[QGIS Commit] r11720 - trunk/qgis/src/ui
svn_qgis at osgeo.org
Sun Sep 27 05:32:30 EDT 2009
Author: jef
Date: 2009-09-27 05:32:30 -0400 (Sun, 27 Sep 2009)
New Revision: 11720
Added:
trunk/qgis/src/ui/qgsaddattrdialogbase.ui
Removed:
trunk/qgis/src/ui/qgsgeomtypedialogbase.ui
fix r11719
Added: trunk/qgis/src/ui/qgsaddattrdialogbase.ui
--- trunk/qgis/src/ui/qgsaddattrdialogbase.ui (rev 0)
+++ trunk/qgis/src/ui/qgsaddattrdialogbase.ui 2009-09-27 09:32:30 UTC (rev 11720)
@@ -0,0 +1,144 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
+ <class>QgsAddAttrDialogBase</class>
+ <widget class="QDialog" name="QgsAddAttrDialogBase">
+ <property name="geometry">
+ <rect>
+ <x>0</x>
+ <y>0</y>
+ <width>356</width>
+ <height>207</height>
+ </rect>
+ </property>
+ <property name="windowTitle">
+ <string>Add Attribute</string>
+ </property>
+ <property name="modal">
+ <bool>true</bool>
+ </property>
+ <layout class="QGridLayout" name="gridLayout">
+ <item row="0" column="0">
+ <widget class="QLabel" name="textLabel1">
+ <property name="text">
+ <string>Name:</string>
+ </property>
+ <property name="buddy">
+ <cstring>mNameEdit</cstring>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="1">
+ <widget class="QLineEdit" name="mNameEdit"/>
+ </item>
+ <item row="1" column="0">
+ <widget class="QLabel" name="textLabel1_2">
+ <string>Comment:</string>
+ </property>
+ <cstring>mCommentEdit</cstring>
+ </property>
+ </widget>
+ </item>
+ <item row="1" column="1">
+ <widget class="QLineEdit" name="mCommentEdit"/>
+ </item>
+ <item row="2" column="0">
+ <widget class="QLabel" name="textLabel2">
+ <string>Type:</string>
+ </property>
+ <cstring>mTypeBox</cstring>
+ </property>
+ </widget>
+ </item>
+ <item row="2" column="1">
+ <widget class="QComboBox" name="mTypeBox"/>
+ </item>
+ <item row="3" column="1">
+ <widget class="QLabel" name="mTypeName">
+ </property>
+ </property>
+ </widget>
+ </item>
+ <item row="4" column="0">
+ <widget class="QLabel" name="textLabel2_2">
+ <string>Width</string>
+ </property>
+ <cstring>mLength</cstring>
+ </property>
+ </widget>
+ </item>
+ <item row="4" column="1">
+ <widget class="QSpinBox" name="mLength"/>
+ </item>
+ <item row="5" column="0">
+ <widget class="QLabel" name="textLabel2_3">
+ <string>Precision</string>
+ </property>
+ <cstring>mPrec</cstring>
+ </property>
+ </widget>
+ </item>
+ <item row="5" column="1">
+ <widget class="QSpinBox" name="mPrec"/>
+ </item>
+ <item row="6" column="1">
+ <widget class="QDialogButtonBox" name="buttonBox">
+ <property name="standardButtons">
+ <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok</set>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ <layoutdefault spacing="6" margin="11"/>
+ <tabstops>
+ <tabstop>mNameEdit</tabstop>
+ <tabstop>mTypeBox</tabstop>
+ </tabstops>
+ <resources/>
+ <connections>
+ <connection>
+ <sender>buttonBox</sender>
+ <signal>accepted()</signal>
+ <receiver>QgsAddAttrDialogBase</receiver>
+ <slot>accept()</slot>
+ <hints>
+ <hint type="sourcelabel">
+ <x>260</x>
+ <y>109</y>
+ </hint>
+ <hint type="destinationlabel">
+ <x>307</x>
+ <y>68</y>
+ </hint>
+ </hints>
+ </connection>
+ <connection>
+ <signal>rejected()</signal>
+ <slot>reject()</slot>
+ <hints>
+ <x>196</x>
+ <y>106</y>
+ </hint>
+ <x>6</x>
+ <y>77</y>
+ </hint>
+ </hints>
+ </connection>
+ </connections>
+</ui>
Deleted: trunk/qgis/src/ui/qgsgeomtypedialogbase.ui
--- trunk/qgis/src/ui/qgsgeomtypedialogbase.ui 2009-09-27 07:55:01 UTC (rev 11719)
+++ trunk/qgis/src/ui/qgsgeomtypedialogbase.ui 2009-09-27 09:32:30 UTC (rev 11720)
@@ -1,273 +0,0 @@
-<ui version="4.0" >
- <class>QgsGeomTypeDialogBase</class>
- <widget class="QDialog" name="QgsGeomTypeDialogBase" >
- <property name="geometry" >
- <rect>
- <x>0</x>
- <y>0</y>
- <width>364</width>
- <height>466</height>
- </rect>
- </property>
- <property name="windowTitle" >
- <string>New Vector Layer</string>
- </property>
- <property name="modal" >
- <bool>true</bool>
- </property>
- <layout class="QGridLayout" >
- <item row="0" column="0" >
- <widget class="QLabel" name="mFileFormatLabel" >
- <property name="enabled" >
- <bool>true</bool>
- </property>
- <property name="text" >
- <string>File format</string>
- </property>
- <property name="buddy" >
- <cstring>mFileFormatComboBox</cstring>
- </property>
- </widget>
- </item>
- <item row="0" column="1" colspan="2" >
- <widget class="QComboBox" name="mFileFormatComboBox" >
- <bool>false</bool>
- </property>
- </widget>
- </item>
- <item row="1" column="0" colspan="3" >
- <widget class="QGroupBox" name="buttonGroup1" >
- <property name="title" >
- <string>Type</string>
- </property>
- <widget class="QRadioButton" name="mPointRadioButton" >
- <string>Point</string>
- </property>
- </widget>
- </item>
- <item row="0" column="1" >
- <widget class="QRadioButton" name="mLineRadioButton" >
- <string>Line</string>
- </property>
- </widget>
- </item>
- <item row="0" column="2" >
- <widget class="QRadioButton" name="mPolygonRadioButton" >
- <string>Polygon</string>
- </property>
- </widget>
- </item>
- </layout>
- </widget>
- </item>
- <item row="2" column="0" colspan="3" >
- <widget class="QGroupBox" name="groupBox" >
- <string>Attributes</string>
- </property>
- <widget class="QLabel" name="textLabel1" >
- <string>Name</string>
- </property>
- <cstring>mNameEdit</cstring>
- </property>
- </widget>
- </item>
- <item row="0" column="1" colspan="3" >
- <widget class="QLineEdit" name="mNameEdit" />
- </item>
- <item row="1" column="0" >
- <widget class="QLabel" name="textLabel2" >
- </property>
- <cstring>mTypeBox</cstring>
- </property>
- </widget>
- </item>
- <item row="1" column="1" colspan="3" >
- <widget class="QComboBox" name="mTypeBox" />
- </item>
- <item row="2" column="0" >
- <widget class="QLabel" name="label" >
- <string>Width</string>
- </property>
- <cstring>mWidth</cstring>
- </property>
- </widget>
- </item>
- <item row="2" column="1" >
- <widget class="QLineEdit" name="mWidth" />
- </item>
- <item row="2" column="2" >
- <widget class="QLabel" name="label_2" >
- <string>Precision</string>
- </property>
- <cstring>mPrecision</cstring>
- </property>
- </widget>
- </item>
- <item row="2" column="3" >
- <widget class="QLineEdit" name="mPrecision" >
- <property name="sizePolicy" >
- <sizepolicy vsizetype="Expanding" hsizetype="Expanding" >
- <horstretch>0</horstretch>
- <verstretch>0</verstretch>
- </sizepolicy>
- </property>
- </widget>
- </item>
- </layout>
- </widget>
- </item>
- <item row="3" column="0" colspan="2" >
- <widget class="QToolButton" name="mRemoveAttributeButton" >
- <property name="toolTip" >
- <string>Delete selected attribute</string>
- </property>
- <string>Removed selected item below</string>
- </property>
- <property name="icon" >
- <iconset>../../images/themes/default/mActionDeleteAttribute.png</iconset>
- </property>
- <property name="toolButtonStyle" >
- <enum>Qt::ToolButtonTextBesideIcon</enum>
- </property>
- </widget>
- </item>
- <item row="3" column="2" >
- <widget class="QToolButton" name="mAddAttributeButton" >
- <string>Add attribute</string>
- </property>
- <property name="layoutDirection" >
- <enum>Qt::RightToLeft</enum>
- </property>
- <string>Add to list below</string>
- </property>
- <iconset>../../images/themes/default/mActionNewAttribute.png</iconset>
- </property>
- </property>
- </widget>
- </item>
- <item row="4" column="0" colspan="3" >
- <widget class="QTreeWidget" name="mAttributeView" >
- </sizepolicy>
- </property>
- <property name="alternatingRowColors" >
- <bool>true</bool>
- </property>
- <property name="rootIsDecorated" >
- </property>
- <property name="columnCount" >
- <number>4</number>
- </property>
- <column>
- </property>
- </column>
- <column>
- </property>
- </column>
- <column>
- </property>
- </column>
- <column>
- </property>
- </column>
- </widget>
- </item>
- <item row="5" column="0" colspan="3" >
- <widget class="QDialogButtonBox" name="buttonBox" >
- <property name="orientation" >
- <enum>Qt::Horizontal</enum>
- </property>
- <property name="standardButtons" >
- <set>QDialogButtonBox::Cancel|QDialogButtonBox::Help|QDialogButtonBox::NoButton|QDialogButtonBox::Ok</set>
- </property>
- </widget>
- </item>
- </layout>
- </widget>
- <layoutdefault spacing="6" margin="11" />
- <tabstops>
- <tabstop>mFileFormatComboBox</tabstop>
- <tabstop>mPointRadioButton</tabstop>
- <tabstop>mLineRadioButton</tabstop>
- <tabstop>mPolygonRadioButton</tabstop>
- <tabstop>mNameEdit</tabstop>
- <tabstop>mTypeBox</tabstop>
- <tabstop>mWidth</tabstop>
- <tabstop>mPrecision</tabstop>
- <tabstop>mRemoveAttributeButton</tabstop>
- <tabstop>mAddAttributeButton</tabstop>
- <tabstop>mAttributeView</tabstop>
- <tabstop>buttonBox</tabstop>
- </tabstops>
- <resources/>
- <connections>
- <connection>
- <sender>buttonBox</sender>
- <signal>accepted()</signal>
- <receiver>QgsGeomTypeDialogBase</receiver>
- <slot>accept()</slot>
- <hints>
- <hint type="sourcelabel" >
- <x>349</x>
- <y>400</y>
- </hint>
- <hint type="destinationlabel" >
- <x>387</x>
- <y>304</y>
- </hint>
- </hints>
- </connection>
- <connection>
- <signal>rejected()</signal>
- <slot>reject()</slot>
- <hints>
- <x>275</x>
- <y>400</y>
- </hint>
- <x>242</x>
- <y>308</y>
- </hint>
- </hints>
- </connection>
- </connections>
-</ui>
