[QGIS Commit] r11573 - trunk/qgis/src/app
svn_qgis at osgeo.org
Sat Sep 5 15:50:05 EDT 2009
Author: jef
Date: 2009-09-05 15:50:05 -0400 (Sat, 05 Sep 2009)
New Revision: 11573
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/app/qgisapp.h
[FEATURE] recenter map canvas to an entered coordinate
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2009-09-05 19:49:47 UTC (rev 11572)
+++ trunk/qgis/src/app/qgisapp.cpp 2009-09-05 19:50:05 UTC (rev 11573)
@@ -1473,17 +1473,38 @@
mToggleExtentsViewButton->setCheckable( true );
connect( mToggleExtentsViewButton, SIGNAL( toggled( bool ) ), this, SLOT( extentsViewToggled( bool ) ) );
statusBar()->addPermanentWidget( mToggleExtentsViewButton, 0 );
- //coords status bar widget
+ // add a label to show current scale
mCoordsLabel = new QLabel( QString(), statusBar() );
+ mCoordsLabel->setFont( myFont );
mCoordsLabel->setMinimumWidth( 10 );
mCoordsLabel->setMaximumHeight( 20 );
- mCoordsLabel->setFont( myFont );
mCoordsLabel->setMargin( 3 );
mCoordsLabel->setAlignment( Qt::AlignCenter );
- mCoordsLabel->setWhatsThis( tr( "Shows the map coordinates at the "
- "current cursor position. The display is continuously updated "
- "as the mouse is moved." ) );
+ mCoordsLabel->setFrameStyle( QFrame::NoFrame );
+ mCoordsLabel->setText( tr( "Coordinate:" ) );
+ mCoordsLabel->setToolTip( tr( "Current map coordinate" ) );
statusBar()->addPermanentWidget( mCoordsLabel, 0 );
+ //coords status bar widget
+ mCoordsEdit = new QLineEdit( QString(), statusBar() );
+ mCoordsEdit->setFont( myFont );
+ mCoordsEdit->setMinimumWidth( 10 );
+ mCoordsEdit->setMaximumWidth( 200 );
+ mCoordsEdit->setMaximumHeight( 20 );
+ mCoordsEdit->setContentsMargins( 0, 0, 0, 0 );
+ mCoordsEdit->setAlignment( Qt::AlignCenter );
+ QRegExp coordValidator( "[+-]?\\d+\\.?\\d*\\s*,\\s*[+-]?\\d+\\.?\\d*" );
+ mCoordsEditValidator = new QRegExpValidator( coordValidator, mCoordsEdit );
+ mCoordsEdit->setWhatsThis( tr( "Shows the map coordinates at the "
+ "current cursor position. The display is continuously updated "
+ "as the mouse is moved. It also allows editing to set the canvas "
+ "center to a given position." ) );
+ mCoordsEdit->setToolTip( tr( "Current map coordinate (formatted as x,y)" ) );
+ statusBar()->addPermanentWidget( mCoordsEdit, 0 );
+ connect( mCoordsEdit, SIGNAL( editingFinished() ), this, SLOT( userCenter() ) );
mScaleLabel = new QLabel( QString(), statusBar() );
mScaleLabel->setFont( myFont );
@@ -4666,11 +4687,10 @@
else
- mCoordsLabel->setText( p.toString( mMousePrecisionDecimalPlaces ) );
- // Set minimum necessary width
- if ( mCoordsLabel->width() > mCoordsLabel->minimumWidth() )
+ mCoordsEdit->setText( p.toString( mMousePrecisionDecimalPlaces ) );
+ if ( mCoordsEdit->width() > mCoordsEdit->minimumWidth() )
- mCoordsLabel->setMinimumWidth( mCoordsLabel->width() );
+ mCoordsEdit->setMinimumWidth( mCoordsEdit->width() );
@@ -4710,7 +4730,34 @@
+void QgisApp::userCenter()
+ QStringList parts = mCoordsEdit->text().split( ',' );
+ if ( parts.size() != 2 )
+ return;
+ bool xOk;
+ double x = parts.at( 0 ).toDouble( &xOk );
+ if ( !xOk )
+ return;
+ bool yOk;
+ double y = parts.at( 1 ).toDouble( &yOk );
+ if ( !yOk )
+ return;
+ QgsRectangle r = mMapCanvas->extent();
+ mMapCanvas->setExtent(
+ QgsRectangle(
+ x - r.width() / 2.0, y - r.height() / 2.0,
+ x + r.width() / 2.0, y + r.height() / 2.0
+ mMapCanvas->refresh();
// toggle overview status
void QgisApp::isInOverview()
@@ -5366,14 +5413,17 @@
//extents view mode!
mToggleExtentsViewButton->setIcon( getThemeIcon( "extents.png" ) );
- mCoordsLabel->setToolTip( tr( "Map coordinates for the current view extents" ) );
+ mCoordsEdit->setToolTip( tr( "Map coordinates for the current view extents" ) );
+ mCoordsEdit->setEnabled( false );
showExtents();
else
//mouse cursor pos view mode!
mToggleExtentsViewButton->setIcon( getThemeIcon( "tracking.png" ) );
- mCoordsLabel->setToolTip( tr( "Map coordinates at mouse cursor position" ) );
+ mCoordsEdit->setToolTip( tr( "Map coordinates at mouse cursor position" ) );
+ mCoordsEdit->setEnabled( true );
@@ -5381,16 +5431,17 @@
if ( !mToggleExtentsViewButton->isChecked() )
- //we are in show coords mode so no need to do anything
return;
// update the statusbar with the current extents.
QgsRectangle myExtents = mMapCanvas->extent();
- mCoordsLabel->setText( tr( "Extents: %1" ).arg( myExtents.toString( true ) ) );
+ mCoordsLabel->setText( tr( "Extents:" ) );
+ mCoordsEdit->setText( myExtents.toString( true ) );
//ensure the label is big enough
} // QgisApp::showExtents
@@ -6288,7 +6339,7 @@
void QgisApp::updateUndoActions()
bool canUndo = false, canRedo = false;
- QgsMapLayer* layer = this->activeLayer();
+ QgsMapLayer* layer = activeLayer();
if ( layer )
QgsVectorLayer* vlayer = dynamic_cast<QgsVectorLayer*>( layer );
Modified: trunk/qgis/src/app/qgisapp.h
--- trunk/qgis/src/app/qgisapp.h 2009-09-05 19:49:47 UTC (rev 11572)
+++ trunk/qgis/src/app/qgisapp.h 2009-09-05 19:50:05 UTC (rev 11573)
@@ -399,6 +399,8 @@
void showScale( double theScale );
//! Slot to handle user scale input;
void userScale();
+ //! Slot to handle user center input;
+ void userCenter();
//! Remove a layer from the map and legend
void removeLayer();
//! zoom to extent of layer
@@ -872,8 +874,12 @@
QLineEdit * mScaleEdit;
//! The validator for the mScaleEdit
QValidator * mScaleEditValidator;
- //! Widget that will live in the statusbar to display coords
+ //! Widget that will live on the statusbar to display "Coordinate / Extent"
QLabel * mCoordsLabel;
+ //! Widget that will live in the statusbar to display and edit coords
+ QLineEdit * mCoordsEdit;
+ //! The validator for the mCoordsEdit
+ QValidator * mCoordsEditValidator;
//! Widget that will live in the statusbar to show progress of operations
QProgressBar * mProgressBar;
//! Widget used to suppress rendering
