[QGIS Commit] r14831 - in trunk/qgis/src: app/composer
core/composer gui ui
svn_qgis at osgeo.org
Fri Dec 3 07:53:22 EST 2010
Author: mhugent
Date: 2010-12-03 04:53:22 -0800 (Fri, 03 Dec 2010)
New Revision: 14831
trunk/qgis/src/app/composer/qgscomposer.cpp
trunk/qgis/src/app/composer/qgscomposer.h
trunk/qgis/src/app/composer/qgscomposershapewidget.cpp
trunk/qgis/src/app/composer/qgscomposertablewidget.cpp
trunk/qgis/src/core/composer/qgscomposeritemgroup.cpp
trunk/qgis/src/core/composer/qgscomposeritemgroup.h
trunk/qgis/src/gui/qgscomposerview.cpp
trunk/qgis/src/ui/qgscomposerbase.ui
Added undo/redo buttons in composer, fix undo problems when deleting grouped items
Modified: trunk/qgis/src/app/composer/qgscomposer.cpp
--- trunk/qgis/src/app/composer/qgscomposer.cpp 2010-12-02 22:22:06 UTC (rev 14830)
+++ trunk/qgis/src/app/composer/qgscomposer.cpp 2010-12-03 12:53:22 UTC (rev 14831)
@@ -151,6 +151,8 @@
viewMenu->addAction( mActionZoomIn );
viewMenu->addAction( mActionZoomOut );
viewMenu->addAction( mActionZoomAll );
+ viewMenu->addAction( mActionUndo );
+ viewMenu->addAction( mActionRedo );
viewMenu->addSeparator();
viewMenu->addAction( mActionRefreshView );
@@ -198,7 +200,17 @@
mView = new QgsComposerView( mViewFrame );
connectSlots();
+ //init undo/redo buttons
mComposition = new QgsComposition( mQgis->mapCanvas()->mapRenderer() );
+ mActionUndo->setEnabled( false );
+ mActionRedo->setEnabled( false );
+ if ( mComposition->undoStack() )
+ connect( mComposition->undoStack(), SIGNAL( canUndoChanged( bool ) ), mActionUndo, SLOT( setEnabled( bool ) ) );
+ connect( mComposition->undoStack(), SIGNAL( canRedoChanged( bool ) ), mActionRedo, SLOT( setEnabled( bool ) ) );
mComposition->setParent( mView );
mView->setComposition( mComposition );
@@ -257,6 +269,8 @@
mActionZoomIn->setIcon( QgisApp::getThemeIcon( "/mActionZoomIn.png" ) );
mActionZoomOut->setIcon( QgisApp::getThemeIcon( "/mActionZoomOut.png" ) );
mActionRefreshView->setIcon( QgisApp::getThemeIcon( "/mActionDraw.png" ) );
+ mActionUndo->setIcon( QgisApp::getThemeIcon( "/mActionUndo.png" ) );
+ mActionRedo->setIcon( QgisApp::getThemeIcon( "/mActionRedo.png" ) );
mActionAddImage->setIcon( QgisApp::getThemeIcon( "/mActionAddImage.png" ) );
mActionAddNewMap->setIcon( QgisApp::getThemeIcon( "/mActionAddMap.png" ) );
mActionAddNewLabel->setIcon( QgisApp::getThemeIcon( "/mActionLabel.png" ) );
@@ -1059,6 +1073,22 @@
+void QgsComposer::on_mActionUndo_triggered()
+ if ( mComposition && mComposition->undoStack() )
+ mComposition->undoStack()->undo();
+void QgsComposer::on_mActionRedo_triggered()
+ mComposition->undoStack()->redo();
void QgsComposer::moveEvent( QMoveEvent *e ) { saveWindowState(); }
void QgsComposer::resizeEvent( QResizeEvent *e )
@@ -1332,9 +1362,19 @@
if ( mUndoView )
- mUndoView->setStack( mComposition->undoStack() );
+ mUndoView->setStack( mComposition->undoStack() );
setSelectionTool();
Modified: trunk/qgis/src/app/composer/qgscomposer.h
--- trunk/qgis/src/app/composer/qgscomposer.h 2010-12-02 22:22:06 UTC (rev 14830)
+++ trunk/qgis/src/app/composer/qgscomposer.h 2010-12-03 12:53:22 UTC (rev 14831)
@@ -203,6 +203,12 @@
//!Align selected composer items to bottom
void on_mActionAlignBottom_triggered();
+ //!Undo last composer change
+ void on_mActionUndo_triggered();
+ //!Redo last composer change
+ void on_mActionRedo_triggered();
//! Save window state
void saveWindowState();
Modified: trunk/qgis/src/app/composer/qgscomposershapewidget.cpp
--- trunk/qgis/src/app/composer/qgscomposershapewidget.cpp 2010-12-02 22:22:06 UTC (rev 14830)
+++ trunk/qgis/src/app/composer/qgscomposershapewidget.cpp 2010-12-03 12:53:22 UTC (rev 14831)
@@ -39,7 +39,7 @@
blockAllSignals( false );
- connect( mShapeComboBox, SIGNAL( itemChanged() ), this, SLOT( setGuiElementValues() ) );
+ connect( mShapeComboBox, SIGNAL( currentIndexChanged( int ) ), this, SLOT( setGuiElementValues() ) );
QgsComposerShapeWidget::~QgsComposerShapeWidget()
Modified: trunk/qgis/src/app/composer/qgscomposertablewidget.cpp
--- trunk/qgis/src/app/composer/qgscomposertablewidget.cpp 2010-12-02 22:22:06 UTC (rev 14830)
+++ trunk/qgis/src/app/composer/qgscomposertablewidget.cpp 2010-12-03 12:53:22 UTC (rev 14831)
@@ -146,10 +146,16 @@
const QgsComposition* tableComposition = mComposerTable->composition();
if ( tableComposition )
- mComposerTable->beginCommand( tr( "Table map changed" ) );
+ if ( sender() ) //only create command if called from GUI
+ mComposerTable->beginCommand( tr( "Table map changed" ) );
mComposerTable->setComposerMap( tableComposition->getComposerMapById( mapId ) );
mComposerTable->update();
- mComposerTable->endCommand();
+ if ( sender() )
+ mComposerTable->endCommand();
Modified: trunk/qgis/src/core/composer/qgscomposeritemgroup.cpp
--- trunk/qgis/src/core/composer/qgscomposeritemgroup.cpp 2010-12-02 22:22:06 UTC (rev 14830)
+++ trunk/qgis/src/core/composer/qgscomposeritemgroup.cpp 2010-12-03 12:53:22 UTC (rev 14831)
@@ -31,7 +31,11 @@
QSet<QgsComposerItem*>::iterator itemIt = mItems.begin();
for ( ; itemIt != mItems.end(); ++itemIt )
- emit childItemDeleted( *itemIt );
+ if ( *itemIt )
+ mComposition->removeItem( *itemIt );
+ ( *itemIt )->setFlag( QGraphicsItem::ItemIsSelectable, true );
@@ -162,13 +166,3 @@
p->drawRect( QRectF( 0, 0, rect().width(), rect().height() ) );
-bool QgsComposerItemGroup::writeXML( QDomElement& elem, QDomDocument & doc ) const
- return true; //soon...
-bool QgsComposerItemGroup::readXML( const QDomElement& itemElem, const QDomDocument& doc )
- return false; //soon...
Modified: trunk/qgis/src/core/composer/qgscomposeritemgroup.h
--- trunk/qgis/src/core/composer/qgscomposeritemgroup.h 2010-12-02 22:22:06 UTC (rev 14830)
+++ trunk/qgis/src/core/composer/qgscomposeritemgroup.h 2010-12-03 12:53:22 UTC (rev 14831)
@@ -48,14 +48,16 @@
* @param elem is Dom element corresponding to 'Composer' tag
* @param doc is the Dom document
- bool writeXML( QDomElement& elem, QDomDocument & doc ) const;
+ bool writeXML( QDomElement& elem, QDomDocument & doc ) const {}
/** sets state from Dom document
* @param itemElem is Dom node corresponding to item tag
- bool readXML( const QDomElement& itemElem, const QDomDocument& doc );
+ bool readXML( const QDomElement& itemElem, const QDomDocument& doc ) {}
+ QSet<QgsComposerItem*> items() { return mItems; }
signals:
void childItemDeleted( QgsComposerItem* item );
Modified: trunk/qgis/src/gui/qgscomposerview.cpp
--- trunk/qgis/src/gui/qgscomposerview.cpp 2010-12-02 22:22:06 UTC (rev 14830)
+++ trunk/qgis/src/gui/qgscomposerview.cpp 2010-12-03 12:53:22 UTC (rev 14831)
@@ -394,9 +394,30 @@
if ( !map || !map->isDrawing() ) //don't delete a composer map while it draws
composition()->removeItem( *itemIt );
- emit itemRemoved( *itemIt );
+ QgsComposerItemGroup* itemGroup = dynamic_cast<QgsComposerItemGroup*>( *itemIt );
+ if ( itemGroup && composition() )
+ //add add/remove item command for every item in the group
+ QUndoCommand* parentCommand = new QUndoCommand( tr( "Remove item group" ) );
- pushAddRemoveCommand( *itemIt, tr( "Item deleted" ), QgsAddRemoveItemCommand::Removed );
+ QSet<QgsComposerItem*> groupedItems = itemGroup->items();
+ QSet<QgsComposerItem*>::iterator it = groupedItems.begin();
+ for ( ; it != groupedItems.end(); ++it )
+ QgsAddRemoveItemCommand* subcommand = new QgsAddRemoveItemCommand( QgsAddRemoveItemCommand::Removed, *it, composition(), "", parentCommand );
+ connectAddRemoveCommandSignals( subcommand );
+ emit itemRemoved( *it );
+ composition()->undoStack()->push( parentCommand );
+ delete itemGroup;
+ emit itemRemoved( itemGroup );
+ else
+ emit itemRemoved( *itemIt );
+ pushAddRemoveCommand( *itemIt, tr( "Item deleted" ), QgsAddRemoveItemCommand::Removed );
@@ -591,8 +612,6 @@
return; //not enough items for a group
QgsComposerItemGroup* itemGroup = new QgsComposerItemGroup( composition() );
- //connect signal/slot to let item group tell if child items get removed
- connect( itemGroup, SIGNAL( childItemDeleted( QgsComposerItem* ) ), this, SIGNAL( itemRemoved( QgsComposerItem* ) ) );
QList<QgsComposerItem*>::iterator itemIter = selectionList.begin();
for ( ; itemIter != selectionList.end(); ++itemIter )
Modified: trunk/qgis/src/ui/qgscomposerbase.ui
--- trunk/qgis/src/ui/qgscomposerbase.ui 2010-12-02 22:22:06 UTC (rev 14830)
+++ trunk/qgis/src/ui/qgscomposerbase.ui 2010-12-03 12:53:22 UTC (rev 14831)
@@ -6,7 +6,7 @@
<rect>
<x>0</x>
<y>0</y>
- <width>1145</width>
+ <width>1333</width>
<height>609</height>
</rect>
</property>
@@ -163,6 +163,8 @@
<addaction name="mActionZoomIn"/>
<addaction name="mActionZoomOut"/>
<addaction name="mActionRefreshView"/>
+ <addaction name="mActionUndo"/>
+ <addaction name="mActionRedo"/>
<addaction name="separator"/>
<addaction name="mActionAddNewMap"/>
<addaction name="mActionAddImage"/>
@@ -479,11 +481,38 @@
<string>Page Setup</string>
</property>
</action>
+ <action name="mActionUndo">
+ <property name="icon">
+ <iconset>
+ <normalon>:/images/themes/default/mActionUndo.png</normalon>
+ </iconset>
+ </property>
+ <property name="text">
+ <string>Undo</string>
+ </property>
+ <property name="toolTip">
+ <string>Revert last change</string>
+ </property>
+ </action>
+ <action name="mActionRedo">
+ <iconset resource="../../images/images.qrc">
+ <normaloff>:/images/themes/default/mActionRedo.png</normaloff>:/images/themes/default/mActionRedo.png</iconset>
+ </property>
+ <string>Redo</string>
+ </property>
+ <string>Restore last change</string>
+ </property>
+ </action>
</widget>
<tabstops>
<tabstop>mCompositionNameComboBox</tabstop>
<tabstop>mOptionsTabWidget</tabstop>
</tabstops>
- <resources/>
+ <resources>
+ <include location="../../images/images.qrc"/>
+ </resources>
<connections/>
</ui>
