[QGIS Commit] r14940 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org
Mon Dec 20 07:02:06 EST 2010
Author: dassau
Date: 2010-12-20 04:02:06 -0800 (Mon, 20 Dec 2010)
New Revision: 14940
docs/trunk/english_us/user_guide/working_with_vector.tex
added options to create a spatialite layer
Modified: docs/trunk/english_us/user_guide/working_with_vector.tex
--- docs/trunk/english_us/user_guide/working_with_vector.tex 2010-12-20 03:58:14 UTC (rev 14939)
+++ docs/trunk/english_us/user_guide/working_with_vector.tex 2010-12-20 12:02:06 UTC (rev 14940)
@@ -500,11 +500,18 @@
\toolbtntwo{mActionAddSpatiaLiteLayer}{Add SpatiaLite Layer} toolbar button or by selecting the
\dropmenuopttwo{mActionAddSpatiaLiteLayer}{Add SpatiaLite Layer...}
option from the \mainmenuopt{Layer} menu or by typing \keystroke{L}.
-This will bring up a window, which will allow you to either connect to a SpatiaLite database already known to \qg, which
-you can choose from the dropdown menu or to define a new connection to a new database. To define a new connection,
-click on \button{New} and use the file browser to point to your SpatiaLite database,
-which is a file with a \filename{.sqlite } extension.
+This will bring up a window, which will allow you to either connect to a SpatiaLite
+database already known to \qg, which you can choose from the dropdown menu or to define
+a new connection to a new database. To define a new connection, click on \button{New} and
+use the file browser to point to your SpatiaLite database, which is a file with
+a \filename{.sqlite } extension.
+If you want to save a vector layer to SpatiaLite format you can do this opening the right
+mouse menu of the layer. Then click on \dropmenuopt{Save as}, define the name of the output
+file, sqlite as format and the CRS and then add 'SPATIALITE=YES' in the OGR data source
+creation option field. This tells OGR to create a SpatiaLite database. See
+also \url{http://www.gdal.org/ogr/drv_sqlite.html}.
\section{The Vector Properties Dialog}\label{sec:vectorprops}
\index{vector layers!properties dialog}
@@ -2049,7 +2056,6 @@
\ref{fig:query_builder} shows an example of the query builder populated with
data from a PostGIS layer with attributes stored in PostgreSQL.
The Fields, Values and Operators sections help the user to construct the SQL-like
-WHERE clause easily in the text field SQL where clause window.
\begin{figure}[ht]
\centering
