[QGIS Commit] r11633 - trunk/qgis/doc
svn_qgis at osgeo.org
Fri Sep 11 20:34:15 EDT 2009
Author: timlinux
Date: 2009-09-11 20:34:15 -0400 (Fri, 11 Sep 2009)
New Revision: 11633
trunk/qgis/doc/index.html
Some formatting repair work
Modified: trunk/qgis/doc/index.html
--- trunk/qgis/doc/index.html 2009-09-12 00:28:02 UTC (rev 11632)
+++ trunk/qgis/doc/index.html 2009-09-12 00:34:15 UTC (rev 11633)
@@ -37,25 +37,25 @@
<p>OSM plugin & provider updates:</p>
<ul>
- <li>new OSM style files</li>
- <li>new icons</li>
- <li>dialog text updated and completed</li>
- <li>"Saving OSM into file" functionality was improvements</li>
- <li>fixed some problems with encoding... ascii to utf-8</li>
- <li>all OSM layers are automatically removed after disabling OSM plugin in plugin manager</li>
- <li>other OSM related bugfixes</li>
+ <li>new OSM style files.</li>
+ <li>new icons.</li>
+ <li>dialog text updated and completed.</li>
+ <li>"Saving OSM into file" functionality was improvements.</li>
+ <li>fixed some problems with encoding... ascii to utf-8.</li>
+ <li>all OSM layers are automatically removed after disabling OSM plugin in plugin manager.</li>
+ <li>other OSM related bugfixes.</li>
</ul>
<p>Other notable features and improvements in this release</p>
<ul>
- <li>Marker size is now configurable when editing a layer</li>
- <li>Incorporation of the analysis library into the mainstream release</li>
- <li>Identify features across multiple layers</li>
+ <li>Marker size is now configurable when editing a layer.</li>
+ <li>Incorporation of the analysis library into the mainstream release.</li>
+ <li>Identify features across multiple layers.</li>
<li>Added a new plugin for carrying out raster terrain analysis (computing slope
- <li>aspect, steepness etc)</li>
+ aspect, steepness etc).</li>
<li>A reshape tool to apply to line/polygon geometries. The part of a geometry
- <li>between the first and last intersection of the reshape line will be replaced</li>
- <li>Added snapping to current layer in measure dialog</li>
+ between the first and last intersection of the reshape line will be replaced.</li>
+ <li>Added snapping to current layer in measure dialog.</li>
<li>Added ability to select the primary key for views.</li>
<li>Zoom to a coordinate by entering it in the status bar coordinate display.</li>
</ul>
