[QGIS Commit] r14830 - trunk/qgis/src/core
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Dec 2 17:22:06 EST 2010
Author: mhugent
Date: 2010-12-02 14:22:06 -0800 (Thu, 02 Dec 2010)
New Revision: 14830
   trunk/qgis/src/core/qgsmaplayer.cpp
   trunk/qgis/src/core/qgsmaplayer.h
Read / write labeling-ng to qml files
Modified: trunk/qgis/src/core/qgsmaplayer.cpp
--- trunk/qgis/src/core/qgsmaplayer.cpp	2010-12-02 21:35:43 UTC (rev 14829)
+++ trunk/qgis/src/core/qgsmaplayer.cpp	2010-12-02 22:22:06 UTC (rev 14830)
@@ -614,6 +614,9 @@
     return myErrorMessage;
+  //also restore custom properties (for labeling-ng)
+  readCustomProperties( myRoot, "labeling" );
   return "";
@@ -653,6 +656,9 @@
     return tr( "Could not save symbology because:\n%1" ).arg( errorMsg );
+  //save customproperties (for labeling ng)
+  writeCustomProperties( myRootNode, myDocument );
   // check if the uri is a file or ends with .qml,
   // which indicates that it should become one
   // everything else goes to the database
@@ -804,7 +810,7 @@
   mCustomProperties.remove( key );
-void QgsMapLayer::readCustomProperties( QDomNode & layerNode )
+void QgsMapLayer::readCustomProperties( QDomNode & layerNode, const QString& keyStartsWith )
   QDomNode propsNode = layerNode.namedItem( "customproperties" );
   if ( propsNode.isNull() ) // no properties stored...
@@ -822,17 +828,20 @@
     QDomElement propElement = propNode.toElement();
     QString key = propElement.attribute( "key" );
-    QString value = propElement.attribute( "value" );
-    mCustomProperties[key] = QVariant( value );
+    if ( key.isEmpty() || key.startsWith( keyStartsWith ) )
+      QString value = propElement.attribute( "value" );
+      mCustomProperties[key] = QVariant( value );
-void QgsMapLayer::writeCustomProperties( QDomNode & layerNode, QDomDocument & doc )
+void QgsMapLayer::writeCustomProperties( QDomNode & layerNode, QDomDocument & doc ) const
   QDomElement propsElement = doc.createElement( "customproperties" );
-  for ( QMap<QString, QVariant>::const_iterator it = mCustomProperties.begin(); it != mCustomProperties.end(); ++it )
+  for ( QMap<QString, QVariant>::const_iterator it = mCustomProperties.constBegin(); it != mCustomProperties.constEnd(); ++it )
     QDomElement propElement = doc.createElement( "property" );
     propElement.setAttribute( "key", it.key() );
Modified: trunk/qgis/src/core/qgsmaplayer.h
--- trunk/qgis/src/core/qgsmaplayer.h	2010-12-02 21:35:43 UTC (rev 14829)
+++ trunk/qgis/src/core/qgsmaplayer.h	2010-12-02 22:22:06 UTC (rev 14830)
@@ -373,11 +373,12 @@
     virtual bool writeXml( QDomNode & layer_node, QDomDocument & document );
-    /** Read custom properties from project file. Added in v1.4 */
-    void readCustomProperties( QDomNode & layerNode );
+    /** Read custom properties from project file. Added in v1.4
+        @param keyStartsWith reads only properties starting with the specified string (or all if the string is empty)*/
+    void readCustomProperties( QDomNode & layerNode, const QString& keyStartsWith = "" );
     /** Write custom properties to project file. Added in v1.4 */
-    void writeCustomProperties( QDomNode & layerNode, QDomDocument & doc );
+    void writeCustomProperties( QDomNode & layerNode, QDomDocument & doc ) const;
     /** debugging member - invoked when a connect() is made to this object */
     void connectNotify( const char * signal );
More information about the QGIS-commit mailing list
