[QGIS Commit] r11634 - in trunk/qgis: doc src/app
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Sep 11 20:47:21 EDT 2009
Author: timlinux
Date: 2009-09-11 20:47:21 -0400 (Fri, 11 Sep 2009)
New Revision: 11634
   trunk/qgis/doc/index.html
   trunk/qgis/src/app/qgisapp.cpp
Updates to whats new and fixed version no in index.html
Modified: trunk/qgis/doc/index.html
--- trunk/qgis/doc/index.html	2009-09-12 00:34:15 UTC (rev 11633)
+++ trunk/qgis/doc/index.html	2009-09-12 00:47:21 UTC (rev 11634)
@@ -10,7 +10,7 @@
   </td>
   <td valign="center">
     <span class="header">Quantum GIS Documentation</span><br>
-    <span class="subheader">Version 1.2.0 <i>Daphnis</i></span><br>
+    <span class="subheader">Version 1.3.0 <i>Mimas</i></span><br>
     <span class="warning">Please read this entire document for important information about this release.</span>
   </td>
 </tr>
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp	2009-09-12 00:34:15 UTC (rev 11633)
+++ trunk/qgis/src/app/qgisapp.cpp	2009-09-12 00:47:21 UTC (rev 11634)
@@ -2044,123 +2044,48 @@
     abt->setVersion( versionString );
     QString whatsNew = "<html><body>" ;
     whatsNew += "<h2>" + tr( "Version" ) + " " + QString( QGis::QGIS_VERSION ) +  "</h2>";
-    whatsNew += "<h3>" + tr( "Whats new in Version 1.2.0?" ) + "</h3>"
+    whatsNew += "<h3>" + tr( "Whats new in Version 1.3.0?" ) + "</h3>"
                 "<p>"
                 + tr( "Please note that this is a release in our 'cutting edge' release series. As "
                       "such it contains new features and extends the programmatic interface over "
-                      "QGIS 1.0.x and QGIS 1.1.0. If stability and long term support is more important to you "
-                      "then cool new and untested features, we recommend that you use a copy "
-                      "of QGIS from our stable 1.0.x release series." )
+                      "QGIS 1.0.x and QGIS 1.2.0. If an unchanging user interface, programmatic API "
+                      "and long term support is more important to you then cool new and untested "
+                      "features, we recommend that you use a copy of QGIS from our Long Term Support "
+                      "(LTS)1.0.x release series." )
                 "</p><p>"
-                tr( "This release includes over 140 bug fixes and enhancements "
-                    "over the QGIS 1.1.0 release. In addition we have added "
+                tr( "This release includes over 30 bug fixes and enhancements "
+                    "over the QGIS 1.2.0 release. In addition we have added "
                     "the following new features:" )
-                + "<pre>"
-                + tr( "Editing:\n"
-                      "\n"
-                      "Editing functionality in QGIS has had a major update in this release. This\n"
-                      "includes the addition of new vector editing tools:\n"
-                      "- delete part of multipart feature\n"
-                      "- delete hole from polygon\n"
-                      "- simplify feature\n"
-                      "- Added a new node tool (in advanced digitizing toolbar).\n"
-                      "- New functionality for merging features\n"
-                      "- Added undo/redo functionality for vector layer editing.\n"
-                      "- Added option to show only markers of selected features in editing mode.\n"
-                      "- Change layer's icon in legend to reflext that the layer is editable.\n"
-                      "\n"
-                      "In addition, there are undo/redo actions in Edit menu, in Advanced digitizing toolbar\n"
-                      "and there is a new dock widget displaying undo stack of active layer.\n"
-                      "\n"
-                      "About the node tool: It resembles a tool for editing paths by nodes that is\n"
-                      "present in every vector editor. How does it work (in QGIS)? Click on a\n"
-                      "feature, its nodes will be marked by small rectangles. Clicking and dragging a\n"
-                      "node moves it. Double clicking a segment will add a new node. Pressing delete\n"
-                      "key will remove active node. It's possible to select more active nodes at\n"
-                      "once: by clicking and dragging a rectangle. It's possible to select a segment's\n"
-                      "adjacent nodes by clicking on the segment. It's possible to add/remove active\n"
-                      "nodes by using Ctrl when clicking a node or dragging a rectangle\n"
-                      "\n"
-                      "We recommend that you turn off vertex markers in QGIS options when working with\n"
-                      "this tool: the redraws are much faster and the map is not cluttered with\n"
-                      "markers. \n"
-                      "\n"
-                      "Keyboard shortcuts:\n"
-                      "\n"
-                      "New feature: configure shortcuts for actions within main window of qgis!\n"
-                      "See menu Setting->Configure shortcuts\n"
-                      "\n"
-                      "Map Composer:\n"
-                      "\n"
-                      "It is now possible to lock/unlock composer item positions by right mouse click.\n"
-                      "The width and height of the composer map will now remain fixed if user sets the\n"
-                      "composer map extent to the map canvas extent. possibility to display\n"
-                      "current date in composer label by typing (d 'June' yyyy) or similar.\n"
-                      "It is now possible to keep the current layers in a composer map even if further\n"
-                      "layers are added to the main map. Export to PDF in composer is now possible.\n"
-                      "\n"
-                      "Attribute tables:\n"
-                      "\n"
-                      "It is now possible to search the attribute table within selected records only.\n"
-                      "General speedups have been made on the attribute table. Setting of field width\n"
-                      "and precision when adding attributes is now possible. Handling of attribute\n"
-                      "types in WFS provider has bee improved.\n"
-                      "\n"
-                      "Attribute aliases for vector layers are now available. The aliases are shown\n"
-                      "instead of the original field names in the info tool and attribute table to\n"
-                      "make things easier for end users. There is now a GUI for setting edit widgets\n"
-                      "for layer attributes.  A new dialog allows loading a value map from a layer\n"
-                      "(could be non-spatial table too!).  The edit widgets settings will also now\n"
-                      "be respected in the attribute table.\n"
-                      "\n"
-                      "Plugins:\n"
-                      "\n"
-                      "- The order of layers in the WMS dialog can now be changed.\n"
-                      "- The eVis plugin, version 1.1.0, has been added to the QGIS project and\n"
-                      "  included as a standard plugin. More information about eVis can be found here:\n"
-                      "  http://biodiversityinformatics.amnh.org/open_source/evis/documentation.php .\n"
-                      "- The interpolation plugin now has the ability to use line layers as constrains\n"
-                      "  for triangulation in interpolation plugin. You can also now save the\n"
-                      "  triangulation to shape file.\n"
-                      "- An new OpenStreetMap provider and plugin have been added to QGIS.\n"
-                      "\n"
-                      "Projects Management:\n"
-                      "\n"
-                      "QGIS now includes support for  project relative position of file data sources\n"
-                      "and svgs. The saving of relative paths of file data sources is optional.\n"
-                      "\n"
-                      "PostGIS & the PostgreSQL Provider:\n"
-                      "\n"
-                      "You can now select the SSL mode when adding a new DB connection. Turning off\n"
-                      "SSL encryption can greatly improve performance of PostGIS data loading where\n"
-                      "connection security is not required. Support has been added for more native\n"
-                      "types and for setting of column comments.\n"
-                      "\n"
-                      "Symbology enhancements:\n"
-                      "\n"
-                      "- allow refresh of symbols via popup menu on the renderer's symbol selection\n"
-                      "- add support for data defined symbol(name)s\n"
-                      "- add support for font symbol markers (only data defined - no gui yet)\n"
-                      "- add symbol size in map units (ie. symbols that keep the size in mapunits\n"
-                      "  independent of the mapscale)\n"
-                      "\n"
-                      "Command line arguments:\n"
-                      "\n"
-                      "Added command line argument support on windows.\n"
-                      "Enhancement of command line arguments:\n"
-                      "- allow given snapshot sizes\n"
-                      "- allow suppression of splash screen\n"
-                      "- capture map decorations from plugins on snapshots\n"
-                      "\n"
-                      "Grass:\n"
-                      "\n"
-                      "There is a new GRASS shell. Also there have been many cleanups and consistency\n"
-                      "updates." )
-                + "</pre></body></html>";
+                + tr("<p>OSM plugin &amp; provider updates:</p>"
+                "<ul>"
+                  "<li>new OSM style files.</li>"
+                  "<li>new icons.</li>"
+                  "<li>dialog text updated and completed.</li>"
+                  "<li>Saving OSM into file functionality was improvements.</li>"
+                  "<li>fixed some problems with encoding... ascii to utf-8.</li>"
+                  "<li>all OSM layers are automatically removed after disabling OSM plugin in plugin manager.</li>"
+                  "<li>other OSM related bugfixes.</li>"
+                "</ul>"
+                "<p>Other notable features and improvements in this release</p>"
+                "<ul>"
+                  "<li>Marker size is now configurable when editing a layer.</li>"
+                  "<li>Incorporation of the analysis library into the mainstream release.</li>"
+                  "<li>Identify features across multiple layers.</li>"
+                  "<li>Added a new plugin for carrying out raster terrain analysis (computing slope"
+                  "    aspect, steepness etc).</li>"
+                  "<li>A reshape tool to apply to line/polygon geometries. The part of a geometry"
+                  "   between the first and last intersection of the reshape line will be replaced.</li>"
+                  "<li>Added snapping to current layer in measure dialog.</li>"
+                  "<li>Added ability to select the primary key for views.</li>"
+                  "<li>Zoom to a coordinate by entering it in the status bar coordinate display.</li>"
+                "</ul>")
+                + "</body></html>";
     abt->setWhatsNew( whatsNew );
     QApplication::restoreOverrideCursor();
More information about the QGIS-commit mailing list
