[QGIS Commit] r11719 - in trunk/qgis/src: app providers/ogr ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Sep 27 03:55:01 EDT 2009
Author: timlinux
Date: 2009-09-27 03:55:01 -0400 (Sun, 27 Sep 2009)
New Revision: 11719
Added:
   trunk/qgis/src/app/qgsnewvectorlayerdialog.cpp
   trunk/qgis/src/app/qgsnewvectorlayerdialog.h
   trunk/qgis/src/ui/qgsnewvectorlayerdialogbase.ui
Removed:
   trunk/qgis/src/app/qgsgeomtypedialog.cpp
   trunk/qgis/src/app/qgsgeomtypedialog.h
   trunk/qgis/src/ui/qgsaddattrdialogbase.ui
   trunk/qgis/src/app/CMakeLists.txt
   trunk/qgis/src/app/qgisapp.cpp
   trunk/qgis/src/providers/ogr/qgsogrprovider.cpp
   trunk/qgis/src/ui/qgsattributetabledialog.ui
   trunk/qgis/src/ui/qgsgeomtypedialogbase.ui
Usability improvements to the new vector layer dialog. Also refactored so that the dialog an class names are now a more logical QgsNewVectorDialog
Modified: trunk/qgis/src/app/CMakeLists.txt
--- trunk/qgis/src/app/CMakeLists.txt	2009-09-27 01:19:07 UTC (rev 11718)
+++ trunk/qgis/src/app/CMakeLists.txt	2009-09-27 07:55:01 UTC (rev 11719)
@@ -20,7 +20,7 @@
   qgsspatialitefilterproxymodel.cpp
   qgsspatialitetablemodel.cpp
   qgsdelattrdialog.cpp
-  qgsgeomtypedialog.cpp
+  qgsnewvectorlayerdialog.cpp
   qgsgraduatedsymboldialog.cpp
   qgshelpviewer.cpp
   qgsidentifyresults.cpp
@@ -122,7 +122,7 @@
   qgsconfigureshortcutsdialog.h
   qgscustomprojectiondialog.h
   qgsdelattrdialog.h
-  qgsgeomtypedialog.h
+  qgsnewvectorlayerdialog.h
   qgsgraduatedsymboldialog.h
   qgshelpviewer.h
   qgsidentifyresults.h
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp	2009-09-27 01:19:07 UTC (rev 11718)
+++ trunk/qgis/src/app/qgisapp.cpp	2009-09-27 07:55:01 UTC (rev 11719)
@@ -102,7 +102,7 @@
 #include "qgsogrsublayersdialog.h"
 #include "qgsexception.h"
 #include "qgsfeature.h"
-#include "qgsgeomtypedialog.h"
+#include "qgsnewvectorlayerdialog.h"
 #include "qgshelpviewer.h"
 #include "qgsgenericprojectionselector.h"
 #include "qgslegend.h"
@@ -3139,6 +3139,9 @@
 void QgisApp::newVectorLayer()
+  QgsDebugMsg( "++++++++++++++++++++++++++++++++++++++++++" );
+  QgsDebugMsg( "newVectorLayer called" );
   if ( mMapCanvas && mMapCanvas->isDrawing() )
@@ -3148,13 +3151,14 @@
   QGis::WkbType geometrytype;
   QString fileformat;
-  QgsGeomTypeDialog geomDialog( this );
+  QgsNewVectorLayerDialog geomDialog( this );
   if ( geomDialog.exec() == QDialog::Rejected )
     return;
   geometrytype = geomDialog.selectedType();
   fileformat = geomDialog.selectedFileFormat();
+  QgsDebugMsg ( QString( "New file format will be: %1" ).arg( fileformat ) );
   std::list<std::pair<QString, QString> > attributes;
   geomDialog.attributes( attributes );
@@ -3260,6 +3264,9 @@
   fileNames.append( fileName );
   //todo: the last parameter will change accordingly to layer type
   addVectorLayers( fileNames, enc, "file" );
+  QgsDebugMsg( "newVectorLayer done!" );
 void QgisApp::fileOpen()
Deleted: trunk/qgis/src/app/qgsgeomtypedialog.cpp
--- trunk/qgis/src/app/qgsgeomtypedialog.cpp	2009-09-27 01:19:07 UTC (rev 11718)
+++ trunk/qgis/src/app/qgsgeomtypedialog.cpp	2009-09-27 07:55:01 UTC (rev 11719)
@@ -1,115 +0,0 @@
-                         qgsgeomtypedialog.cpp  -  description
-    begin                : October 2004
-    copyright            : (C) 2004 by Marco Hugentobler
-    email                : marco.hugentobler at autoform.ch
- *   This program is free software; you can redistribute it and/or modify  *
- *   it under the terms of the GNU General Public License as published by  *
- *   the Free Software Foundation; either version 2 of the License, or     *
- *   (at your option) any later version.                                   *
-/* $Id$ */
-#include "qgsapplication.h"
-#include "qgisapp.h" // <- for theme icons
-#include "qgslogger.h"
-#include <QPushButton>
-QgsGeomTypeDialog::QgsGeomTypeDialog( QWidget *parent, Qt::WFlags fl )
-    : QDialog( parent, fl )
-  setupUi( this );
-  mAddAttributeButton->setIcon( QgisApp::getThemeIcon( "/mActionNewAttribute.png" ) );
-  mRemoveAttributeButton->setIcon( QgisApp::getThemeIcon( "/mActionDeleteAttribute.png" ) );
-  mTypeBox->addItem( tr( "String" ), "String" );
-  mTypeBox->addItem( tr( "Integer" ), "Integer" );
-  mTypeBox->addItem( tr( "Real" ), "Real" );
-  mPointRadioButton->setChecked( true );
-  mFileFormatComboBox->addItem( "ESRI Shapefile" );
-  /*mFileFormatComboBox->addItem("Comma Separated Value");
-  mFileFormatComboBox->addItem("GML");
-  mFileFormatComboBox->addItem("Mapinfo File");*/
-  mOkButton = buttonBox->button( QDialogButtonBox::Ok );
-  mOkButton->setEnabled( false );
-QgsGeomTypeDialog::~QgsGeomTypeDialog()
-void QgsGeomTypeDialog::on_mTypeBox_currentIndexChanged( int index )
-  mPrecision->setEnabled( index == 2 );  // Real
-QGis::WkbType QgsGeomTypeDialog::selectedType() const
-  if ( mPointRadioButton->isChecked() )
-    return QGis::WKBPoint;
-  else if ( mLineRadioButton->isChecked() )
-    return QGis::WKBLineString;
-  else if ( mPolygonRadioButton->isChecked() )
-    return QGis::WKBPolygon;
-  return QGis::WKBUnknown;
-void QgsGeomTypeDialog::on_mAddAttributeButton_clicked()
-  QString myName = mNameEdit->text();
-  QString myWidth = mWidth->text();
-  QString myPrecision = mPrecision->text();
-  //use userrole to avoid translated type string
-  QString myType = mTypeBox->itemData( mTypeBox->currentIndex(), Qt::UserRole ).toString();
-  mAttributeView->addTopLevelItem( new QTreeWidgetItem( QStringList() << myName << myType << myWidth << myPrecision ) );
-  if ( mAttributeView->topLevelItemCount() > 0 )
-    mOkButton->setEnabled( true );
-  mNameEdit->clear();
-void QgsGeomTypeDialog::on_mRemoveAttributeButton_clicked()
-  delete( mAttributeView->currentItem() );
-  if ( mAttributeView->topLevelItemCount() == 0 )
-void QgsGeomTypeDialog::on_buttonBox_helpRequested()
-  QgsContextHelp::run( context_id );
-void QgsGeomTypeDialog::attributes( std::list<std::pair<QString, QString> >& at ) const
-  QTreeWidgetItemIterator it( mAttributeView );
-  while ( *it )
-    QTreeWidgetItem *item = *it;
-    QString type = QString( "%1;%2;%3" ).arg( item->text( 1 ) ).arg( item->text( 2 ) ).arg( item->text( 3 ) );
-    at.push_back( std::make_pair( item->text( 0 ), type ) );
-    QgsDebugMsg( QString( "appending %1//%2" ).arg( item->text( 0 ) ).arg( type ) );
-    ++it;
-QString QgsGeomTypeDialog::selectedFileFormat() const
-  return mFileFormatComboBox->currentText();
Deleted: trunk/qgis/src/app/qgsgeomtypedialog.h
--- trunk/qgis/src/app/qgsgeomtypedialog.h	2009-09-27 01:19:07 UTC (rev 11718)
+++ trunk/qgis/src/app/qgsgeomtypedialog.h	2009-09-27 07:55:01 UTC (rev 11719)
@@ -1,52 +0,0 @@
-                         qgsgeomtypedialog.h  -  description
-/* $Id$ */
-#ifndef QGSGEOMTYPEDIALOG_H
-#define QGSGEOMTYPEDIALOG_H
-#include "ui_qgsgeomtypedialogbase.h"
-#include "qgisgui.h"
-#include "qgscontexthelp.h"
-#include "qgis.h"
-class QgsGeomTypeDialog: public QDialog, private Ui::QgsGeomTypeDialogBase
-    Q_OBJECT
-  public:
-    QgsGeomTypeDialog( QWidget *parent = 0, Qt::WFlags fl = QgisGui::ModalDialogFlags );
-    ~QgsGeomTypeDialog();
-    /**Returns the selected geometry type*/
-    QGis::WkbType selectedType() const;
-    /**Appends the chosen attribute names and types to at*/
-    void attributes( std::list<std::pair<QString, QString> >& at ) const;
-    /**Returns the file format for storage*/
-    QString selectedFileFormat() const;
-  protected slots:
-    void on_mAddAttributeButton_clicked();
-    void on_mRemoveAttributeButton_clicked();
-    void on_buttonBox_helpRequested();
-    void on_mTypeBox_currentIndexChanged( int index );
-  private:
-    QPushButton * mOkButton;
-    static const int context_id = 165149618;
-#endif //QGSGEOMTYPEDIALOG_H
Copied: trunk/qgis/src/app/qgsnewvectorlayerdialog.cpp (from rev 11718, trunk/qgis/src/app/qgsgeomtypedialog.cpp)
--- trunk/qgis/src/app/qgsnewvectorlayerdialog.cpp	                        (rev 0)
+++ trunk/qgis/src/app/qgsnewvectorlayerdialog.cpp	2009-09-27 07:55:01 UTC (rev 11719)
@@ -0,0 +1,123 @@
+                         qgsnewvectorlayerdialog.cpp  -  description
+    begin                : October 2004
+    copyright            : (C) 2004 by Marco Hugentobler
+    email                : marco.hugentobler at autoform.ch
+ *   This program is free software; you can redistribute it and/or modify  *
+ *   it under the terms of the GNU General Public License as published by  *
+ *   the Free Software Foundation; either version 2 of the License, or     *
+ *   (at your option) any later version.                                   *
+/* $Id$ */
+#include "qgsapplication.h"
+#include "qgisapp.h" // <- for theme icons
+#include "qgslogger.h"
+#include <QPushButton>
+QgsNewVectorLayerDialog::QgsNewVectorLayerDialog( QWidget *parent, Qt::WFlags fl )
+    : QDialog( parent, fl )
+  setupUi( this );
+  mAddAttributeButton->setIcon( QgisApp::getThemeIcon( "/mActionNewAttribute.png" ) );
+  mRemoveAttributeButton->setIcon( QgisApp::getThemeIcon( "/mActionDeleteAttribute.png" ) );
+  mTypeBox->addItem( tr( "Text data" ), "String" );
+  mTypeBox->addItem( tr( "Whole number" ), "Integer" );
+  mTypeBox->addItem( tr( "Decimal number" ), "Real" );
+  mPointRadioButton->setChecked( true );
+  mFileFormatComboBox->addItem( tr( "ESRI Shapefile" ), "ESRI Shapefile" );
+  /* Disabled until provider properly supports editing the created file formats */
+  //mFileFormatComboBox->addItem( tr( "Comma Separated Value" ), "Comma Separated Value" );
+  //mFileFormatComboBox->addItem(tr( "GML"), "GML" );
+  //mFileFormatComboBox->addItem(tr( "Mapinfo File" ), "Mapinfo File" );
+  if ( mFileFormatComboBox->count() == 1 )
+    mFileFormatComboBox->setVisible( false );
+    mFileFormatLabel->setVisible( false );
+  mOkButton = buttonBox->button( QDialogButtonBox::Ok );
+  mOkButton->setEnabled( false );
+QgsNewVectorLayerDialog::~QgsNewVectorLayerDialog()
+void QgsNewVectorLayerDialog::on_mTypeBox_currentIndexChanged( int index )
+  mPrecision->setEnabled( index == 2 );  // Real
+QGis::WkbType QgsNewVectorLayerDialog::selectedType() const
+  if ( mPointRadioButton->isChecked() )
+    return QGis::WKBPoint;
+  else if ( mLineRadioButton->isChecked() )
+    return QGis::WKBLineString;
+  else if ( mPolygonRadioButton->isChecked() )
+    return QGis::WKBPolygon;
+  return QGis::WKBUnknown;
+void QgsNewVectorLayerDialog::on_mAddAttributeButton_clicked()
+  QString myName = mNameEdit->text();
+  QString myWidth = mWidth->text();
+  QString myPrecision = mPrecision->text();
+  //use userrole to avoid translated type string
+  QString myType = mTypeBox->itemData( mTypeBox->currentIndex(), Qt::UserRole ).toString();
+  mAttributeView->addTopLevelItem( new QTreeWidgetItem( QStringList() << myName << myType << myWidth << myPrecision ) );
+  if ( mAttributeView->topLevelItemCount() > 0 )
+    mOkButton->setEnabled( true );
+  mNameEdit->clear();
+void QgsNewVectorLayerDialog::on_mRemoveAttributeButton_clicked()
+  delete( mAttributeView->currentItem() );
+  if ( mAttributeView->topLevelItemCount() == 0 )
+void QgsNewVectorLayerDialog::on_buttonBox_helpRequested()
+  QgsContextHelp::run( context_id );
+void QgsNewVectorLayerDialog::attributes( std::list<std::pair<QString, QString> >& at ) const
+  QTreeWidgetItemIterator it( mAttributeView );
+  while ( *it )
+    QTreeWidgetItem *item = *it;
+    QString type = QString( "%1;%2;%3" ).arg( item->text( 1 ) ).arg( item->text( 2 ) ).arg( item->text( 3 ) );
+    at.push_back( std::make_pair( item->text( 0 ), type ) );
+    QgsDebugMsg( QString( "appending %1//%2" ).arg( item->text( 0 ) ).arg( type ) );
+    ++it;
+QString QgsNewVectorLayerDialog::selectedFileFormat() const
+  QString myType = mFileFormatComboBox->itemData( mFileFormatComboBox->currentIndex(), Qt::UserRole ).toString();
+  return myType;
Property changes on: trunk/qgis/src/app/qgsnewvectorlayerdialog.cpp
___________________________________________________________________
Added: svn:keywords
   + Author Date Id Revision
Added: svn:mergeinfo
Added: svn:eol-style
   + native
Copied: trunk/qgis/src/app/qgsnewvectorlayerdialog.h (from rev 11718, trunk/qgis/src/app/qgsgeomtypedialog.h)
--- trunk/qgis/src/app/qgsnewvectorlayerdialog.h	                        (rev 0)
+++ trunk/qgis/src/app/qgsnewvectorlayerdialog.h	2009-09-27 07:55:01 UTC (rev 11719)
@@ -0,0 +1,52 @@
+                         qgsnewvectorlayerdialog.h  -  description
+/* $Id$ */
+#ifndef qgsnewvectorlayerdialog_H
+#define qgsnewvectorlayerdialog_H
+#include "ui_qgsnewvectorlayerdialogbase.h"
+#include "qgisgui.h"
+#include "qgscontexthelp.h"
+#include "qgis.h"
+class QgsNewVectorLayerDialog: public QDialog, private Ui::QgsNewVectorLayerDialogBase
+    Q_OBJECT
+  public:
+    QgsNewVectorLayerDialog( QWidget *parent = 0, Qt::WFlags fl = QgisGui::ModalDialogFlags );
+    ~QgsNewVectorLayerDialog();
+    /**Returns the selected geometry type*/
+    QGis::WkbType selectedType() const;
+    /**Appends the chosen attribute names and types to at*/
+    void attributes( std::list<std::pair<QString, QString> >& at ) const;
+    /**Returns the file format for storage*/
+    QString selectedFileFormat() const;
+  protected slots:
+    void on_mAddAttributeButton_clicked();
+    void on_mRemoveAttributeButton_clicked();
+    void on_buttonBox_helpRequested();
+    void on_mTypeBox_currentIndexChanged( int index );
+  private:
+    QPushButton * mOkButton;
+    static const int context_id = 165149618;
+#endif //qgsnewvectorlayerdialog_H
Property changes on: trunk/qgis/src/app/qgsnewvectorlayerdialog.h
Added: svn:keywords
   + native
Modified: trunk/qgis/src/providers/ogr/qgsogrprovider.cpp
--- trunk/qgis/src/providers/ogr/qgsogrprovider.cpp	2009-09-27 01:19:07 UTC (rev 11718)
+++ trunk/qgis/src/providers/ogr/qgsogrprovider.cpp	2009-09-27 07:55:01 UTC (rev 11719)
@@ -1383,6 +1383,7 @@
                                        QGis::WkbType vectortype,
                                        const std::list<std::pair<QString, QString> >& attributes )
+  QgsDebugMsg( QString( "Creating empty vector layer with format: %1" ).arg( format ));
   OGRSFDriverH driver;
   QgsApplication::registerOgrDrivers();
   driver = OGRGetDriverByName( format.toAscii() );
Deleted: trunk/qgis/src/ui/qgsaddattrdialogbase.ui
--- trunk/qgis/src/ui/qgsaddattrdialogbase.ui	2009-09-27 01:19:07 UTC (rev 11718)
+++ trunk/qgis/src/ui/qgsaddattrdialogbase.ui	2009-09-27 07:55:01 UTC (rev 11719)
@@ -1,144 +0,0 @@
-<?xml version="1.0" encoding="UTF-8"?>
-<ui version="4.0">
- <class>QgsAddAttrDialogBase</class>
- <widget class="QDialog" name="QgsAddAttrDialogBase">
-  <property name="geometry">
-   <rect>
-    <x>0</x>
-    <y>0</y>
-    <width>356</width>
-    <height>207</height>
-   </rect>
-  </property>
-  <property name="windowTitle">
-   <string>Add Attribute</string>
-  </property>
-  <property name="modal">
-   <bool>true</bool>
-  </property>
-  <layout class="QGridLayout" name="gridLayout">
-   <item row="0" column="0">
-    <widget class="QLabel" name="textLabel1">
-     <property name="text">
-      <string>Name:</string>
-     </property>
-     <property name="buddy">
-      <cstring>mNameEdit</cstring>
-     </property>
-    </widget>
-   </item>
-   <item row="0" column="1">
-    <widget class="QLineEdit" name="mNameEdit"/>
-   </item>
-   <item row="1" column="0">
-    <widget class="QLabel" name="textLabel1_2">
-      <string>Comment:</string>
-     </property>
-      <cstring>mCommentEdit</cstring>
-     </property>
-    </widget>
-   </item>
-   <item row="1" column="1">
-    <widget class="QLineEdit" name="mCommentEdit"/>
-   </item>
-   <item row="2" column="0">
-    <widget class="QLabel" name="textLabel2">
-      <string>Type:</string>
-     </property>
-      <cstring>mTypeBox</cstring>
-     </property>
-    </widget>
-   </item>
-   <item row="2" column="1">
-    <widget class="QComboBox" name="mTypeBox"/>
-   </item>
-   <item row="3" column="1">
-    <widget class="QLabel" name="mTypeName">
-     </property>
-     </property>
-    </widget>
-   </item>
-   <item row="4" column="0">
-    <widget class="QLabel" name="textLabel2_2">
-      <string>Width</string>
-     </property>
-      <cstring>mLength</cstring>
-     </property>
-    </widget>
-   </item>
-   <item row="4" column="1">
-    <widget class="QSpinBox" name="mLength"/>
-   </item>
-   <item row="5" column="0">
-    <widget class="QLabel" name="textLabel2_3">
-      <string>Precision</string>
-     </property>
-      <cstring>mPrec</cstring>
-     </property>
-    </widget>
-   </item>
-   <item row="5" column="1">
-    <widget class="QSpinBox" name="mPrec"/>
-   </item>
-   <item row="6" column="1">
-    <widget class="QDialogButtonBox" name="buttonBox">
-     <property name="standardButtons">
-      <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
-     </property>
-    </widget>
-   </item>
-  </layout>
- </widget>
- <layoutdefault spacing="6" margin="11"/>
- <tabstops>
-  <tabstop>mNameEdit</tabstop>
-  <tabstop>mTypeBox</tabstop>
- </tabstops>
- <resources/>
- <connections>
-  <connection>
-   <sender>buttonBox</sender>
-   <signal>accepted()</signal>
-   <receiver>QgsAddAttrDialogBase</receiver>
-   <slot>accept()</slot>
-   <hints>
-    <hint type="sourcelabel">
-     <x>260</x>
-     <y>109</y>
-    </hint>
-    <hint type="destinationlabel">
-     <x>307</x>
-     <y>68</y>
-    </hint>
-   </hints>
-  </connection>
-  <connection>
-   <signal>rejected()</signal>
-   <slot>reject()</slot>
-   <hints>
-     <x>196</x>
-     <y>106</y>
-    </hint>
-     <x>6</x>
-     <y>77</y>
-    </hint>
-   </hints>
-  </connection>
- </connections>
-</ui>
Modified: trunk/qgis/src/ui/qgsattributetabledialog.ui
--- trunk/qgis/src/ui/qgsattributetabledialog.ui	2009-09-27 01:19:07 UTC (rev 11718)
+++ trunk/qgis/src/ui/qgsattributetabledialog.ui	2009-09-27 07:55:01 UTC (rev 11719)
@@ -43,7 +43,7 @@
      <item>
       <widget class="QToolButton" name="mRemoveSelectionButton" >
        <property name="toolTip" >
-        <string>Remove selection</string>
+        <string>Unselect all</string>
        </property>
        <property name="text" >
         <string/>
@@ -65,7 +65,7 @@
      <item>
       <widget class="QToolButton" name="mSelectedToTopButton" >
-        <string>Move selected to top</string>
+        <string>Move selection to top</string>
        </property>
         <string/>
Modified: trunk/qgis/src/ui/qgsgeomtypedialogbase.ui
--- trunk/qgis/src/ui/qgsgeomtypedialogbase.ui	2009-09-27 01:19:07 UTC (rev 11718)
+++ trunk/qgis/src/ui/qgsgeomtypedialogbase.ui	2009-09-27 07:55:01 UTC (rev 11719)
@@ -1,58 +1,64 @@
-<ui version="4.0">
+<ui version="4.0" >
  <class>QgsGeomTypeDialogBase</class>
- <widget class="QDialog" name="QgsGeomTypeDialogBase">
+ <widget class="QDialog" name="QgsGeomTypeDialogBase" >
+  <property name="geometry" >
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>353</width>
-    <height>397</height>
+    <width>364</width>
+    <height>466</height>
    </rect>
   </property>
+  <property name="windowTitle" >
    <string>New Vector Layer</string>
   </property>
+  <property name="modal" >
    <bool>true</bool>
   </property>
-  <layout class="QGridLayout">
-    <widget class="QLabel" name="mFileFormatLabel">
+  <layout class="QGridLayout" >
+   <item row="0" column="0" >
+    <widget class="QLabel" name="mFileFormatLabel" >
+     <property name="enabled" >
+      <bool>true</bool>
+     </property>
+     <property name="text" >
       <string>File format</string>
      </property>
+     <property name="buddy" >
       <cstring>mFileFormatComboBox</cstring>
      </property>
     </widget>
    </item>
-   <item row="0" column="1" colspan="3">
-    <widget class="QComboBox" name="mFileFormatComboBox"/>
+   <item row="0" column="1" colspan="2" >
+    <widget class="QComboBox" name="mFileFormatComboBox" >
+      <bool>false</bool>
+     </property>
+    </widget>
    </item>
-   <item row="1" column="0" colspan="4">
-    <widget class="QGroupBox" name="buttonGroup1">
-     <property name="title">
+   <item row="1" column="0" colspan="3" >
+    <widget class="QGroupBox" name="buttonGroup1" >
+     <property name="title" >
       <string>Type</string>
      </property>
-       <widget class="QRadioButton" name="mPointRadioButton">
+       <widget class="QRadioButton" name="mPointRadioButton" >
          <string>Point</string>
         </property>
        </widget>
       </item>
-       <widget class="QRadioButton" name="mLineRadioButton">
+      <item row="0" column="1" >
+       <widget class="QRadioButton" name="mLineRadioButton" >
          <string>Line</string>
         </property>
        </widget>
       </item>
-      <item row="0" column="2">
-       <widget class="QRadioButton" name="mPolygonRadioButton">
+      <item row="0" column="2" >
+       <widget class="QRadioButton" name="mPolygonRadioButton" >
          <string>Polygon</string>
         </property>
        </widget>
@@ -60,149 +66,161 @@
      </layout>
     </widget>
    </item>
-   <item row="2" column="0" colspan="4">
-    <widget class="QLabel" name="mAttributeLabel">
+   <item row="2" column="0" colspan="3" >
+    <widget class="QGroupBox" name="groupBox" >
       <string>Attributes</string>
      </property>
+       <widget class="QLabel" name="textLabel1" >
+         <string>Name</string>
+        </property>
+         <cstring>mNameEdit</cstring>
+        </property>
+       </widget>
+      </item>
+      <item row="0" column="1" colspan="3" >
+       <widget class="QLineEdit" name="mNameEdit" />
+      </item>
+      <item row="1" column="0" >
+       <widget class="QLabel" name="textLabel2" >
+         <string>Type</string>
+        </property>
+         <cstring>mTypeBox</cstring>
+        </property>
+       </widget>
+      </item>
+      <item row="1" column="1" colspan="3" >
+       <widget class="QComboBox" name="mTypeBox" />
+      </item>
+      <item row="2" column="0" >
+       <widget class="QLabel" name="label" >
+         <string>Width</string>
+        </property>
+         <cstring>mWidth</cstring>
+        </property>
+       </widget>
+      </item>
+      <item row="2" column="1" >
+       <widget class="QLineEdit" name="mWidth" />
+      </item>
+      <item row="2" column="2" >
+       <widget class="QLabel" name="label_2" >
+         <string>Precision</string>
+        </property>
+         <cstring>mPrecision</cstring>
+        </property>
+       </widget>
+      </item>
+      <item row="2" column="3" >
+       <widget class="QLineEdit" name="mPrecision" >
+        <property name="sizePolicy" >
+         <sizepolicy vsizetype="Expanding" hsizetype="Expanding" >
+          <horstretch>0</horstretch>
+          <verstretch>0</verstretch>
+         </sizepolicy>
+        </property>
+       </widget>
+      </item>
+     </layout>
     </widget>
    </item>
-   <item row="3" column="0">
-      <string>Name</string>
+   <item row="3" column="0" colspan="2" >
+    <widget class="QToolButton" name="mRemoveAttributeButton" >
+     <property name="toolTip" >
+      <string>Delete selected attribute</string>
      </property>
+      <string>Removed selected item below</string>
      </property>
-    </widget>
-   </item>
-   <item row="3" column="1" colspan="3">
-   </item>
-      <string>Type</string>
+     <property name="icon" >
+      <iconset>../../images/themes/default/mActionDeleteAttribute.png</iconset>
      </property>
+     <property name="toolButtonStyle" >
+      <enum>Qt::ToolButtonTextBesideIcon</enum>
      </property>
     </widget>
    </item>
-   <item row="4" column="1" colspan="3">
-   </item>
-   <item row="6" column="0">
-    <widget class="QLabel" name="label">
-     </property>
-    </widget>
-   </item>
-    <widget class="QLineEdit" name="mWidth"/>
-   </item>
-   <item row="6" column="2">
-    <widget class="QLabel" name="label_2">
-     </property>
-    </widget>
-   </item>
-   <item row="6" column="3">
-    <widget class="QLineEdit" name="mPrecision">
-     <property name="sizePolicy">
-      <sizepolicy hsizetype="Expanding" vsizetype="Expanding">
-       <horstretch>0</horstretch>
-       <verstretch>0</verstretch>
-      </sizepolicy>
-     </property>
-    </widget>
-   </item>
-   <item row="13" column="0" colspan="4">
-     <property name="orientation">
-      <enum>Qt::Horizontal</enum>
-     </property>
-      <set>QDialogButtonBox::Cancel|QDialogButtonBox::Help|QDialogButtonBox::Ok</set>
-     </property>
-    </widget>
-   </item>
-   <item row="7" column="0">
-    <widget class="QToolButton" name="mRemoveAttributeButton">
-     <property name="toolTip">
-      <string>Delete selected attribute</string>
-     </property>
-      <string>...</string>
-     </property>
-     <property name="icon">
-      <iconset>
-       <normaloff>../../images/themes/default/mActionDeleteAttribute.png</normaloff>../../images/themes/default/mActionDeleteAttribute.png</iconset>
-     </property>
-    </widget>
-   </item>
-   <item row="7" column="3">
-    <widget class="QToolButton" name="mAddAttributeButton">
+   <item row="3" column="2" >
+    <widget class="QToolButton" name="mAddAttributeButton" >
       <string>Add attribute</string>
      </property>
-     <property name="layoutDirection">
+     <property name="layoutDirection" >
       <enum>Qt::RightToLeft</enum>
      </property>
+      <string>Add to list below</string>
      </property>
-      <iconset>
-       <normaloff>../../images/themes/default/mActionNewAttribute.png</normaloff>../../images/themes/default/mActionNewAttribute.png</iconset>
+      <iconset>../../images/themes/default/mActionNewAttribute.png</iconset>
      </property>
+     </property>
     </widget>
    </item>
-   <item row="12" column="0" colspan="4">
-    <widget class="QTreeWidget" name="mAttributeView">
+   <item row="4" column="0" colspan="3" >
+    <widget class="QTreeWidget" name="mAttributeView" >
       </sizepolicy>
      </property>
-     <property name="alternatingRowColors">
+     <property name="alternatingRowColors" >
       <bool>true</bool>
      </property>
-     <property name="rootIsDecorated">
+     <property name="rootIsDecorated" >
       <bool>false</bool>
      </property>
-     <property name="columnCount">
+     <property name="columnCount" >
       <number>4</number>
      </property>
      <column>
       </property>
      </column>
      <column>
       </property>
      </column>
      <column>
       </property>
      </column>
      <column>
       </property>
      </column>
     </widget>
    </item>
+   <item row="5" column="0" colspan="3" >
+    <widget class="QDialogButtonBox" name="buttonBox" >
+     <property name="orientation" >
+      <enum>Qt::Horizontal</enum>
+     </property>
+     <property name="standardButtons" >
+      <set>QDialogButtonBox::Cancel|QDialogButtonBox::Help|QDialogButtonBox::NoButton|QDialogButtonBox::Ok</set>
+     </property>
+    </widget>
+   </item>
   </layout>
  </widget>
+ <layoutdefault spacing="6" margin="11" />
  <tabstops>
   <tabstop>mFileFormatComboBox</tabstop>
   <tabstop>mPointRadioButton</tabstop>
@@ -210,6 +228,10 @@
   <tabstop>mPolygonRadioButton</tabstop>
+  <tabstop>mWidth</tabstop>
+  <tabstop>mPrecision</tabstop>
+  <tabstop>mRemoveAttributeButton</tabstop>
+  <tabstop>mAddAttributeButton</tabstop>
   <tabstop>mAttributeView</tabstop>
   <tabstop>buttonBox</tabstop>
  </tabstops>
@@ -221,11 +243,11 @@
    <receiver>QgsGeomTypeDialogBase</receiver>
    <hints>
+    <hint type="sourcelabel" >
      <x>349</x>
      <y>400</y>
     </hint>
+    <hint type="destinationlabel" >
      <x>387</x>
      <y>304</y>
     </hint>
@@ -237,11 +259,11 @@
    <hints>
      <x>275</x>
      <y>400</y>
     </hint>
      <x>242</x>
      <y>308</y>
     </hint>
Copied: trunk/qgis/src/ui/qgsnewvectorlayerdialogbase.ui (from rev 11718, trunk/qgis/src/ui/qgsaddattrdialogbase.ui)
--- trunk/qgis/src/ui/qgsnewvectorlayerdialogbase.ui	                        (rev 0)
+++ trunk/qgis/src/ui/qgsnewvectorlayerdialogbase.ui	2009-09-27 07:55:01 UTC (rev 11719)
@@ -0,0 +1,320 @@
+ <class>QgsNewVectorLayerDialogBase</class>
+ <widget class="QDialog" name="QgsNewVectorLayerDialogBase" >
+   <rect>
+    <x>0</x>
+    <y>0</y>
+    <height>488</height>
+   </rect>
+  </property>
+   <string>New Vector Layer</string>
+  </property>
+   <bool>true</bool>
+  </property>
+      <bool>true</bool>
+     </property>
+      <string>File format</string>
+     </property>
+      <cstring>mFileFormatComboBox</cstring>
+     </property>
+    </widget>
+   </item>
+      <bool>true</bool>
+     </property>
+    </widget>
+   </item>
+   <item row="1" column="0" colspan="2" >
+     </property>
+         <string>Point</string>
+        </property>
+       </widget>
+      </item>
+         <string>Line</string>
+        </property>
+       </widget>
+      </item>
+         <string>Polygon</string>
+        </property>
+       </widget>
+      </item>
+     </layout>
+    </widget>
+   </item>
+   <item row="2" column="0" colspan="2" >
+      <string>New attribute</string>
+     </property>
+        </property>
+        </property>
+       </widget>
+      </item>
+      <item row="0" column="1" colspan="4" >
+      </item>
+        </property>
+        </property>
+       </widget>
+      </item>
+      <item row="1" column="1" colspan="4" >
+      </item>
+        </property>
+        </property>
+       </widget>
+      </item>
+      <item row="2" column="1" colspan="2" >
+      </item>
+        </property>
+        </property>
+       </widget>
+      </item>
+      <item row="2" column="4" >
+         </sizepolicy>
+        </property>
+       </widget>
+      </item>
+       <spacer>
+        </property>
+        <property name="sizeHint" >
+         <size>
+          <width>121</width>
+          <height>20</height>
+         </size>
+        </property>
+       </spacer>
+      </item>
+      <item row="3" column="2" colspan="3" >
+         <sizepolicy vsizetype="Fixed" hsizetype="MinimumExpanding" >
+         </sizepolicy>
+        </property>
+         <string>Add attribute to list</string>
+        </property>
+         <enum>Qt::LeftToRight</enum>
+        </property>
+         <string>Add to attributes list</string>
+        </property>
+        </property>
+        </property>
+       </widget>
+      </item>
+     </layout>
+    </widget>
+   </item>
+    <widget class="QGroupBox" name="groupBox_2" >
+      <string>Attributes list</string>
+     </property>
+      <item row="0" column="0" colspan="2" >
+         </sizepolicy>
+        </property>
+         <bool>true</bool>
+        </property>
+        </property>
+         <number>4</number>
+        </property>
+        <column>
+         </property>
+        </column>
+        <column>
+         </property>
+        </column>
+        <column>
+         </property>
+        </column>
+        <column>
+         </property>
+        </column>
+       </widget>
+      </item>
+       <spacer>
+        </property>
+         <size>
+         </size>
+        </property>
+       </spacer>
+      </item>
+      <item row="1" column="1" >
+         </sizepolicy>
+        </property>
+        </property>
+         <string>Removed selected attribute</string>
+        </property>
+        </property>
+        </property>
+       </widget>
+      </item>
+     </layout>
+    </widget>
+   </item>
+   <item row="4" column="0" colspan="2" >
+     </property>
+     </property>
+    </widget>
+   </item>
+  </layout>
+ </widget>
+ <tabstops>
+  <tabstop>mFileFormatComboBox</tabstop>
+  <tabstop>mPointRadioButton</tabstop>
+  <tabstop>mLineRadioButton</tabstop>
+  <tabstop>mPolygonRadioButton</tabstop>
+  <tabstop>mNameEdit</tabstop>
+  <tabstop>mTypeBox</tabstop>
+  <tabstop>mAttributeView</tabstop>
+  <tabstop>buttonBox</tabstop>
+ </tabstops>
+ <resources/>
+ <connections>
+  <connection>
+   <sender>buttonBox</sender>
+   <signal>accepted()</signal>
+   <receiver>QgsNewVectorLayerDialogBase</receiver>
+   <slot>accept()</slot>
+   <hints>
+     <x>349</x>
+     <y>400</y>
+    </hint>
+     <x>387</x>
+     <y>304</y>
+    </hint>
+   </hints>
+  </connection>
+  <connection>
+   <signal>rejected()</signal>
+   <slot>reject()</slot>
+   <hints>
+     <x>275</x>
+     <y>400</y>
+    </hint>
+     <x>242</x>
+     <y>308</y>
+    </hint>
+   </hints>
+  </connection>
+ </connections>
+</ui>
Property changes on: trunk/qgis/src/ui/qgsnewvectorlayerdialogbase.ui
Added: svn:keywords
   + native
More information about the QGIS-commit mailing list
