature is identified</source>
+ <translation>Ouvrir le formulaire si une seule entité est identifiée</translation>
</message>
<message>
<location filename="../src/ui/qgsoptionsbase.ui" line="560"/>
@@ -23323,12 +23330,12 @@
<message>
<location filename="../src/ui/qgsoptionsbase.ui" line="1356"/>
<source>Digitising</source>
+ <translation>Numérisation</translation>
</message>
<message>
<location filename="../src/ui/qgsoptionsbase.ui" line="1383"/>
<source>Network & Proxy</source>
+ <translation>Réseau et Proxy</translation>
</message>
<message>
<location filename="../src/ui/qgsoptionsbase.ui" line="447"/>
@@ -23401,7 +23408,7 @@
<message>
<location filename="../src/ui/qgsoptionsbase.ui" line="977"/>
<source>Default Coordinate Reference System</source>
+ <translation>Système de coordonnées de référence par défaut</translation>
</message>
<message>
<location filename="../src/ui/qgsoptionsbase.ui" line="986"/>
@@ -23540,12 +23547,12 @@
<message>
<location filename="../src/ui/qgsoptionsbase.ui" line="1326"/>
<source>Rendering & SVG</source>
+ <translation>Rendu et SVG</translation>
</message>
<message>
<location filename="../src/ui/qgsoptionsbase.ui" line="1338"/>
<source>Map tools</source>
+ <translation>Outils cartographiques</translation>
</message>
<message>
<location filename="../src/ui/qgsoptionsbase.ui" line="1347"/>
@@ -23701,17 +23708,17 @@
<message>
<location filename="../src/gui/symbology-ng/qgspenstylecombobox.cpp" line="93"/>
<source>Square</source>
+ <translation>Carré</translation>
</message>
<message>
<location filename="../src/gui/symbology-ng/qgspenstylecombobox.cpp" line="94"/>
<source>Flat</source>
+ <translation>Plat</translation>
</message>
<message>
<location filename="../src/gui/symbology-ng/qgspenstylecombobox.cpp" line="95"/>
<source>Round</source>
+ <translation>Rond</translation>
</message>
</context>
<context>
@@ -23719,7 +23726,7 @@
<message>
<location filename="../src/gui/symbology-ng/qgspenstylecombobox.cpp" line="69"/>
<source>Bevel</source>
+ <translation>Oblique</translation>
</message>
<message>
<location filename="../src/gui/symbology-ng/qgspenstylecombobox.cpp" line="70"/>
@@ -23729,7 +23736,7 @@
<message>
<location filename="../src/gui/symbology-ng/qgspenstylecombobox.cpp" line="71"/>
</message>
</context>
<context>
@@ -26721,12 +26728,12 @@
<message>
<location filename="../src/ui/qgspythondialog.ui" line="50"/>
<source>E&xecute</source>
+ <translation>E&xécuter</translation>
</message>
<message>
<location filename="../src/ui/qgspythondialog.ui" line="57"/>
<source>&Eval</source>
+ <translation>&Évaluer</translation>
</message>
<message>
<location filename="../src/ui/qgspythondialog.ui" line="64"/>
@@ -26740,7 +26747,11 @@
</style></head><body style=" font-family:'MS Shell Dlg 2'; font-size:8.25pt; font-weight:400; font-style:normal;">
<p style="-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif'; font-size:9pt;"></p></body></html></source>
+</style></head><body style=" font-family:'MS Shell Dlg 2'; font-size:8.25pt; font-weight:400; font-style:normal;">
+<p style="-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif'; font-size:9pt;"></p></body></html></translation>
</message>
</context>
<context>
@@ -28680,7 +28691,11 @@
</style></head><body style=" font-family:'DejaVu Sans'; font-size:10pt; font-weight:400; font-style:normal;">
+</style></head><body style=" font-family:'DejaVu Sans'; font-size:10pt; font-weight:400; font-style:normal;">
</message>
<message>
<location filename="../src/ui/qgsrasterlayerpropertiesbase.ui" line="1854"/>
@@ -28815,12 +28830,12 @@
<message>
<location filename="../src/gui/symbology-ng/qgsrendererv2propertiesdialog.cpp" line="175"/>
<source>Symbology</source>
+ <translation>Convention des signes</translation>
</message>
<message>
<location filename="../src/gui/symbology-ng/qgsrendererv2propertiesdialog.cpp" line="176"/>
<source>Do you wish to use original symbology implementation for this layer?</source>
+ <translation>Souhaitez-vous utiliser l'ancienne implémentation de la symbologie pour cette couche ?</translation>
</message>
</context>
<context>
@@ -28828,27 +28843,27 @@
<message>
<location filename="../src/ui/qgsrendererv2propsdialogbase.ui" line="14"/>
<source>Renderer settings</source>
+ <translation>Paramètres de rendu</translation>
</message>
<message>
<location filename="../src/ui/qgsrendererv2propsdialogbase.ui" line="22"/>
<source>Renderer:</source>
+ <translation>Rendu :</translation>
</message>
<message>
<location filename="../src/ui/qgsrendererv2propsdialogbase.ui" line="45"/>
<source>Symbol levels</source>
+ <translation>Niveaux de symbole :</translation>
</message>
<message>
<location filename="../src/ui/qgsrendererv2propsdialogbase.ui" line="52"/>
<source>Old symbology</source>
+ <translation>Ancienne symbologie</translation>
</message>
<message>
<location filename="../src/ui/qgsrendererv2propsdialogbase.ui" line="77"/>
<source>This renderer doesn't implement a graphical interface.</source>
+ <translation>Ce rendu ne créé pas d'interface graphique</translation>
</message>
</context>
<context>
@@ -28979,7 +28994,7 @@
<message>
<location filename="../src/plugins/diagram_overlay/qgssvgdiagramfactorywidgetbase.ui" line="126"/>
</message>
<message>
<source>Browse...</source>
@@ -29948,7 +29963,7 @@
<message>
<location filename="../src/providers/spatialite/qgsspatialiteprovider.cpp" line="1461"/>
<source>invalid metadata tables</source>
+ <translation>Tables de métadonnées invalides</translation>
</message>
</context>
<context>
@@ -29956,7 +29971,7 @@
<message>
<location filename="../src/app/qgsspatialitesourceselect.cpp" line="44"/>
<source>&Add</source>
+ <translation>&Ajouter</translation>
</message>
<message>
<location filename="../src/app/qgsspatialitesourceselect.cpp" line="51"/>
@@ -30800,27 +30815,27 @@
<message>
<location filename="../src/ui/qgsstylev2managerdialogbase.ui" line="14"/>
<source>Style Manager</source>
+ <translation>Gestionnaire de style :</translation>
</message>
<message>
<location filename="../src/ui/qgsstylev2managerdialogbase.ui" line="20"/>
<source>Style item type:</source>
+ <translation>Style par type d'objets :</translation>
</message>
<message>
<location filename="../src/ui/qgsstylev2managerdialogbase.ui" line="57"/>
<source>Add item</source>
+ <translation>Ajouter objet</translation>
</message>
<message>
<location filename="../src/ui/qgsstylev2managerdialogbase.ui" line="64"/>
<source>Edit item</source>
+ <translation>Éditer objet</translation>
</message>
<message>
<location filename="../src/ui/qgsstylev2managerdialogbase.ui" line="71"/>
<source>Remove item</source>
+ <translation>Supprimer objet</translation>
</message>
</context>
<context>
@@ -30828,12 +30843,12 @@
<message>
<location filename="../src/ui/qgssymbollevelsv2dialogbase.ui" line="14"/>
<source>Symbol Levels</source>
+ <translation>Niveaux de symbole</translation>
</message>
<message>
<location filename="../src/ui/qgssymbollevelsv2dialogbase.ui" line="20"/>
<source>Enable symbol levels</source>
+ <translation>Activer les niveaux de symbole</translation>
</message>
</context>
<context>
@@ -30841,56 +30856,56 @@
<message>
<location filename="../src/ui/qgssymbolv2selectordialogbase.ui" line="14"/>
<source>Symbol selector</source>
+ <translation>Sélection de symbole</translation>
</message>
<message>
<location filename="../src/ui/qgssymbolv2selectordialogbase.ui" line="57"/>
<location filename="../src/ui/qgssymbolv2selectordialogbase.ui" line="115"/>
<location filename="../src/ui/qgssymbolv2selectordialogbase.ui" line="150"/>
</message>
<message>
<location filename="../src/ui/qgssymbolv2selectordialogbase.ui" line="64"/>
<location filename="../src/ui/qgssymbolv2selectordialogbase.ui" line="122"/>
<location filename="../src/ui/qgssymbolv2selectordialogbase.ui" line="157"/>
<source>Change</source>
+ <translation>Changer</translation>
</message>
<message>
<location filename="../src/ui/qgssymbolv2selectordialogbase.ui" line="71"/>
</message>
<message>
<location filename="../src/ui/qgssymbolv2selectordialogbase.ui" line="88"/>
</message>
<message utf8="true">
<location filename="../src/ui/qgssymbolv2selectordialogbase.ui" line="95"/>
<source>°</source>
+ <translation>°</translation>
</message>
<message>
<location filename="../src/ui/qgssymbolv2selectordialogbase.ui" line="129"/>
<source>Width</source>
- <translation type="unfinished">Largeur</translation>
</message>
<message>
<location filename="../src/ui/qgssymbolv2selectordialogbase.ui" line="172"/>
<source>Properties</source>
- <translation type="unfinished">Propriétés</translation>
+ <translation>Propriétés</translation>
</message>
<message>
<location filename="../src/ui/qgssymbolv2selectordialogbase.ui" line="192"/>
<source>Add to style</source>
+ <translation>Ajouter au style</translation>
</message>
<message>
<location filename="../src/ui/qgssymbolv2selectordialogbase.ui" line="201"/>
<source>Symbols from style:</source>
+ <translation>Symbole du style :</translation>
</message>
</context>
<context>
@@ -31054,22 +31069,22 @@
<message>
<location filename="../src/ui/qgsvectorcolorbrewercolorrampv2dialogbase.ui" line="14"/>
<source>ColorBrewer ramp</source>
+ <translation>Rampe du mélangeur de couleur</translation>
</message>
<message>
<location filename="../src/ui/qgsvectorcolorbrewercolorrampv2dialogbase.ui" line="22"/>
<source>Scheme name:</source>
+ <translation>Nom du schéma :</translation>
</message>
<message>
<location filename="../src/ui/qgsvectorcolorbrewercolorrampv2dialogbase.ui" line="45"/>
<source>Colors:</source>
+ <translation>Couleurs :</translation>
</message>
<message>
<location filename="../src/ui/qgsvectorcolorbrewercolorrampv2dialogbase.ui" line="76"/>
<source>Preview</source>
- <translation type="unfinished">Aperçu</translation>
+ <translation>Aperçu</translation>
</message>
</context>
<context>
@@ -31077,28 +31092,28 @@
<message>
<location filename="../src/ui/qgsvectorgradientcolorrampv2dialogbase.ui" line="14"/>
<source>Gradient color ramp</source>
+ <translation>Rampe de couleurs graduées</translation>
</message>
<message>
<location filename="../src/ui/qgsvectorgradientcolorrampv2dialogbase.ui" line="22"/>
<source>Color 1:</source>
+ <translation>Couleur 1 :</translation>
</message>
<message>
<location filename="../src/ui/qgsvectorgradientcolorrampv2dialogbase.ui" line="29"/>
<location filename="../src/ui/qgsvectorgradientcolorrampv2dialogbase.ui" line="59"/>
</message>
<message>
<location filename="../src/ui/qgsvectorgradientcolorrampv2dialogbase.ui" line="52"/>
<source>Color 2:</source>
+ <translation>Couleur 2 :</translation>
</message>
<message>
<location filename="../src/ui/qgsvectorgradientcolorrampv2dialogbase.ui" line="84"/>
</message>
</context>
<context>
@@ -31773,12 +31788,12 @@
<message>
<location filename="../src/app/qgsvectorlayerproperties.cpp" line="535"/>
</message>
<message>
<location filename="../src/app/qgsvectorlayerproperties.cpp" line="536"/>
</message>
<message>
<location filename="../src/app/qgsvectorlayerproperties.cpp" line="735"/>
@@ -31829,22 +31844,22 @@
<message>
<location filename="../src/app/qgsvectorlayerproperties.cpp" line="1065"/>
<source>Select edit form</source>
+ <translation>Sélectionnez le formulaire d'édition</translation>
</message>
<message>
<source>UI file (*.ui)</source>
+ <translation>fichier UI (*.ui)</translation>
</message>
<message>
<location filename="../src/app/qgsvectorlayerproperties.cpp" line="1121"/>
+ <translation>Convention des signes/symbologie</translation>
</message>
<message>
<location filename="../src/app/qgsvectorlayerproperties.cpp" line="1122"/>
</message>
<message>
<source>Unknown style format: %1</source>
@@ -32050,17 +32065,17 @@
<message>
<location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="476"/>
<source>Edit UI</source>
+ <translation>Éditer UI</translation>
</message>
<message>
<location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="488"/>
</message>
<message>
<location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="527"/>
<source>Init function</source>
+ <translation>Fonction Init</translation>
</message>
<message>
<location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="549"/>
@@ -32084,7 +32099,7 @@
<message>
<location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="252"/>
<source>New symbology</source>
+ <translation>Nouvelle symbologie</translation>
</message>
<message>
<location filename="../src/ui/qgsvectorlayerpropertiesbase.ui" line="305"/>
@@ -32123,46 +32138,46 @@
<message>
<location filename="../src/ui/qgsvectorrandomcolorrampv2dialogbase.ui" line="14"/>
<source>Random color ramp</source>
+ <translation>Rampe de couleurs aléatoires</translation>
</message>
<message>
<location filename="../src/ui/qgsvectorrandomcolorrampv2dialogbase.ui" line="22"/>
<source>Hue</source>
+ <translation>Teinte</translation>
</message>
<message>
<location filename="../src/ui/qgsvectorrandomcolorrampv2dialogbase.ui" line="29"/>
<location filename="../src/ui/qgsvectorrandomcolorrampv2dialogbase.ui" line="67"/>
<location filename="../src/ui/qgsvectorrandomcolorrampv2dialogbase.ui" line="105"/>
<source>from</source>
+ <translation>de</translation>
</message>
<message>
<location filename="../src/ui/qgsvectorrandomcolorrampv2dialogbase.ui" line="43"/>
<location filename="../src/ui/qgsvectorrandomcolorrampv2dialogbase.ui" line="81"/>
<location filename="../src/ui/qgsvectorrandomcolorrampv2dialogbase.ui" line="119"/>
<source>to</source>
+ <translation>à</translation>
</message>
<message>
<location filename="../src/ui/qgsvectorrandomcolorrampv2dialogbase.ui" line="60"/>
<source>Saturation</source>
+ <translation>Saturation</translation>
</message>
<message>
<location filename="../src/ui/qgsvectorrandomcolorrampv2dialogbase.ui" line="98"/>
<source>Value</source>
- <translation type="unfinished">Valeur</translation>
+ <translation>Valeur</translation>
</message>
<message>
<location filename="../src/ui/qgsvectorrandomcolorrampv2dialogbase.ui" line="140"/>
<source>Classes</source>
+ <translation>Classes</translation>
</message>
<message>
<location filename="../src/ui/qgsvectorrandomcolorrampv2dialogbase.ui" line="194"/>
</message>
</context>
<context>
@@ -32390,12 +32405,12 @@
<message>
<location filename="../src/plugins/diagram_overlay/qgswkndiagramfactorywidgetbase.ui" line="50"/>
</message>
<message>
<location filename="../src/plugins/diagram_overlay/qgswkndiagramfactorywidgetbase.ui" line="57"/>
</message>
<message>
<location filename="../src/plugins/diagram_overlay/qgswkndiagramfactorywidgetbase.ui" line="68"/>
@@ -32417,7 +32432,7 @@
<message>
<location filename="../src/app/qgswmssourceselect.cpp" line="60"/>
</message>
<message>
<location filename="../src/app/qgswmssourceselect.cpp" line="200"/>
@@ -33418,17 +33433,17 @@
<message>
<location filename="../src/ui/symbollayer/widget_linedecoration.ui" line="14"/>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_linedecoration.ui" line="22"/>
<source>Color:</source>
- <translation type="unfinished">Couleur:</translation>
+ <translation>Couleur :</translation>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_linedecoration.ui" line="35"/>
</message>
</context>
<context>
@@ -33436,32 +33451,32 @@
<message>
<location filename="../src/ui/symbollayer/widget_markerline.ui" line="14"/>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_markerline.ui" line="22"/>
<source>Marker:</source>
+ <translation>Marqueur :</translation>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_markerline.ui" line="29"/>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_markerline.ui" line="52"/>
<source>Marker interval:</source>
+ <translation>Intervalle :</translation>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_markerline.ui" line="59"/>
<source>Rotate marker</source>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_markerline.ui" line="66"/>
<source>Line offset:</source>
+ <translation>Décalage de la ligne :</translation>
</message>
</context>
<context>
@@ -33469,38 +33484,38 @@
<message>
<location filename="../src/ui/symbollayer/widget_simplefill.ui" line="14"/>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_simplefill.ui" line="22"/>
+ <translation>Couleur:</translation>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_simplefill.ui" line="29"/>
<location filename="../src/ui/symbollayer/widget_simplefill.ui" line="59"/>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_simplefill.ui" line="52"/>
<source>Border color:</source>
+ <translation>Couleur de la bordure</translation>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_simplefill.ui" line="69"/>
<source>Fill style:</source>
- <translation type="unfinished"></translation>
+ <translation>Style de remplissage :</translation>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_simplefill.ui" line="76"/>
<source>Border style:</source>
+ <translation>Style de la bordure :</translation>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_simplefill.ui" line="86"/>
<source>Border width:</source>
+ <translation>Largeur de bordure :</translation>
</message>
</context>
<context>
@@ -33508,42 +33523,42 @@
<message>
<location filename="../src/ui/symbollayer/widget_simpleline.ui" line="14"/>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_simpleline.ui" line="22"/>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_simpleline.ui" line="35"/>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_simpleline.ui" line="58"/>
<source>Pen width:</source>
- <translation type="unfinished">Largeur du crayon :</translation>
+ <translation>Largeur du crayon :</translation>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_simpleline.ui" line="65"/>
<source>Pen style:</source>
+ <translation>Style de crayon :</translation>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_simpleline.ui" line="75"/>
<source>Offset:</source>
+ <translation>Décalage :</translation>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_simpleline.ui" line="131"/>
<source>Join style:</source>
+ <translation>Style de jointure :</translation>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_simpleline.ui" line="157"/>
<source>Cap style:</source>
+ <translation>Style de cap :</translation>
</message>
</context>
<context>
@@ -33551,38 +33566,38 @@
<message>
<location filename="../src/ui/symbollayer/widget_simplemarker.ui" line="14"/>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_simplemarker.ui" line="22"/>
+ <translation>Couleur de la bordure :</translation>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_simplemarker.ui" line="29"/>
<location filename="../src/ui/symbollayer/widget_simplemarker.ui" line="59"/>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_simplemarker.ui" line="52"/>
<source>Fill color:</source>
+ <translation>Couleur de remplissage :</translation>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_simplemarker.ui" line="66"/>
<source>Size:</source>
- <translation type="unfinished">Taille:</translation>
+ <translation>Taille:</translation>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_simplemarker.ui" line="73"/>
<source>Angle:</source>
+ <translation>Angle</translation>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_simplemarker.ui" line="93"/>
<source>Offset X,Y:</source>
+ <translation>Décalage X,Y :</translation>
</message>
</context>
<context>
@@ -33590,27 +33605,27 @@
<message>
<location filename="../src/ui/symbollayer/widget_svgmarker.ui" line="14"/>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_svgmarker.ui" line="28"/>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_svgmarker.ui" line="48"/>
+ <translation>Angle :</translation>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_svgmarker.ui" line="92"/>
</message>
<message>
<location filename="../src/ui/symbollayer/widget_svgmarker.ui" line="117"/>
<source>SVG Image:</source>
+ <translation>Image SVG</translation>
</message>
</context>
<context>
