[QGIS Commit] r11572 - in trunk/qgis: python/core src/app src/core
src/core/raster src/ui
svn_qgis at osgeo.org
Sat Sep 5 15:49:47 EDT 2009
Author: jef
Date: 2009-09-05 15:49:47 -0400 (Sat, 05 Sep 2009)
New Revision: 11572
trunk/qgis/python/core/qgsrect.sip
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/app/qgsidentifyresults.cpp
trunk/qgis/src/app/qgsidentifyresults.h
trunk/qgis/src/app/qgsmaptoolidentify.cpp
trunk/qgis/src/app/qgsmaptoolidentify.h
trunk/qgis/src/app/qgsoptions.cpp
trunk/qgis/src/app/qgsprojectproperties.cpp
trunk/qgis/src/core/qgsrectangle.cpp
trunk/qgis/src/core/qgsrectangle.h
trunk/qgis/src/core/raster/qgsrasterlayer.cpp
trunk/qgis/src/ui/qgsoptionsbase.ui
trunk/qgis/src/ui/qgsprojectpropertiesbase.ui
[FEATURE] multi-layer identify
Modified: trunk/qgis/python/core/qgsrect.sip
--- trunk/qgis/python/core/qgsrect.sip 2009-09-05 19:49:10 UTC (rev 11571)
+++ trunk/qgis/python/core/qgsrect.sip 2009-09-05 19:49:47 UTC (rev 11572)
@@ -64,6 +64,9 @@
//! return true when rectangle contains other rectangle
//! @note added in version 1.1
bool contains( const QgsRectangle& rect ) const;
+ //! return true when rectangle contains a point
+ //! @note added in version 1.3
+ bool contains( const QgsPoint& p ) const;
//! expand the rectangle so that covers both the original rectangle and the given rectangle
void combineExtentWith(QgsRectangle *rect);
//! expand the rectangle so that covers both the original rectangle and the given point
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2009-09-05 19:49:10 UTC (rev 11571)
+++ trunk/qgis/src/app/qgisapp.cpp 2009-09-05 19:49:47 UTC (rev 11572)
@@ -767,7 +767,7 @@
shortcuts->registerAction( mActionIdentify, tr( "Ctrl+Shift+I", "Click on features to identify them" ) );
mActionIdentify->setStatusTip( tr( "Click on features to identify them" ) );
connect( mActionIdentify, SIGNAL( triggered() ), this, SLOT( identify() ) );
- mActionIdentify->setEnabled( false );
+ mActionIdentify->setEnabled( QSettings().value( "/Map/identifyMode", 0 ).toInt() != 0 );
mActionMeasure = new QAction( getThemeIcon( "mActionMeasure.png" ), tr( "Measure Line " ), this );
shortcuts->registerAction( mActionMeasure, tr( "Ctrl+Shift+M", "Measure a Line" ) );
@@ -5542,7 +5542,7 @@
if ( !layer )
mActionSelect->setEnabled( false );
mActionZoomActualSize->setEnabled( false );
mActionOpenTable->setEnabled( false );
mActionToggleEditing->setEnabled( false );
@@ -5785,19 +5785,25 @@
//Enable the Identify tool ( GDAL datasets draw without a provider )
//but turn off if data provider exists and has no Identify capabilities
mActionIdentify->setEnabled( true );
- const QgsRasterLayer* vlayer = dynamic_cast<const QgsRasterLayer*>( layer );
- const QgsRasterDataProvider* dprovider = vlayer->dataProvider();
- if ( dprovider )
+ QSettings settings;
+ int identifyMode = settings.value( "/Map/identifyMode", 0 ).toInt();
+ if ( identifyMode == 0 )
- // does provider allow the identify map tool?
- if ( dprovider->capabilities() & QgsRasterDataProvider::Identify )
+ const QgsRasterLayer *rlayer = dynamic_cast<const QgsRasterLayer*>( layer );
+ const QgsRasterDataProvider* dprovider = rlayer->dataProvider();
+ if ( dprovider )
- mActionIdentify->setEnabled( TRUE );
+ // does provider allow the identify map tool?
+ if ( dprovider->capabilities() & QgsRasterDataProvider::Identify )
+ mActionIdentify->setEnabled( true );
+ else
+ mActionIdentify->setEnabled( false );
- else
- mActionIdentify->setEnabled( FALSE );
Modified: trunk/qgis/src/app/qgsidentifyresults.cpp
--- trunk/qgis/src/app/qgsidentifyresults.cpp 2009-09-05 19:49:10 UTC (rev 11571)
+++ trunk/qgis/src/app/qgsidentifyresults.cpp 2009-09-05 19:49:47 UTC (rev 11572)
@@ -21,6 +21,12 @@
#include "qgscontexthelp.h"
#include "qgsapplication.h"
#include "qgisapp.h"
+#include "qgsmaplayer.h"
+#include "qgsvectorlayer.h"
+#include "qgsrubberband.h"
+#include "qgsgeometry.h"
+#include "qgsattributedialog.h"
+#include "qgsmapcanvas.h"
#include <QCloseEvent>
#include <QLabel>
@@ -33,13 +39,25 @@
#include "qgslogger.h"
-QgsIdentifyResults::QgsIdentifyResults( const QgsAttributeAction& actions,
- QWidget *parent, Qt::WFlags f )
+// Tree hierachy
+// layer [userrole: QgsMapLayer]
+// feature: displayfield|displayvalue [userrole: fid]
+// derived attributes
+// name value
+// name value
+// name value
+// name value
+// feature
+// name value
+// name value
+QgsIdentifyResults::QgsIdentifyResults( QgsMapCanvas *canvas, QWidget *parent, Qt::WFlags f )
: QDialog( parent, f ),
- mActions( actions ),
- mClickedOnValue( 0 ),
mActionPopup( 0 ),
- mCurrentFeatureId( 0 )
+ mRubberBand( 0 ),
+ mCanvas( canvas )
setupUi( this );
lstResults->setColumnCount( 2 );
@@ -48,16 +66,12 @@
connect( buttonCancel, SIGNAL( clicked() ),
this, SLOT( close() ) );
- connect( lstResults, SIGNAL( itemClicked( QTreeWidgetItem*, int ) ),
- this, SLOT( clicked( QTreeWidgetItem * ) ) );
connect( lstResults, SIGNAL( itemExpanded( QTreeWidgetItem* ) ),
this, SLOT( itemExpanded( QTreeWidgetItem* ) ) );
connect( lstResults, SIGNAL( currentItemChanged( QTreeWidgetItem*, QTreeWidgetItem* ) ),
this, SLOT( handleCurrentItemChanged( QTreeWidgetItem*, QTreeWidgetItem* ) ) );
- // The label to use for the Derived node in the identify results
- mDerivedLabel = tr( "(Derived)" );
QgsIdentifyResults::~QgsIdentifyResults()
@@ -65,6 +79,58 @@
delete mActionPopup;
+QTreeWidgetItem *QgsIdentifyResults::layerItem( QObject *layer )
+ QTreeWidgetItem *item;
+ for ( int i = 0; i < lstResults->topLevelItemCount(); i++ )
+ item = lstResults->topLevelItem( i );
+ if ( item->data( 0, Qt::UserRole ).value<QObject*>() == layer )
+ return item;
+ return 0;
+void QgsIdentifyResults::addFeature( QgsMapLayer *layer, int fid,
+ QString displayField, QString displayValue,
+ const QMap<QString, QString> &attributes,
+ const QMap<QString, QString> &derivedAttributes )
+ QTreeWidgetItem *item = layerItem( layer );
+ if ( item == 0 )
+ item = new QTreeWidgetItem( QStringList() << layer->name() << tr( "Layer" ) );
+ item->setData( 0, Qt::UserRole, QVariant::fromValue( dynamic_cast<QObject*>( layer ) ) );
+ lstResults->addTopLevelItem( item );
+ connect( layer, SIGNAL( destroyed() ), this, SLOT( layerDestroyed() ) );
+ QTreeWidgetItem *featItem = new QTreeWidgetItem( QStringList() << displayField << displayValue );
+ featItem->setData( 0, Qt::UserRole, fid );
+ for ( QMap<QString, QString>::const_iterator it = attributes.begin(); it != attributes.end(); it++ )
+ featItem->addChild( new QTreeWidgetItem( QStringList() << it.key() << it.value() ) );
+ if ( derivedAttributes.size() >= 0 )
+ QTreeWidgetItem *derivedItem = new QTreeWidgetItem( QStringList() << tr( "(Derived)" ) );
+ featItem->addChild( derivedItem );
+ for ( QMap< QString, QString>::const_iterator it = derivedAttributes.begin(); it != derivedAttributes.end(); it++ )
+ derivedItem->addChild( new QTreeWidgetItem( QStringList() << it.key() << it.value() ) );
+ item->addChild( featItem );
// Call to show the dialog box.
void QgsIdentifyResults::show()
@@ -96,16 +162,30 @@
void QgsIdentifyResults::contextMenuEvent( QContextMenuEvent* event )
- QTreeWidgetItem* item = lstResults->itemAt( lstResults->viewport()->mapFrom( this, event->pos() ) );
+ QTreeWidgetItem *item = lstResults->itemAt( lstResults->viewport()->mapFrom( this, event->pos() ) );
// if the user clicked below the end of the attribute list, just return
- if ( item == NULL )
+ if ( !item )
return;
if ( mActionPopup == 0 )
+ QgsVectorLayer *vlayer = vectorLayer( item );
+ if ( vlayer == 0 )
+ return;
+ QgsAttributeAction *actions = vlayer->actions();
mActionPopup = new QMenu();
QAction *a;
+ if ( vlayer->isEditable() )
+ a = mActionPopup->addAction( tr( "Edit feature" ) );
+ a->setEnabled( true );
+ a->setData( QVariant::fromValue( -3 ) );
a = mActionPopup->addAction( tr( "Copy attribute value" ) );
a->setData( QVariant::fromValue( -2 ) );
@@ -114,7 +194,7 @@
a->setData( QVariant::fromValue( -1 ) );
- if ( mActions.size() > 0 )
+ if ( actions && actions->size() > 0 )
// The assumption is made that an instance of QgsIdentifyResults is
// created for each new Identify Results dialog box, and that the
@@ -124,8 +204,8 @@
a->setEnabled( false );
mActionPopup->addSeparator();
- QgsAttributeAction::aIter iter = mActions.begin();
- for ( int j = 0; iter != mActions.end(); ++iter, ++j )
+ QgsAttributeAction::aIter iter = actions->begin();
+ for ( int j = 0; iter != actions->end(); ++iter, ++j )
QAction* a = mActionPopup->addAction( iter->name() );
// The menu action stores an integer that is used later on to
@@ -134,14 +214,9 @@
- connect( mActionPopup, SIGNAL( triggered( QAction* ) ),
- this, SLOT( popupItemSelected( QAction* ) ) );
+ connect( mActionPopup, SIGNAL( triggered( QAction* ) ), this, SLOT( popupItemSelected( QAction* ) ) );
- // Save the attribute values as these are needed for substituting into
- // the action.
- extractAllItemData( item );
mActionPopup->popup( event->globalPos() );
@@ -160,75 +235,6 @@
settings.setValue( "/Windows/Identify/geometry", saveGeometry() );
-/** add an attribute and its value to the list */
-void QgsIdentifyResults::addAttribute( QTreeWidgetItem * fnode, QString field, QString value )
- QStringList labels;
- labels << field << value;
- new QTreeWidgetItem( fnode, labels );
-void QgsIdentifyResults::addAttribute( QString field, QString value )
- new QTreeWidgetItem( lstResults, labels );
-void QgsIdentifyResults::addDerivedAttribute( QTreeWidgetItem * fnode, QString field, QString value )
- QTreeWidgetItem * daRootNode;
- // Determine if this is the first derived attribute for this feature or not
- if ( mDerivedAttributeRootNodes.find( fnode ) != mDerivedAttributeRootNodes.end() )
- // Reuse existing derived-attribute root node
- daRootNode = mDerivedAttributeRootNodes[fnode];
- else
- // Create new derived-attribute root node
- daRootNode = new QTreeWidgetItem( fnode, QStringList( mDerivedLabel ) );
- QFont font = daRootNode->font( 0 );
- font.setItalic( true );
- daRootNode->setFont( 0, font );
- mDerivedAttributeRootNodes[fnode] = daRootNode;
- new QTreeWidgetItem( daRootNode, labels );
-void QgsIdentifyResults::addEdit( QTreeWidgetItem * fnode, int id )
- labels << "edit" << QString::number( id );
- QTreeWidgetItem *item = new QTreeWidgetItem( fnode, labels );
- item->setIcon( 0, QgisApp::getThemeIcon( "/mIconEditable.png" ) );
-void QgsIdentifyResults::addAction( QTreeWidgetItem * fnode, int id, QString field, QString value )
- labels << field << value << "action" << QString::number( id );
- item->setIcon( 0, QgisApp::getThemeIcon( "/mAction.png" ) );
-/** Add a feature node to the list */
-QTreeWidgetItem *QgsIdentifyResults::addNode( QString label )
- return new QTreeWidgetItem( lstResults, QStringList( label ) );
-void QgsIdentifyResults::setTitle( QString title )
- setWindowTitle( tr( "Identify Results - %1" ).arg( title ) );
void QgsIdentifyResults::setColumnText( int column, const QString & label )
QTreeWidgetItem* header = lstResults->headerItem();
@@ -238,6 +244,10 @@
// Run the action that was selected in the popup menu
void QgsIdentifyResults::popupItemSelected( QAction* menuAction )
+ QTreeWidgetItem *item = lstResults->currentItem();
+ if ( item == 0 )
+ return;
int id = menuAction->data().toInt();
if ( id < 0 )
@@ -245,13 +255,20 @@
QClipboard *clipboard = QApplication::clipboard();
QString text;
- if ( id == -2 )
+ if ( id == -3 )
- text = mValues[ mClickedOnValue ].second;
+ editFeature( item );
+ else if ( id == -2 )
+ text = item->data( 1, Qt::DisplayRole ).toString();
else
- for ( std::vector< std::pair<QString, QString> >::const_iterator it = mValues.begin(); it != mValues.end(); it++ )
+ std::vector< std::pair<QString, QString> > attributes;
+ retrieveAttributes( item, attributes );
+ for ( std::vector< std::pair<QString, QString> >::iterator it = attributes.begin(); it != attributes.end(); it++ )
text += QString( "%1: %2\n" ).arg( it->first ).arg( it->second );
@@ -262,17 +279,10 @@
else
- mActions.doAction( id, mValues, mClickedOnValue );
+ doAction( item );
-/** Expand all the identified features (show their attributes). */
-void QgsIdentifyResults::showAllAttributes()
- // Easy now with Qt 4.2...
- lstResults->expandAll();
void QgsIdentifyResults::expandColumnsToFit()
lstResults->resizeColumnToContents( 0 );
@@ -281,40 +291,86 @@
void QgsIdentifyResults::clear()
- mDerivedAttributeRootNodes.clear();
lstResults->clear();
+ if ( mRubberBand )
+ delete mRubberBand;
+ mRubberBand = 0;
-void QgsIdentifyResults::setMessage( QString shortMsg, QString longMsg )
+void QgsIdentifyResults::doAction( QTreeWidgetItem *item )
- labels << shortMsg << longMsg;
+ QTreeWidgetItem *featItem = retrieveAttributes( item, attributes );
+ if ( !featItem )
+ return;
+ int id = featItem->data( 0, Qt::UserRole ).toInt();
+ QgsVectorLayer *layer = dynamic_cast<QgsVectorLayer *>( featItem->parent()->data( 0, Qt::UserRole ).value<QObject *>() );
+ if ( !layer )
+ return;
+ layer->actions()->doAction( id, attributes, id );
-void QgsIdentifyResults::setActions( const QgsAttributeAction& actions )
+QTreeWidgetItem *QgsIdentifyResults::featureItem( QTreeWidgetItem *item )
- mActions = actions;
+ QTreeWidgetItem *featItem;
+ if ( item->parent() )
+ if ( item->parent()->parent() )
+ // attribute item
+ featItem = item->parent();
+ else
+ // feature item
+ featItem = item;
+ else
+ // layer item
+ if ( item->childCount() > 1 )
+ return 0;
+ featItem = item->child( 0 );
+ return featItem;
-void QgsIdentifyResults::clicked( QTreeWidgetItem *item )
+QgsVectorLayer *QgsIdentifyResults::vectorLayer( QTreeWidgetItem *item )
- if ( !item )
- return;
- if ( item->text( 2 ) == "action" )
- int id = item->text( 3 ).toInt();
+ item = featureItem( item )->parent();
+ return dynamic_cast<QgsVectorLayer *>( item->data( 0, Qt::UserRole ).value<QObject *>() );
- else if ( item->text( 0 ) == "edit" )
+QTreeWidgetItem *QgsIdentifyResults::retrieveAttributes( QTreeWidgetItem *item, std::vector< std::pair<QString, QString> > &attributes )
+ QTreeWidgetItem *featItem = featureItem( item );
+ attributes.clear();
+ for ( int i = 0; i < featItem->childCount(); i++ )
- emit editFeature( item->text( 1 ).toInt() );
+ QTreeWidgetItem *item = featItem->child( i );
+ if ( item->childCount() > 0 )
+ continue;
+ attributes.push_back( std::make_pair( item->data( 0, Qt::DisplayRole ).toString(), item->data( 1, Qt::DisplayRole ).toString() ) );
+ return featItem;
void QgsIdentifyResults::on_buttonHelp_clicked()
QgsContextHelp::run( context_id );
@@ -327,99 +383,94 @@
void QgsIdentifyResults::handleCurrentItemChanged( QTreeWidgetItem* current, QTreeWidgetItem* previous )
- if ( lstResults->model()->rowCount() <= 1 )
- return;
if ( current == NULL )
- mCurrentFeatureId = 0;
- emit selectedFeatureChanged( 0 );
+ emit selectedFeatureChanged( 0, 0 );
return;
- // move to node where is saved feature ID
- QTreeWidgetItem* topLevelItem = current;
- while ( topLevelItem->parent() != NULL )
- topLevelItem = topLevelItem->parent();
+ highlightFeature( current );
- QVariant fid = topLevelItem->data( 0, Qt::UserRole );
+void QgsIdentifyResults::layerDestroyed()
+ delete layerItem( sender() );
- // no data saved...
- if ( fid.type() != QVariant::Int )
+void QgsIdentifyResults::highlightFeature( QTreeWidgetItem *item )
+ QgsVectorLayer *layer = vectorLayer( item );
+ if ( !layer )
return;
- int fid2 = fid.toInt();
- if ( fid2 == mCurrentFeatureId )
+ if ( !featItem )
return;
- mCurrentFeatureId = fid2;
- emit selectedFeatureChanged( mCurrentFeatureId );
+ int fid = featItem->data( 0, Qt::UserRole ).toInt();
-void QgsIdentifyResults::extractAllItemData( QTreeWidgetItem* item )
- // Extracts the name/value pairs from the given item. This includes data
- // under the (Derived) item.
+ mRubberBand = 0;
- // A little bit complicated because the user could of right-clicked
- // on any item in the dialog box. We want a toplevel item, so walk upwards
- // as far as possible.
- // We also want to keep track of which row in the identify results table was
- // actually clicked on. This is stored as an index into the mValues vector.
+ QgsFeature feat;
+ if ( ! layer->featureAtId( fid, feat, true, false ) )
+ return;
- QTreeWidgetItem* child = item;
- QTreeWidgetItem* parent = child->parent();
- while ( parent != 0 )
+ if ( !feat.geometry() )
- child = parent;
- parent = parent->parent();
+ return;
- parent = child;
- mValues.clear();
+ mRubberBand = new QgsRubberBand( mCanvas, feat.geometry()->type() == QGis::Polygon );
- // For the code below we
- // need to do the comparison on the text strings rather than the
- // pointers because if the user clicked on the parent, we need
- // to pick up which child that actually is (the parent in the
- // identify results dialog box is just one of the children
- // that has been chosen by some method).
+ mRubberBand->setToGeometry( feat.geometry(), layer );
+ mRubberBand->setWidth( 2 );
+ mRubberBand->setColor( Qt::red );
+ mRubberBand->show();
- int valuesIndex = 0;
+void QgsIdentifyResults::editFeature( QTreeWidgetItem *item )
+ if ( !layer || !layer->isEditable() )
+ return;
- for ( int j = 0; j < parent->childCount(); ++j )
- // For derived attributes, build up a virtual name
- if ( parent->child( j )->text( 0 ) == mDerivedLabel )
- for ( int k = 0; k < parent->child( j )->childCount(); ++k )
- mValues.push_back(
- std::make_pair( mDerivedLabel + "."
- + parent->child( j )->child( k )->text( 0 ),
- parent->child( j )->child( k )->text( 1 ) ) );
+ if ( !featItem )
+ return;
- if ( item == parent->child( j )->child( k ) )
- mClickedOnValue = valuesIndex;
- valuesIndex++;
- else // do the actual feature attributes
+ QgsFeature f;
+ if ( ! layer->featureAtId( fid, f ) )
+ return;
+ QgsAttributeMap src = f.attributeMap();
+ layer->beginEditCommand( tr( "Attribute changed" ) );
+ QgsAttributeDialog *ad = new QgsAttributeDialog( layer, &f );
+ if ( ad->exec() )
+ const QgsAttributeMap &dst = f.attributeMap();
+ for ( QgsAttributeMap::const_iterator it = dst.begin(); it != dst.end(); it++ )
- mValues.push_back( std::make_pair( parent->child( j )->text( 0 ),
- parent->child( j )->text( 1 ) ) );
- if ( item == parent->child( j ) )
+ if ( !src.contains( it.key() ) || it.value() != src[it.key()] )
+ layer->changeAttributeValue( f.id(), it.key(), it.value() );
- valuesIndex++;
+ layer->endEditCommand();
+ else
+ layer->destroyEditCommand();
+ delete ad;
+ mCanvas->refresh();
Modified: trunk/qgis/src/app/qgsidentifyresults.h
--- trunk/qgis/src/app/qgsidentifyresults.h 2009-09-05 19:49:10 UTC (rev 11571)
+++ trunk/qgis/src/app/qgsidentifyresults.h 2009-09-05 19:49:47 UTC (rev 11572)
@@ -30,6 +30,11 @@
class QAction;
class QMenu;
+class QgsMapLayer;
+class QgsVectorLayer;
+class QgsRubberBand;
+class QgsMapCanvas;
*@author Gary E.Sherman
@@ -41,54 +46,26 @@
//! Constructor - takes it own copy of the QgsAttributeAction so
// that it is independent of whoever created it.
- QgsIdentifyResults( const QgsAttributeAction& actions, QWidget *parent = 0, Qt::WFlags f = 0 );
+ QgsIdentifyResults( QgsMapCanvas *canvas, QWidget *parent = 0, Qt::WFlags f = 0 );
~QgsIdentifyResults();
- /** Add an attribute to the feature display node */
- void addAttribute( QTreeWidgetItem *parent, QString field, QString value );
+ /** Remove results */
+ void clear();
- /** Add an attribute */
- void addAttribute( QString field, QString value );
+ /** Add add feature */
+ void addFeature( QgsMapLayer *layer, int fid,
+ const QMap< QString, QString > &attributes,
+ const QMap< QString, QString > &derivedAttributes );
- /** Add a derived attribute (e.g. Length, Area) to the feature display node */
- void addDerivedAttribute( QTreeWidgetItem *parent, QString field, QString value );
- /** Add an action to the feature display node */
- void addAction( QTreeWidgetItem *parent, int id, QString field, QString value );
- /** Add an edit action to the feature display node */
- void addEdit( QTreeWidgetItem *parent, int id );
- /** Add a feature node to the feature display */
- QTreeWidgetItem * addNode( QString label );
- /** Set the title for the identify results dialog */
- void setTitle( QString title );
- /** Set header column */
- void setColumnText( int column, const QString & label );
- void saveWindowLocation();
- void restorePosition();
void closeEvent( QCloseEvent *e );
- void showAllAttributes();
- /** Resize all of the columns to fit the data in them */
- void expandColumnsToFit();
- /** Remove results */
- void clear();
/** Set "No features ... " */
void setMessage( QString shortMsg, QString longMsg );
- /** Set actions */
- void setActions( const QgsAttributeAction& actions );
- //void accept();
- //void reject();
signals:
- void selectedFeatureChanged( int featureId );
- void editFeature( int featureId );
+ void selectedFeatureChanged( QgsVectorLayer *, int featureId );
public slots:
@@ -98,43 +75,39 @@
void contextMenuEvent( QContextMenuEvent* );
void popupItemSelected( QAction* menuAction );
- /* Item in tree was clicked */
- void clicked( QTreeWidgetItem *lvi );
+ void layerDestroyed();
//! Context help
void on_buttonHelp_clicked();
/* Called when an item is expanded so that we can ensure that the
column width if expanded to show it */
- void itemExpanded( QTreeWidgetItem* );
+ void itemExpanded( QTreeWidgetItem * );
//! sends signal if current feature id has changed
- void handleCurrentItemChanged( QTreeWidgetItem* current, QTreeWidgetItem* previous );
+ void handleCurrentItemChanged( QTreeWidgetItem *current, QTreeWidgetItem *previous );
private:
+ QMenu *mActionPopup;
+ QgsRubberBand *mRubberBand;
+ QgsMapCanvas *mCanvas;
- bool mEditable;
- QgsAttributeAction mActions;
- int mClickedOnValue;
- QMenu* mActionPopup;
- std::vector<std::pair<QString, QString> > mValues;
static const int context_id = 689216579;
- int mCurrentFeatureId;
- QString mDerivedLabel;
- Keeps track of what derived-attribute (e.g. Length, Area)
- root nodes have been generated for each feature in this widget.
+ QgsVectorLayer *vectorLayer( QTreeWidgetItem *item );
+ QTreeWidgetItem *featureItem( QTreeWidgetItem *item );
+ QTreeWidgetItem *layerItem( QObject *layer );
+ QTreeWidgetItem *retrieveAttributes( QTreeWidgetItem *item, std::vector< std::pair<QString, QString> > &attributes );
- First item: Feature root node
- Second item: Derived-attribute root node for that feature
- std::map<QTreeWidgetItem *, QTreeWidgetItem *> mDerivedAttributeRootNodes;
+ void setColumnText( int column, const QString & label );
+ void expandColumnsToFit();
+ void saveWindowLocation();
+ void restorePosition();
- // Convenience function to populate mValues with all of the item names and
- // values for a item, including the derived ones.
- void extractAllItemData( QTreeWidgetItem* item );
+ void highlightFeature( QTreeWidgetItem *item );
+ void editFeature( QTreeWidgetItem *item );
+ void doAction( QTreeWidgetItem *item );
#endif
Modified: trunk/qgis/src/app/qgsmaptoolidentify.cpp
--- trunk/qgis/src/app/qgsmaptoolidentify.cpp 2009-09-05 19:49:10 UTC (rev 11571)
+++ trunk/qgis/src/app/qgsmaptoolidentify.cpp 2009-09-05 19:49:47 UTC (rev 11572)
@@ -26,11 +26,11 @@
#include "qgsmessageviewer.h"
#include "qgsmaptoolidentify.h"
#include "qgsrasterlayer.h"
-#include "qgsrubberband.h"
#include "qgscoordinatereferencesystem.h"
#include "qgsvectordataprovider.h"
-#include "qgsattributedialog.h"
+#include "qgsproject.h"
+#include "qgsmaplayerregistry.h"
#include <QSettings>
#include <QMessageBox>
@@ -39,14 +39,13 @@
#include <QPixmap>
QgsMapToolIdentify::QgsMapToolIdentify( QgsMapCanvas* canvas )
- : QgsMapTool( canvas ),
- mResults( 0 ),
- mRubberBand( 0 ),
- mLayer( 0 )
+ : QgsMapTool( canvas )
// set cursor
QPixmap myIdentifyQPixmap = QPixmap(( const char ** ) identify_cursor );
mCursor = QCursor( myIdentifyQPixmap, 1, 1 );
+ mResults = new QgsIdentifyResults( canvas, mCanvas->window() );
QgsMapToolIdentify::~QgsMapToolIdentify()
@@ -55,8 +54,6 @@
mResults->done( 0 );
- delete mRubberBand;
void QgsMapToolIdentify::canvasMoveEvent( QMouseEvent * e )
@@ -74,173 +71,93 @@
return;
- // delete rubber band if there was any
- mRubberBand = 0;
+ mResults->clear();
- mLayer = mCanvas->currentLayer();
- if ( !mLayer )
+ bool res = false;
- QMessageBox::warning( mCanvas,
- tr( "No active layer" ),
- tr( "To identify features, you must choose an active layer by clicking on its name in the legend" ) );
- return;
+ QgsMapLayer *layer = mCanvas->currentLayer();
- // cleanup, when layer is removed
- connect( mLayer, SIGNAL( destroyed() ), this, SLOT( layerDestroyed() ) );
+ if ( !layer )
+ QMessageBox::warning( mCanvas,
+ tr( "No active layer" ),
+ tr( "To identify features, you must choose an active layer by clicking on its name in the legend" ) );
+ return;
- // call identify method for selected layer
- // In the special case of the WMS provider,
- // coordinates are sent back to the server as pixel coordinates
- // not the layer's native CRS. So identify on screen coordinates!
- if ( mLayer->type() == QgsMapLayer::RasterLayer &&
- dynamic_cast<QgsRasterLayer*>( mLayer )->providerKey() == "wms" )
- identifyRasterWmsLayer( QgsPoint( e->x(), e->y() ) );
+ res = identifyLayer( layer, e->x(), e->y() );
else
- // convert screen coordinates to map coordinates
- QgsPoint idPoint = mCanvas->getCoordinateTransform()->toMapCoordinates( e->x(), e->y() );
+ QStringList noIdentifyLayerIdList = QgsProject::instance()->readListEntry( "Identify", "/disabledLayers" );
- if ( mLayer->type() == QgsMapLayer::VectorLayer )
+ for ( int i = 0; i < mCanvas->layerCount(); i++ )
- identifyVectorLayer( idPoint );
- else if ( mLayer->type() == QgsMapLayer::RasterLayer )
- identifyRasterLayer( idPoint );
- else
- QgsDebugMsg( "unknown layer type!" );
+ QgsMapLayer *layer = mCanvas->layer( i );
+ if ( noIdentifyLayerIdList.contains( layer->getLayerID() ) )
+ continue;
-void QgsMapToolIdentify::identifyRasterLayer( const QgsPoint& point )
- QgsRasterLayer *layer = dynamic_cast<QgsRasterLayer*>( mLayer );
- if ( !layer )
- return;
+ if ( identifyLayer( layer, e->x(), e->y() ) )
+ res = true;
+ if ( identifyMode == 1 )
+ break;
- QMap<QString, QString> attributes;
- layer->identify( point, attributes );
- if ( !mResults )
+ if ( res )
- QgsAttributeAction aa;
- mResults = new QgsIdentifyResults( aa, mCanvas->window() );
- mResults->setAttribute( Qt::WA_DeleteOnClose );
- // Be informed when the dialog box is closed so that we can stop using it.
- connect( mResults, SIGNAL( accepted() ), this, SLOT( resultsDialogGone() ) );
- connect( mResults, SIGNAL( rejected() ), this, SLOT( resultsDialogGone() ) );
- mResults->restorePosition();
+ mResults->show();
+ mResults->raise();
else
- mResults->raise();
- mResults->clear();
+ mResults->hide();
+ QMessageBox::information( 0, tr( "Identify results" ), tr( "No features at this position found." ) );
- mResults->setTitle( layer->name() );
- mResults->setColumnText( 0, tr( "Band" ) );
- QMap<QString, QString>::iterator it;
- for ( it = attributes.begin(); it != attributes.end(); it++ )
- mResults->addAttribute( it.key(), it.value() );
- mResults->addAttribute( tr( "(clicked coordinate)" ), point.toString() );
- mResults->showAllAttributes();
- mResults->show();
-void QgsMapToolIdentify::identifyRasterWmsLayer( const QgsPoint& point )
+bool QgsMapToolIdentify::identifyLayer( QgsMapLayer *layer, int x, int y )
- if ( !layer )
- return;
+ bool res = false;
- //if WMS layer does not cover the view origin,
- //we need to map the view pixel coordinates
- //to WMS layer pixel coordinates
- QgsRectangle viewExtent = mCanvas->extent();
- double mapUnitsPerPixel = mCanvas->mapUnitsPerPixel();
- if ( mapUnitsPerPixel == 0 )
+ if ( layer->type() == QgsMapLayer::RasterLayer )
- return;
+ res = identifyRasterLayer( dynamic_cast<QgsRasterLayer *>( layer ), x, y );
- double xMinView = viewExtent.xMinimum();
- double yMaxView = viewExtent.yMaximum();
- QgsRectangle layerExtent = layer->extent();
- double xMinLayer = layerExtent.xMinimum();
- double yMaxLayer = layerExtent.yMaximum();
- double i, j;
- if ( xMinView < xMinLayer )
- i = ( int )( point.x() - ( xMinLayer - xMinView ) / mapUnitsPerPixel );
else
- i = point.x();
+ res = identifyVectorLayer( dynamic_cast<QgsVectorLayer *>( layer ), x, y );
- if ( yMaxView > yMaxLayer )
- j = ( int )( point.y() - ( yMaxView - yMaxLayer ) / mapUnitsPerPixel );
- else
- j = point.y();
+ return res;
- QString text = layer->identifyAsText( QgsPoint( i, j ) );
+bool QgsMapToolIdentify::identifyVectorLayer( QgsVectorLayer *layer, int x, int y )
+ if ( !layer )
+ return false;
- if ( text.isEmpty() )
- showError();
- return;
+ QMap< QString, QString > attributes, derivedAttributes;
- QgsMessageViewer* viewer = new QgsMessageViewer();
- viewer->setWindowTitle( layer->name() );
- viewer->setMessageAsPlainText( tr( "WMS identify result for %1:\n%2" ).arg( point.toString() ).arg( text ) );
+ QgsPoint point = mCanvas->getCoordinateTransform()->toMapCoordinates( x, y );
- viewer->showMessage(); // deletes itself on close
+ derivedAttributes.insert( tr( "(clicked coordinate)" ), point.toString() );
-void QgsMapToolIdentify::identifyVectorLayer( const QgsPoint& point )
- QgsVectorLayer *layer = dynamic_cast<QgsVectorLayer*>( mLayer );
- if ( !layer )
- return;
// load identify radius from settings
QSettings settings;
double identifyValue = settings.value( "/Map/identifyRadius", QGis::DEFAULT_IDENTIFY_RADIUS ).toDouble();
QString ellipsoid = settings.value( "/qgis/measure/ellipsoid", "WGS84" ).toString();
int featureCount = 0;
- QgsAttributeAction& actions = *layer->actions();
- QString fieldIndex = layer->displayField();
const QgsFieldMap& fields = layer->pendingFields();
// init distance/area calculator
@@ -249,9 +166,10 @@
calc.setEllipsoid( ellipsoid );
calc.setSourceCrs( layer->srs().srsid() );
- mFeatureList.clear();
QApplication::setOverrideCursor( Qt::WaitCursor );
+ QgsFeatureList featureList;
// toLayerCoordinates will throw an exception for an 'invalid' point.
// For example, if you project a world map onto a globe using EPSG 2163
// and then click somewhere off the globe, an exception will be thrown.
@@ -271,7 +189,7 @@
layer->select( layer->pendingAllAttributesList(), r, true, true );
QgsFeature f;
while ( layer->nextFeature( f ) )
- mFeatureList << QgsFeature( f );
+ featureList << QgsFeature( f );
catch ( QgsCsException & cse )
@@ -282,62 +200,29 @@
QApplication::restoreOverrideCursor();
- if ( layer->isEditable() && mFeatureList.size() == 1 )
- editFeature( mFeatureList[0] );
- return;
+ QgsFeatureList::iterator f_it = featureList.begin();
- // display features falling within the search radius
- if ( !mResults )
+ for ( ; f_it != featureList.end(); ++f_it )
- mResults = new QgsIdentifyResults( actions, mCanvas->window() );
- connect( mResults, SIGNAL( selectedFeatureChanged( int ) ), this, SLOT( highlightFeature( int ) ) );
- connect( mResults, SIGNAL( editFeature( int ) ), this, SLOT( editFeature( int ) ) );
- // restore the identify window position and show it
- else
- mResults->setActions( actions );
- QApplication::setOverrideCursor( Qt::WaitCursor );
- int lastFeatureId = 0;
- QgsFeatureList::iterator f_it = mFeatureList.begin();
- for ( ; f_it != mFeatureList.end(); ++f_it )
featureCount++;
- QTreeWidgetItem* featureNode = mResults->addNode( "foo" );
- featureNode->setData( 0, Qt::UserRole, QVariant( f_it->id() ) ); // save feature id
- lastFeatureId = f_it->id();
- featureNode->setText( 0, fieldIndex );
+ int fid = f_it->id();
+ QString displayField, displayValue;
+ QMap<QString, QString> attributes, derivedAttributes;
- if ( layer->isEditable() )
- mResults->addEdit( featureNode, f_it->id() );
const QgsAttributeMap& attr = f_it->attributeMap();
for ( QgsAttributeMap::const_iterator it = attr.begin(); it != attr.end(); ++it )
- //QgsDebugMsg(it->fieldName() + " == " + fieldIndex);
+ QString attributeName = layer->attributeDisplayName( it.key() );
- if ( fields[it.key()].name() == fieldIndex )
+ if ( fields[it.key()].name() == layer->displayField() )
- featureNode->setText( 1, it->toString() );
+ displayField = attributeName;
+ displayValue = it->toString();
- QString attributeName = layer->attributeDisplayName( it.key() );
- mResults->addAttribute( featureNode, attributeName, it->isNull() ? "NULL" : it->toString() );
+ attributes.insert( attributeName, it->isNull() ? "NULL" : it->toString() );
// Calculate derived attributes and insert:
@@ -348,18 +233,18 @@
QGis::UnitType myDisplayUnits;
convertMeasurement( calc, dist, myDisplayUnits, false );
QString str = calc.textUnit( dist, 3, myDisplayUnits, false ); // dist and myDisplayUnits are out params
- mResults->addDerivedAttribute( featureNode, tr( "Length" ), str );
+ derivedAttributes.insert( tr( "Length" ), str );
if ( f_it->geometry()->wkbType() == QGis::WKBLineString )
// Add the start and end points in as derived attributes
str = QLocale::system().toString( f_it->geometry()->asPolyline().first().x(), 'g', 10 );
- mResults->addDerivedAttribute( featureNode, tr( "firstX", "attributes get sorted; translation for lastX should be lexically larger than this one" ), str );
+ derivedAttributes.insert( tr( "firstX", "attributes get sorted; translation for lastX should be lexically larger than this one" ), str );
str = QLocale::system().toString( f_it->geometry()->asPolyline().first().y(), 'g', 10 );
- mResults->addDerivedAttribute( featureNode, tr( "firstY" ), str );
+ derivedAttributes.insert( tr( "firstY" ), str );
str = QLocale::system().toString( f_it->geometry()->asPolyline().last().x(), 'g', 10 );
- mResults->addDerivedAttribute( featureNode, tr( "lastX", "attributes get sorted; translation for firstX should be lexically smaller than this one" ), str );
+ derivedAttributes.insert( tr( "lastX", "attributes get sorted; translation for firstX should be lexically smaller than this one" ), str );
str = QLocale::system().toString( f_it->geometry()->asPolyline().last().y(), 'g', 10 );
- mResults->addDerivedAttribute( featureNode, tr( "lastY" ), str );
+ derivedAttributes.insert( tr( "lastY" ), str );
else if ( layer->geometryType() == QGis::Polygon )
@@ -368,179 +253,91 @@
convertMeasurement( calc, area, myDisplayUnits, true ); // area and myDisplayUnits are out params
QString str = calc.textUnit( area, 3, myDisplayUnits, true );
- mResults->addDerivedAttribute( featureNode, tr( "Area" ), str );
+ derivedAttributes.insert( tr( "Area" ), str );
else if ( layer->geometryType() == QGis::Point )
// Include the x and y coordinates of the point as a derived attribute
QString str;
str = QLocale::system().toString( f_it->geometry()->asPoint().x(), 'g', 10 );
- mResults->addDerivedAttribute( featureNode, "X", str );
+ derivedAttributes.insert( "X", str );
str = QLocale::system().toString( f_it->geometry()->asPoint().y(), 'g', 10 );
- mResults->addDerivedAttribute( featureNode, "Y", str );
+ derivedAttributes.insert( "Y", str );
- // Add actions
- QgsAttributeAction::aIter iter = actions.begin();
- for ( register int i = 0; iter != actions.end(); ++iter, ++i )
- mResults->addAction( featureNode, i, tr( "action" ), iter->name() );
+ mResults->addFeature( layer, fid, displayField, displayValue, attributes, derivedAttributes );
QgsDebugMsg( "Feature count on identify: " + QString::number( featureCount ) );
- //also test the not commited features //todo: eliminate copy past code
- if ( featureCount == 1 )
- highlightFeature( lastFeatureId );
- else if ( featureCount == 0 )
- mResults->setMessage( tr( "No features found" ), tr( "No features were found in the active layer at the point you clicked" ) );
- mResults->setTitle( tr( "%1 - %n feature(s) found", "Identify results window title", featureCount ).arg( layer->name() ) );
- mResults->show();
+ return featureCount > 0;
-void QgsMapToolIdentify::showError()
+bool QgsMapToolIdentify::identifyRasterLayer( QgsRasterLayer *layer, int x, int y )
-#if 0
- this,
- mapLayer->lastErrorTitle(),
- tr( "Could not draw %1 because:\n%2", "COMMENTED OUT" ).arg( mapLayer->name() ).arg( mapLayer->lastError() )
-#endif
+ bool res = true;
- QgsMessageViewer * mv = new QgsMessageViewer();
- if ( mLayer )
- mv->setWindowTitle( mLayer->lastErrorTitle() );
- mv->setMessageAsPlainText( tr( "Could not identify objects on %1 because:\n%2" )
- .arg( mLayer->name() ).arg( mLayer->lastError() ) );
- else
- mv->setWindowTitle( tr( "Layer was removed" ) );
- mv->setMessageAsPlainText( tr( "Layer to identify objects on was removed" ) );
- mv->exec(); // deletes itself on close
-void QgsMapToolIdentify::resultsDialogGone()
- mResults = 0;
- mRubberBand = 0;
-void QgsMapToolIdentify::deactivate()
- if ( mResults )
- mResults->done( 0 ); // close the window
- QgsMapTool::deactivate();
-void QgsMapToolIdentify::highlightFeature( int featureId )
- QgsVectorLayer* layer = dynamic_cast<QgsVectorLayer*>( mLayer );
if ( !layer )
- return;
+ return false;
- mRubberBand = 0;
+ QgsRasterDataProvider *dprovider = layer->dataProvider();
+ if ( dprovider && ( dprovider->capabilities() & QgsRasterDataProvider::Identify ) == 0 )
+ return false;
- QgsFeature feat;
- if ( ! layer->featureAtId( featureId, feat, true, false ) )
- return;
+ QgsPoint idPoint = mCanvas->getCoordinateTransform()->toMapCoordinates( x, y );
+ QString type;
- if ( !feat.geometry() )
+ if ( layer->providerKey() == "wms" )
- return;
+ type = tr( "WMS layer" );
- mRubberBand = new QgsRubberBand( mCanvas, feat.geometry()->type() == QGis::Polygon );
+ //if WMS layer does not cover the view origin,
+ //we need to map the view pixel coordinates
+ //to WMS layer pixel coordinates
+ QgsRectangle viewExtent = mCanvas->extent();
+ QgsRectangle layerExtent = layer->extent();
+ double mapUnitsPerPixel = mCanvas->mapUnitsPerPixel();
+ if ( mapUnitsPerPixel > 0 && viewExtent.intersects( layerExtent ) )
+ double xMinView = viewExtent.xMinimum();
+ double yMaxView = viewExtent.yMaximum();
+ double xMinLayer = layerExtent.xMinimum();
+ double yMaxLayer = layerExtent.yMaximum();
- if ( mRubberBand )
- mRubberBand->setToGeometry( feat.geometry(), layer );
- mRubberBand->setWidth( 2 );
- mRubberBand->setColor( Qt::red );
- mRubberBand->show();
+ idPoint.set(
+ xMinView < xMinLayer ? floor( x - ( xMinLayer - xMinView ) / mapUnitsPerPixel ) : x,
+ yMaxView > yMaxLayer ? floor( y - ( yMaxView - yMaxLayer ) / mapUnitsPerPixel ) : y
-void QgsMapToolIdentify::editFeature( int featureId )
- for ( QgsFeatureList::iterator it = mFeatureList.begin(); it != mFeatureList.end(); it++ )
- if ( it->id() == featureId )
+ attributes.insert( tr( "Feature info" ), layer->identifyAsText( idPoint ) );
+ else
- editFeature( *it );
- break;
+ res = false;
-void QgsMapToolIdentify::editFeature( QgsFeature &f )
- if ( !layer || !layer->isEditable() )
+ else
- return;
+ type = tr( "Raster" );
+ res = layer->extent().contains( idPoint ) && layer->identify( idPoint, attributes );
- QgsAttributeMap src = f.attributeMap();
- layer->beginEditCommand( tr( "Attribute changed" ) );
- QgsAttributeDialog *ad = new QgsAttributeDialog( layer, &f );
- if ( ad->exec() )
+ if ( res )
- const QgsAttributeMap &dst = f.attributeMap();
- for ( QgsAttributeMap::const_iterator it = dst.begin(); it != dst.end(); it++ )
- if ( !src.contains( it.key() ) || it.value() != src[it.key()] )
- layer->changeAttributeValue( f.id(), it.key(), it.value() );
- layer->endEditCommand();
+ derivedAttributes.insert( tr( "(clicked coordinate)" ), idPoint.toString() );
+ mResults->addFeature( layer, -1, type, "", attributes, derivedAttributes );
- else
- layer->destroyEditCommand();
- delete ad;
- mCanvas->refresh();
+ return res;
-void QgsMapToolIdentify::layerDestroyed()
- mLayer = 0;
- if ( mResults )
- mRubberBand = 0;
+void QgsMapToolIdentify::resultsDialogGone()
+ mResults = 0;
void QgsMapToolIdentify::convertMeasurement( QgsDistanceArea &calc, double &measure, QGis::UnitType &u, bool isArea )
Modified: trunk/qgis/src/app/qgsmaptoolidentify.h
--- trunk/qgis/src/app/qgsmaptoolidentify.h 2009-09-05 19:49:10 UTC (rev 11571)
+++ trunk/qgis/src/app/qgsmaptoolidentify.h 2009-09-05 19:49:47 UTC (rev 11572)
@@ -57,68 +57,27 @@
//! Overridden mouse release event
virtual void canvasReleaseEvent( QMouseEvent * e );
- //! called when map tool is being deactivated
- virtual void deactivate();
- public slots:
- //! creates rubberband on top of the feature to highlight it
- void highlightFeature( int featureId );
- //! edit a feature
private:
+ bool identifyLayer( QgsMapLayer *layer, int x, int y );
+ bool identifyRasterLayer( QgsRasterLayer *layer, int x, int y );
+ bool identifyVectorLayer( QgsVectorLayer *layer, int x, int y );
- * \brief function for identifying pixel values at a coordinate in a non-OGC-WMS raster layer
- * \param point[in] The coordinate (as the CRS of the raster layer)
- void identifyRasterLayer( const QgsPoint& point );
- * \brief function for identifying a pixel in a OGC WMS raster layer
- * \param point[in] The pixel coordinate (as it was displayed locally on screen)
- * \note WMS Servers prefer to receive coordinates in image space not CRS space, therefore
- * this special variant of identifyRasterLayer.
- void identifyRasterWmsLayer( const QgsPoint& point );
- * \brief function for identifying features at a coordinate in a vector layer
- * \param point[in] The coordinate (as the CRS of the vector layer)
- void identifyVectorLayer( const QgsPoint& point );
- //! show whatever error is exposed by the QgsMapLayer.
- void showError();
- void editFeature( QgsFeature &f );
//! Pointer to the identify results dialog for name/value pairs
QgsIdentifyResults *mResults;
- //! Rubber band for highlighting identified feature
- QgsRubberBand* mRubberBand;
- QgsMapLayer *mLayer;
- //! list of identified features
- QgsFeatureList mFeatureList;
//! Private helper
void convertMeasurement( QgsDistanceArea &calc, double &measure, QGis::UnitType &u, bool isArea );
+ /** Add an action to the feature display node */
private slots:
// Let us know when the QgsIdentifyResults dialog box has been closed
void resultsDialogGone();
- // layer was destroyed
- void layerDestroyed();
#endif
Modified: trunk/qgis/src/app/qgsoptions.cpp
--- trunk/qgis/src/app/qgsoptions.cpp 2009-09-05 19:49:10 UTC (rev 11571)
+++ trunk/qgis/src/app/qgsoptions.cpp 2009-09-05 19:49:47 UTC (rev 11572)
@@ -50,9 +50,14 @@
connect( buttonBox, SIGNAL( rejected() ), this, SLOT( reject() ) );
connect( this, SIGNAL( accepted() ), this, SLOT( saveOptions() ) );
+ cmbIdentifyMode->addItem( tr( "current layer" ), 0 );
+ cmbIdentifyMode->addItem( tr( "top down, stop at first" ), 1 );
+ cmbIdentifyMode->addItem( tr( "top down" ), 2 );
// read the current browser and set it
QSettings settings;
- QgsDebugMsg( QString( "Standard Identify radius setting: %1" ).arg( QGis::DEFAULT_IDENTIFY_RADIUS ) );
+ cmbIdentifyMode->setCurrentIndex( cmbIdentifyMode->findData( identifyMode ) );
QgsDebugMsg( QString( "Standard Identify radius setting read from settings file: %1" ).arg( identifyValue ) );
spinBoxIdentifyValue->setValue( identifyValue );
@@ -349,6 +354,7 @@
settings.setValue( "proxy/proxyExcludedUrls", proxyExcludeString );
//general settings
+ settings.setValue( "/Map/identifyMode", cmbIdentifyMode->itemData( cmbIdentifyMode->currentIndex() ).toInt() );
settings.setValue( "/Map/identifyRadius", spinBoxIdentifyValue->value() );
settings.setValue( "/qgis/showLegendClassifiers", cbxLegendClassifiers->isChecked() );
settings.setValue( "/qgis/hideSplash", cbxHideSplash->isChecked() );
Modified: trunk/qgis/src/app/qgsprojectproperties.cpp
--- trunk/qgis/src/app/qgsprojectproperties.cpp 2009-09-05 19:49:10 UTC (rev 11571)
+++ trunk/qgis/src/app/qgsprojectproperties.cpp 2009-09-05 19:49:47 UTC (rev 11572)
@@ -30,6 +30,7 @@
#include "qgsrenderer.h"
#include "qgssnappingdialog.h"
+#include "qgsrasterlayer.h"
//qt includes
#include <QColorDialog>
@@ -205,6 +206,56 @@
mSnappingLayerSettings.insert( *idIter, newEntry );
+ const QMap<QString, QgsMapLayer*> &mapLayers = QgsMapLayerRegistry::instance()->mapLayers();
+ twIdentifyLayers->setColumnCount( 3 );
+ twIdentifyLayers->horizontalHeader()->setVisible( true );
+ twIdentifyLayers->setHorizontalHeaderItem( 0, new QTableWidgetItem( tr( "Layer" ) ) );
+ twIdentifyLayers->setHorizontalHeaderItem( 1, new QTableWidgetItem( tr( "Type" ) ) );
+ twIdentifyLayers->setHorizontalHeaderItem( 2, new QTableWidgetItem( tr( "Identifiable" ) ) );
+ twIdentifyLayers->setRowCount( mapLayers.size() );
+ twIdentifyLayers->verticalHeader()->setResizeMode( QHeaderView::ResizeToContents );
+ int i = 0;
+ for ( QMap<QString, QgsMapLayer*>::const_iterator it = mapLayers.constBegin(); it != mapLayers.constEnd(); it++, i++ )
+ currentLayer = it.value();
+ QTableWidgetItem *twi = new QTableWidgetItem( QString::number( i ) );
+ twi->setData( Qt::UserRole, it.key() );
+ twIdentifyLayers->setVerticalHeaderItem( i, twi );
+ twIdentifyLayers->setItem( i, 0, new QTableWidgetItem( currentLayer->name() ) );
+ QString type;
+ if ( currentLayer->type() == QgsMapLayer::VectorLayer )
+ type = tr( "Vector" );
+ else if ( currentLayer->type() == QgsMapLayer::RasterLayer )
+ QgsRasterLayer *rl = dynamic_cast<QgsRasterLayer *>( currentLayer );
+ if ( rl && rl->providerKey() == "wms" )
+ type = tr( "WMS" );
+ else
+ twIdentifyLayers->setItem( i, 1, new QTableWidgetItem( type ) );
+ QCheckBox *cb = new QCheckBox();
+ cb->setChecked( !noIdentifyLayerIdList.contains( currentLayer->getLayerID() ) );
+ twIdentifyLayers->setCellWidget( i, 2, cb );
restoreState();
@@ -387,6 +438,19 @@
QgsProject::instance()->writeEntry( "Digitizing", "/LayerSnappingEnabledList", enabledList );
+ QStringList noIdentifyLayerList;
+ for ( int i = 0; i < twIdentifyLayers->rowCount(); i++ )
+ QCheckBox *cb = dynamic_cast<QCheckBox*>( twIdentifyLayers->cellWidget( i, 2 ) );
+ if ( cb && !cb->isChecked() )
+ QString id = twIdentifyLayers->verticalHeaderItem( i )->data( Qt::UserRole ).toString();
+ noIdentifyLayerList << id;
+ QgsProject::instance()->writeEntry( "Identify", "/disabledLayers", noIdentifyLayerList );
//todo XXX set canvas colour
emit refresh();
Modified: trunk/qgis/src/core/qgsrectangle.cpp
--- trunk/qgis/src/core/qgsrectangle.cpp 2009-09-05 19:49:10 UTC (rev 11571)
+++ trunk/qgis/src/core/qgsrectangle.cpp 2009-09-05 19:49:47 UTC (rev 11572)
@@ -161,6 +161,11 @@
return ( rect.xmin >= xmin && rect.xmax <= xmax && rect.ymin >= ymin && rect.ymax <= ymax );
+bool QgsRectangle::contains( const QgsPoint &p ) const
+ return xmin <= p.x() && p.x() <= xmax &&
+ ymin <= p.y() && p.y() <= ymax;
void QgsRectangle::combineExtentWith( QgsRectangle * rect )
Modified: trunk/qgis/src/core/qgsrectangle.h
--- trunk/qgis/src/core/qgsrectangle.h 2009-09-05 19:49:10 UTC (rev 11571)
+++ trunk/qgis/src/core/qgsrectangle.h 2009-09-05 19:49:47 UTC (rev 11572)
@@ -87,6 +87,9 @@
+ bool contains( const QgsPoint &p ) const;
void combineExtentWith( QgsRectangle *rect );
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.cpp
--- trunk/qgis/src/core/raster/qgsrasterlayer.cpp 2009-09-05 19:49:10 UTC (rev 11571)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.cpp 2009-09-05 19:49:47 UTC (rev 11572)
@@ -1507,7 +1507,7 @@
QgsDebugMsg( "Wanting a '" + mProviderKey + "' provider to draw this." );
- emit statusChanged( tr( "Retrieving using %1" ).arg( mProviderKey ) );
+ emit statusChanged( tr( "Retrieving %1 using %2" ).arg( name() ).arg( mProviderKey ) );
mDataProvider->setDpi( rendererContext.rasterScaleFactor() * 25.4 * rendererContext.scaleFactor() );
@@ -1594,6 +1594,7 @@
delete image;
+ emit statusChanged( tr( "%1 retrieved using %2" ).arg( name() ).arg( mProviderKey ) );
else
@@ -1846,12 +1847,9 @@
return false;
- double x = thePoint.x();
- double y = thePoint.y();
+ QgsDebugMsg( thePoint.toString() );
- QgsDebugMsg( QString::number( x ) + ", " + QString::number( y ) );
- if ( x < mLayerExtent.xMinimum() || x > mLayerExtent.xMaximum() || y < mLayerExtent.yMinimum() || y > mLayerExtent.yMaximum() )
+ if ( !mLayerExtent.contains( thePoint ) )
// Outside the raster
for ( int i = 1; i <= GDALGetRasterCount( mGdalDataset ); i++ )
@@ -1861,6 +1859,9 @@
else
+ double x = thePoint.x();
+ double y = thePoint.y();
/* Calculate the row / column where the point falls */
double xres = ( mLayerExtent.xMaximum() - mLayerExtent.xMinimum() ) / mWidth;
double yres = ( mLayerExtent.yMaximum() - mLayerExtent.yMinimum() ) / mHeight;
Modified: trunk/qgis/src/ui/qgsoptionsbase.ui
--- trunk/qgis/src/ui/qgsoptionsbase.ui 2009-09-05 19:49:10 UTC (rev 11571)
+++ trunk/qgis/src/ui/qgsoptionsbase.ui 2009-09-05 19:49:47 UTC (rev 11572)
@@ -6,8 +6,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>617</width>
- <height>521</height>
+ <width>654</width>
+ <height>546</height>
</rect>
</property>
<property name="windowTitle">
@@ -503,13 +503,13 @@
<item row="0" column="0">
<widget class="QGroupBox" name="groupBox_7">
<property name="title">
- <string>Search radius</string>
+ <string>Identify</string>
</property>
<layout class="QGridLayout">
<property name="margin">
<number>11</number>
</property>
- <item row="1" column="0" colspan="2">
+ <item row="2" column="0" colspan="2">
<widget class="QLabel" name="textLabel2">
<property name="text">
<string><b>Note:</b> Specify the search radius as a percentage of the map width</string>
@@ -519,7 +519,7 @@
</property>
</widget>
</item>
- <item row="0" column="0">
+ <item row="1" column="0">
<widget class="QLabel" name="textLabel1_3">
<string>Search radius for identifying features and displaying map tips</string>
@@ -529,7 +529,7 @@
</property>
</widget>
</item>
- <item row="0" column="1">
+ <item row="1" column="1">
<widget class="QDoubleSpinBox" name="spinBoxIdentifyValue">
<property name="suffix">
<string>%</string>
@@ -545,6 +545,16 @@
</property>
</widget>
</item>
+ <item row="0" column="1">
+ <widget class="QComboBox" name="cmbIdentifyMode"/>
+ </item>
+ <item row="0" column="0">
+ <widget class="QLabel" name="label_4">
+ <property name="text">
+ <string>Mode</string>
+ </property>
+ </widget>
+ </item>
</layout>
</widget>
</item>
Modified: trunk/qgis/src/ui/qgsprojectpropertiesbase.ui
--- trunk/qgis/src/ui/qgsprojectpropertiesbase.ui 2009-09-05 19:49:10 UTC (rev 11571)
+++ trunk/qgis/src/ui/qgsprojectpropertiesbase.ui 2009-09-05 19:49:47 UTC (rev 11572)
@@ -1,81 +1,87 @@
-<ui version="4.0" >
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
<class>QgsProjectPropertiesBase</class>
- <widget class="QDialog" name="QgsProjectPropertiesBase" >
- <property name="geometry" >
+ <widget class="QDialog" name="QgsProjectPropertiesBase">
+ <property name="geometry">
<rect>
<x>0</x>
<y>0</y>
- <width>536</width>
- <height>713</height>
+ <width>451</width>
+ <height>515</height>
</rect>
</property>
- <property name="windowTitle" >
+ <property name="windowTitle">
<string>Project Properties</string>
</property>
- <property name="windowIcon" >
- <iconset>
- <normaloff/>
- </iconset>
- </property>
- <property name="sizeGripEnabled" >
+ <property name="sizeGripEnabled">
<bool>true</bool>
</property>
- <property name="modal" >
+ <property name="modal">
<bool>true</bool>
</property>
- <layout class="QGridLayout" >
- <item row="0" column="0" >
- <widget class="QTabWidget" name="tabWidget" >
- <property name="currentIndex" >
+ <layout class="QGridLayout">
+ <item row="2" column="0">
+ <widget class="QDialogButtonBox" name="buttonBox">
+ <property name="orientation">
+ <enum>Qt::Horizontal</enum>
+ </property>
+ <property name="standardButtons">
+ <set>QDialogButtonBox::Apply|QDialogButtonBox::Cancel|QDialogButtonBox::Help|QDialogButtonBox::Ok</set>
+ </property>
+ </widget>
+ </item>
+ <widget class="QTabWidget" name="tabWidget">
+ <property name="currentIndex">
<number>0</number>
</property>
- <widget class="QWidget" name="tab1" >
- <attribute name="title" >
+ <widget class="QWidget" name="tab1">
+ <attribute name="title">
<string>General</string>
</attribute>
- <widget class="QGroupBox" name="titleBox" >
- <property name="title" >
- <string>Title and colors</string>
+ <widget class="QGroupBox" name="titleBox">
+ <property name="title">
+ <string>General settings</string>
</property>
- <widget class="QLabel" name="label_2" >
- <property name="text" >
+ <widget class="QLabel" name="label_2">
<string>Project title</string>
</property>
</widget>
</item>
- <item row="0" column="1" colspan="3" >
- <widget class="QLineEdit" name="titleEdit" >
- <property name="toolTip" >
+ <item row="0" column="1" colspan="3">
+ <widget class="QLineEdit" name="titleEdit">
+ <property name="toolTip">
<string>Descriptive project name</string>
</property>
<string>Default project title</string>
</property>
</widget>
</item>
- <item row="1" column="0" >
- <widget class="QLabel" name="textLabel1" >
+ <widget class="QLabel" name="textLabel1">
<string>Selection color</string>
</property>
- <property name="buddy" >
+ <property name="buddy">
<cstring>pbnSelectionColour</cstring>
</property>
</widget>
</item>
- <item row="1" column="2" >
+ <item row="1" column="2">
<spacer>
- <property name="orientation" >
</property>
- <property name="sizeType" >
+ <property name="sizeType">
<enum>QSizePolicy::Expanding</enum>
</property>
- <property name="sizeHint" >
+ <property name="sizeHint" stdset="0">
<size>
<width>40</width>
<height>20</height>
@@ -83,35 +89,35 @@
</property>
</spacer>
</item>
- <item row="1" column="3" >
- <widget class="QgsColorButton" name="pbnSelectionColour" >
- <property name="minimumSize" >
+ <item row="1" column="3">
+ <widget class="QgsColorButton" name="pbnSelectionColour">
+ <property name="minimumSize">
<size>
<width>100</width>
<height>0</height>
</size>
</property>
<string/>
</property>
</widget>
</item>
- <item row="2" column="0" colspan="2" >
- <widget class="QLabel" name="label" >
+ <widget class="QLabel" name="label">
<string>Background color</string>
</property>
<cstring>pbnCanvasColor</cstring>
</property>
</widget>
</item>
- <item row="2" column="2" >
+ <item row="2" column="2">
<spacer>
</property>
<size>
<width>40</width>
<height>20</height>
@@ -119,60 +125,58 @@
</property>
</spacer>
</item>
- <item row="2" column="3" >
- <widget class="QgsColorButton" name="pbnCanvasColor" >
+ <item row="2" column="3">
+ <widget class="QgsColorButton" name="pbnCanvasColor">
<size>
<width>100</width>
<height>0</height>
</size>
</property>
<string/>
</property>
</widget>
</item>
+ <item row="3" column="0" colspan="4">
+ <widget class="QCheckBox" name="cbxAbsolutePath">
+ <string>Save absolute paths</string>
+ </property>
+ </widget>
+ </item>
</layout>
</widget>
</item>
- <widget class="QGroupBox" name="btnGrpMapUnits" >
+ <widget class="QGroupBox" name="btnGrpMapUnits">
<string>Layer units (only used when CRS transformation is disabled)</string>
</property>
- <layout class="QHBoxLayout" >
- <property name="leftMargin" >
+ <layout class="QHBoxLayout">
+ <property name="margin">
<number>11</number>
</property>
- <property name="topMargin" >
- <number>11</number>
- </property>
- <property name="rightMargin" >
- </property>
- <property name="bottomMargin" >
- </property>
<item>
- <widget class="QRadioButton" name="radMeters" >
+ <widget class="QRadioButton" name="radMeters">
<string>Meters</string>
</property>
- <property name="checked" >
+ <property name="checked">
<bool>true</bool>
</property>
</widget>
</item>
<item>
- <widget class="QRadioButton" name="radFeet" >
+ <widget class="QRadioButton" name="radFeet">
<string>Feet</string>
</property>
</widget>
</item>
<item>
- <widget class="QRadioButton" name="radDecimalDegrees" >
+ <widget class="QRadioButton" name="radDecimalDegrees">
<string>Decimal degrees</string>
</property>
</widget>
@@ -180,60 +184,60 @@
</layout>
</widget>
</item>
- <item row="2" column="0" >
- <widget class="QGroupBox" name="btnGrpPrecision" >
+ <widget class="QGroupBox" name="btnGrpPrecision">
<string>Precision</string>
</property>
- <widget class="QRadioButton" name="radAutomatic" >
+ <widget class="QRadioButton" name="radAutomatic">
<string>Automatically sets the number of decimal places in the mouse position display</string>
</property>
- <property name="whatsThis" >
+ <property name="whatsThis">
<string>The number of decimal places that are used when displaying the mouse position is automatically set to be enough so that moving the mouse by one pixel gives a change in the position display</string>
</property>
<string>Automatic</string>
</property>
<bool>true</bool>
</property>
</widget>
</item>
- <item row="0" column="1" >
- <widget class="QRadioButton" name="radManual" >
+ <widget class="QRadioButton" name="radManual">
<string>Sets the number of decimal places to use for the mouse position display</string>
</property>
</property>
<string>Manual</string>
</property>
</widget>
</item>
- <item row="0" column="2" >
- <widget class="QSpinBox" name="spinBoxDP" >
+ <item row="0" column="2">
+ <widget class="QSpinBox" name="spinBoxDP">
<string>The number of decimal places for the manual option</string>
</property>
</property>
</widget>
</item>
- <item row="0" column="3" >
- <widget class="QLabel" name="textLabel3" >
- <property name="sizePolicy" >
- <sizepolicy vsizetype="Fixed" hsizetype="Fixed" >
+ <item row="0" column="3">
+ <widget class="QLabel" name="textLabel3">
+ <property name="sizePolicy">
+ <sizepolicy hsizetype="Fixed" vsizetype="Fixed">
<horstretch>0</horstretch>
<verstretch>0</verstretch>
</sizepolicy>
</property>
<string>decimal places</string>
</property>
</widget>
@@ -241,35 +245,35 @@
</layout>
</widget>
</item>
- <item row="3" column="0" >
- <widget class="QGroupBox" name="grpDigitizing" >
- <sizepolicy vsizetype="Expanding" hsizetype="Preferred" >
+ <item row="3" column="0">
+ <widget class="QGroupBox" name="grpDigitizing">
+ <sizepolicy hsizetype="Preferred" vsizetype="Expanding">
</sizepolicy>
</property>
<string>Digitizing</string>
</property>
- <widget class="QCheckBox" name="mEnableTopologicalEditingCheckBox" >
+ <widget class="QCheckBox" name="mEnableTopologicalEditingCheckBox">
<string>Enable topological editing</string>
</property>
</widget>
</item>
- <widget class="QCheckBox" name="mAvoidIntersectionsCheckBox" >
+ <widget class="QCheckBox" name="mAvoidIntersectionsCheckBox">
<string>Avoid intersections of new polygons</string>
</property>
</widget>
</item>
- <widget class="QPushButton" name="mSnappingOptionsPushButton" >
+ <widget class="QPushButton" name="mSnappingOptionsPushButton">
<string>Snapping options...</string>
</property>
</widget>
@@ -277,59 +281,86 @@
</layout>
</widget>
</item>
- <item row="4" column="0" >
- <widget class="QCheckBox" name="cbxAbsolutePath" >
- <string>Save absolute paths</string>
- </property>
- </widget>
- </item>
</layout>
</widget>
- <widget class="QWidget" name="tab2" >
+ <widget class="QWidget" name="tab2">
<string>Coordinate Reference System (CRS)</string>
</attribute>
+ <property name="leftMargin">
<number>3</number>
</property>
+ <property name="topMargin">
<number>11</number>
</property>
+ <property name="rightMargin">
<number>3</number>
</property>
+ <property name="bottomMargin">
<number>11</number>
</property>
- <widget class="QCheckBox" name="cbxProjectionEnabled" >
+ <widget class="QCheckBox" name="cbxProjectionEnabled">
<string>Enable 'on the fly' CRS transformation</string>
</property>
</widget>
</item>
- <widget class="QgsProjectionSelector" native="1" name="projectionSelector" />
+ <widget class="QgsProjectionSelector" name="projectionSelector" native="true"/>
</item>
</layout>
</widget>
+ <widget class="QWidget" name="tab3">
+ <string>Identifiable layers</string>
+ </attribute>
+ <layout class="QHBoxLayout" name="horizontalLayout">
+ <item>
+ <widget class="QTableWidget" name="twIdentifyLayers">
+ <property name="sortingEnabled">
+ <bool>true</bool>
+ </property>
+ <attribute name="horizontalHeaderVisible">
+ <bool>false</bool>
+ </attribute>
+ <attribute name="horizontalHeaderShowSortIndicator" stdset="0">
+ </attribute>
+ <attribute name="horizontalHeaderStretchLastSection">
+ <bool>true</bool>
+ </attribute>
+ </attribute>
+ <column>
+ <string>Layer</string>
+ </property>
+ </column>
+ <column>
+ <string>Type</string>
+ </property>
+ </column>
+ <column>
+ <string>Identifiable</string>
+ </property>
+ <property name="textAlignment">
+ <set>AlignHCenter|AlignVCenter|AlignCenter</set>
+ </property>
+ </column>
+ </widget>
+ </item>
+ </layout>
+ </widget>
</widget>
</item>
- <widget class="QDialogButtonBox" name="buttonBox" >
- <enum>Qt::Horizontal</enum>
- </property>
- <property name="standardButtons" >
- <set>QDialogButtonBox::Apply|QDialogButtonBox::Cancel|QDialogButtonBox::Help|QDialogButtonBox::NoButton|QDialogButtonBox::Ok</set>
- </property>
- </widget>
- </item>
</layout>
</widget>
- <layoutdefault spacing="6" margin="11" />
+ <layoutdefault spacing="6" margin="11"/>
<customwidgets>
<customwidget>
<class>QgsColorButton</class>
@@ -368,11 +399,11 @@
<receiver>spinBoxDP</receiver>
<slot>setEnabled(bool)</slot>
<hints>
- <hint type="sourcelabel" >
+ <hint type="sourcelabel">
<x>229</x>
<y>280</y>
</hint>
- <hint type="destinationlabel" >
+ <hint type="destinationlabel">
<x>416</x>
<y>286</y>
</hint>
@@ -384,11 +415,11 @@
<receiver>textLabel3</receiver>
<hints>
<x>240</x>
<y>281</y>
</hint>
<x>583</x>
<y>290</y>
</hint>
@@ -400,11 +431,11 @@
<slot>setDisabled(bool)</slot>
<hints>
<x>100</x>
<y>290</y>
</hint>
<x>395</x>
<y>285</y>
</hint>
@@ -416,11 +447,11 @@
<hints>
<x>87</x>
<y>284</y>
</hint>
<x>589</x>
<y>285</y>
</hint>
