[QGIS Commit] r11671 - in trunk/qgis: images/themes/default src/app
svn_qgis at osgeo.org
Wed Sep 16 15:02:27 EDT 2009
Author: mhugent
Date: 2009-09-16 15:02:26 -0400 (Wed, 16 Sep 2009)
New Revision: 11671
Added:
trunk/qgis/images/themes/default/mActionRotatePointSymbols.png
trunk/qgis/src/app/qgsmaptoolrotatepointsymbols.cpp
trunk/qgis/src/app/qgsmaptoolrotatepointsymbols.h
trunk/qgis/src/app/qgspointrotationitem.cpp
trunk/qgis/src/app/qgspointrotationitem.h
trunk/qgis/src/app/CMakeLists.txt
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/app/qgisapp.h
[FEATURE]: add tool to graphically rotate points (by changing the value of the rotation field). Needs some more beautifying, perhaps a nicer arrow
Added: trunk/qgis/images/themes/default/mActionRotatePointSymbols.png
(Binary files differ)
Property changes on: trunk/qgis/images/themes/default/mActionRotatePointSymbols.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Modified: trunk/qgis/src/app/CMakeLists.txt
--- trunk/qgis/src/app/CMakeLists.txt 2009-09-16 11:55:36 UTC (rev 11670)
+++ trunk/qgis/src/app/CMakeLists.txt 2009-09-16 19:02:26 UTC (rev 11671)
@@ -40,6 +40,7 @@
qgsmaptoolmovevertex.cpp
qgsmaptoolnodetool.cpp
qgsmaptoolreshape.cpp
+ qgsmaptoolrotatepointsymbols.cpp
qgsmaptoolselect.cpp
qgsmaptoolsimplify.cpp
qgsmaptoolsplitfeatures.cpp
@@ -52,6 +53,7 @@
qgsogrsublayersdialog.cpp
qgsoptions.cpp
qgspastetransformations.cpp
+ qgspointrotationitem.cpp
qgspluginitem.cpp
qgspluginmanager.cpp
qgspluginmetadata.cpp
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2009-09-16 11:55:36 UTC (rev 11670)
+++ trunk/qgis/src/app/qgisapp.cpp 2009-09-16 19:02:26 UTC (rev 11671)
@@ -172,6 +172,7 @@
#include "qgsmaptoolpan.h"
#include "qgsmaptoolselect.h"
#include "qgsmaptoolreshape.h"
+#include "qgsmaptoolrotatepointsymbols.h"
#include "qgsmaptoolsplitfeatures.h"
#include "qgsmaptoolvertexedit.h"
#include "qgsmaptoolzoom.h"
@@ -740,6 +741,12 @@
connect( mActionNodeTool, SIGNAL( triggered() ), this, SLOT( nodeTool() ) );
mActionNodeTool->setEnabled( false );
+ mActionRotatePointSymbols = new QAction( getThemeIcon( "mActionRotatePointSymbols.png" ), tr( "Rotate Point Symbols" ), this );
+ shortcuts->registerAction( mActionRotatePointSymbols );
+ mActionRotatePointSymbols->setStatusTip( tr( "Rotate Point Symbols" ) );
+ connect( mActionRotatePointSymbols, SIGNAL( triggered() ), this, SLOT( rotatePointSymbols() ) );
+ mActionRotatePointSymbols->setEnabled( false );
// View Menu Items
mActionPan = new QAction( getThemeIcon( "mActionPan.png" ), tr( "Pan Map" ), this );
@@ -1094,7 +1101,8 @@
mMapToolGroup->addAction( mActionMergeFeatures );
mActionNodeTool->setCheckable( true );
mMapToolGroup->addAction( mActionNodeTool );
+ mActionRotatePointSymbols->setCheckable( true );
+ mMapToolGroup->addAction( mActionRotatePointSymbols );
void QgisApp::createMenus()
@@ -1189,6 +1197,7 @@
mEditMenu->addAction( mActionSplitFeatures );
mEditMenu->addAction( mActionMergeFeatures );
mEditMenu->addAction( mActionNodeTool );
+ mEditMenu->addAction( mActionRotatePointSymbols );
if ( layout == QDialogButtonBox::GnomeLayout || layout == QDialogButtonBox::MacLayout )
@@ -1398,6 +1407,7 @@
mAdvancedDigitizeToolBar->addAction( mActionSplitFeatures );
mAdvancedDigitizeToolBar->addAction( mActionMergeFeatures );
mAdvancedDigitizeToolBar->addAction( mActionNodeTool );
+ mAdvancedDigitizeToolBar->addAction( mActionRotatePointSymbols );
mToolbarMenu->addAction( mAdvancedDigitizeToolBar->toggleViewAction() );
@@ -1788,6 +1798,8 @@
mMapTools.mDeletePart->setAction( mActionDeletePart );
mMapTools.mNodeTool = new QgsMapToolNodeTool( mMapCanvas );
mMapTools.mNodeTool->setAction( mActionNodeTool );
+ mMapTools.mRotatePointSymbolsTool = new QgsMapToolRotatePointSymbols( mMapCanvas );
+ mMapTools.mRotatePointSymbolsTool->setAction( mActionRotatePointSymbols );
//ensure that non edit tool is initialised or we will get crashes in some situations
mNonEditMapTool = mMapTools.mPan;
@@ -4298,6 +4310,11 @@
mMapCanvas->setMapTool( mMapTools.mNodeTool );
+void QgisApp::rotatePointSymbols()
+ mMapCanvas->setMapTool( mMapTools.mRotatePointSymbolsTool );
void QgisApp::splitFeatures()
mMapCanvas->setMapTool( mMapTools.mSplitFeatures );
@@ -5639,11 +5656,19 @@
mActionSplitFeatures->setEnabled( false );
mActionSimplifyFeature->setEnabled( false );
mActionDeleteRing->setEnabled( false );
if ( vlayer->isEditable() && dprovider->capabilities() & QgsVectorDataProvider::ChangeGeometries )
mActionMoveVertex->setEnabled( true );
+ if ( vlayer->isEditable() && dprovider->capabilities() & QgsVectorDataProvider::ChangeAttributeValues )
+ if ( QgsMapToolRotatePointSymbols::layerIsRotatable( vlayer ) )
+ mActionRotatePointSymbols->setEnabled( true );
return;
else if ( vlayer->geometryType() == QGis::Line )
@@ -5752,6 +5777,9 @@
mActionCopyFeatures->setEnabled( false );
mActionCutFeatures->setEnabled( false );
mActionPasteFeatures->setEnabled( false );
+ mActionNodeTool->setEnabled( false );
+ mActionDeletePart->setEnabled( false );
//NOTE: This check does not really add any protection, as it is called on load not on layer select/activate
//If you load a layer with a provider and idenitfy ability then load another without, the tool would be disabled for both
Modified: trunk/qgis/src/app/qgisapp.h
--- trunk/qgis/src/app/qgisapp.h 2009-09-16 11:55:36 UTC (rev 11670)
+++ trunk/qgis/src/app/qgisapp.h 2009-09-16 19:02:26 UTC (rev 11671)
@@ -523,6 +523,8 @@
void mergeSelectedFeatures();
//! provides operations with nodes
void nodeTool();
+ //! activates the rotate points tool
+ void rotatePointSymbols();
//! activates the selection tool
void select();
@@ -742,6 +744,7 @@
QAction *mActionDeletePart;
QAction *mActionMergeFeatures;
QAction *mActionNodeTool;
+ QAction *mActionRotatePointSymbols;
QAction *mActionEditSeparator3;
QAction *mActionPan;
@@ -864,6 +867,7 @@
QgsMapTool* mDeleteRing;
QgsMapTool* mDeletePart;
QgsMapTool* mNodeTool;
+ QgsMapTool* mRotatePointSymbolsTool;
} mMapTools;
QgsMapTool *mNonEditMapTool;
Added: trunk/qgis/src/app/qgsmaptoolrotatepointsymbols.cpp
--- trunk/qgis/src/app/qgsmaptoolrotatepointsymbols.cpp (rev 0)
+++ trunk/qgis/src/app/qgsmaptoolrotatepointsymbols.cpp 2009-09-16 19:02:26 UTC (rev 11671)
@@ -0,0 +1,250 @@
+ begin : September 2009
+ copyright : (C) 2009 by Marco Hugentobler
+ email : marco at hugis dot net
+ * This program is free software; you can redistribute it and/or modify *
+ * it under the terms of the GNU General Public License as published by *
+ * the Free Software Foundation; either version 2 of the License, or *
+ * (at your option) any later version. *
+#include "qgsapplication.h"
+#include "qgsmapcanvas.h"
+#include "qgspointrotationitem.h"
+#include "qgsrenderer.h"
+#include "qgssymbol.h"
+#include "qgsvectorlayer.h"
+#include <QGraphicsPixmapItem>
+#include <QMessageBox>
+#include <QMouseEvent>
+QgsMapToolRotatePointSymbols::QgsMapToolRotatePointSymbols( QgsMapCanvas* canvas ): QgsMapToolEdit( canvas ), \
+ mActiveLayer( 0 ), mFeatureNumber( 0 ), mCurrentMouseAzimut( 0.0 ), mCurrentRotationFeature( 0.0 ), mRotating( false ), mRotationItem( 0 )
+QgsMapToolRotatePointSymbols::~QgsMapToolRotatePointSymbols()
+ delete mRotationItem;
+bool QgsMapToolRotatePointSymbols::layerIsRotatable( QgsMapLayer* ml )
+ if ( !ml )
+ return false;
+ //a vector layer
+ QgsVectorLayer* vLayer = dynamic_cast<QgsVectorLayer*>( ml );
+ if ( !vLayer )
+ return false;
+ //does it have point or multipoint type?
+ if ( vLayer->geometryType() != QGis::Point )
+ return false;
+ //does it have a least one rotation attribute?
+ QList<int> rotationAttributes;
+ layerRotationAttributes( vLayer, rotationAttributes );
+ if ( rotationAttributes.size() < 1 )
+ return false;
+ return true;
+void QgsMapToolRotatePointSymbols::canvasPressEvent( QMouseEvent * e )
+ if ( !mCanvas )
+ return;
+ mActiveLayer = currentVectorLayer();
+ if ( !mActiveLayer )
+ return;
+ if ( mActiveLayer->geometryType() != QGis::Point || !mActiveLayer->isEditable() )
+ return;
+ //find the closest feature to the pressed position
+ QgsMapCanvasSnapper canvasSnapper( mCanvas );
+ QList<QgsSnappingResult> snapResults;
+ if ( canvasSnapper.snapToCurrentLayer( e->pos(), snapResults, QgsSnapper::SnapToVertex, -1 ) != 0 || snapResults.size() < 1 )
+ QMessageBox::critical( 0, tr( "No point feature" ), tr( "No point feature was detected at the clicked position. Please click closer to the feature or enhance the search tolerance under Settings->Options->Digitizing->Serch radius for vertex edits" ) );
+ return; //error during snapping
+ mFeatureNumber = snapResults.at( 0 ).snappedAtGeometry;
+ //get list with renderer rotation attributes
+ if ( layerRotationAttributes( mActiveLayer, mCurrentRotationAttributes ) != 0 )
+ return;
+ if ( mCurrentRotationAttributes.size() < 1 )
+ QMessageBox::critical( 0, tr( "No rotation Attributes" ), tr( "The active point layer does not have a rotation attribute" ) );
+ return;
+ mSnappedPoint = toCanvasCoordinates( snapResults.at( 0 ).snappedVertex );
+ //find out initial arrow direction
+ QgsFeature pointFeature;
+ if ( !mActiveLayer->featureAtId( mFeatureNumber, pointFeature, false, true ) )
+ return;
+ const QgsAttributeMap pointFeatureAttributes = pointFeature.attributeMap();
+ const QgsAttributeMap::const_iterator attIt = pointFeatureAttributes.find( mCurrentRotationAttributes.at( 0 ) );
+ if ( attIt == pointFeatureAttributes.constEnd() )
+ return;
+ mCurrentRotationFeature = attIt.value().toDouble();
+ createPixmapItem();
+ if ( mRotationItem )
+ mRotationItem->setPointLocation( snapResults.at( 0 ).snappedVertex );
+ mCurrentMouseAzimut = calculateAzimut( e->pos() );
+ setPixmapItemRotation( mCurrentMouseAzimut );
+ mRotating = true;
+void QgsMapToolRotatePointSymbols::canvasMoveEvent( QMouseEvent * e )
+ if ( !mRotating )
+ return;
+ double azimut = calculateAzimut( e->pos() );
+ double azimutDiff = azimut - mCurrentMouseAzimut;
+ //assign new feature rotation, making sure to respect the 0 - 360 degree range
+ mCurrentRotationFeature += azimutDiff;
+ if ( mCurrentRotationFeature < 0 )
+ mCurrentRotationFeature = 360 - mCurrentRotationFeature;
+ else if ( mCurrentRotationFeature >= 360 )
+ mCurrentRotationFeature -= 360;
+ mCurrentMouseAzimut = azimut;
+ if ( mCurrentMouseAzimut < 0 )
+ mCurrentMouseAzimut = 360 - mCurrentMouseAzimut;
+ else if ( mCurrentMouseAzimut >= 360 )
+ mCurrentMouseAzimut -= 360;
+ setPixmapItemRotation( mCurrentRotationFeature );
+void QgsMapToolRotatePointSymbols::canvasReleaseEvent( QMouseEvent * e )
+ if ( mRotating && mActiveLayer )
+ mActiveLayer->beginEditCommand( tr( "Rotate symbol" ) );
+ bool rotateSuccess = true;
+ //write mCurrentRotationFeature to all rotation attributes of feature (mFeatureNumber)
+ QList<int>::const_iterator it = mCurrentRotationAttributes.constBegin();
+ for ( ; it != mCurrentRotationAttributes.constEnd(); ++it )
+ if ( !mActiveLayer->changeAttributeValue( mFeatureNumber, *it, mCurrentRotationFeature, true ) )
+ rotateSuccess = false;
+ if ( rotateSuccess )
+ mActiveLayer->endEditCommand();
+ else
+ mActiveLayer->destroyEditCommand();
+ mRotating = false;
+ mRotationItem = 0;
+ mCanvas->refresh();
+int QgsMapToolRotatePointSymbols::layerRotationAttributes( const QgsVectorLayer* vl, QList<int>& attList )
+ attList.clear();
+ if ( !vl )
+ return 1;
+ //get renderer
+ const QgsRenderer* layerRenderer = vl->renderer();
+ if ( !layerRenderer )
+ return 2;
+ //get renderer symbols
+ const QList<QgsSymbol*> rendererSymbols = layerRenderer->symbols();
+ int currentRotationAttribute;
+ QList<QgsSymbol*>::const_iterator symbolIt = rendererSymbols.constBegin();
+ for ( ; symbolIt != rendererSymbols.constEnd(); ++symbolIt )
+ currentRotationAttribute = ( *symbolIt )->rotationClassificationField();
+ if ( currentRotationAttribute >= 0 )
+ attList.push_back( currentRotationAttribute );
+ return 0;
+double QgsMapToolRotatePointSymbols::calculateAzimut( const QPoint& mousePos )
+ int dx = mousePos.x() - mSnappedPoint.x();
+ int dy = mousePos.y() - mSnappedPoint.y();
+ return 180 - atan2( dx, dy ) * 180.0 / M_PI;
+void QgsMapToolRotatePointSymbols::createPixmapItem()
+ mRotationItem = new QgsPointRotationItem( mCanvas );
+ mRotationItem->setSymbol( QgsApplication::defaultThemePath() + "mActionArrowUp.png" );
+ mCanvas->scene()->addItem( mRotationItem );
+void QgsMapToolRotatePointSymbols::setPixmapItemRotation( double rotation )
+ mRotationItem->setSymbolRotation( rotation );
+ mRotationItem->update();
Added: trunk/qgis/src/app/qgsmaptoolrotatepointsymbols.h
--- trunk/qgis/src/app/qgsmaptoolrotatepointsymbols.h (rev 0)
+++ trunk/qgis/src/app/qgsmaptoolrotatepointsymbols.h 2009-09-16 19:02:26 UTC (rev 11671)
@@ -0,0 +1,68 @@
+ qgsmaptoolrotatepointsymbols.h
+#ifndef QGSMAPTOOLROTATEPOINTSYMBOLS_H
+#define QGSMAPTOOLROTATEPOINTSYMBOLS_H
+#include "qgsmaptooledit.h"
+class QgsPointRotationItem;
+/**A class that allows to interactively manipulate the value of the rotation field(s) for point layers*/
+class QgsMapToolRotatePointSymbols: public QgsMapToolEdit
+ public:
+ QgsMapToolRotatePointSymbols( QgsMapCanvas* canvas );
+ ~QgsMapToolRotatePointSymbols();
+ void canvasPressEvent( QMouseEvent * e );
+ void canvasMoveEvent( QMouseEvent * e );
+ void canvasReleaseEvent( QMouseEvent * e );
+ bool isEditTool() {return true;}
+ /**Returns true if the symbols of a maplayer can be rotated. This means the layer \
+ is a vector layer, has type point or multipoint and has at least one rotation attribute in the renderer*/
+ static bool layerIsRotatable( QgsMapLayer* ml );
+ private:
+ QgsVectorLayer* mActiveLayer;
+ int mFeatureNumber;
+ /**Last azimut between mouse and edited point*/
+ double mCurrentMouseAzimut;
+ /**Last feature rotation*/
+ double mCurrentRotationFeature;
+ bool mRotating;
+ QList<int> mCurrentRotationAttributes;
+ /**Screen coordinate of the snaped feature*/
+ QPoint mSnappedPoint;
+ /**Item that displays rotation during mouse move*/
+ QgsPointRotationItem* mRotationItem;
+ /**Finds out the rotation attributes of mActiveLayers
+ @param vl the point vector layer
+ @param attList out: the list containing the rotation indices
+ @return 0 in case of success*/
+ static int layerRotationAttributes( const QgsVectorLayer* vl, QList<int>& attList );
+ void drawArrow( double azimut ) const;
+ /**Calculates the azimut between mousePos and mSnappedPoint*/
+ double calculateAzimut( const QPoint& mousePos );
+ /**Create item that shows rotation to the user*/
+ void createPixmapItem();
+ /**Sets the rotation of the pixmap item*/
+ void setPixmapItemRotation( double rotation );
+#endif // QGSMAPTOOLROTATEPOINTSYMBOLS_H
Added: trunk/qgis/src/app/qgspointrotationitem.cpp
--- trunk/qgis/src/app/qgspointrotationitem.cpp (rev 0)
+++ trunk/qgis/src/app/qgspointrotationitem.cpp 2009-09-16 19:02:26 UTC (rev 11671)
@@ -0,0 +1,97 @@
+#include <QPainter>
+#ifndef Q_OS_MACX
+#include <cmath>
+#else
+#include <math.h>
+#endif
+QgsPointRotationItem::QgsPointRotationItem( QgsMapCanvas* canvas ): QgsMapCanvasItem( canvas ), mRotation( 0.0 )
+ //setup font
+ mFont.setPointSize( 12 );
+ mFont.setBold( true );
+QgsPointRotationItem::QgsPointRotationItem(): QgsMapCanvasItem( 0 ), mRotation( 0.0 )
+QgsPointRotationItem::~QgsPointRotationItem()
+void QgsPointRotationItem::paint( QPainter * painter )
+ if ( !painter )
+ return;
+ painter->save();
+ //do a bit of trigonometry to find out how to transform a rotated item such that the center point is at the point feature
+ double x = 0;
+ double y = 0;
+ double h, dAngel;
+ if ( mPixmap.width() > 0 && mPixmap.height() > 0 )
+ h = sqrt( mPixmap.width() * mPixmap.width() + mPixmap.height() * mPixmap.height() ) / 2; //the half of the item diagonal
+ dAngel = acos( mPixmap.width() / ( h * 2 ) ) * 180 / M_PI; //the diagonal angel of the original rect
+ x = h * cos(( mRotation - dAngel ) * M_PI / 180 );
+ y = h * sin(( mRotation - dAngel ) * M_PI / 180 );
+ //painter->translate(-mPixmap.width() / 2.0, -mPixmap.width() / 2.0);
+ painter->rotate( mRotation );
+ painter->translate( x - mPixmap.width() / 2.0, -y - mPixmap.height() / 2.0 );
+ painter->drawPixmap( 0, 0, mPixmap );
+ //draw numeric value beside the symbol
+ painter->restore();
+ QFontMetricsF fm( mFont );
+ painter->fillRect( mPixmap.width(), 0, mItemSize.width() - mPixmap.width(), mItemSize.height(), QColor( Qt::white ) );
+ painter->setFont( mFont );
+ painter->drawText( mPixmap.width(), mPixmap.height() / 2.0 + fm.height() / 2.0, QString::number( mRotation, 'f', 2 ) );
+void QgsPointRotationItem::setPointLocation( const QgsPoint& p )
+ QPointF transformedPoint = toCanvasCoordinates( p );
+ setPos( transformedPoint.x() - mPixmap.width() / 2.0, transformedPoint.y() - mPixmap.height() / 2.0 );
+void QgsPointRotationItem::setSymbol( const QString& symbolPath )
+ mPixmap = QPixmap( symbolPath );
+ mItemSize.setWidth( mPixmap.width() + fm.width( "360.99" ) );
+ double pixmapHeight = mPixmap.height();
+ double fontHeight = fm.height();
+ if ( pixmapHeight >= fontHeight )
+ mItemSize.setHeight( mPixmap.height() );
+ else
+ mItemSize.setHeight( fm.height() );
Added: trunk/qgis/src/app/qgspointrotationitem.h
--- trunk/qgis/src/app/qgspointrotationitem.h (rev 0)
+++ trunk/qgis/src/app/qgspointrotationitem.h 2009-09-16 19:02:26 UTC (rev 11671)
@@ -0,0 +1,51 @@
+ qgspointrotationitem.h
+#ifndef QGSPOINTROTATIONITEM_H
+#define QGSPOINTROTATIONITEM_H
+#include "qgsmapcanvasitem.h"
+#include <QFontMetricsF>
+#include <QPixmap>
+/**An item that shows a rotated point symbol (e.g. arrow) centered to a map location together with a text displaying the rotation value*/
+class QgsPointRotationItem: public QgsMapCanvasItem
+ public:
+ QgsPointRotationItem( QgsMapCanvas* canvas );
+ ~QgsPointRotationItem();
+ void paint( QPainter * painter );
+ /**Sets the center point of the rotation symbol (in map coordinates)*/
+ void setPointLocation( const QgsPoint& p );
+ /**Sets the rotation of the symbol and displays the new rotation number. \
+ Units are degrees, starting from north direction, clockwise direction*/
+ void setSymbolRotation( double r ) {mRotation = r;}
+ /**Sets a symbol from image file*/
+ void setSymbol( const QString& symbolPath );
+ private:
+ QgsPointRotationItem();
+ /**Font to display the numerical rotation values*/
+ QFont mFont;
+ /**Symboll pixmap*/
+ QPixmap mPixmap;
+ double mRotation;
+#endif // QGSPOINTROTATIONITEM_H
